[Mapbender-commits] r6592 - in trunk/mapbender: http/classes
http/php lib
svn_mapbender at osgeo.org
Tue Jul 13 07:45:54 EDT 2010
Author: christoph
Date: 2010-07-13 11:45:54 +0000 (Tue, 13 Jul 2010)
New Revision: 6592
Added:
trunk/mapbender/lib/editGroup.php
trunk/mapbender/http/classes/class_group.php
trunk/mapbender/http/php/mod_editFilteredGroup.php
trunk/mapbender/http/php/mod_editGroup.php
unified editGroup, editFilteredGroup
added fields from other projects
uses class group, no sql in sources
Modified: trunk/mapbender/http/classes/class_group.php
--- trunk/mapbender/http/classes/class_group.php 2010-07-13 07:22:23 UTC (rev 6591)
+++ trunk/mapbender/http/classes/class_group.php 2010-07-13 11:45:54 UTC (rev 6592)
@@ -108,7 +108,7 @@
$sql_group_create = "INSERT INTO mb_group (mb_group_name) VALUES ($1)";
$v = array($this->name);
$t = array("s");
- $insert_result = db_query($sql_group_create);
+ $insert_result = db_prep_query($sql_group_create, $v, $t);
if (!$insert_result) {
db_rollback();
@@ -145,14 +145,21 @@
public function change($changes) {
//FIXME: validate input
- if ($changes->owner) {
- $owner = User::byName($changes->owner);
$this->name = $changes->name ? $changes->name : $this->name;
- $this->owner = $changes->owner ? $owner->id : $this->owner;
+ $this->owner = $changes->owner ? $changes->owner : $this->owner;
$this->description = $changes->description ? $changes->description : $this->description;
- $this->id = $changes->id ? $changes->id->value : $this->id;
- return true;
+ $this->id = $changes->id ? $changes->id : $this->id;
+ $this->title = $changes->title ? $changes->title : $this->title;
+ $this->address = $changes->address ? $changes->address : $this->address;
+ $this->postcode = $changes->postcode ? $changes->postcode : $this->postcode;
+ $this->city = $changes->city ? $changes->city : $this->city;
+ $this->stateorprovince = $changes->stateorprovince ? $changes->stateorprovince : $this->stateorprovince;
+ $this->country = $changes->country ? $changes->country : $this->country;
+ $this->voicetelephone = $changes->voicetelephone ? $changes->voicetelephone : $this->voicetelephone;
+ $this->facsimiletelephone = $changes->facsimiletelephone ? $changes->facsimiletelephone : $this->facsimiletelephone;
+ $this->email = $changes->email ? $changes->email : $this->email;
+ $this->logo_path = $changes->logo_path ? $changes->logo_path : $this->logo_path;
+ return true;
public function commit() {
@@ -160,21 +167,47 @@
$sql_update = "UPDATE mb_group SET ".
"mb_group_name = $1, ".
"mb_group_owner = $2, ".
- "mb_group_description = $3 ".
- "WHERE mb_group_id = $4;";
+ "mb_group_description = $3, ".
+ "mb_group_title = $4, ".
+ "mb_group_address = $5, ".
+ "mb_group_postcode = $6, ".
+ "mb_group_city = $7, ".
+ "mb_group_stateorprovince = $8, ".
+ "mb_group_country = $9, ".
+ "mb_group_voicetelephone = $10, ".
+ "mb_group_facsimiletelephone = $11, ".
+ "mb_group_email = $12, ".
+ "mb_group_logo_path = $13 ".
+ "WHERE mb_group_id = $14";
- $v = array($this->name,
- $this->owner,
- $this->description,
- $this->id);
+ $v = array(
+ $this->name,
+ $this->owner,
+ $this->description,
+ $this->title,
+ $this->address,
+ $this->postcode,
+ $this->city,
+ $this->stateorprovince,
+ $this->country,
+ $this->voicetelephone,
+ $this->facsimiletelephone,
+ $this->email,
+ $this->logo_path,
+ $this->id
- $t = array("s", "i", "s", "i");
+ $t = array(
+ "s", "i", "s", "s", "s",
+ "i", "s", "s", "s", "s",
+ "s", "s", "s", "i"
$update_result = db_prep_query($sql_update,$v,$t);
- if(!$update_result)
+ if(!$update_result) {
throw new Exception("Database error updating Group");
+ return false;
return true;
@@ -215,8 +248,7 @@
$this->name = $row['mb_group_name'];
//FIXME: needs checking
- $tmpuser = new User($row['mb_group_owner']);
- $this->owner = $tmpuser->name;
+ $this->owner = $row['mb_group_owner'];
$this->description = $row['mb_group_description'];
$this->title = $row["mb_group_title"];
$this->address = $row["mb_group_address"];
@@ -242,32 +274,57 @@
public static function getList($filter) {
- //set up filters:
- $id = $filter->id ? $filter->id : "%";
- $name = $filter->name ? $filter->name : "%";
+ $name = $filter->name ? $filter->name : null;
+ $id = $filter->id && is_numeric($filter->id) ?
