[Mapbender-commits] r6806 -
trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Wed Aug 25 07:16:02 EDT 2010
Author: astrid_emde
Date: 2010-08-25 11:16:02 +0000 (Wed, 25 Aug 2010)
New Revision: 6806
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
checked new print sql and aconfigured an SQL to add the new print to gui1
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql 2010-08-24 19:54:26 UTC (rev 6805)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql 2010-08-25 11:16:02 UTC (rev 6806)
@@ -1450,17 +1450,28 @@
-- gui_digitze: added new printPDF (with rotation and pdf Template)
-- does not work with 4326 :(
---Delete from gui_element where fkey_gui_id = 'gui_digitize' and e_id = 'printPDF';
---INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes,
--- e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES(
---'gui_digitize','printPDF',2,1,'pdf print','Print','div','','',1,1,2,2,5,'','<div id="printPDF_working_bg"></div><div id="printPDF_working"><img src="../img/indicator_wheel.gif" style="padding:10px 0 0 10px">Generating PDF</div><div id="printPDF_input"><form id="printPDF_form" action="../print/printFactory.php"><div id="printPDF_selector"></div><div class="print_option"><input type="hidden" id="map_url" name="map_url" value=""/><input type="hidden" id="overview_url" name="overview_url" value=""/><input type="hidden" id="map_scale" name="map_scale" value=""/><input type="hidden" name="measured_x_values" /><input type="hidden" name="measured_y_values" /><br /></div><div class="print_option" id="printPDF_formsubmit"><input id="submit" type="submit" value="Print"><br /></div></form><div id="printPDF_result"></div></div>','div','../plugins/mb_print.js','../../lib/printbox.js,../extensions/jquery-ui-1.7.2.custom/development-bundle/external/bgiframe/jquery.bgiframe.min.js,../exten
sions/jquery.form.min.js','mapframe1','','http://www.mapbender.org/index.php/Print');
+Delete from gui_element where fkey_gui_id = 'gui1' and e_id = 'printPDF';
---INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES(
---'gui_digitize', 'printPDF', 'mbPrintConfig', '{"A4 landscape": "A4_lanscape_template.json","A4 portrait": "A4_portrait_template.json","A4 landscape": "A4_landscape_template.json","A3 landscape": "A3_landscape_template.json"}', '' ,'var');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title,
+e_element, e_src, e_attributes, e_left, e_top, e_width, e_height,
+e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+e_mb_mod, e_target, e_requires, e_url)
+VALUES('gui1','printPDF',2,1,'pdf print','Print','div','','',
+10,520,200,380,5,'',
+'<div id="printPDF_working_bg"></div><div id="printPDF_working"><img src="../img/indicator_wheel.gif" style="padding:10px 0 0 10px">Generating PDF</div><div id="printPDF_input"><form id="printPDF_form" action="../print/printFactory.php"><div id="printPDF_selector"></div><div class="print_option"><input type="hidden" id="map_url" name="map_url" value=""/><input type="hidden" id="overview_url" name="overview_url" value=""/><input type="hidden" id="map_scale" name="map_scale" value=""/><input type="hidden" name="measured_x_values" /><input type="hidden" name="measured_y_values" /><br /></div><div class="print_option" id="printPDF_formsubmit"><input id="submit" type="submit" value="Print"><br /></div></form><div id="printPDF_result"></div></div>',
+'div','../plugins/mb_print.js',
+'../../lib/printbox.js,../extensions/jquery-ui-1.7.2.custom/development-bundle/external/bgiframe/jquery.bgiframe.min.js,../extensions/jquery.form.min.js',
+'mapframe1','','http://www.mapbender.org/index.php/Print');
---'gui_digitize', 'body', 'print_css', '../css/print_div.css', '' ,'file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name,
+var_value, context, var_type)
+VALUES('gui1', 'printPDF', 'mbPrintConfig', '{"A4 landscape": "A4_landscape_template.json","A4 portrait": "A4_portrait_template.json","A4 landscape": "A4_landscape_template.json","A3 landscape": "A3_landscape_template.json"}', '' ,'var');
+VALUES('gui1', 'body', 'print_css', '../css/print_div.css', '' ,'file/css');
-- standard gui gui_wfs_conf entries for search
INSERT INTO gui_wfs_conf(fkey_gui_id, fkey_wfs_conf_id)
SELECT 'gui',wfs_conf_id from wfs_conf WHERE wfs_conf_id = 1
More information about the Mapbender_commits
