[Mapbender-commits] r6764 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Tue Aug 17 07:44:34 EDT 2010
Author: christoph
Date: 2010-08-17 11:44:34 +0000 (Tue, 17 Aug 2010)
New Revision: 6764
trunk/mapbender/http/javascripts/mod_measure.php
reverted to 5533
Modified: trunk/mapbender/http/javascripts/mod_measure.php
--- trunk/mapbender/http/javascripts/mod_measure.php 2010-08-17 09:19:29 UTC (rev 6763)
+++ trunk/mapbender/http/javascripts/mod_measure.php 2010-08-17 11:44:34 UTC (rev 6764)
@@ -20,22 +20,16 @@
require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
echo "var mod_measure_target = '".$e_target[0]."';";
var mod_measure_color1 = "white";
var mod_measure_color2 = "black";
var mod_measure_font = "Arial, Helvetica, sans-serif";
-var mod_measure_fontsize = "10px";
-var mod_measure_basepoint = "#FF0000";
-var mod_measure_line = "#005395";
-var mod_measure_poly = "#c1d0e3";
-var mod_measure_line_opacity = "1";
-var mod_measure_poly_opacity = "0.2";
+var mod_measure_fontsize = "9px";
+var mod_measure_basepoint = "#8a2be2";
+var mod_measure_linepoint = "#ff00ff";
var mod_measure_bg = "";
var mod_measure_pgsql = true;
-var polygonIsSimple = true;
-var MeasureIsPolygon = false;
var mod_measure_win = null;
var mod_measure_elName = "measure";
@@ -49,15 +43,6 @@
var mod_measure_Dist = new Array();
var mod_measure_TotalDist = new Array();
-var mod_measure_WinContent_header = "<div style='font-family:verdana;font-size:12px;margin:5pt;'>";
-var mod_measure_WinContent_koord = "Koordinate:<br>";
-var mod_measure_WinContent_strecke = "<br>";
-var mod_measure_WinContent_flaeche = "<br>";
-var mod_measure_WinContent_clear = "<br><img src='../http_ms/img/button_ms/clear_off.png' onclick='javascript:mod_measure_clear();' onmouseover='this.src = this.src.replace(/_off/,\"_over\");' onmouseout='this.src = this.src.replace(/_over/,\"_off\");' alt='Messung löschen' title='Messung löschen'>";
-var mod_measure_WinContent_footer = "</div>";
-var MeasurePaper;
// global variable
window.eventAfterMeasure = new MapbenderEvent();
@@ -65,15 +50,9 @@
var mod_measure_img_off = new Image(); mod_measure_img_off.src = "<?php echo $e_src; ?>";
var mod_measure_img_over = new Image(); mod_measure_img_over.src = "<?php echo preg_replace("/_off/","_over",$e_src); ?>";
-function mod_measure_update(){
- MeasureWin.setHtml(mod_measure_WinContent_header+mod_measure_WinContent_koord+mod_measure_WinContent_strecke+mod_measure_WinContent_flaeche+mod_measure_WinContent_clear+mod_measure_WinContent_footer);
function init_mod_measure(ind){
- local_ind=ind;
mod_measure_mapObj = getMapObjByName(mod_measure_target);
//ensure we have the div elements in Mapframe
var map_el = mod_measure_mapObj.getDomElement()
@@ -119,69 +98,44 @@
drawDashedLine();
mb_registerPanSubElement(mod_measure_target+"_measuring");
- MeasurePaper = Raphael(el, mod_measure_width, mod_measure_height);
function mod_measure_go(){
var el = mod_measure_mapObj.getDomElement();
- if (el) {
- $(el).bind("mousedown", mod_measure_start)
- .bind("mousemove", mod_measure_run);
+ el.onmousedown = mod_measure_start;
+ el.onmousemove = mod_measure_run;
+ el.onmouseover = function () {
el.style.cursor = 'crosshair';
+ el.onmouseout = function () {
+ el.style.cursor = 'auto';
var measureSub = eventAfterMeasure.trigger({}, "CAT");
- MeasureWin = new mb_popup({
- title:"Messung",frameName:"",
- left:265,top:75,width:250,height:120,
