[Mapbender-commits] r6802 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Tue Aug 24 08:28:59 EDT 2010
Author: verenadiewald
Date: 2010-08-24 12:28:59 +0000 (Tue, 24 Aug 2010)
New Revision: 6802
trunk/mapbender/http/javascripts/initWmcObj.php
current status for loading featuretype confs
Modified: trunk/mapbender/http/javascripts/initWmcObj.php
--- trunk/mapbender/http/javascripts/initWmcObj.php 2010-08-24 12:27:34 UTC (rev 6801)
+++ trunk/mapbender/http/javascripts/initWmcObj.php 2010-08-24 12:28:59 UTC (rev 6802)
@@ -215,12 +215,85 @@
-//workaround to have a fully merged WMS for loading
+$getParams["FEATURETYPE"] = getConfiguration("FEATURETYPE");
+function normalizeFeaturetypeInput ($input) {
+ if (is_array($input)) {
+ $keys = array_keys($input);
+ $isSingleFeaturetype = false;
+ foreach ($keys as $key) {
+ if (!is_numeric($key)) {
+ $isSingleFeaturetype = true;
+ break;
+ // FEATURETYPE[id]=12&FEATURETYPE[active]=something
+ if ($isSingleFeaturetype) {
+ $input[0] = array();
+ $input[0][$key] = $input[$key];
+ unset($input[$key]);
+ else {
+ for ($i = 0; $i < count($input); $i++) {
+ // assume FEATURETYPE[]=12&FEATURETYPE[]=13
+ if (is_numeric($input[$i])) {
+ $id = $input[$i];
+ $input[$i] = array("id" => $id);
+ else {
+ // assume FEATURETYPE=12,13,14
+ $inputArray = split(",", $input);
+ $input = array();
+ $i = 0;
+ foreach ($inputArray as $id) {
+ if (is_numeric($id)) {
+ $input[$i++]["id"] = $id;
+ // check if each featuretype has at least an id, if not, delete
+ $i = 0;
+ while ($i < count($input)) {
+ if (!is_array($input[$i]) || !isset($input[$i]["id"]) || !is_numeric($input[$i]["id"])) {
+ array_splice($input, $i, 1);
+ continue;
+ $input[$i]["id"] = intval($input[$i]["id"]);
+ $i++;
+ return $input;
+if ($getParams["FEATURETYPE"]) {
+ $inputFeaturetypeArray = normalizeFeaturetypeInput($getParams['FEATURETYPE']);
+ $wfsConfIds = array();
+ foreach ($inputFeaturetypeArray as $input) {
+ array_push($wfsConfIds, $input["id"]);
+ $wmc->generalExtensionArray['WFSCONFIDSTRING'] = implode(",", array_merge(
+ explode(",", $wmc->generalExtensionArray['WFSCONFIDSTRING']),
+ $wfsConfIds
+ //$firephp->log($wmc->generalExtensionArray['WFSCONFIDSTRING']);
+//workaround to have a fully merged WMC for loading
$xml = $wmc->toXml();
+#$firephp->log($xml);
$wmc = new wmc();
$wmc->createFromXml($xml);
+//$firephp->log($wmc);
$output = $wmc->wmsToJavaScript();
@@ -228,10 +301,21 @@
$extent = $wmc->mainMap->getExtent();
Mapbender::session()->set("mb_myBBOX", $extent->min->x . "," . $extent->min->y . "," . $extent->max->x . "," . $extent->max->y);
+$outputString = "";
for ($i = 0; $i < count($output); $i++) {
- echo administration::convertOutgoingString($output[$i]);
+ $outputString .= administration::convertOutgoingString($output[$i]);
+$wmcFeaturetypeJson = $wmc->featuretypeConfToJavaScript();
+$wmcFeaturetypeStr = "Mapbender.events.afterInit.register(function () {
+ $('#body').trigger('addFeaturetypeConfs', [{featuretypeConfObj : ".$wmcFeaturetypeJson."}]);
+$outputString .= $wmcFeaturetypeStr;
+echo $outputString;
Mapbender::session()->delete("addwms_showWMS");
Mapbender::session()->delete("addwms_zoomToExtent");
unset($output);
More information about the Mapbender_commits
