[Mapbender-commits] r6712 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sun Aug 8 13:03:12 EDT 2010
Author: astrid_emde
Date: 2010-08-08 17:03:12 +0000 (Sun, 08 Aug 2010)
New Revision: 6712
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
favicon, resizable, dragable, expandable to all map applications
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql	2010-08-08 17:01:56 UTC (rev 6711)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql	2010-08-08 17:03:12 UTC (rev 6712)
@@ -2542,3 +2542,31 @@
 ALTER TABLE ONLY layer_load_count
     ADD CONSTRAINT layer_load_count_fkey_layer_id_fkey FOREIGN KEY (fkey_layer_id) REFERENCES layer (layer_id) ON UPDATE CASCADE ON DELETE CASCADE;
+-- adds Mapbender favicon to all applications whch do not have favicon yet
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id, 'body', 'favicon', '../img/favicon.ico', 'refers to image to use as favicon' ,'php_var'
+FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'favicon'
+AND fkey_e_id = 'body');
+-- tabs - expandable
+'tabs', 'expandable', '1', '1 = expand the tabs to fit the document vertically, default is 0' ,'php_var'
+FROM gui_element WHERE gui_element.e_id = 'tabs' AND gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'expandable'
+AND fkey_e_id = 'tabs');
+-- draggable in map applications
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
+SELECT gui.gui_id,'jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.draggable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/'
+FROM gui WHERE gui.gui_id NOT LIKE 'admin%' AND gui.gui_id NOT LIKE 'wms%' AND gui.gui_id
+WHERE e_id = 'jq_ui_draggable');
+-- resize map applications
+SELECT gui.gui_id,'jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/minified/jquery.ui.resizable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/resizable/'
+WHERE e_id = 'jq_ui_resizable');
More information about the Mapbender_commits mailing list
