[Mapbender-commits] r5539 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sat Feb 20 06:10:42 EST 2010
Author: astrid_emde
Date: 2010-02-20 06:10:41 -0500 (Sat, 20 Feb 2010)
New Revision: 5539
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
SQl entry in translations for GeoRSS
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql	2010-02-20 10:59:09 UTC (rev 5538)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql	2010-02-20 11:10:41 UTC (rev 5539)
@@ -746,7 +746,7 @@
 -- add georss in gui1
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
-SELECT gui.gui_id,'addGeoRSS',2,1,'add a GeoRSS Feed to a running application','','img','../img/georss_logo_off.png','onclick=''loadGeoRSSByForm()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' title="GeoRSSFeed hinzuladen"',950,60,24,24,1,'','','','mod_georss.php','popupballon.js,usemap.js,geometry.js,../extensions/wz_jsgraphics.js','mapframe1','',''
+SELECT gui.gui_id,'addGeoRSS',2,1,'add a GeoRSS Feed to a running application','Add GeoRSS','img','../img/georss_logo_off.png','onclick=''loadGeoRSSByForm()''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''',950,60,24,24,1,'','','','mod_georss.php','popupballon.js,usemap.js,geometry.js,../extensions/wz_jsgraphics.js','mapframe1','',''
 FROM gui WHERE gui.gui_id = 'gui1' AND gui.gui_id
 NOT IN (SELECT fkey_gui_id FROM gui_element
 WHERE e_id = 'addGeoRSS');
@@ -1175,7 +1175,7 @@
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'shake', '0', '1 = effect active', 'php_var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'slide', '0', '1 = effect active', 'php_var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('toolbox_jquery', 'jq_ui_effects', 'transfer', '1', '1 = effect active', 'php_var');
-INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('toolbox_jquery','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.draggable.js','','jq_ui','');
+INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('toolbox_jquery','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.draggable.js','','jq_ui','http://jqueryui.com/demos/draggable/');
 INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('toolbox_jquery', 1, 'owner');
@@ -1266,3 +1266,20 @@
 -- missing wz_jsgraphics in gazetteer
 -- replacing obsolete tablesorter
 UPDATE gui_element SET e_mb_mod = 'geometry.js,requestGeometryConstructor.js,popup.js,../extensions/wz_jsgraphics.js' WHERE e_id = 'gazetteerWFS';
+ e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
+Select 'toolbox_jquery','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',
+NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/jquery-ui-1.7.2.custom/development-bundle/ui/min.ui.draggable.js','','jq_ui',
+'http://jqueryui.com/demos/draggable/'
+from gui_element WHERE
+gui_element.e_id = 'gazetteerWFS' AND
+gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element WHERE e_id = 'jq_ui_draggable');
+INSERT INTO translations (locale, msgid, msgstr ) VALUES ('de', 'Add GeoRSS', 'GeoRSS hinzufügen');
More information about the Mapbender_commits mailing list
