[Mapbender-commits] r5541 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org
Sat Feb 20 06:13:04 EST 2010
Author: tbaschetti
Date: 2010-02-20 06:13:04 -0500 (Sat, 20 Feb 2010)
New Revision: 5541
trunk/mapbender/resources/db/install.sh
dropped mysql and ISO-8859-1 support
added support for commandline args
Modified: trunk/mapbender/resources/db/install.sh
--- trunk/mapbender/resources/db/install.sh 2010-02-20 11:12:49 UTC (rev 5540)
+++ trunk/mapbender/resources/db/install.sh 2010-02-20 11:13:04 UTC (rev 5541)
@@ -6,7 +6,7 @@
function show_disclaimer() {
# Disclaimer
echo ""
- echo "DISCLAIMER: this Mapbender database setup script is not stable. USE AT YOUR OWN RISK!"
+ echo "DISCLAIMER: Mapbender database setup script. USE AT YOUR OWN RISK!"
echo "The script will create a database for you and will import the Mapbender data to the new database"
echo "It will also compile the Mapbender.mo files"
echo ""
@@ -20,7 +20,16 @@
echo ""
echo ""
echo "If everything is prepared you can continue."
+ echo "-------"
echo ""
+ echo "You can give nearly all arguments on commandline:"
+ echo "$0 <HOST> <PORT> <DBNAME> <DBTEMPLATE> <DBUSER>"
+ echo ""
+ echo "e.g."
+ echo "$0 localhost 5432 mapbender template0 postgres"
+ echo ""
+ echo "------"
+ echo ""
function del_logfile() {
@@ -31,63 +40,34 @@
#get Database Configuration
function get_db_config(){
- until [ "$DBVERSION" = "p" -o "$DBVERSION" = "m" ]
- do
- echo ""
- echo "database version? (p)ostgresql or (m)ysql?"
- read DBVERSION
- done
- # db encoding
- until [ "$DBENCODING" = "i" -o "$DBENCODING" = "u" ]
- do
- echo ""
- echo "database character encoding? (i)so-8859-1 or (u)tf-8?"
- read DBENCODING
- done
+ #ask for database host
+ echo ""
+ echo "database host (e.g. localhost)?"
+ read DBHOST
+ : ${DBHOST:="localhost"}
- #ask for database template
- if [ "$DBVERSION" = "p" ]
- then
- echo ""
- echo "database template to use (just hit return for default template0)?"
- read DBTEMPLATE
- : ${DBTEMPLATE:="template0"}
- fi
+ #ask for database port
+ echo ""
+ echo "database port (e.g. 5432 for postgres)?"
+ read DBPORT
+ : ${DBPORT:="5432"}
# db name
until [ -n "$DBNAME" ]
do
echo ""
echo "database name?"
read DBNAME
- done
+ done
- #nicer vars
- then
- DBVERSION="pgsql"
- else
- DBVERSION="mysql"
- fi
- if [ "$DBENCODING" = "i" ]
- then
- DBENCODING="ISO-8859-1"
- else
- DBENCODING="UTF-8"
- fi
+ #ask for database template
+ echo ""
+ echo "database template to use (just hit return for default template0)?"
+ read DBTEMPLATE
+ : ${DBTEMPLATE:="template0"}
echo ""
- echo "database host (e.g. localhost)?"
- read DBHOST
- : ${DBHOST:="localhost"}
- echo ""
- echo "database port (e.g. 5432 for postgres, 3306 for mysql)?"
- read DBPORT
- : ${DBPORT:="5432"}
- echo ""
echo "database user?"
read DBUSER
@@ -100,6 +80,18 @@
+#set Database Configuration from commandline
+function set_db_config(){
+ echo ""
+ echo "set variables to input:"
+ DBHOST=$1
+ DBPORT=$2
+ DBNAME=$3
+ DBTEMPLATE=$4
+ DBUSER=$5
#show Database Configuration
function show_db_config(){
echo ""
@@ -118,46 +110,14 @@
-function create_mysql_db(){
- which mysql > /dev/null
- if [ $? -ne 0 ]
- then
- echo "commando mysql, but not found, exiting..."
