[Mapbender-commits] r5563 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sat Feb 20 09:50:30 EST 2010
Author: astrid_emde
Date: 2010-02-20 09:50:29 -0500 (Sat, 20 Feb 2010)
New Revision: 5563
   trunk/mapbender/http/php/mod_gazetteerMetadata.php
i18n and some repairs
Modified: trunk/mapbender/http/php/mod_gazetteerMetadata.php
--- trunk/mapbender/http/php/mod_gazetteerMetadata.php	2010-02-20 14:46:54 UTC (rev 5562)
+++ trunk/mapbender/http/php/mod_gazetteerMetadata.php	2010-02-20 14:50:29 UTC (rev 5563)
@@ -110,6 +110,24 @@
 var metadataPopup;
+function i18nInit(){
+        parent.Mapbender.events.localize.register(function(){
+                window.location.reload();
+function init(){
+        if (parent.Mapbender.events.init.done){
+                i18nInit();
+        else{
+                parent.Mapbender.events.init.register(function(){
+                        i18nInit();
 var loadWmsAndZoomCallback = function (opt) {
 	if (typeof opt === "object" && opt.success) {
@@ -117,7 +135,7 @@
 		var wms = map.wms[map.wms.length - 1];
 		if (wms === null) {
-			opt.msg = "Ein unbekannter Fehler ist aufgetreten.";
+			opt.msg = "<?php echo _mb("An error occured."); ?>";
 		else {
 			var wmsId = wms.wms_id;
@@ -129,10 +147,7 @@
 					if (addwms_showWMS > 0) {
 						try {
-							var msg = "Der hinzugeladene Kartendienst " +
-								"verfügt über mehr als " + addwms_showWMS +
-								" Ebenen. Die Ebenen des Dienstes werden " +
-								"<b>nicht</b> aktiviert.";
+							var msg = "<?php echo _mb("The added Service has more than"); ?> " + addwms_showWMS + 								" <?php echo _mb("layer. The layer of the MapService will NOT be activated."); ?>";
 							parent.Mapbender.Modules.dialogManager.openDialog({
 								content: msg,
@@ -183,19 +198,18 @@
 	var msg = typeof opt.msg === "string" ? opt.msg : "";
 	if (typeof opt !== "object" || !opt.success) {
-		msg = "Ein unbekannter Fehler ist aufgetreten. ";
+		msg = "<?php echo _mb("An error occured."); ?>";
 	else {
 		var map = parent.getMapObjByName(myTarget);
 		if (wms !== null) {
-			msg = "Der folgende Dienst wurde zu 'Aktive Dienste' " +
-				"hinzugefügt:<br><br>";
+			msg = "<?php echo _mb("The following Service has been added"); ?>:<br><br>";
 			msg += "<b>" + wms.wms_title + "</b><br><br>";
 		else {
 	try {
@@ -217,7 +231,7 @@
  		keywordPopup.destroy();
 	keywordPopup = new parent.mb_popup({
-		title : "SelectKeyword",
+		title : "<?php echo _mb("Select a keyword"); ?>",
 		url : "../php/mod_SelectKeyword.php",
 		width : 550,
 		height : 260,
@@ -232,7 +246,7 @@
 // 		metadataPopup.destroy();
 	metadataPopup = new parent.mb_popup({
-		title : "Metadata",
+		title : "<?php echo _mb("Metadata"); ?>",
 		url : "../php/mod_layerMetadata.php?id=" + layerId,
 		width : 450,
 		height : 600,
@@ -250,7 +264,7 @@
       return false;
    else{
-		document.getElementById("resultDivTag").innerHTML = "<table><tr><td><img src='../img/indicator_wheel.gif'></td><td>Searching...</td></tr></table>";
+		document.getElementById("resultDivTag").innerHTML = "<table><tr><td><img src='../img/indicator_wheel.gif'></td><td><?php echo _mb("Searching"); ?>...</td></tr></table>";
 		var ind = parent.getMapObjIndexByName('mapframe1');
 		parent.mb_ajax_json(
@@ -300,7 +314,7 @@
 			text += "<img name='add_wms' style='cursor: pointer;' src='" + imgUrl + "' ";
-			text += "border='0' title='Load' ";
+			text += "border='0' title='<?php echo _mb("Load"); ?>' ";
 			text += "onclick='" + onclickFunction + "'>";
 			if (typeof(resultObj.layer_name) !== "undefined") {
@@ -325,7 +339,7 @@
 			text += "<img src='../img/tree_zoom.png' ";
-			text += "border='0' title='WMS zu aktiven Diensten hinzufügen und auf Ausschnitt zoomen' ";
+			text += "title='<?php echo _mb("Add WMS and zoom to extent"); ?>' ";
 			text += "</td><td>";
 			text += "<a href='#' ";
@@ -418,12 +432,12 @@
 </script>
 </head>
-<body leftmargin="2" topmargin="0" bgcolor="#ffffff">
+<body leftmargin="2" topmargin="0" bgcolor="#ffffff" onload='init();'>
 <form name='form1' target='result' onsubmit='return validate();'>
 <p>
 <input class='textfield' id='metadataSearchString' name='search' type='text' style='width:110px'>
-<img src="../img/add.png" style="cursor: pointer;vertical-align:middle;" title="keywords" onclick="openKeywordPopup();">
+<img src="../img/add.png" style="cursor: pointer;vertical-align:middle;" title="<?php echo _mb("keywords") ?>" onclick="openKeywordPopup();">
 <input type='submit' name='send' value='ok'>
 </p>
 </form>
More information about the Mapbender_commits mailing list