- html: mod_measure_WinContent_header+"Fahren Sie mit der Maus über die Karte, um die Koordinaten anzuzeigen.<br> Klicken Sie, um eine Messung zu starten"+ mod_measure_WinContent_footer,
- closeCallback:function(){mod_measure_disable();}
- MeasureWin.show();
+ writeTag("",mod_measure_target+"_measure_sub",measureSub);
function mod_measure_disable(){
- if (el) {
- $(el).unbind("mousedown", mod_measure_start)
- .unbind("mousemove", mod_measure_run);
- el.style.cursor = 'auto';
+ el.onmousedown = null;
+ el.onmousemove = null;
+ el.onmouseover = null;
+ el.onmouseout = null;
writeTag("",mod_measure_target+"_measure_display","");
- MeasureWin.destroy();
- mod_measure_delete();
- parent.mb_disableThisButton('measure');
+ writeTag("",mod_measure_target+"_measure_sub","");
function mod_measure_timeout(){
- var el = mod_measure_mapObj.getDomElement();
- if (el) {
+ var el = mod_measure_mapObj.getDomElement();
+ el.ondblclick = null;
function mod_measure_disableTimeout(){
- if (el) {
function mod_measure_start(e){
- var pos = mod_measure_mapObj.getMousePosition(e);
+ mod_measure_mapObj.getMousePos(e);
- var realWorldPos = makeClickPos2RealWorldPos(mod_measure_target, pos.x, pos.y);
+ var realWorldPos = makeClickPos2RealWorldPos(mod_measure_target,clickX,clickY);
if(mod_measure_epsg=="EPSG:4326"){
mod_measure_RX[mod_measure_RX.length] = realWorldPos[0];
mod_measure_RY[mod_measure_RY.length] = realWorldPos[1];
@@ -214,28 +168,8 @@
mod_measure_Dist[mod_measure_Dist.length] = 0;
mod_measure_TotalDist[mod_measure_TotalDist.length] = 0;
- if (polygonIsSimple){checkpolygon()};
- var closedist_x = Math.abs(mod_measure_RX[0] - mod_measure_RX[mod_measure_RX.length-1]);
- var closedist_y = Math.abs(mod_measure_RY[0] - mod_measure_RY[mod_measure_RY.length-1]);
- var closedist = Math.round(Math.sqrt(Math.pow(closedist_x,2) + Math.pow(closedist_y,2))*100)/100;
- if (closedist > mod_measure_TotalDist[mod_measure_TotalDist.length-1]/2 ) {MeasureIsPolygon = false} else {MeasureIsPolygon = true}
drawDashedLine();
- if(mod_measure_RX.length == 1){
- mod_measure_WinContent_strecke="Punkt: "+mod_measure_RX[0]+" "+mod_measure_RY[0]+"<br>";
- } else {
- mod_measure_WinContent_strecke="Strecke: "+Math.round(mod_measure_TotalDist[mod_measure_TotalDist.length-1]*10)/10+" m<br>";
- tmp_area = mod_measure_calc_area();
- if (tmp_area != '' && polygonIsSimple && MeasureIsPolygon){
- mod_measure_WinContent_flaeche="Fläche: "+mod_measure_calc_area()+"<br>";
- } else {
- mod_measure_WinContent_flaeche="<br>";
- mod_measure_update();
function drawDashedLine(){
//check if epsg has changed
mod_measure_width = mod_measure_mapObj.width;
@@ -244,28 +178,51 @@
mod_measure_epsg = mod_measure_mapObj.epsg;
- MeasurePaper.clear();
- if(mod_measure_RX.length>0){
- var str_path;
- for(var k=0; k<mod_measure_RX.length; k++){
+ var str_mPoints = "<div style='position:absolute;left:0px;top:0px' ><img src='"+mb_trans.src+"' width='"+mod_measure_width+"' height='0'></div>";
+ str_mPoints += "<div style='position:absolute;left:0px;top:0px' ><img src='"+mb_trans.src+"' width='0' height='"+mod_measure_height+"'></div>";
+ for(var i=0; i<mod_measure_RX.length; i++){
+ var pos = makeRealWorld2mapPos(mod_measure_target,mod_measure_RX[i],mod_measure_RY[i]);
+ str_mPoints += "<div style='font-size:1px;position:absolute;top:"+(pos[1]-2)+"px;left:"+(pos[0]-2)+"px;width:4px;height:4px;background-color:"+mod_measure_basepoint+"'></div>";
+ if(i>0){
