[Mapbender-commits] r6709 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Fri Aug 6 07:11:24 EDT 2010
Author: christoph
Date: 2010-08-06 11:11:24 +0000 (Fri, 06 Aug 2010)
New Revision: 6709
trunk/mapbender/http/classes/class_wmc.php
always increment load count when loading a wmc
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php 2010-08-06 09:33:07 UTC (rev 6708)
+++ trunk/mapbender/http/classes/class_wmc.php 2010-08-06 11:11:24 UTC (rev 6709)
@@ -84,7 +84,6 @@
var $xml;
// constants
- var $monitoringIsOn = false;
var $saveWmcAsFile = false;
var $extensionNamespace = "mapbender";
var $extensionNamespaceUrl = "http://www.mapbender.org/context";
@@ -151,8 +150,6 @@
* @param integer $wmc_id the ID of the WMC document in the database table "mb_user_wmc"
function createFromDb($wmcId){
- $this->monitoringIsOn = true;
$doc = wmc::getDocument($wmcId);
if ($doc === false) {
return false;
@@ -880,6 +877,14 @@
return $this->xml;
+ private function incrementLoadCount ($wms) {
+ // counts how often a layer has been loaded
+ $monitor = new Layer_load_count();
+ foreach ($wms->objLayer as $l) {
+ $monitor->increment($l->layer_uid);
public function wmsToJavaScript() {
$wmsArray = $this->mainMap->getWmsArray();
@@ -888,6 +893,7 @@
$currentWms = $wmsArray[$i];
$wmcJsArray[] = $currentWms->createJsObjFromWMS_();
+ $this->incrementLoadCount($currentWms);
return $wmcJsArray;
@@ -898,15 +904,6 @@
* @return String[]
public function toJavaScript () {
- // counts how often a layer has been loaded
- if ($this->monitoringIsOn) {
- $monitor = new Layer_load_count();
- for ($i = 0; $i < count($this->wmc_layer_id); $i++) {
- $monitor->increment($this->wmc_layer_id[$i]);
$skipWmsArray = array();
if (func_num_args() === 1) {
$skipWmsArray = func_get_arg(0);
@@ -953,6 +950,7 @@
continue;
array_push($wmcJsArray, $wmsArray[$i]->createJsObjFromWMS_());
+ $this->incrementLoadCount($wmsArray[$i]);
// delete existing map objects...
More information about the Mapbender_commits
