[Mapbender-commits] r6800 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Tue Aug 24 05:48:26 EDT 2010
Author: armin11
Date: 2010-08-24 09:48:26 +0000 (Tue, 24 Aug 2010)
New Revision: 6800
trunk/mapbender/http/classes/class_metadata_new.php
Update mapbender metadataserver component
Modified: trunk/mapbender/http/classes/class_metadata_new.php
--- trunk/mapbender/http/classes/class_metadata_new.php 2010-08-24 09:47:30 UTC (rev 6799)
+++ trunk/mapbender/http/classes/class_metadata_new.php 2010-08-24 09:48:26 UTC (rev 6800)
@@ -22,7 +22,7 @@
#We need a parameter for internationalization - it should be send with the search request! Some of the Classes can be provided with different languages.
#WMC and GeoRSS-Feeds have no or a to complex authorization info - maybe we need to test if wmc consists of info which is fully or only partually available to the anonymous user.
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
require_once(dirname(__FILE__)."/class_administration.php");
require_once(dirname(__FILE__)."/class_mb_exception.php");
require_once(dirname(__FILE__)."/class_json.php");
@@ -88,7 +88,7 @@
$this->maxObjects = 15;
$this->maxFontSize = 30;
$this->maxWeight = 0;
- $this->scale == 'linear';
+ $this->scale = 'linear';
@@ -138,34 +138,34 @@
$this->resourceCategories[0]['name'] = 'WMS';
$this->resourceCategories[1]['name'] = 'WFS';
$this->resourceCategories[2]['name'] = 'WMC';
- $this->resourceCategories[3]['name'] = 'GeoRSS';
+ $this->resourceCategories[3]['name'] = 'DAD';
switch($this->languageCode){
case 'de':
$this->resourceCategories[0]['name2show'] = 'Darstellungsdienste';
- $this->resourceCategories[1]['name2show'] = 'Such- und Downloaddienste';
+ $this->resourceCategories[1]['name2show'] = 'Such- und Download- und Erfassungsmodule';
$this->resourceCategories[2]['name2show'] = 'Kartenzusammenstellungen';
- $this->resourceCategories[3]['name2show'] = 'Geokodierte Newsfeeds';
+ $this->resourceCategories[3]['name2show'] = 'KML/Newsfeeds';
$this->keywordTitle = 'Schlagwortliste';
break;
case 'en':
$this->resourceCategories[0]['name2show'] = 'Viewingservices';
$this->resourceCategories[1]['name2show'] = 'Search- and Downloadservices';
$this->resourceCategories[2]['name2show'] = 'Combined Maps';
- $this->resourceCategories[3]['name2show'] = 'Geocodet Newsfeeds';
$this->keywordTitle = 'Keywordlist';
break;
case 'fr':
break;
default:
//not needed til now - maybe usefull for georss output
@@ -242,7 +242,7 @@
if (isset($this->searchResources) & strtolower($this->searchResources) === "wmc") {
$this->searchView = 'search_wmc_view';
$this->databaseIdColumnName = 'wmc_id';
- $this->databaseTableName = 'mb_user_wmc';
+ $this->databaseTableName = 'wmc';
switch ($this->orderBy) {
case "rank":
@@ -457,6 +457,7 @@
$this->wmcJSON->wmc->srv[$i]->date = date("d.m.Y",$wmcMatrix[$i]['wmc_timestamp']);
$this->wmcJSON->wmc->srv[$i]->respOrg = $wmcMatrix[$i]['mb_group_name'];
$this->wmcJSON->wmc->srv[$i]->mdLink = "http://".$this->hostName."/mapbender/x_geoportal/showWMCMetadata.php?id=".$wmcMatrix[$i]['wmc_id'];
+ $this->wmcJSON->wmc->srv[$i]->previewURL = "http://".$this->hostName."/mapbender/x_geoportal/mod_wmcPreview.php?id=".$wmcMatrix[$i]['wmc_id'];
$spatialSource = "";
$stateOrProvince = $wmcMatrix[$i]['mb_group_stateorprovince'];
if ($stateOrProvince == "NULL" || $stateOrProvince == "") {
@@ -509,7 +510,6 @@
#echo "<br>user_id: ".$this->userId."<br><br>";
#var_dump($this->accessableLayers);
#echo "<br>";
#$countWmsMatrix = count($wmsMatrix);
#echo $countWmsMatrix;
if ($n != 0) {
@@ -551,7 +551,6 @@
#echo "<br>".$rootLayerId."<br>";
//push root layer id in array
array_push($layerIdArray, $rootLayerId);
#echo "<br>root Layer ID: ".$rootLayerId."<br>";
#array_multisort($subLayers['layer_pos'], SORT_ASC);
#print_r($subLayers);
@@ -565,7 +564,6 @@
#$this->wmsJSON->wms->srv[$j]->respOrg = "test";
$this->wmsJSON->wms->srv[$j]->loadCount = (integer)$subLayers[$rootIndex]['load_count'];
#$this->wmsJSON->wms->srv[$j]->mdLink = "http://".$_SERVER['HTTP_HOST']."/mapbender/x_geoportal/mod_layerMetadata.php?id=".(integer)$subLayers[$rootIndex]['layer_id'];
$stateOrProvince = $subLayers[$rootIndex]['stateorprovince'];
#echo $stateOrProvince."<br>";
@@ -584,10 +582,6 @@
//TODO check the field accessconstraints - which should be presented?
