[Mapbender-commits] r6473 - in trunk/mapbender/http: classes javascripts php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jul 1 04:22:42 EDT 2010
Author: verenadiewald
Date: 2010-07-01 08:22:42 +0000 (Thu, 01 Jul 2010)
New Revision: 6473
   trunk/mapbender/http/classes/class_wmc.php
   trunk/mapbender/http/javascripts/mod_loadwmc.js
   trunk/mapbender/http/javascripts/mod_savewmc.js
   trunk/mapbender/http/javascripts/mod_savewmc.php
   trunk/mapbender/http/php/mod_savewmc_server.php
added possibility to edit wmc from loadwmc list
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php	2010-06-30 14:41:58 UTC (rev 6472)
+++ trunk/mapbender/http/classes/class_wmc.php	2010-07-01 08:22:42 UTC (rev 6473)
@@ -195,7 +195,7 @@
 	 * @param object $extensionData data exclusive to Mapbender, which will be
 	 * 								mapped into the extension part of the WMC
-	public function createFromJs($mapObject, $generalTitle, $extensionData) {
+	public function createFromJs($mapObject, $generalTitle,$extensionData, $id=null) {
 		if (count($mapObject) > 2) {
 			$e = new mb_exception("Save WMC only works for two concurrent map frames (overview plus main) at the moment.");
@@ -204,6 +204,11 @@
 		// set extension data
 		$this->generalExtensionArray = $extensionData;
+		if ($id !== null) {
+			//set id
+			$this->wmc_id = $id;
 		// set title
 		$this->wmc_title = $generalTitle;
@@ -604,9 +609,9 @@
 			if($overwrite) {
-	            $findsql = "SELECT fkey_user_id,wmc_title,wmc_timestamp, wmc_id FROM mb_user_wmc WHERE fkey_user_id = $1 AND wmc_title = $2 ORDER BY wmc_timestamp DESC LIMIT 1;";
-	            $v = array($this->userId, administration::convertOutgoingString($this->wmc_title));
-	            $t = array("i","s");
+	            $findsql = "SELECT fkey_user_id,wmc_title,wmc_timestamp, wmc_id FROM mb_user_wmc WHERE fkey_user_id = $1 AND wmc_id = $2 ORDER BY wmc_timestamp DESC LIMIT 1;";
+	            $v = array($this->userId, $this->wmc_id);
+	            $t = array("i","i");
 	            $res = db_prep_query($findsql,$v,$t);
 				if (db_error()) {
@@ -619,10 +624,10 @@
 	            if($row = db_fetch_row($res)) {
 					$sql = "UPDATE mb_user_wmc SET wmc = $1, wmc_timestamp = $2, abstract = $3, srs = $4, minx = $5, miny = $6,".
-						" maxx = $7, maxy = $8 WHERE fkey_user_id = $9 AND wmc_title=$10 AND wmc_timestamp = $11;";
+						" maxx = $7, maxy = $8, wmc_title = $9 WHERE fkey_user_id = $10 AND wmc_id=$11 AND wmc_timestamp = $12;";
 					$v = array($this->xml, time(), $this->wmc_abstract, $this->wmc_srs, $this->wmc_extent->minx, $this->wmc_extent->minx,
-						 $this->wmc_extent->maxx, $this->wmc_extent->maxy ,$this->userId, administration::convertOutgoingString($this->wmc_title),$row[2]);
-					$t = array("s", "s","s","s","i","i","i","i", "i", "s","s");
+						 $this->wmc_extent->maxx, $this->wmc_extent->maxy ,administration::convertOutgoingString($this->wmc_title), $this->userId, $this->wmc_id,$row[2]);
+					$t = array("s", "s","s","s","i","i","i","i", "s", "i", "i","s");
 					// need the database Id
 					$wmc_DB_ID = $row[3];
 					$delsql = "DELETE FROM wmc_md_topic_category WHERE fkey_wmc_id = $1;";
Modified: trunk/mapbender/http/javascripts/mod_loadwmc.js
--- trunk/mapbender/http/javascripts/mod_loadwmc.js	2010-06-30 14:41:58 UTC (rev 6472)
