[Mapbender-commits] r6716 -
trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Mon Aug 9 05:01:32 EDT 2010
Author: christoph
Date: 2010-08-09 09:01:32 +0000 (Mon, 09 Aug 2010)
New Revision: 6716
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
expandable tabs off by default
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql 2010-08-09 08:37:50 UTC (rev 6715)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql 2010-08-09 09:01:32 UTC (rev 6716)
@@ -2556,7 +2556,7 @@
-- tabs - expandable
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT gui_element.fkey_gui_id,
-'tabs', 'expandable', '1', '1 = expand the tabs to fit the document vertically, default is 0' ,'php_var'
+'tabs', 'expandable', '0', '1 = expand the tabs to fit the document vertically, default is 0' ,'php_var'
FROM gui_element WHERE gui_element.e_id = 'tabs' AND gui_element.fkey_gui_id
NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'expandable'
AND fkey_e_id = 'tabs');
@@ -2576,3 +2576,5 @@
WHERE e_id = 'jq_ui_resizable');
More information about the Mapbender_commits
