[Mapbender-commits] r5629 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Wed Feb 24 08:09:26 EST 2010
Author: kmq
Date: 2010-02-24 08:09:25 -0500 (Wed, 24 Feb 2010)
New Revision: 5629
trunk/mapbender/http/javascripts/mod_ResultList.js
cleaning up that code a little
Modified: trunk/mapbender/http/javascripts/mod_ResultList.js
--- trunk/mapbender/http/javascripts/mod_ResultList.js 2010-02-24 11:51:04 UTC (rev 5628)
+++ trunk/mapbender/http/javascripts/mod_ResultList.js 2010-02-24 13:09:25 UTC (rev 5629)
@@ -54,27 +54,13 @@
me.options = options;
me.rowclick = new Mapbender.Event();
- this.addRowcallback = function(callback){
- //disaabled
- // the signature of the callback function (columns)
- // where columns is an object containiing pairs of column:value
- //row_callback = callback;
- this.row_click_callback = function(){
- // Fixme get from row
- // If we were dynamic, this is what we would do
- //row_callback.call(null,{"firstname":"gonzales"});
- //but for now we just open a popup with infos abotut the table
- // we have:
- // DOMTableRow
- // DOMTableRow.data("modelindex")
- // model.getFeatureProperty(modelIndex) - but we need all of them :-(
- //alert($(this).data("modelindex"));
+ * Method: addGlobalButton
+ * Descriptions: adds a Button to the bottom of the resultList
+ * Parameters:
+ * buttondef: {Object} an object with five properties, "title", "type" (either button or select) "classes" (the classes the button should have), "selectoptions" (an array in case the type is select), "callback"
this.addGlobalButton = function(buttondef){
//buttondef format:
//{"title":<if no image is given then this is displayed>, callback: <function( ))
@@ -88,7 +74,7 @@
bd.title = bd.title || "no title";
bd.type = bd.type || "button";
bd.classes = bd.classes || "";
- bd.selectoptions = bd.selectoptions || []
+ bd.selectoptions = bd.selectoptions || [];
bd.callback = bd.callback || function(){};
var result = function(){
@@ -121,25 +107,14 @@
alert("invalid buttondefintion");
- this.addRowButton = function(buttondef){
- // buttondef format:
- // title:
- // src:
- // callback = function(feature) {}
- // index: ( 0=> in front, 1, after first, -1 end, -2 second to last...
- // modify buttoncolumns
- // and reinitialize
- me.buttoncolumns.push(buttondef);
-// me.reinitialize();
+ * Method: addPopupButton
+ * Description: adds a Button to the Popupmenu that is displayed when the user clicks an entry in the result list
+ * Parameters:
+ * buttondef: {Object} an object with two properties: "title" and "callback", a function that gets the feature that corresponds to the popup as it's argument
this.addPopupButton = function(buttondef){
- // title:
popupButtons.push(buttondef);
@@ -152,7 +127,7 @@
this.setTitle = function(title){
$('#'+options.id).data("title.dialog",title);
* Method: getSelected
@@ -170,7 +145,7 @@
return selected;
this.show = function(){
@@ -178,68 +153,62 @@
options.target,
"resultListHighlight",
{"position":"absolute", "top":"0px", "left":"0px", "z-index":options.resultHighlightZIndex},
- options.resultHighlightLineWidth
+ options.resultHighlightLineWidth);
if(display_popup){
$('#'+options.id).dialog("open");
}else{
$('#'+options.id).css("display","block");
me.resultHighlight = new Highlight(
options.target,
var rowNodes = me.datatable.fnGetNodes();
for (rowNodeIndex in rowNodes){
(function() {
- var row = rowNodes[rowNodeIndex];
- $(".wfsFproperty", row).click(function(){
- me.rowclick.trigger((function(){return row;})());
+ var row = rowNodes[rowNodeIndex];
+ $(".wfsFproperty", row).click(function(){
+ me.rowclick.trigger((function(){return row;})());
- $(row).mouseover(function () {
- var i = $(this).data("modelindex");
- var feature = me.model.getFeature(i);
- if (options.maxHighlightedPoints > 0 && feature.getTotalPointCount() > options.maxHighlightedPoints) {
- feature = feature.getBBox4();
- me.resultHighlight.add(feature, options.resultHighlightColor);
- me.resultHighlight.paint();
- }).mouseout(function () {
- me.resultHighlight.del(feature, options.resultHighlightColor);
- // make rows selectable only when there are Global Buttons that could actually do womething with that selection
- if($('#'+options.id+"buttonrow").length > 0){
- $(row).click((function(){
- if($(this).hasClass('row_selected')){
- $(this).removeClass('row_selected');
+ $(row).mouseover(function () {
+ var i = $(this).data("modelindex");
+ var feature = me.model.getFeature(i);
+ if (options.maxHighlightedPoints > 0 && feature.getTotalPointCount() > options.maxHighlightedPoints) {
+ feature = feature.getBBox4();
- else{
- $(this).addClass('row_selected');
+ me.resultHighlight.add(feature, options.resultHighlightColor);
+ me.resultHighlight.paint();
+ }).mouseout(function () {
- return true;
- // set style of cursor to pointer for the result table
- if(me.rowclick.getProperties().count > 0) {$(".wfsFproperty", row).css("cursor","pointer")};
+ me.resultHighlight.del(feature, options.resultHighlightColor);
+ // make rows selectable only when there are Global Buttons that could actually do womething with that selection
+ if($('#'+options.id+"buttonrow").length > 0){
+ $(row).click((function(){
+ if($(this).hasClass('row_selected')){
+ $(this).removeClass('row_selected');
+ else{
+ $(this).addClass('row_selected');
+ return true;
+ // set style of cursor to pointer for the result table
+ if(me.rowclick.getProperties().count > 0) {$(".wfsFproperty", row).css("cursor","pointer");}
@@ -266,8 +235,6 @@
-//var table = $('<table class="display" id="'+ options.id +'_table"><thead><tr></tr></thead><tbody></tbody></table>');
-//$('#'+options.id).append(table);
ResultGeometryList.prototype = new ResultGeometryListController(options);
ResultGeometryList.prototype.constructor = ResultGeometryList;
More information about the Mapbender_commits
