[Mapbender-commits] r6478 - in trunk/mapbender/http/extensions: . ajaxChange-0.1
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jul 1 06:21:59 EDT 2010
Author: christoph
Date: 2010-07-01 10:21:59 +0000 (Thu, 01 Jul 2010)
New Revision: 6478
Added:
   trunk/mapbender/http/extensions/ajaxChange-0.1/
   trunk/mapbender/http/extensions/ajaxChange-0.1/ajaxChange-0.1.js
   trunk/mapbender/http/extensions/ajaxChange-0.1/ajaxChange-0.2.js
Added: trunk/mapbender/http/extensions/ajaxChange-0.1/ajaxChange-0.1.js
--- trunk/mapbender/http/extensions/ajaxChange-0.1/ajaxChange-0.1.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/ajaxChange-0.1/ajaxChange-0.1.js	2010-07-01 10:21:59 UTC (rev 6478)
@@ -0,0 +1,119 @@
+ * ajaxChange - a jQuery plugin that enhances the change event for select boxes
+ * Dual licensed under the MIT and GPL licenses:
+ *   http://www.opensource.org/licenses/mit-license.php
+ *   http://www.gnu.org/licenses/gpl.html
+ * Author: Christoph Baudson (christoph AT osgeo DOT org)
+ * Contributors: Marc Jansen
+ * Version: 0.2
+ * Changelog:
+ * - return jQuery object
+ * - using jQuery utility function isFunction
+ * - added author and contributors
+ * Date: May 7th, 2010
+ * This plugin enhances the change event for select boxes.
+ * It only has two features:
+ * - disable: 	automatically disable the select box when the
+ * 				change event is triggered (for example, to avoid
+ * 				multiple AJAX request requests)
+ * - undo: 		reset the selected index to its original value
+ * 				before the change event had been triggered (for
+ * 				example, if the result of an AJAX request reveals
+ * 				that the new selected index is invalid)
+ * initialization:
+ * $("select").ajaxChange(func [, options]);
+ * func is a function to be executed on change
+ * options is an object with two attributes
+ * - boolean "disable" [true]
+ * - boolean "undo" [true]
+ * control:
+ * $("select").ajaxChange("abort");
+ * - if disable is set, the select box is enabled.
+ * - if undo is set, the selectedIndex is set to the original value.
+ * $("select").ajaxChange("done");
+ * - if disable is set, the select box is enabled, otherwise "done" is irrelevant.
+(function ($) {
+	$.fn.ajaxChange = function () {
+		var args = arguments;
+		return this.each(function () {
+			if (this.tagName.toUpperCase() !== "SELECT") {
+				return;
+			var $this = $(this);
+			// initialization
+			if (args.length >= 1 && $.isFunction(args[0])) {
+				var f = args[0];
+				var options = {};
+				if (args.length >= 2 && typeof args[1] === "object") {
+					options = args[1];
+				options = $.extend({
+					disable: true,
+					undo: true
+				}, options);
+				$this
+					.data("ajaxChangeDisable", options.disable)
+					.data("ajaxChangeUndo", options.undo)
+					.data("ajaxChangeSelectedIndex", null)
+					.change(function () {
+						if ($this.data("ajaxChangeDisable") === true) {
+							$this.attr("disabled", "disabled");
+						f.apply(this, arguments);
+					.mousedown(function () {
+						if ($this.data("ajaxChangeSelectedIndex") === null
+							&& $this.data("ajaxChangeUndo")
+							$this.data("ajaxChangeSelectedIndex", this.selectedIndex);
+			// control
+			else if (args.length >= 1 && typeof args[0] === "string") {
+				var command = args[0];
+				switch (command) {
+					case "abort":
+							$this.removeAttr("disabled");
+						if ($this.data("ajaxChangeUndo")) {
+							this.selectedIndex = $this.data("ajaxChangeSelectedIndex");
+							$this.data("ajaxChangeSelectedIndex", null);
+						break;
+					case "done":
+						break;
+}(jQuery));
\ No newline at end of file
Added: trunk/mapbender/http/extensions/ajaxChange-0.1/ajaxChange-0.2.js
--- trunk/mapbender/http/extensions/ajaxChange-0.1/ajaxChange-0.2.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/ajaxChange-0.1/ajaxChange-0.2.js	2010-07-01 10:21:59 UTC (rev 6478)
@@ -0,0 +1,119 @@
+ * Version: 0.2
+ * Changelog:
+ * initialization:
+ * control:
+(function ($) {
+				return;
+			// initialization
+				var f = args[0];
+				var options = {};
+					disable: true,
+					undo: true
+				}, options);
+				$this
+			// control
+					case "abort":
+						break;
+					case "done":
+						break;
+}(jQuery));
More information about the Mapbender_commits mailing list