+ intval($filter->id) : null;
+ $owner = $filter->owner && is_numeric($filter->owner) ?
+ intval($filter->owner) : null;
+ $groups = Array();
+ $sql_grouplist = "SELECT mb_group_id FROM mb_group";
+ $andConditions = array();
+ $v = array();
+ $t = array();
+ if (!is_null($name)) {
+ $v[]= $name;
+ $t[]= "s";
+ $andConditions[]= "mb_group_name LIKE $" . count($v);
+ if (!is_null($id)) {
+ $v[]= $id;
+ $t[]= "i";
+ $andConditions[]= "mb_group_id = $" . count($v);
+ if (!is_null($owner)) {
+ $v[]= $owner;
+ $t[]= "i";
+ $andConditions[]= "mb_group_owner = $" . count($v);
+ if (count($andConditions) > 0) {
+ $sql_grouplist .= " WHERE " . implode("AND", $andConditions);
+ $sql_grouplist .= " ORDER BY mb_group_name";
- $groups = Array();
- $sql_grouplist = "SELECT mb_group_id FROM mb_group WHERE mb_group_name LIKE $1;";
- $v = array($name);
- $t = array("s");
- $res_groups = db_prep_query($sql_grouplist,$v,$t);
+ $res_groups = db_prep_query($sql_grouplist,$v,$t);
+ while ($row = db_fetch_array($res_groups)) {
+ try {
+ $groups[] = new Group($row['mb_group_id']);
+ catch (Exception $E) {
+ continue;
+ //FIXME: should catch some errors here
+ return $groups;
- while($row = db_fetch_array($res_groups)) {
- try{
- $groups[] = new Group($row['mb_group_id']);
- catch(Exception $E)
- continue;
- //FIXME: should catch some errors here
- return $groups;
* tries to initialize a Groupobject by Name
* @return A group Object
@@ -276,17 +333,17 @@
public static function byName($name) {
- if($name == null) { return new Group(null); }
+ if (is_null($name)) {
+ return new Group(null);
- $sql_group = "SELECT mb_group_id FROM mb_group WHERE mb_group_name = $1";
- $res_group = db_prep_query($sql_group, array($name), array("s"));
- if($row = db_fetch_array($res_group))
- return new Group($row['mb_group_id']);
- return null;
+ $sql_group = "SELECT mb_group_id FROM mb_group WHERE mb_group_name = $1";
+ $res_group = db_prep_query($sql_group, array($name), array("s"));
+ if ($row = db_fetch_array($res_group)) {
+ return new Group($row['mb_group_id']);
+ return null;
public function isValid () {
Modified: trunk/mapbender/http/php/mod_editFilteredGroup.php
--- trunk/mapbender/http/php/mod_editFilteredGroup.php 2010-07-13 07:22:23 UTC (rev 6591)
+++ trunk/mapbender/http/php/mod_editFilteredGroup.php 2010-07-13 11:45:54 UTC (rev 6592)
@@ -21,196 +21,10 @@
import_request_variables("PG");
$e_id="editFilteredGroup";
require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>Edit Filtered Group</title>
-<?php
-include '../include/dyn_css.php';
-<script language="JavaScript">
-function validate(val){
- var ok = validateInput();
- if(ok == 'true'){
- var permission = false;
- if(val == 'save'){
- permission = confirm("Save changes?");
- if(val == 'update'){
- if(val == 'delete'){
- permission = confirm("Delete Group?");
- if(permission === true){
- document.forms[0].action.value = val;
- document.forms[0].submit();
-function validateInput(){
- var str_alert = "Input incorrect !";
- if(document.forms[0].name.value === ''){
- alert(str_alert);
- document.forms[0].name.focus();
- return 'false';
- return 'true';
-</script>
-</head>
-<body>
-<?php
-#delete
-if($action == 'delete'){
- $sql = "DELETE FROM mb_group WHERE mb_group_id = $1";
- $v = array($selected_group);
- $t = array('i');
- $res = db_prep_query($sql,$v,$t);
- $selected_group = 'new';
-#save
-if($action == 'save'){
