[Mapbender-commits] r6510 - trunk/build/osgeolive
svn_mapbender at osgeo.org
Sat Jul 3 07:06:54 EDT 2010
Author: uli
Date: 2010-07-03 11:06:54 +0000 (Sat, 03 Jul 2010)
New Revision: 6510
trunk/build/osgeolive/install_mapbender.sh
Modified: trunk/build/osgeolive/install_mapbender.sh
--- trunk/build/osgeolive/install_mapbender.sh 2010-07-03 11:03:07 UTC (rev 6509)
+++ trunk/build/osgeolive/install_mapbender.sh 2010-07-03 11:06:54 UTC (rev 6510)
@@ -33,6 +33,9 @@
INSTALLURL="http://www.mapbender.org/download/"
INSTALLFILE="mapbender_2.6.1"
INSTALL_DIR="/var/www"
+MAPBENDER_DATABASE_NAME="mapbender"
+MAPBENDER_DATABASE_TEMPLATE="template_postgis"
+MAPBENDER_DATABASE_USER="user"
mkdir -p "$TMP_DIR"
@@ -55,6 +58,9 @@
# check more libraries...
+# download and unzip sources...
cd "$TMP_DIR"
if [ ! -e "$INSTALLFILE".zip] ; then
wget -O mapbender_osgeo.zip --progress=dot:mega \
@@ -70,6 +76,15 @@
chown -R www-data:www-data $INSTALL_DIR/mapbender
+# create mabpender database
+cd $INSTALL_DIR/resources/db
+chmod +x install.sh
+./install.sh localhost 5432 MAPBENDER_DATABASE_NAME MAPBENDER_DATABASE_TEMPLATE MAPBENDER_DATABASE_USER
#Create apache2 configuration for mapbender
echo "#Configure apache for mapbender " >> /etc/apache2/conf.d/mapbender
echo "Alias /mapbender $INSTALL_DIR/mapbender/http/" >> /etc/apache2/conf.d/mapbender
More information about the Mapbender_commits
