[Mapbender-commits] r5613 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Feb 24 03:55:39 EST 2010
Author: astrid_emde
Date: 2010-02-24 03:55:37 -0500 (Wed, 24 Feb 2010)
New Revision: 5613
Added:
   trunk/mapbender/http/plugins/mb_resultList_setVendorspecific.js
new module to configure vendor specifics from result list
http://trac.osgeo.org/mapbender/ticket/611
Added: trunk/mapbender/http/plugins/mb_resultList_setVendorspecific.js
--- trunk/mapbender/http/plugins/mb_resultList_setVendorspecific.js	                        (rev 0)
+++ trunk/mapbender/http/plugins/mb_resultList_setVendorspecific.js	2010-02-24 08:55:37 UTC (rev 5613)
@@ -0,0 +1,76 @@
+//[  { featureTypeId: 24, fields: [ "hausnummer", "schlüssel" ] },   ...]
+var API = function(options){
+	var parameters = [];
+	var currentFeatureTypeId = null;
+	this.getParamater = function(wms){
+		var layer = null;
+		var resultString = "";
+		var i = 0;
+		for(i in wms.objLayer){
+			layer = wms.objLayer[i];
+			if(currentFeatureTypeId == layer.gui_layer_wfs_featuretype){
+				// currentFeatureType is valid for this WMS
+				var j = 0;
+				for(j in parameters){
+					resultString += encodeURIComponent(parameters[j].key) + "=" +encodeURIComponent(parameters[j].value) + "&";
+				return resultString;
+		return "";
+	Mapbender.modules[options.target[0]].rowclick.register(function(row){
+		var me = Mapbender.modules[options.target[0]];
+		var modelIndex = $(row).data("modelindex");
+		// check if the currentFeatureTypeId is configured in the options
+		// and if so, get the values
+		var key ="";
+		var value="";
+		var i = 0;
+		for(i in options.config){
+			parameters  = [];
+			if(options.config[i].ftId == currentFeatureTypeId){
+				var j = 0;
+				for(j in options.config[i].fields){
+					key = options.config[i].fields[j];
+					value = me.model.getFeatureProperty(modelIndex, key);
+					parameters.push({ key: key, value: value});
+		var feature = me.model.getFeature(modelIndex);
+		var bbox = feature.getBBox();
+		var bufferFloat = parseFloat(me.WFSConf.g_buffer);
+		var buffer = new Point(bufferFloat,bufferFloat);
+		bbox[0] = bbox[0].minus(buffer);
+		bbox[1] = bbox[1].plus(buffer);
+		var map = Mapbender.modules[me.options.target[0]];
+		map.calculateExtent( new Mapbender.Extent(bbox[0], bbox[1]));
+		map.setMapRequest();
+	Mapbender.modules[options.target[1]].events.onWfsConfSelect.register(function(data){
+		console.log("NEW FTid");
+		currentFeatureTypeId = data.wfsConfId;
+	Mapbender.modules[options.target[1]].events.onFormReset.register(function(){
+		currentFeatureTypeId = null;
+Mapbender.events.afterInit.register(function(){
+	Mapbender.modules[options.id] = $.extend(new API(options), Mapbender.modules[options.id]);
+	mb_registerVendorSpecific("Mapbender.modules." +options.id + ".getParamater(currentWms, functionName)");
More information about the Mapbender_commits mailing list