- $sql = "SELECT mb_group_id FROM mb_group WHERE mb_group_name = $1 ";
- $t = array('s');
- if(db_fetch_row($res)){
- echo "<script language='JavaScript'>alert('groupname must be unique!');</script>";
- else{
- $sql = "Insert INTO mb_group (mb_group_name, mb_group_owner, mb_group_description) VALUES ";
- $sql.= "($1, $2, $3);";
- $v = array($name,$owner_id,$description);
- $t = array('s','i','s');
- $selected_group = db_insert_id($res,"mb_group","mb_group_id");
-#update
-if($action == 'update'){
- $sql = "SELECT mb_group_id FROM mb_group WHERE mb_group_name = $1 AND mb_group_id <> $2";
- $v = array($name,$selected_group);
- $t = array('s','i');
- echo "<script language='JavaScript'>alert('Groupname must be unique!');</script>";
- else{
- $sql = "UPDATE mb_group SET mb_group_name = $1";
- $sql.=", mb_group_description = $2";
- $sql.=" where mb_group_id = $3";
- $v = array($name,$description,$selected_group);
- $t = array('s','s','i');
-if (!isset($name) || $selected_group == 'new'){
- $name = "";
- $owner_id = Mapbender::session()->get("mb_user_id");
- $owner_name = Mapbender::session()->get("mb_user_name");
- $description = "";
+require_once(dirname(__FILE__)."/../classes/class_user.php");
+require_once(dirname(__FILE__)."/../classes/class_group.php");
$myGroup = true;
-/*HTML*****************************************************************************************************/
+include "../../lib/editGroup.php";
-echo "<form name='form1' action='" . $self ."' method='post'>";
-echo "<table border='0'>";
-#User
-echo "<tr>";
- echo "<td>";
- echo "Group: ";
- echo "</td>";
-echo "<td>";
-echo "<select name='selected_group' onchange='submit()'>";
- echo "<option value='new'>NEW...</option>";
- $sql = "SELECT mb_group_name,mb_group_id FROM mb_group ";
- $v = array();
- $t = array();
- if(isset($myGroup)){
- $sql .= "WHERE mb_group_owner = $1";
- array_push($v, Mapbender::session()->get("mb_user_id"));
- array_push($t, "i");
- $sql .= " ORDER BY mb_group_name ";
- $res = db_prep_query($sql, $v, $t);
- $count=0;
- while($row = db_fetch_array($res)){
- echo "<option value='".$row["mb_group_id"]."' ";
- if($selected_group && $selected_group == $row["mb_group_id"]){
- echo "selected";
- echo ">".$row["mb_group_name"]."</option>";
- $count++;
- echo "</select>";
- echo "</td>";
-echo "</tr>";
-if(isset($selected_group) && $selected_group != 0){
- $sql = "SELECT * FROM mb_group WHERE mb_group_id = $1 ORDER BY mb_group_name ";
- $t = array('i');
- if($row = db_fetch_array($res)){
- $name = $row["mb_group_name"];
- $owner_id = $row["mb_group_owner"];
- $description = $row["mb_group_description"];
- $sql = "SELECT mb_user_name FROM mb_user WHERE mb_user_id = $1";
- $v = array($owner_id);
- $t = array('i');
- $owner_name = $row["mb_user_name"];
-#name
-echo "<tr>";
- echo "<td>Name:</td>";
- echo "<td>";
- echo "<input type='text' size='30' name='name' value='".$name."'>";
- echo "</td>";
-echo "</tr>";
-#owner
-echo "<tr>";
- echo "<td>Owner: </td>";
- echo "<td>";
- echo "<input type='text' size='30' name='owner_name' value='".$owner_name."' readonly>";
- echo "<input type='hidden' size='30' name='owner_id' value='".$owner_id."' readonly>";
- echo "</td>";
-echo "</tr>";
-#description
-echo "<tr>";
- echo "<td>Description: </td>";
- echo "<td>";
- echo "<input type='text' size='30' name='description' value='".$description."'>";
- echo "</td>";
-echo "</tr>";
-echo"</table>";