+ str_mPoints += "<div style='font-family:"+mod_measure_font+";font-size:"+mod_measure_fontsize+";color:"+mod_measure_color1+";";
+ if(mod_measure_bg != ""){
+ str_mPoints += "background-color:"+mod_measure_bg+";";
+ str_mPoints += "position:absolute;top:"+(pos[1] + 3)+"px;left:"+(pos[0]+3)+"px;z-index:20'>"+mod_measure_TotalDist[i]+"</div>";
+ str_mPoints += "<div style='font-family:"+mod_measure_font+";font-size:"+mod_measure_fontsize+";color:"+mod_measure_color2+";position:absolute;top:"+(pos[1] + 4)+"px;left:"+(pos[0]+4)+"px;z-index:21'>"+mod_measure_TotalDist[i]+"</div>";
+ if(mod_measure_RX.length>1){
+ for(var k=1; k<mod_measure_RX.length; k++){
var pos0 = makeRealWorld2mapPos(mod_measure_target,mod_measure_RX[k], mod_measure_RY[k]);
- if (k == 0){str_path += 'M'} else {str_path += 'L'};
- str_path += pos0[0]+' '+pos0[1];
- var circle = MeasurePaper.circle(pos0[0],pos0[1],3);
- if (k==0){circle.attr({fill: mod_measure_basepoint, stroke: "none", opacity: mod_measure_line_opacity})}else{circle.attr({fill: mod_measure_line, stroke: "none", opacity: mod_measure_line_opacity})};
+ var pos1 = makeRealWorld2mapPos(mod_measure_target,mod_measure_RX[k-1], mod_measure_RY[k-1]);
+ str_mPoints += evaluateDashes(pos1[0],pos1[1],pos0[0],pos0[1],k);
- if (mod_measure_RX.length >2 && polygonIsSimple && MeasureIsPolygon) {
- poly = MeasurePaper.path(str_path + 'Z');
- poly.attr({fill: mod_measure_poly, opacity: mod_measure_poly_opacity});
- //poly.toFront();
- var line = MeasurePaper.path(str_path);
- line.attr({stroke: mod_measure_line, "stroke-width": 2, opacity: mod_measure_line_opacity});
- line.toFront();
+ writeTag("",mod_measure_target+"_measuring",str_mPoints);
+function evaluateDashes(x1,y1,x2,y2,count){
+ var str_dashedLine = "";
+ var s = 10;
+ var d = Math.sqrt(Math.pow((y1-y2),2) + Math.pow((x1-x2),2)) ;
+ var n = Math.round(d/s);
+ var s_x = (x2 - x1)/n;
+ var s_y = (y2 - y1)/n;
+ for(var i=1; i<n; i++){
+ var x = Math.round(x1 + i * s_x)-2;
+ var y = Math.round(y1 + i * s_y)-2;
+ if(x >= 0 && x <= mod_measure_width && y >= 0 && y <= mod_measure_height){
+ str_dashedLine += "<div style='font-size:1px;position:absolute;top:"+y+"px;left:"+x+"px;width:4px;height:4px;background-color:"+mod_measure_linepoint+"'></div>";
+ str_dashedLine += "<div style='font-family:"+mod_measure_font+";font-size:"+mod_measure_fontsize+";color:"+mod_measure_color1+";";
+ str_dashedLine += "background-color:"+mod_measure_bg+";";
+ str_dashedLine += "position:absolute;top:"+(Math.round(y1 + (y2-y1)/2 +3))+"px;left:"+(Math.round(x1 + (x2-x1)/2 +3))+"px'>"+mod_measure_Dist[count]+"</div>";
+ str_dashedLine += "<div style='font-family:"+mod_measure_font+";font-size:"+mod_measure_fontsize+";color:"+mod_measure_color2+";position:absolute;top:"+(Math.round(y1 + (y2-y1)/2 + 4))+"px;left:"+(Math.round(x1 + (x2-x1)/2+4))+"px'>"+mod_measure_Dist[count]+"</div>";
+ return str_dashedLine;
function mod_measure_run(e){
var pos = makeClickPos2RealWorldPos(mod_measure_target,clickX,clickY);
@@ -283,75 +240,135 @@
var dist_y = Math.abs(mod_measure_RY[mod_measure_RY.length-1] - pos[1]);
dist=Math.sqrt(dist_x*dist_x+dist_y*dist_y);
- if(isNaN(dist) == false && pos.x > 0 && pos.x < mod_measure_width && pos.y > 0 && pos.y < mod_measure_height){
+ if(isNaN(dist) == false && clickX > 0 && clickX < mod_measure_width && clickY > 0 && clickY < mod_measure_height){
var str_display = "<span style='font-family:"+mod_measure_font+";font-size:"+mod_measure_fontsize+";color:"+mod_measure_color2+";'>"+(Math.round(dist*100)/100)+" m</span>";