$this->wmsJSON->wms->srv[$j]->status = $subLayers[$rootIndex]['status']; //$wmsMatrix[$i][''];
$this->wmsJSON->wms->srv[$j]->avail = $subLayers[$rootIndex]['availability']; //$wmsMatrix[$i][''];
//get info about defined price
if ($subLayers[$rootIndex]['wms_pricevolume'] == '' OR $subLayers[$rootIndex]['wms_pricevolume'] == 0){
$this->wmsJSON->wms->srv[$j]->price = NULL;
@@ -609,7 +603,6 @@
else {
$this->wmsJSON->wms->srv[$j]->nwaccess = true;
#$this->wmsJSON->wms->srv[$j]->logged = NULL; //$wmsMatrix[$i][''];
#$this->wmsJSON->wms->srv[$j]->price = NULL; //$wmsMatrix[$i][''];
#$this->wmsJSON->wms->srv[$j]->nwaccess = NULL; //$wmsMatrix[$i][''];
@@ -818,84 +811,77 @@
-/* This is only for the later postgis versions. The within and disjoint is to slow, cause there is no usage of the geometrical index in the old versions!
-//check for postgis version
-//sql for get version string
-//get version number
-decide which type of search should be done
- //spatial search filter - ist should be the first filter in the where clause, cause it is
- if (strtolower($this->searchResources) === "wms" & $this->searchBbox != NULL) {
- #$spatialFilter = "(the_geom ";
- #echo "<br> spatial operator: ".$this->searchTypeBbox."<br>";
- if ($this->searchTypeBbox == 'outside') {
- $spatialFilter = ' disjoint(';
- } elseif ($this->searchTypeBbox == 'inside') {
- $spatialFilter = ' within(';
- } else {
- $spatialFilter = ' intersects(';
- //define spatial filter
- if(count(explode(',',$this->searchBbox)) == 4){ //if searchBbox has 4 entries
- $spatialFilterCoords = explode(',',$this->searchBbox);//read out searchBbox
- //definition of the spatial filter
- $spatialFilter .= 'GeomFromText(\'POLYGON(('.$spatialFilterCoords[0];//minx
- $spatialFilter .= ' '.$spatialFilterCoords[1].',';//miny
- $spatialFilter .= $spatialFilterCoords[0];//minx
- $spatialFilter .= ' '.$spatialFilterCoords[3].',';//maxy
- $spatialFilter .= $spatialFilterCoords[2];//maxx
- $spatialFilter .= ' '.$spatialFilterCoords[1].'))\',4326)';//miny
- $spatialFilter .= ",the_geom)";
- array_push($whereCondArray, $spatialFilter);
- #array_push($whereCondArray, $spatialFilter);
+ // This is only for the later postgis versions. The within and disjoint is to slow, cause there is no usage of the geometrical index in the old versions!
