[Mapbender-commits] r6744 - branches/banjo_dev/mapbender/http/rest
svn_mapbender at osgeo.org
Tue Aug 10 12:26:02 EDT 2010
Author: banjo
Date: 2010-08-10 16:26:02 +0000 (Tue, 10 Aug 2010)
New Revision: 6744
Removed:
branches/banjo_dev/mapbender/http/rest/die_rest_response.php
branches/banjo_dev/mapbender/http/rest/http_auth.php
refactoring
Deleted: branches/banjo_dev/mapbender/http/rest/die_rest_response.php
--- branches/banjo_dev/mapbender/http/rest/die_rest_response.php 2010-08-10 16:11:11 UTC (rev 6743)
+++ branches/banjo_dev/mapbender/http/rest/die_rest_response.php 2010-08-10 16:26:02 UTC (rev 6744)
@@ -1,30 +0,0 @@
-<?php
-send_rest_response($status = 500, $body = '', $content_type = 'text/html') {
- $ini_file = "http_status.ini";
- $status_codes = parse_ini_file($file);
- $status_header = 'HTTP/1.1 '.$status.' '.$status_codes[$status];
- header($status_header);
- header('Content-type: '.$content_type);
- if($body != '')
- echo $body;
- exit;
- else
- $body = '<html>
- <head>
- <meta http-equiv="Content-Type" content="text/html">
- <title>' . $status . ' '. $status_codes[$status]. '</title>
- </head>
- <body>
- <h1>'. $status_codes[$status].'</h1>
- </body>
- </html>';
- echo $body;
- exit;
Modified: branches/banjo_dev/mapbender/http/rest/http_auth.php
--- branches/banjo_dev/mapbender/http/rest/http_auth.php 2010-08-10 16:11:11 UTC (rev 6743)
+++ branches/banjo_dev/mapbender/http/rest/http_auth.php 2010-08-10 16:26:02 UTC (rev 6744)
@@ -1,7 +1,7 @@
<?php
require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
require_once("db_connect.php");
-require_once("die_rest_response.php");
+require_once("rest_response.php");
//nonceLife in seconds
$nonceLife = 300;
More information about the Mapbender_commits
