[Mapbender-commits] r6776 - trunk/mapbender/lib
svn_mapbender at osgeo.org
Fri Aug 20 08:04:03 EDT 2010
Author: christoph
Date: 2010-08-20 12:04:03 +0000 (Fri, 20 Aug 2010)
New Revision: 6776
trunk/mapbender/lib/class_Filter.php
allow filters like FALSE
Modified: trunk/mapbender/lib/class_Filter.php
--- trunk/mapbender/lib/class_Filter.php 2010-08-20 10:48:23 UTC (rev 6775)
+++ trunk/mapbender/lib/class_Filter.php 2010-08-20 12:04:03 UTC (rev 6776)
@@ -17,6 +17,7 @@
const OPERATORS = "=,>,>=,<,<=,<>,LIKE,ILIKE,IN";
const BOOLEAN_OPERATORS = "AND,OR";
+ const BOOLEAN = "TRUE,FALSE";
public function __construct () {
if (func_num_args() === 3) {
@@ -47,6 +48,11 @@
$this->filterArray = func_get_arg(1);
+ else if (func_num_args() === 1) {
+ if (in_array(strtoupper(func_get_arg(0)), explode(",", Filter::BOOLEAN))) {
+ $this->value = strtoupper(func_get_arg(0));
else {
@@ -95,9 +101,12 @@
else {
$sqlObject->sql = !is_null($this->key) && !is_null($this->operator) ?
- $this->key . $this->operator . "$" . $parameterCount : "";
- $sqlObject->v = !is_null($this->value) ? array($this->value) : array();
- $sqlObject->t = !is_null($this->value) ? array($this->getType($this->value)) : array();
+ $this->key . $this->operator . "$" . $parameterCount :
+ (!is_null($this->value) ? $this->value : "");
+ $sqlObject->v = !is_null($this->key) && !is_null($this->operator) && !is_null($this->value) ?
+ array($this->value) : array();
+ $sqlObject->t = !is_null($this->key) && !is_null($this->operator) && !is_null($this->value) ?
+ array($this->getType($this->value)) : array();
return $sqlObject;
More information about the Mapbender_commits
