[Mapbender-commits] r6587 - branches/banjo_dev/mapbender/http/rest
svn_mapbender at osgeo.org
Sat Jul 10 10:13:14 EDT 2010
Author: banjo
Date: 2010-07-10 14:13:14 +0000 (Sat, 10 Jul 2010)
New Revision: 6587
Added:
branches/banjo_dev/mapbender/http/rest/db_connect.php
branches/banjo_dev/mapbender/http/rest/http_auth.php
Adding files of authentication module
Added: branches/banjo_dev/mapbender/http/rest/db_connect.php
--- branches/banjo_dev/mapbender/http/rest/db_connect.php (rev 0)
+++ branches/banjo_dev/mapbender/http/rest/db_connect.php 2010-07-10 14:13:14 UTC (rev 6587)
@@ -0,0 +1,19 @@
+<?php
+require_once(dirname(__FILE__)."../../conf/mapbender.conf");
+//Include proper database wrapper library
+if(SYS_DBTYPE=="mysql") {
+ require_once(dirname(__FILE__) . "/../../lib/database-mysql.php");
+elseif(SYS_DBTYPE=="pgsql") {
+ require_once(dirname(__FILE__) . "/../../lib/database-pgsql.php");
+elseif(SYS_DBTYPE=="mysqli") {
+ require_once(dirname(__FILE__) . "../../lib/database-mysqli.php");
+//Database Connection
+$db_connection = db_connect($DBSERVER, $OWNER, $PW);
+db_select_db($DB, $db_connection);
Added: branches/banjo_dev/mapbender/http/rest/http_auth.php
--- branches/banjo_dev/mapbender/http/rest/http_auth.php (rev 0)
+++ branches/banjo_dev/mapbender/http/rest/http_auth.php 2010-07-10 14:13:14 UTC (rev 6587)
@@ -0,0 +1,100 @@
+<?php
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once("db_connect.php");
+//nonceLife in seconds
+$nonceLife = 300
+function authenticate() {
+require(dirname(__FILE__)."/../../conf/mapbender.conf");
+ //Check if digest auth is set. If it is not set, send the header with a
+ //challenge
+ if (empty($_SERVER['PHP_AUTH_DIGEST'])) {
+ header('HTTP/1.1 401 Unauthorised');
+ header('WWW-Authenticate: Digest realm="'.REALM.
+ '",qop="auth",nonce="'.getNonce().'",opaque="'.md5(REALM).'"');
+ die(send_rest_response(401);
+ //Get the http header in an array
+ $getHeaderArray = http_digest_parse($_SERVER['PHP_AUTH_DIGEST']);
+ if (!($getHeaderArray)) {
+ echo 'Following Header information cannot be validated - check your client software! <br>';
+ echo $_SERVER['PHP_AUTH_DIGEST'].'<br>';
+ //Retrieve mb_username and mb_email from http_auth username string
+ $userID = explode(';', $getHeaderArray['username']);
+ $mbUsername = $userID[0];
+ $mbEmail = $userID[1];
+ $userInfo = getUserInfo($mbUsername, $mbEmail);
+ if ($userInfo[0] == '-1') {
+ die(send_rest_response(401));
+ //First check the stale!
+ if($getHeaderArray['nonce'] == getNonce()) {
+ //up to date nonce received
+ $stale = false;
+ } else {
+ //Stale nonce received (probably more than x seconds old)
+ $stale = true;
+ die(send_rest_response(408));
+ // generate the expected response
+ $A1 = md5($mbUsername.';'.$mbEmail.':'.REALM.':'.$userInfo[1]);
+ $A2 = md5($_SERVER['REQUEST_METHOD'].':'.$getHeaderArray['uri']);
+ $expected_response = $A1.':'.getNonce().':'.$getHeaderArray['nc'];
+ $expected_response = md5($expected_response);
+ //Compare the expected response with the actual response
+ if ($getHeaderArray['response'] != $expected_response) {
+ //Authenticated
+ //Return the userid
+ return $userInfo[0];
+//function to parse the http auth header
+function http_digest_parse($txt)
+ //protection against any missing data
+ $needed_parts = array('nonce'=>1, 'nc'=>1, 'cnonce'=>1, 'qop'=>1, 'username'=>1, 'uri'=>1, 'response'=>1);
+ $data = array();
+ $key = implode('|', array_keys($needed_parts));
+ preg_match_all('@(' . $keys . ')=(?:([\'"])([^\2]+?)\2|([^\s,]+))@', $txt, $matches, PREG_SET_ORDER);
+ foreach ($matches as $m) {
+ $data[$m[1]] = $m[3] ? $m[3] : $m[4];
+ unset($needed_parts[$m[1]]);
+ return $needed_parts ? false : $data;
+//function to get userid and password from mb db
+function getUserInfo($mbUsername, $mbEmail) {
+ $result = array();
+ $sql = "SELECT mb_user_id, mb_user_password FROM mb_user where mb_user_name = $1 AND mb_user_email = $2";
+ $v = array($mbUsername, $mbEmail);
+ $t = array("s", "s");
+ $res = db_prep_query($sql, $v, $t);
+ if(!($row = db_fetch_array($res))) {
+ $result[0] = "-1";
+ } else {
+ $result[0] = $row['mb_user_id'];
+ $result[1] = $row['mb_user_password'];
+ return $result;
+//function to generate nonce
+function getNonce() {
+ global $nonceLife;
+ $time = ceil(time() / $nonceLife) * $nonceLife;
+ return md5(date('Y-m-d H:i', $time).':'.$_SERVER['REMOTE_ADDR']);
More information about the Mapbender_commits