- echo "is mysql installed?"
- echo ""
- exit 1;
- fi
- echo "Your password will be asked several times, this is normal"
- echo "creating database"
- if [ $DBENCODING = "ISO-8859-1" ]
- then
- mysql -e "create database $DBNAME CHARACTER SET latin1 COLLATE latin1_german1_ci;" -p$DBPASSWORD -u $DBUSER
- else
- mysql -e "create database $DBNAME CHARACTER SET utf8 COLLATE utf8_general_ci;" -p$DBPASSWORD -u $DBUSER
- fi
- echo "creating schema"
- mysql $DBNAME -p$DBPASSWORD -u $DBUSER -h $DBHOST -P $DBPORT < mysql/mysql_schema_2.5.sql > log_schema.txt 2> err_schema.txt
- echo "loading data"
- mysql $DBNAME -p$DBPASSWORD -u $DBUSER -h $DBHOST -P $DBPORT < mysql/$DBENCODING/mysql_data_2.5.sql > log_data.txt 2> err_data.txt
- echo "update to 2.5.1rc1"
- mysql $DBNAME -p$DBPASSWORD -u $DBUSER -h $DBHOST -P $DBPORT < mysql/$DBENCODING/update/update_2.5_to_2.5.1rc1_mysql_$DBENCODING.sql > log_update.txt 2> err_update.txt
- echo "update to 2.5.1"
- mysql $DBNAME -p$DBPASSWORD -u $DBUSER -h $DBHOST -P $DBPORT < mysql/$DBENCODING/update/update_2.5.1rc1_to_2.5.1_mysql_$DBENCODING.sql >> log_update.txt 2>> err_update.txt
- echo "update to 2.6rc1"
- mysql $DBNAME -p$DBPASSWORD -u $DBUSER -h $DBHOST -P $DBPORT < mysql/$DBENCODING/update/update_2.5.1_to_2.6rc1_mysql_$DBENCODING.sql >> log_update.txt 2>> err_update.txt
- echo "update to 2.6"
- mysql $DBNAME -p$DBPASSWORD -u $DBUSER -h $DBHOST -P $DBPORT < mysql/$DBENCODING/update/update_2.6rc1_to_2.6_mysql_$DBENCODING.sql >> log_update.txt 2>> err_update.txt
#Create Database (Postgres)
function create_pgsql_db(){
which psql createdb > /dev/null
if [ $? -ne 0 ]
then
- echo "commando pgsql or createdb needed, but not found, exiting..."
+ echo "commando psql or createdb needed, but not found, exiting..."
echo "is PostgreSQL installed?"
echo ""
exit 1;
@@ -242,13 +202,23 @@
#magic starts here
show_disclaimer;
-echo "Continue? (y)es or (n)o"
-read disclaimer
-if test $disclaimer != "y"
+# we only support postgresql and utf-8
+DBENCODING="UTF-8"
+DBVERSION="pgsql"
+if [ $# -ne 5 ]
then
- exit 1
-fi
-get_db_config;
+ echo "Continue? (y)es or (n)o"
+ read disclaimer
+ if test $disclaimer != "y"
+ then
+ exit 1
+ fi
+ echo "get_db_config - variables have to be set"
+ get_db_config;
+else
+ echo "set_db_config - variables where passed when the script was called"
+ set_db_config $@;
+fi;
show_db_config;
echo "Look ok? Start Install? (y)es or (n)o"
read ANSWER
@@ -257,15 +227,8 @@
exec $0
fi
-if [ $DBVERSION = "pgsql" ]
-then
- echo "Creating Postgres Database with encoding:$DBENCODING"
- create_pgsql_db;
-else
- echo "Creating Mysql Database with encoding:$DBENCODING"
- create_mysql_db;
- echo ""
-fi
+echo "Creating Mapbender administration database"
+create_pgsql_db;
set_permissions;
compile_po;
More information about the Mapbender_commits
