[Mapbender-commits] r6774 - trunk/mapbender/lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Aug 20 06:28:00 EDT 2010
Author: christoph
Date: 2010-08-20 10:28:00 +0000 (Fri, 20 Aug 2010)
New Revision: 6774
   trunk/mapbender/lib/class_Filter.php
empty filters
multiple filters with a single filter as argument
Modified: trunk/mapbender/lib/class_Filter.php
--- trunk/mapbender/lib/class_Filter.php	2010-08-20 07:20:45 UTC (rev 6773)
+++ trunk/mapbender/lib/class_Filter.php	2010-08-20 10:28:00 UTC (rev 6774)
@@ -32,7 +32,7 @@
 			$this->value = func_get_arg(2);
-		if (func_num_args() === 2) {
+		else if (func_num_args() === 2) {
 			if (!in_array(func_get_arg(0), explode(",", Filter::BOOLEAN_OPERATORS))) {
 				throw new Exception ("Filter: Invalid boolean operator " . func_get_arg(0));
@@ -47,30 +47,11 @@
 				$this->filterArray = func_get_arg(1);
-	protected function isComplex () {
-		if (in_array($this->booleanOperator, explode(",", Filter::BOOLEAN_OPERATORS)) &&
-			is_array($this->filterArray)
-			foreach ($this->filterArray as $filter) {
-				if (!is_a($filter, "Filter")) {
-					throw new Exception("Filter: Not a valid filter.");
-					return false;
-			return true;
+		else {
-		return false;
-	private function getType ($v) {
-		if (is_float($v) || is_integer($v)) {
-			return "i";
-		return "s";
 	public function toSql ($parameterCount = 1) {
 		$sqlObject = new stdClass();
 		$sqlObject->sql = "";
@@ -81,6 +62,10 @@
 			$i = $parameterCount;
 				$currentSqlObject = $filter->toSql($i);
+				if ($currentSqlObject->sql === "") {
+					continue;
 				$currentBooleanOperator = ($i === $parameterCount) ?
 					"" : " " . $this->booleanOperator . " ";
 				$sqlObject->sql .= $currentBooleanOperator .
@@ -109,12 +94,55 @@
 			else {
-				$sqlObject->sql = $this->key . $this->operator . "$" . $parameterCount;
-				$sqlObject->v = array($this->value);
-				$sqlObject->t = array($this->getType($this->value));
+				$sqlObject->sql = !is_null($this->key) && !is_null($this->operator) ?
+					$this->key . $this->operator . "$" . $parameterCount : "";
+				$sqlObject->v = !is_null($this->value) ? array($this->value) : array();
+				$sqlObject->t = !is_null($this->value) ? array($this->getType($this->value)) : array();
 			return $sqlObject;
+	public static function merge ($booleanOperator, $filterArray) {
+		if (!in_array($booleanOperator, explode(",", Filter::BOOLEAN_OPERATORS))) {
+			throw new Exception ("Filter: Invalid boolean operator " . $booleanOperator);
+		$validFilterArray = array();
+		if (is_array($filterArray)) {
+			foreach ($filterArray as $filter) {
+				if (!is_a($filter, "Filter")) {
+					continue;
+				$validFilterArray[]= $filter;
+		return count($validFilterArray) > 0 ?
+			count($validFilterArray) === 1 ? $validFilterArray[0] : new Filter($booleanOperator, $validFilterArray)
+			: null;
+	protected function isComplex () {
+		if (in_array($this->booleanOperator, explode(",", Filter::BOOLEAN_OPERATORS)) &&
+			is_array($this->filterArray)
+			foreach ($this->filterArray as $filter) {
+					throw new Exception("Filter: Not a valid filter.");
+					return false;
+			return true;
+		return false;
+	private function getType ($v) {
+		if (is_float($v) || is_integer($v)) {
+			return "i";
+		return "s";
\ No newline at end of file
More information about the Mapbender_commits mailing list