+++ trunk/mapbender/http/javascripts/mod_loadwmc.js	2010-07-01 08:22:42 UTC (rev 6473)
@@ -12,6 +12,8 @@
 options.deleteWmc = typeof options.deleteWmc === "number" ? options.deleteWmc : 1;
 options.uploadWmc = typeof options.uploadWmc === "number" ? options.uploadWmc : 1;
 options.listWmc = typeof options.listWmc === "number" ? options.listWmc : 1;
+options.editWmc = typeof options.editWmc === "number" ? options.editWmc : 1;
+options.saveWmcTarget = typeof options.saveWmcTarget === "string" ? options.saveWmcTarget : "savewmc";
 var originalI18nObject = {
 	"labelList": "List",
@@ -25,6 +27,7 @@
 	"labelPublic": "public",
 	"labelShow": "show",
 	"labelDelete": "delete",
+	"labelEdit": "edit",
 	"labelOpenLayers": "OpenLayers",
 	"labelCurrentState": "currentState",
 	"labelDeleteWmc": "delete this WMC",
@@ -52,6 +55,7 @@
 	var wmcPopup = null;
 	var wmcDisplayPopup = null;
 	var wmcOpenLayersPopup = null;
+	var wmcListTableInitialized = false;
 	var LOAD_WMC_OPTIONS = {
 		src: "../img/button_gray/wmc_load.png",
@@ -94,6 +98,12 @@
 		src: "../img/button_gray/wmc_xml.png",
 		title: translatedI18nObject.labelDisplayWmc
+	var EDIT_WMC_OPTIONS = {
+		src: "../img/pencil.png",
+		title: translatedI18nObject.labelEditWmc,
+		method: "editWmc"
 	this.events = {
 		loaded: new Mapbender.Event()
@@ -207,6 +217,31 @@
 		req.send();
+	this.showWmcSaveForm = function (id) {
+		Mapbender.modules[options.saveWmcTarget].getExistingWmcData(function (obj) {
+			for (var i = 0; i < obj.length; i++) {
+				var wmc = obj[i];
+				if (wmc.id === id) {
+					$("#" + options.saveWmcTarget + "_wmc_id").val(wmc.id);
+					$("#" + options.saveWmcTarget + "_wmctype").append("<option value='" + wmc.id + "' selected>" + wmc.title + "</option>");
+					$("#" + options.saveWmcTarget + "_wmctype").attr("disabled","disabled");
+					$("#" + options.saveWmcTarget + "_wmcname").val(wmc.title);
+					$("#" + options.saveWmcTarget + "_wmcabstract").val(wmc.abstract);
+					$("#" + options.saveWmcTarget + "_wmckeywords").val(wmc.keywords.join(","));
+					$("input[id^='" + options.saveWmcTarget + "_wmcinspire_']").removeAttr("checked");
+					for (var j = 0; j < wmc.categories.length; j++) {
+						var cat = wmc.categories[j];
+						$("#" + options.saveWmcTarget + "_wmcinspire_" + cat).attr("checked", "checked");
+			$("#" + options.saveWmcTarget + "_saveWMCForm").dialog('open');
+		Mapbender.modules[options.saveWmcTarget].events.saved.register(function () {
+			//that.refreshList();
 	var getInitialDialogHtml = function (id) {
 		if (!options.listWmc && !options.uploadWmc) {
@@ -222,11 +257,12 @@
 				translatedI18nObject.labelUpload + "</a></li></ul>";
+		initialHtml += "<div id='" + id + "_wmclist' >";
 		// add listWMC if available
 		var t = translatedI18nObject;
 		if (options.listWmc) {
-			initialHtml += "<div id='" + id + "_wmclist' >" +
-					"<table width='100%' id='" + id + "_wmclist_table'>" +
+			initialHtml += "<table width='100%' id='" + id + "_wmclist_table'>" +
 						"<thead><tr>" +
 							"<th>" + t.labelWmcName + "</td>" +
 							"<th>" + t.labelLastUpdate + "</td>" +
@@ -237,14 +273,17 @@
 				(options.publishWmc ? "<th>" + t.labelPublic + "</td>" : "") +
 				(options.showWmc ? "<th>" + t.labelShow + "</td>" : "") +
