[Mapbender-commits] r6768 - in trunk/mapbender: http/classes lib
test/http/classes
svn_mapbender at osgeo.org
Thu Aug 19 12:02:21 EDT 2010
Author: christoph
Date: 2010-08-19 16:02:21 +0000 (Thu, 19 Aug 2010)
New Revision: 6768
Added:
trunk/mapbender/lib/class_Filter.php
trunk/mapbender/test/http/classes/FilterTest.php
trunk/mapbender/http/classes/class_RPCEndpoint.php
added class Filter
Modified: trunk/mapbender/http/classes/class_RPCEndpoint.php
--- trunk/mapbender/http/classes/class_RPCEndpoint.php 2010-08-19 15:59:06 UTC (rev 6767)
+++ trunk/mapbender/http/classes/class_RPCEndpoint.php 2010-08-19 16:02:21 UTC (rev 6768)
@@ -1,4 +1,5 @@
<?php
+require_once dirname(__FILE__)."/../../lib/class_Filter.php";
interface RPCObject{
Added: trunk/mapbender/lib/class_Filter.php
--- trunk/mapbender/lib/class_Filter.php (rev 0)
+++ trunk/mapbender/lib/class_Filter.php 2010-08-19 16:02:21 UTC (rev 6768)
@@ -0,0 +1,119 @@
+<?php
+# License:
+# Copyright (c) 2009, Open Source Geospatial Foundation
+# This program is dual licensed under the GNU General Public License
+# and Simplified BSD license.
+# http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+class Filter {
+ // simple filter
+ protected $operator;
+ protected $key;
+ protected $value;
+ // complex filter
+ protected $booleanOperator;
+ protected $filterArray;
+ const OPERATORS = "=,>,>=,<,<=,<>,LIKE,ILIKE,IN";
+ const BOOLEAN_OPERATORS = "AND,OR";
+ public function __construct () {
+ if (func_num_args() === 3) {
+ if (!in_array(func_get_arg(0), explode(",", Filter::OPERATORS))) {
+ throw new Exception ("Filter: Invalid operator " . func_get_arg(0));
+ $this->operator = func_get_arg(0);
+ if (!is_string(func_get_arg(1)) || func_get_arg(1) === "") {
+ throw new Exception ("Filter: Invalid key " . func_get_arg(1));
+ $this->key = func_get_arg(1);
+ $this->value = func_get_arg(2);
+ if (func_num_args() === 2) {
+ if (!in_array(func_get_arg(0), explode(",", Filter::BOOLEAN_OPERATORS))) {
+ throw new Exception ("Filter: Invalid boolean operator " . func_get_arg(0));
+ $this->booleanOperator = func_get_arg(0);
+ if (is_array(func_get_arg(1))) {
+ foreach (func_get_arg(1) as $filter) {
+ if (!is_a($filter, "Filter")) {
+ throw new Exception("Filter: Not a valid filter.");
+ $this->filterArray = func_get_arg(1);
+ protected function isComplex () {
+ if (in_array($this->booleanOperator, explode(",", Filter::BOOLEAN_OPERATORS)) &&
+ is_array($this->filterArray)
+ foreach ($this->filterArray as $filter) {
+ return true;
+ return false;
+ private function getType ($v) {
+ if (is_float($v) || is_integer($v)) {
+ return "i";
+ return "s";
+ public function toSql ($parameterCount = 1) {
+ $sqlObject = new stdClass();
+ $sqlObject->sql = "";
+ $sqlObject->v = array();
+ $sqlObject->t = array();
+ if ($this->isComplex()) {
+ $i = $parameterCount;
+ $currentSqlObject = $filter->toSql($i);
+ $currentBooleanOperator = ($i === $parameterCount) ?
+ "" : " " . $this->booleanOperator . " ";
+ $sqlObject->sql .= $currentBooleanOperator .
+ $currentSqlObject->sql;
+ $sqlObject->v = array_merge($sqlObject->v, $currentSqlObject->v);
+ $sqlObject->t = array_merge($sqlObject->t, $currentSqlObject->t);
+ $i += count($currentSqlObject->v);
+ $sqlObject->sql = "(" . $sqlObject->sql . ")";
+ return $sqlObject;
+ else {
+ if (is_array($this->value)) {
+ if ($this->operator === "IN") {
+ $parameters = array();
+ foreach ($this->value as $value) {
+ $parameters[]= "$" . $parameterCount++;
+ $sqlObject->v[]= $value;
+ $sqlObject->t[]= $this->getType($value);
+ $sqlObject->sql = $this->key . " " . $this->operator .
+ " (" . implode(",", $parameters) . ")";
+ else {
+ throw new Exception("Filter: Multiple values only supported for IN.");
+ else {
+ $sqlObject->sql = $this->key . $this->operator . "$" . $parameterCount;
+ $sqlObject->v = array($this->value);
+ $sqlObject->t = array($this->getType($this->value));
\ No newline at end of file
Added: trunk/mapbender/test/http/classes/FilterTest.php
--- trunk/mapbender/test/http/classes/FilterTest.php (rev 0)
+++ trunk/mapbender/test/http/classes/FilterTest.php 2010-08-19 16:02:21 UTC (rev 6768)
@@ -0,0 +1,54 @@
+<?php
+require_once 'PHPUnit/Framework.php';
+require_once dirname(__FILE__) . "/../../../lib/class_Filter.php";
+class FilterTest extends PHPUnit_Framework_TestCase {
+ public function testConstructorOperatorKeyValue () {
+ $filter = new Filter("=", "a", "b");
+ $sqlObject->sql = "a=$1";
+ $sqlObject->v = array("b");
+ $sqlObject->t = array("s");
+ $this->assertEquals($sqlObject, $filter->toSql());
+ public function testConstructorOperatorKeyValueArray () {
+ $filter = new Filter("IN", "a", array("a", "b", "c"));
+ $sqlObject->sql = "a IN ($1,$2,$3)";
+ $sqlObject->v = array("a", "b", "c");
+ $sqlObject->t = array("s", "s", "s");
+ public function testConstructorOperatorFilterArray () {
+ $filterA = new Filter("=", "a", "b");
+ $filterB = new Filter(">=", "b", 3);
+ $filter = new Filter("AND", array($filterA, $filterB));
+ $sqlObject->sql = "(a=$1 AND b>=$2)";
+ $sqlObject->v = array("b", 3);
+ $sqlObject->t = array("s", "i");
+ public function testConstructorRecursive() {
+ $filterA1 = new Filter("=", "a", "b");
+ $filterB1 = new Filter(">=", "b", 3);
+ $filter1all = new Filter("AND",array($filterA1,$filterB1));
+ $filterA2 = new Filter("=", "c", "d");
+ $filterB2 = new Filter(">=", "e", 4);
+ $filter2all = new Filter("AND",array($filterA2,$filterB2));
+ $filter = new Filter("AND", array($filter1all, $filter2all));
+ $sqlObject->sql = "((a=$1 AND b>=$2) AND (c=$3 AND e>=$4))";
+ $sqlObject->v = array("b", 3, "d", 4);
+ $sqlObject->t = array("s", "i","s", "i");
More information about the Mapbender_commits
