[Mapbender-commits] r5550 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org
Sat Feb 20 07:05:29 EST 2010
Author: tbaschetti
Date: 2010-02-20 07:05:28 -0500 (Sat, 20 Feb 2010)
New Revision: 5550
Added:
trunk/mapbender/resources/db/update.bat
added updatescript for windows
Added: trunk/mapbender/resources/db/update.bat
--- trunk/mapbender/resources/db/update.bat (rev 0)
+++ trunk/mapbender/resources/db/update.bat 2010-02-20 12:05:28 UTC (rev 5550)
@@ -0,0 +1,120 @@
+ at echo off
+REM Script to update an existing Mapbender database
+REM
+setlocal
+REM Delete old Logfiles
+del log_update*.txt
+del err_update*.txt
+:PREP
+echo.
+echo ==============================================================================
+REM Disclaimer
+echo.
+echo DISCLAIMER: Mapbender database update script. USE AT YOUR OWN RISK!
+echo The script will run the update SQLs to update you Mapbender database
+echo.
+echo.
+echo If everything is prepared you can continue.
+echo "You can give nearly all arguments on commandline:"
+echo "%0 <HOST> <PORT> <DBNAME> <DBUSER>"
+echo ""
+echo "e.g."
+echo "%0 localhost 5432 mapbender postgres"
+echo.
+echo.
+REM 4 Params expected
+if not %4x==x goto ARGSSUPPLIED
+echo Continue?
+set /p PREPARED="(y)es or (n)o:"
+if %PREPARED%x==x goto :PREP
+if %PREPARED%==y goto :PREP_OK
+if %PREPARED%==n goto :End
+goto :PREP
+:PREP_OK
+rem Database
+:DB_TYPE
+echo.
+set /p DBHOST="Database host (just hit return for default 'localhost'):"
+echo.
+echo.
+set /p DBPORT="Database port (just hit return for default '5432'):"
+echo.
+echo.
+set /p DBNAME="Database name:"
+echo.
+echo.
+set /p DBUSER="Database user:"
+echo.
+rem Password
+rem echo.
+echo Database Password will be asked many times during update, unless pgpass.conf is used...
+IF %DBHOST%x==x set DBHOST=localhost
+IF %DBPORT%x==x set DBPORT=5432
+goto CHOICES
+:ARGSSUPPLIED
+set DBHOST=%1
+set DBPORT=%2
+set DBNAME=%3
+set DBUSER=%4
+echo.
+set USEDBTYPE=PostgreSQL
+REM Encoding
+set USEDBENC=UTF-8
+:CHOICES
+echo.
+echo Your Choices:
+echo Database Host: %DBHOST%
+echo Database Port: %DBPORT%
+echo Database Name: %DBNAME%
+echo Database User: %DBUSER%
+echo.
+echo Looks ok, start install?
+echo.
+rem delete ARG#5
+shift
+set /p START_INSTALL="(y)es or (n)o? "
+if %START_INSTALL%x==x goto CHOICES
+if %START_INSTALL%==y goto START_INSTALL
+goto PREP
+:START_INSTALL
+ echo on
+:INSTPOSTGRESQL
+REM do these exist?
+psql --version 2> nul 1> nul
+if NOT %ERRORLEVEL% == 0 goto PGNOTFOUND
+set USEDBENC=UTF-8
+echo performing updates
+echo update to 2.6.1
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6_to_2.6.1_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
+echo update to 2.7
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6.1_to_2.7rc1_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
+goto END:
+:PGNOTFOUND
+echo Sorry, psql not found, must be in PATH-Variable, exiting...
+goto END
+:END
+endlocal
+echo Finished...check the log files to see if an error occured.
+echo.
More information about the Mapbender_commits
