[Mapbender-commits] r6579 - trunk/mapbender/http/frames
svn_mapbender at osgeo.org
Tue Jul 6 10:21:14 EDT 2010
Author: topi
Date: 2010-07-06 14:21:14 +0000 (Tue, 06 Jul 2010)
New Revision: 6579
trunk/mapbender/http/frames/index.php
order css files by var name
Modified: trunk/mapbender/http/frames/index.php
--- trunk/mapbender/http/frames/index.php 2010-07-06 12:35:27 UTC (rev 6578)
+++ trunk/mapbender/http/frames/index.php 2010-07-06 14:21:14 UTC (rev 6579)
@@ -51,7 +51,7 @@
<META http-equiv="Content-Script-Type" content="text/javascript">
<title><?php echo $gui_id;?> - presented by Mapbender</title>
<?php
-$sql = "SELECT * FROM gui_element_vars WHERE fkey_e_id = 'body' AND fkey_gui_id = $1 and var_name='favicon'";
+$sql = "SELECT * FROM gui_element_vars WHERE fkey_e_id = 'body' AND fkey_gui_id = $1 and var_name='favicon' ORDER BY var_name";
$v = array($gui_id);
$t = array('s');
$res = db_prep_query($sql,$v,$t);
@@ -76,7 +76,7 @@
display: none;
<?php
-$sql = "SELECT var_value FROM gui_element_vars WHERE fkey_gui_id = $1 and var_type='text/css'";
+$sql = "SELECT var_value FROM gui_element_vars WHERE fkey_gui_id = $1 and var_type='text/css' ORDER BY var_name";
$t = array('s');
More information about the Mapbender_commits