writeTag("", mod_measure_target+"_measure_display",str_display);
- mb_arrangeElement("",mod_measure_target+"_measure_display",pos.x +2, pos.y - 10);
+ mb_arrangeElement("",mod_measure_target+"_measure_display",clickX +2, clickY - 10);
else{
- mod_measure_WinContent_koord="Koordinate: "+Math.round(pos[0])+ " "+Math.round(pos[1])+"<br>";
+function mod_measure_close(){
+ if(mod_measure_RX.length < 3 || (mod_measure_RX[mod_measure_RX.length-1] == mod_measure_RX[0] && mod_measure_RY[mod_measure_RY.length-1] == mod_measure_RY[0])){return;}
+ mod_measure_RX[mod_measure_RX.length] = mod_measure_RX[0];
+ mod_measure_RY[mod_measure_RY.length] = mod_measure_RY[0];
+ if(mod_measure_RX.length > 1){
+ var dist;
+ if(mod_measure_epsg=="EPSG:4326"){
+ //convert coordinates to radian
+ var lon_from=(mod_measure_RX[mod_measure_RX.length-2]*Math.PI)/180;
+ var lat_from=(mod_measure_RY[mod_measure_RY.length-2]*Math.PI)/180;
+ var lon_to=(mod_measure_RX[mod_measure_RX.length-1]*Math.PI)/180;
+ var lat_to=(mod_measure_RY[mod_measure_RY.length-1]*Math.PI)/180;
+ dist=6371229*Math.acos(Math.sin(lat_from)*Math.sin(lat_to)+Math.cos(lat_from)*Math.cos(lat_to)*Math.cos(lon_from-lon_to));
+ dist=Math.round(dist*100)/100;
+ else{
+ var dist_x = Math.abs(mod_measure_RX[mod_measure_RX.length-2] - mod_measure_RX[mod_measure_RX.length-1]);
+ var dist_y = Math.abs(mod_measure_RY[mod_measure_RY.length-2] - mod_measure_RY[mod_measure_RY.length-1]);
+ dist = Math.round(Math.sqrt(Math.pow(dist_x,2) + Math.pow(dist_y,2))*100)/100;
+ mod_measure_Dist[mod_measure_Dist.length] = dist;
+ var totalDist = mod_measure_TotalDist[mod_measure_TotalDist.length-1] + dist;
+ mod_measure_TotalDist[mod_measure_TotalDist.length] = Math.round(totalDist * 100)/100;
+ else{
+ mod_measure_Dist[mod_measure_Dist.length] = 0;
+ mod_measure_TotalDist[mod_measure_TotalDist.length] = 0;
+ drawDashedLine();
function mod_measure_delete(){
- mod_measure_clear();
-function mod_measure_clear(){
mod_measure_RX = new Array();
mod_measure_RY = new Array();
writeTag("",mod_measure_target+"_measuring","");
- mod_measure_WinContent_strecke = "<br>";
- mod_measure_WinContent_flaeche = "<br>";
- polygonIsSimple = true;
+var mod_closePolygon_img = new Image();
+mod_closePolygon_img.src = "../img/button_gray/closePolygon_off.gif";
+mod_closePolygon_img.title = '<?php echo _mb("Close polygon");?>';
-function mod_measure_calc_area(){
- if(mod_measure_RX.length < 3 || (mod_measure_RX[mod_measure_RX.length-1] == mod_measure_RX[0] && mod_measure_RY[mod_measure_RY.length-1] == mod_measure_RY[0])){return "";}
- var area = 0;
- for (var i=1;i<mod_measure_RX.length;i++) {
- area += (Number(mod_measure_RY[i-1])+Number(mod_measure_RY[i]))*(Number(mod_measure_RX[i-1])-Number(mod_measure_RX[i]))/2;
- area += (mod_measure_RY[mod_measure_RX.length-1]+mod_measure_RY[0])*(mod_measure_RX[mod_measure_RX.length-1]-mod_measure_RX[0])/2;
- area= Math.abs(area);
- if (area > 10000000){
- area /= 1000000; return Math.round(area*10)/10+" km²";
- } else if (area > 100000){
- area /= 10000; return Math.round(area*10)/10+" ha";
- } else {
- return Math.round(area*10)/10+" m²";
+eventAfterMeasure.register(function(){
+ return mod_closePolygon();
+function mod_closePolygon(){
+ var str = "<div style='position:absolute;top:25px' onmouseup='mod_closePolygon_go()' ";