 				(options.openLayers ? "<th>" + t.labelOpenLayers + "</td>" : "") +
+				(options.editWmc ? "<th>" + t.labelEdit + "</td>" : "") +
 				(options.deleteWmc ? "<th>" + t.labelDelete + "</td>" : "") +
-				"</thead></tr></table></div>";
+				"</tr></thead></table>";
+		initialHtml += "</div>";
 		// add uploadWMC if available
 		if (options.uploadWmc) {
 			initialHtml += "<div id='" + id + "_wmcUpload' ></div>";
 		return "<div style='display:none' id='" + id + "_tabs'>" + initialHtml + "</div>";
@@ -430,6 +469,15 @@
+	var createEditWmcCell = function (wmc) {
+		return createTableCell(
+			EDIT_WMC_OPTIONS,
+			function(){
+				that.showWmcSaveForm(wmc.id);
 	var createDeleteWmcCell = function (wmc) {
 		var $deleteTd = createTableCell(
 			$.extend({}, DELETE_WMC_OPTIONS, {
@@ -450,6 +498,49 @@
 	var displayWmcList = function (wmcObj, status) {
+		if(wmcListTableInitialized === true) {
+			wmcTable.fnClearTable();
+			for (var i=0; i < wmcObj.wmc.length; i++) {
+				(function () {
+					var currentIndex = i;
+					var currentWmc = wmcObj.wmc[currentIndex];
+					var dataArray = [currentWmc.title, currentWmc.timestamp, currentWmc.timestamp_create];
+					if (options.loadWmc) {
+						dataArray.push(createLoadWmcCell(currentWmc));
+					if (options.mergeWmc) {
+						dataArray.push(createMergeWmcCell(currentWmc));
+					if (options.appendWmc) {
+						dataArray.push(createAppendWmcCell(currentWmc));
+					if (options.publishWmc) {
+						dataArray.push(createPublishWmcCell(currentWmc));
+					if (options.showWmc) {
+						dataArray.push(createDisplayWmcCell(currentWmc));
+					if (options.openLayers) {
+						dataArray.push(createOpenLayersWmcCell(currentWmc));
+					if (options.editWmc) {
+						dataArray.push(createEditWmcCell(currentWmc));
+					if (options.deleteWmc) {
+						dataArray.push(createDeleteWmcCell(currentWmc));
+					wmcTable.fnAddData(dataArray);
+					//$tr.appendTo($("tbody", wmcTable));
+		else {
 		// create table
 			(function () {
@@ -479,13 +570,25 @@
 					$tr.append(createOpenLayersWmcCell(currentWmc));
+					$tr.append(createEditWmcCell(currentWmc));
 					$tr.append(createDeleteWmcCell(currentWmc));
 				$tr.appendTo("#" + options.id + "_wmclist_table");
+		if(wmcListTableInitialized === false) {
+			// create horizontal tabs
 		if (options.listWmc && options.uploadWmc) {
 			$("#" + options.id + "_tabs").tabs().css("display", "block");
@@ -511,16 +614,19 @@
 		// create datatables
-		Mapbender.languageId;
 			wmcTable = $("#" + options.id + "_wmclist_table").dataTable({
 				"bPaginate": true,
-				"bJQueryUI": true,
-				"oLanguage": {
-					"sUrl":"../extensions/dataTables-1.5/lang/"+Mapbender.languageId +".txt"
+				"bJQueryUI": true
+			wmcListTableInitialized = true;
+		else {
+			wmcTable.fnDraw();
 	var constraintCheckRequired = function () {
Modified: trunk/mapbender/http/javascripts/mod_savewmc.js
--- trunk/mapbender/http/javascripts/mod_savewmc.js	2010-06-30 14:41:58 UTC (rev 6472)
+++ trunk/mapbender/http/javascripts/mod_savewmc.js	2010-07-01 08:22:42 UTC (rev 6473)
@@ -168,7 +168,7 @@
 					$(this).text(translatedI18nObj.labelNewOrOverwrite).next()
 						.children().eq(0).text(translatedI18nObj.labelNewWmc);
 					break;
