[Mapbender-commits] r5497 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Thu Feb 11 06:28:48 EST 2010
Author: armin11
Date: 2010-02-11 06:28:46 -0500 (Thu, 11 Feb 2010)
New Revision: 5497
trunk/mapbender/http/classes/class_administration.php
new function to get a list of all accessable layers for one user
Modified: trunk/mapbender/http/classes/class_administration.php
--- trunk/mapbender/http/classes/class_administration.php 2010-02-11 09:40:08 UTC (rev 5496)
+++ trunk/mapbender/http/classes/class_administration.php 2010-02-11 11:28:46 UTC (rev 5497)
@@ -1387,7 +1387,44 @@
return $r;
+ * identifies the layers where the current user is has permission to access
+ * @param integer userid the user-ID of the current user
+ * @return integer[] the IDs of the layers
+ * @boolean if the user has no rights to access any layer
+ function getLayersByPermission($user_id){
+ $arrayGuis = $this->getGuisByPermission($user_id,true);
+ $v = array();
+ $t = array();
+ $sql = "SELECT DISTINCT fkey_layer_id FROM gui_layer WHERE fkey_gui_id IN (";
+ $c = 1;
+ for($i=0; $i<count($arrayGuis); $i++){
+ if($i>0){ $sql .= ",";}
+ $sql .= "$".$c;
+ $c++;
+ array_push($v, $arrayGuis[$i]);
+ array_push($t, 's');
+ $sql .= ") AND gui_layer_status = 1";
+ array_push($t,'i');
+ $res = db_prep_query($sql,$v,$t);
+ $arrayLayers = array();
+ if($row = db_fetch_array($res)){
+ while($row = db_fetch_array($res)){
+ array_push($arrayLayers,$row["fkey_layer_id"]);
+ return $arrayLayers;
+ return false;
/** identifies the Conf-FeatureServices where the current user is owner
* @deprecated
More information about the Mapbender_commits
