[Mapbender-commits] r5561 - trunk/mapbender/tools
    svn_mapbender at osgeo.org
    Sat Feb 20 09:39:44 EST 2010
Author: tbaschetti
Date: 2010-02-20 09:39:44 -0500 (Sat, 20 Feb 2010)
New Revision: 5561
   trunk/mapbender/tools/mapbender_setup.php
added warning if mysql is used (not supported anymore!)
Modified: trunk/mapbender/tools/mapbender_setup.php
--- trunk/mapbender/tools/mapbender_setup.php	2010-02-20 14:38:34 UTC (rev 5560)
+++ trunk/mapbender/tools/mapbender_setup.php	2010-02-20 14:39:44 UTC (rev 5561)
@@ -139,7 +139,7 @@
 	<?php
 	$con = @db_connect(DBSERVER,OWNER,PW);
 	if (SYS_DBTYPE=="mysql"){
-		$check = "<tr ><td width=\"25%\">Administration Database</td><td>X</td><td><font color=#00D000>MySQL</td><tr>";
+		$check = "<tr ><td width=\"25%\">Administration Database</td><td>X</td><td><font color=#FF0000>MySQL (no longer supported!)</td><tr>";
 		$check .= "<tr ><td>Connect to Database</td>";
 		if($con) $check .="<td width=\"10\">X</td><td><font color=#00D000>connected</font></td></tr>";
 		else $check .="<td width=\"10\"></td><td><font color=#FF0000>not connected</font></td></tr>";
More information about the Mapbender_commits