+ str += "onmouseover='mod_measure_timeout()' onmouseout='mod_measure_disableTimeout()'><img src='"+mod_closePolygon_img.src+"' style='cursor:pointer' title='"+mod_closePolygon_img.title+"'></div>";
+ return str;
+function mod_closePolygon_go(){
+ mod_measure_close();
-function checkpolygon(){
- for (var i=1;i<mod_measure_RX.length-2;i++) {
- if (line_intersect(mod_measure_RX[i-1],mod_measure_RY[i-1],mod_measure_RX[i],mod_measure_RY[i],mod_measure_RX[mod_measure_RX.length-2],mod_measure_RY[mod_measure_RX.length-2],mod_measure_RX[mod_measure_RX.length-1],mod_measure_RY[mod_measure_RX.length-1] ) ) {polygonIsSimple = false}
+var mod_rubber_img = new Image();
+mod_rubber_img.src = "../img/button_gray/rubber_off.gif";
+mod_rubber_img.title = '<?php echo _mb("Rubber");?>';
+eventAfterMeasure.register(function () {
+ return mod_rubber();
+function mod_rubber(){
+ var str = "<div onmouseup='mod_rubber_go()' onmouseover='mod_measure_timeout()' onmouseout='mod_measure_go()'><img src='"+mod_rubber_img.src+"' style='cursor:pointer' title='"+mod_rubber_img.title+"'></div>";
+ return str;
+function mod_rubber_go(){
+ mod_measure_delete();
+var mod_getArea_img = new Image();
+mod_getArea_img.src = "../img/button_gray/getArea_off.gif";
+mod_getArea_img.title = '<?php echo _mb("Get area");?>';
+ return mod_getArea();
-function line_intersect ( a1, a2, b1, b2, c1, c2, d1, d2 ) {
- var s;
- var t;
- //alert (a1+' '+a2+' '+b1+' '+b2+' '+c1+' '+c2+' '+d1+' '+d2);
- var N = (b1-a1)*(d2-c2)-(b2-a2)*(d1-c1);
- if (N == 0) {
- // Strecken sind parallel
- return false;
- } else {
- s = ((c1-a1)*(d2-c2)-(c2-a2)*(d1-c1)) / N;
- t = (a1-c1 + s*(b1-a1)) / (d1-c1);
- if (s <= 1 && s>=0 && t <= 1 && t>=0){return true;}else {return false;};
\ No newline at end of file
+function mod_getArea(){
+ var str = "<div id='getAreaButton' style='position:absolute;top:50px' onmouseup='mod_getArea_go()' ";
+ str += "onmouseover='mod_measure_timeout()' onmouseout='mod_measure_disableTimeout()'><img src='"+mod_getArea_img.src+"' style='cursor:pointer' title='"+mod_getArea_img.title+"'></div>";
+ return str;
+function mod_getArea_go(){
+ if(mod_measure_RX[mod_measure_RX.length -1] == mod_measure_RX[0] && mod_measure_RY[mod_measure_RY.length -1] == mod_measure_RY[0]){
+ var ind = getMapObjIndexByName(mod_measure_target);
+ var url = "../php/mod_evalArea.php?x=";
+ for(var i=0; i<mod_measure_RX.length;i++){
+ if(i>0){ url += ",";}
+ url += mod_measure_RX[i];
+ url += "&y=";
+ for(var i=0; i<mod_measure_RY.length;i++){
+ url += mod_measure_RY[i];
+ var srs = mb_mapObj[ind].epsg.split(":");
+ url += "&srs="+ escape(srs[1]);
+ url += "&length=" + mod_measure_TotalDist[mod_measure_TotalDist.length-1];
+ url += "&distance=" + mod_measure_TotalDist[mod_measure_TotalDist.length-2];
+ if(!mod_measure_win || mod_measure_win == null || mod_measure_win.closed == true){
+ mod_measure_win = window.open(url,"mod_measure_win","width=200,height=150,resizable=yes");
+ else{
+ mod_measure_win.document.location.href = url;
+ mod_measure_win.focus();
+ else{
+ mod_measure_win = window.open("","mod_measure_win","width=200,height=150,resizable=yes");
+ mod_measure_win.document.open("text/html");
+ mod_measure_win.document.write("<span style = 'font-family : Arial, Helvetica, sans-serif;font-size : 12px;font-weight : bold;';>Strecke: " +mod_measure_TotalDist[mod_measure_TotalDist.length-1]+" m</span>");
+ mod_measure_win.document.close();
+ else{
More information about the Mapbender_commits
