[Mapbender-commits] r6501 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jul 2 13:06:43 EDT 2010
Author: verenadiewald
Date: 2010-07-02 17:06:43 +0000 (Fri, 02 Jul 2010)
New Revision: 6501
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
removed onclick from e_attributes for e_id loadwmc
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql	2010-07-02 16:58:55 UTC (rev 6500)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql	2010-07-02 17:06:43 UTC (rev 6501)
@@ -716,7 +716,7 @@
 WHERE e_id = 'wmcPublic' AND fkey_gui_id = 'admin1');
 -- add required modules for loadwmc and savewmc
-UPDATE gui_element SET e_requires = 'jq_ui_dialog,jq_ui_tabs,jq_upload,jq_datatables' WHERE e_id = 'loadwmc';
+UPDATE gui_element SET e_attributes = 'onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");''', e_requires = 'jq_ui_dialog,jq_ui_tabs,jq_upload,jq_datatables' WHERE e_id = 'loadwmc';
 UPDATE gui_element SET e_requires = 'jq_ui_dialog' WHERE e_id = 'savewmc';
More information about the Mapbender_commits mailing list