-				case options.id + ":wmcname" :
+				case options.id + "_wmcname" :
 					$(this).text(translatedI18nObj.labelName);
 					break;
 				case options.id + "_wmcabstract" :
@@ -186,7 +186,7 @@
 		$legend.text(translatedI18nObj.labelCategories);
-	var getExistingWmcData = function (callback) {
+	this.getExistingWmcData = function (callback) {
 		// get WMC data from server
 		var req = new Mapbender.Ajax.Request({
 			url: "../php/mod_loadwmc_server.php",
@@ -207,6 +207,7 @@
 	var createSelectBoxForExistingWmcs = function (obj) {
 		(function () {
 			$select = $("#" + options.id + "_wmctype").empty();
+			$select.removeAttr("disabled");
 			var select = "<option value=''>" + translatedI18nObj.labelNewWmc + "</option>";
 			if (typeof obj === "object" && obj.length) {
@@ -224,6 +225,7 @@
 				// reset fields if new wmc is saved
 				if (this.value === "") {
+					$("#" + options.id + "_wmc_id").val("");
 					$("#" + options.id + "_wmcname").val("");
 					$("#" + options.id + "_wmcabstract").val("");
 					$("#" + options.id + "_wmckeywords").val("");
@@ -236,6 +238,7 @@
 					var wmc = obj[i];
 					if (wmc.id === this.value) {
+						$("#" + options.id + "_wmc_id").val(wmc.id);
 						$("#" + options.id + "_wmcname").val(wmc.title);
 						$("#" + options.id + "_wmcabstract").val(wmc.abstract);
 						$("#" + options.id + "_wmckeywords").val(wmc.keywords.join(","));
@@ -262,6 +265,7 @@
 			var attributes = {};
+			attributes.wmc_id 	= $("#" + options.id + "_wmc_id").val();
 			attributes.title 	= $("#" + options.id + "_wmcname").val();
 			attributes.abstract = $("#" + options.id + "_wmcabstract").val();
 			attributes.keywords = $("#" + options.id + "_wmckeywords").val();
@@ -285,7 +289,7 @@
 	var mod_savewmc = function () {
-		getExistingWmcData(function (obj) {
+		that.getExistingWmcData(function (obj) {
 			createSelectBoxForExistingWmcs(obj);
 			$("#" + options.id + "_saveWMCForm").dialog('open');
Modified: trunk/mapbender/http/javascripts/mod_savewmc.php
--- trunk/mapbender/http/javascripts/mod_savewmc.php	2010-06-30 14:41:58 UTC (rev 6472)
+++ trunk/mapbender/http/javascripts/mod_savewmc.php	2010-07-01 08:22:42 UTC (rev 6473)
@@ -76,6 +76,7 @@
 	'<textarea id="{$e_id}_wmcabstract" class="text ui-widget-content ui-corner-all"></textarea>' +
 	'<label for="{$e_id}_wmckeywords">{$labelKeywords}</label>' +
 	'<input id="{$e_id}_wmckeywords" type="text" class="text ui-widget-content ui-corner-all" />' +
+	'<input id="{$e_id}_wmc_id" type="hidden" />' +
 	'</fieldset><fieldset id="{$e_id}_inspire_cat"><legend>{$labelCategories}' +
 	'</legend>' +
 	'{$saveWmcCategoryString}' +
Modified: trunk/mapbender/http/php/mod_savewmc_server.php
--- trunk/mapbender/http/php/mod_savewmc_server.php	2010-06-30 14:41:58 UTC (rev 6472)
+++ trunk/mapbender/http/php/mod_savewmc_server.php	2010-07-01 08:22:42 UTC (rev 6473)
@@ -35,7 +35,12 @@
 // create WMC object
 $wmc = new wmc();
-$wmc->createFromJs($mapObject, $attributes->title, $extensionData);
+if($overwrite) {
+	$wmc->createFromJs($mapObject, $attributes->title, $extensionData, $attributes->wmc_id);
+else {
+	$wmc->createFromJs($mapObject, $attributes->title, $extensionData);
 if ($saveInSession === 1) {
 	// store XML in session
More information about the Mapbender_commits mailing list
