[Mapbender-commits] r6699 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Thu Aug 5 10:20:46 EDT 2010
Author: verenadiewald
Date: 2010-08-05 14:20:46 +0000 (Thu, 05 Aug 2010)
New Revision: 6699
trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php
workaround for search values containing commas
Modified: trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php
--- trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php 2010-08-05 12:40:36 UTC (rev 6698)
+++ trunk/mapbender/http/javascripts/mod_wfs_gazetteer_client.php 2010-08-05 14:20:46 UTC (rev 6699)
@@ -1007,9 +1007,11 @@
for (var i = 0; i < el.length; i++) {
if (el[i]['f_search'] == 1){
+ var a = new Array();
if(el[i]['f_form_element_html'].match(/\<select/)){
var elementValue = document.getElementById(el[i]['element_name']).options[document.getElementById(el[i]['element_name']).selectedIndex].value;
+ a.push(elementValue);
else if(el[i]['f_form_element_html'].match(/checkbox/)){
var elementArray = document.getElementsByName(el[i]['element_name']);
var selectedVal = [];
@@ -1018,16 +1020,16 @@
selectedVal.push(elementArray[j].value);
- var elementValue = selectedVal.join(",");
+ var elementValue = selectedVal;
+ a = elementValue;
else{
var elementValue = document.getElementById(el[i]['element_name']).value;
+ a = elementValue.split(",");
if (el[i]['f_search'] == 1 && elementValue != '') {
- var a = new Array();
- a = elementValue.split(",");
var orConditions = "";
for (var j=0; j < a.length; j++) {
if(el[i]['f_operator']=='bothside'){
@@ -1262,7 +1264,7 @@
var filter = "<ogc:Filter>"+andConditionString+"</ogc:Filter>";
+ console.log(filter);
document.getElementById("res").innerHTML = "<table><tr><td><img src='"+progressIndicatorImg+"'></td><td>"+progressIndicatorText+"</td></tr></table>";
var parameters = {
"command" : "getSearchResults",
@@ -1272,6 +1274,7 @@
"filter" : filter,
"backlink" : ""
+ return false;
parent.mb_ajax_get("../php/mod_wfs_gazetteer_server.php", parameters, function (jsCode, status) {
document.getElementById("res").innerHTML = "<table><tr><td>"+arrangeResultsText+"</td></tr></table>";
if(status=='success'){
More information about the Mapbender_commits