+ //check for postgis version
+ //sql for get version string
+ //get version number
if ((strtolower($this->searchResources) === "wms" or strtolower($this->searchResources) === "wmc") & $this->searchBbox != NULL) {
- #if ($this->searchTypeBbox == 'outside') {
- # $spatialFilter = ' disjoint(';
- #} elseif ($this->searchTypeBbox == 'inside') {
- # $spatialFilter = ' within(';
- #} else {
- # $spatialFilter = ' intersects(';
- $spatialFilter = ' the_geom && ';
- #$spatialFilter .= ",the_geom)";
+ //decide which type of search should be done
+ //check for postgis version cause postgis versions < 1.4 have problems when doing disjoint and inside
+ $sqlPostgisVersion = "SELECT postgis_version();";
+ $vPostgisVersion = array();
+ $tPostgisVersion = array();
+ $resPostgisVersion = db_prep_query($sqlPostgisVersion, $vPostgisVersion, $tPostgisVersion);
+ // get version string
+ while($row = db_fetch_array($resPostgisVersion)){
+ $postgisVersion = $row['postgis_version'];
+ $postgisVersionArray = explode(" ",$postgisVersion);
+ $postgisVersionSmall = explode(".",$postgisVersionArray[0]);
+ $postgisSubNumber = $postgisVersionSmall[1];
+ $e = new mb_exception("class_metadata.php: postgis sub number = ".$postgisSubNumber);
+ if ((integer)$postgisSubNumber >= 4){
+ #$spatialFilter = "(the_geom ";
+ $e = new mb_exception("class_metadata.php: spatial operator: ".$this->searchTypeBbox);
+ if ($this->searchTypeBbox == 'outside') {
+ $spatialFilter = ' disjoint(';
+ } elseif ($this->searchTypeBbox == 'inside') {
+ $spatialFilter = ' within(';
+ } else {
+ $spatialFilter = ' intersects(';
+ //define spatial filter
+ if(count(explode(',',$this->searchBbox)) == 4){ //if searchBbox has 4 entries
+ $spatialFilterCoords = explode(',',$this->searchBbox);//read out searchBbox
+ //definition of the spatial filter
+ $spatialFilter .= 'GeomFromText(\'POLYGON(('.$spatialFilterCoords[0];//minx
+ $spatialFilter .= ' '.$spatialFilterCoords[1].',';//miny
+ $spatialFilter .= $spatialFilterCoords[0];//minx
+ $spatialFilter .= ' '.$spatialFilterCoords[3].',';//maxy
+ $spatialFilter .= $spatialFilterCoords[2];//maxx
+ $spatialFilter .= ' '.$spatialFilterCoords[1].'))\',4326)';//miny
+ $spatialFilter .= ",the_geom)";
+ array_push($whereCondArray, $spatialFilter);
+ } else {
+ $spatialFilter = ' the_geom && ';
+ #$spatialFilter .= ",the_geom)";
//search filter for md_topic_categories
if ((strtolower($this->searchResources) === "wms" or strtolower($this->searchResources) === "wmc") & $this->isoCategories != NULL) {
@@ -1074,15 +1060,26 @@
if (count($keywordCounts) > 0) {
$this->maxWeight = $keywordCounts[0]['count'];
for ($j = 0; $j < count($keywordCounts); $j++) {
- $this->keyJSON->tagCloud->tags[$j]->title = $keywordCounts[$j]['keyword'];
- //generate the weight:
if ($this->scale == 'linear'){
//order in a linear scale desc
- $this->keyJSON->tagCloud->tags[$j]->weight = $this->maxFontSize-($j*$this->inc);
+ $keywordCounts[$j]['count'] = $this->maxFontSize-($j*$this->inc);
} else {
//set weight prop to count
- $this->keyJSON->tagCloud->tags[$j]->weight = $keywordCounts[$j]['count']*$this->maxFontSize/$this->maxWeight;
+ $keywordCounts[$j]['count'] = $keywordCounts[$j]['count']*$this->maxFontSize/$this->maxWeight;
+ //$this->maxWeight = $keywordCounts[0]['count'];
+ shuffle($keywordCounts);
+ for ($j = 0; $j < count($keywordCounts); $j++) {
+ $this->keyJSON->tagCloud->tags[$j]->title = $keywordCounts[$j]['keyword'];
+ //generate the weight:
+ //if ($this->scale == 'linear'){
+ //order in a linear scale desc
+ $this->keyJSON->tagCloud->tags[$j]->weight = $keywordCounts[$j]['count'];
+ //} else {
+ //set weight prop to count
+ // $this->keyJSON->tagCloud->tags[$j]->weight = $keywordCounts[$j]['count']*$this->maxFontSize/$this->maxWeight;
//$this->keyJSON->tags[$j]->weight = $keywordCounts[$j]['count'];
$paramValue = $this->getValueForParam('searchText', $this->searchURL);
@@ -1741,4 +1738,4 @@
\ No newline at end of file
More information about the Mapbender_commits
