[Mapbender-commits] r5534 -
trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Sat Feb 20 05:03:13 EST 2010
Author: astrid_emde
Date: 2010-02-20 05:03:13 -0500 (Sat, 20 Feb 2010)
New Revision: 5534
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
added jq_ui_draggable to toolboy_jquery
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql 2010-02-20 09:56:57 UTC (rev 5533)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql 2010-02-20 10:03:13 UTC (rev 5534)
@@ -1175,6 +1175,7 @@
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'shake', '0', '1 = effect active', 'php_var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'slide', '0', '1 = effect active', 'php_var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'transfer', '1', '1 = effect active', 'php_var');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('toolbox_jquery','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.draggable.js','','jq_ui','');
INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('toolbox_jquery', 1, 'owner');
More information about the Mapbender_commits
