[Mapbender-commits] r6560 - branches/2.6/http/javascripts
svn_mapbender at osgeo.org
Sun Jul 4 06:45:11 EDT 2010
Author: christoph
Date: 2010-07-04 10:45:11 +0000 (Sun, 04 Jul 2010)
New Revision: 6560
branches/2.6/http/javascripts/map_obj.js
branches/2.6/http/javascripts/mod_dragMapSize.php
http://trac.osgeo.org/mapbender/ticket/657
Modified: branches/2.6/http/javascripts/map_obj.js
--- branches/2.6/http/javascripts/map_obj.js 2010-07-04 10:32:43 UTC (rev 6559)
+++ branches/2.6/http/javascripts/map_obj.js 2010-07-04 10:45:11 UTC (rev 6560)
@@ -386,7 +386,7 @@
this.getExtentInfos = function(){
var c = this.getExtent();
- if (typeof c !== "object" || c.length !== 4) {
+ if (typeof c !== "string" || c.split(",").length !== 4) {
return null;
c = c.split(",");
@@ -548,7 +548,7 @@
this.convertPixelToReal = function (aPoint) {
var arrayBBox = this.extent;
- if (typeof arrayBBox !== "object" || arrayBBox.length !== 4) {
+ if (typeof arrayBBox !== "string" || arrayBBox.split(",").length !== 4) {
return new Point(0,0);
arrayBBox = arrayBBox.split(",");
@@ -750,7 +750,7 @@
this.getScale = function(skipEpsg4326){
var scale;
var bbox = this.extent;
- if (typeof bbox !== "object" || bbox.length !== 4) {
+ if (typeof bbox !== "string" || bbox.split(",").length !== 4) {
return null;
bbox = bbox.split(",");
Modified: branches/2.6/http/javascripts/mod_dragMapSize.php
--- branches/2.6/http/javascripts/mod_dragMapSize.php 2010-07-04 10:32:43 UTC (rev 6559)
+++ branches/2.6/http/javascripts/mod_dragMapSize.php 2010-07-04 10:45:11 UTC (rev 6560)
@@ -109,7 +109,7 @@
targetObject.setHeight(targetObject.getHeight() + parseFloat(dif_y));
var mybbox = targetObject.extent;
- if (typeof mybbox !== "object" || mybbox.length !== 4) {
+ if (typeof mybbox !== "string" || mybbox.split(",").length !== 4) {
return;
mybbox = mybbox.split(",");
More information about the Mapbender_commits
