[Mapbender-commits] r6707 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Fri Aug 6 04:57:35 EDT 2010
Author: christoph
Date: 2010-08-06 08:57:35 +0000 (Fri, 06 Aug 2010)
New Revision: 6707
trunk/mapbender/http/javascripts/initWmcObj.php
normalized layer inputs in order to accept these: http://www.mapbender.org/GET-Parameter#LAYER
Modified: trunk/mapbender/http/javascripts/initWmcObj.php
--- trunk/mapbender/http/javascripts/initWmcObj.php 2010-08-06 08:56:28 UTC (rev 6706)
+++ trunk/mapbender/http/javascripts/initWmcObj.php 2010-08-06 08:57:35 UTC (rev 6707)
@@ -103,23 +103,80 @@
$getParams["LAYER"] = getConfiguration("LAYER");
-if ($getParams["LAYER"]) {
- // Layer param given as array
- if (is_array($getParams['LAYER'])) {
- $inputLayerArray = $getParams['LAYER'];
+// for possible inputs see http://www.mapbender.org/GET-Parameter#LAYER
+// for test cases, see http://www.mapbender.org/Talk:GET-Parameter#LAYER
+function normalizeLayerInput ($input) {
+ if (is_array($input)) {
+ $keys = array_keys($input);
+ $isSingleLayer = false;
+ foreach ($keys as $key) {
+ if (!is_numeric($key)) {
+ $isSingleLayer = true;
+ break;
+ // LAYER[id]=12&LAYER[application]=something
+ if ($isSingleLayer) {
+ $input[0] = array();
+ $input[0][$key] = $input[$key];
+ unset($input[$key]);
+ else {
+ for ($i = 0; $i < count($input); $i++) {
+ // assume LAYER[]=12&LAYER[]=13
+ if (is_numeric($input[$i])) {
+ $id = $input[$i];
+ $input[$i] = array("id" => $id);
+ // else assume LAYER[0][id]=12&LAYER[0][application]=something
- // Layer param given as comma separated list
else {
- $inputLayerArray = split(",",$getParams['LAYER']);
+ // assume LAYER=12,13,14
+ $inputArray = split(",", $input);
+ $input = array();
+ $i = 0;
+ foreach ($inputArray as $id) {
+ if (is_numeric($id)) {
+ $input[$i++]["id"] = $id;
- // just make it work for a single layer id
- $wmsFactory = new UniversalWmsFactory();
- $layerId = intval($getParams["LAYER"]);
- $wms = $wmsFactory->createLayerFromDb($layerId);
- $wmc->mergeWmsArray(array($wms));
+ // check if each layer has at least an id, if not, delete
+ $i = 0;
+ while ($i < count($input)) {
+ if (!is_array($input[$i]) || !isset($input[$i]["id"]) || !is_numeric($input[$i]["id"])) {
+ array_splice($input, $i, 1);
+ continue;
+ $input[$i]["id"] = intval($input[$i]["id"]);
+ $i++;
+ return $input;
+if ($getParams["LAYER"]) {
+ $inputLayerArray = normalizeLayerInput($getParams['LAYER']);
+ foreach ($inputLayerArray as $input) {
+ // just make it work for a single layer id
+ $wmsFactory = new UniversalWmsFactory();
+ $wms = $wmsFactory->createLayerFromDb($input["id"]);
+ $options = array();
+ if ($input["visible"]) {
+ // this is a hack for the time being:
+ // make WMS visible if it has less than 100000 layers
+ $options["show"] = 100000;
+ $wmc->mergeWmsArray(array($wms), $options);
$output = $wmc->wmsToJavaScript();
for ($i = 0; $i < count($output); $i++) {
More information about the Mapbender_commits
