[Mapbender-commits] r5548 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sat Feb 20 07:01:51 EST 2010
Author: tbaschetti
Date: 2010-02-20 07:01:51 -0500 (Sat, 20 Feb 2010)
New Revision: 5548
   trunk/mapbender/resources/db/install.bat
strip unix-commands
Modified: trunk/mapbender/resources/db/install.bat
--- trunk/mapbender/resources/db/install.bat	2010-02-20 11:46:59 UTC (rev 5547)
+++ trunk/mapbender/resources/db/install.bat	2010-02-20 12:01:51 UTC (rev 5548)
@@ -100,6 +100,7 @@
 rem delete ARG#5
 shift
 set /p START_INSTALL="(y)es or (n)o? "
+if %START_INSTALL%x==x goto CHOICES
 if %START_INSTALL%==y goto START_INSTALL
 goto PREP
 :START_INSTALL
@@ -145,7 +146,7 @@
 if NOT %ERRORLEVEL% == 0 goto MSGFMTNOTFOUND
 echo "Compiling .po files..."
 pushd ..\..\tools\
-findstr /v ^# i18n_update_mo.sh > i18n_update_mo.bat
+findstr /v "^# ^chmod" i18n_update_mo.sh > i18n_update_mo.bat
 call i18n_update_mo.bat
 del i18n_update_mo.bat
 popd
More information about the Mapbender_commits mailing list