-if($selected_group == 'new' || !isset($selected_group)){
- echo "<input type='button' value='save' onclick='validate(\"save\")'>";
-if(Mapbender::session()->get("mb_user_id") == $owner_id && $selected_group != 'new' && $selected_group != '' ){
- echo "<input type='button' value='save' onclick='validate(\"update\")'>";
- echo "<input type='button' value='delete' onclick='validate(\"delete\")'>";
-<input type='hidden' name='action' value=''>
-</form>
-</body>
-</html>
\ No newline at end of file
Modified: trunk/mapbender/http/php/mod_editGroup.php
--- trunk/mapbender/http/php/mod_editGroup.php 2010-07-13 07:22:23 UTC (rev 6591)
+++ trunk/mapbender/http/php/mod_editGroup.php 2010-07-13 11:45:54 UTC (rev 6592)
@@ -17,196 +17,12 @@
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+import_request_variables("PG");
$e_id="editGroup";
-<html>
-<?php
-<head>
-<title>Edit Group</title>
-<?php
+$myGroup = false;
- if(ok == 'true'){
- if(permission == true){
- if(document.forms[0].name.value == ''){
- alert(str_alert);
- return 'false';
- return 'true';
-</script>
-</head>
-<body>
-<?php
-#delete
- $v = array( $selected_group);
- $t = array('i');
-#save
- $t = array('s');
- else{
- $sql.= "($1, $2,$3);";
-#update
- else{
- $name = "";
-#User
-echo "<tr>";
- echo "<td>";
- echo "Group: ";
- echo "</td>";
-echo "<td>";
- echo "<select name='selected_group' onchange='submit()'>";
- $v = array();
- $t = array();
- if (isset($myGroup)) {
- $count=0;
- echo "selected";
- $count++;
- echo "</select>";
- echo "</td>";
-echo "</tr>";
- $t = array('i');
- $t = array('i');
-#name
-echo "<tr>";
- echo "<td>";
- echo "</td>";
-echo "</tr>";
-#owner
-echo "<tr>";
- echo "<td>";
- echo "</td>";
-echo "</tr>";
-#description
-echo "<tr>";
- echo "<td>";
- echo "</td>";
-echo "</tr>";
-echo"</table>";
-</form>
-</body>
-</html>
Added: trunk/mapbender/lib/editGroup.php
--- trunk/mapbender/lib/editGroup.php (rev 0)
+++ trunk/mapbender/lib/editGroup.php 2010-07-13 11:45:54 UTC (rev 6592)
@@ -0,0 +1,332 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>Edit Filtered Group</title>
+<?php
+include '../include/dyn_css.php';
+<script type="text/javascript">
+function validate(val){
+ var ok = validateInput();
+ if(ok == 'true'){
+ var permission = false;
+ if(val == 'save'){
+ permission = confirm("Save changes?");
+ if(val == 'update'){
+ if(val == 'delete'){
+ permission = confirm("Delete Group?");
+ if(permission === true){
+ document.forms[0].action.value = val;
+ document.forms[0].submit();
+function validateInput(){
+ var str_alert = "Input incorrect !";
+ if(document.forms[0].name.value === ''){
+ alert(str_alert);
+ document.forms[0].name.focus();
+ return 'false';
+ return 'true';
+</script>
+</head>
+<body>
+<?php
+#delete
+if($action == 'delete'){
+ $group = new Group(intval($selected_group));
+ $group->remove();
+ $selected_group = 'new';
+#save
+if($action == 'save'){
+ $group = Group::byName($name);
+ if(!is_null($group)){
+ echo "<script type='text/javascript'>alert('groupname must be unique!');</script>";
+ else {
+ $group = new Group(null);
+ $changes = new stdClass();
+ $changes->name = $name;
+ $changes->owner = $owner_id;
+ $changes->description = $description;
+ $changes->title = $title;
+ $changes->address = $address;
+ $changes->postcode = $postcode;
+ $changes->city = $city;
+ $changes->stateorprovince = $stateorprovince;
+ $changes->country = $country;
+ $changes->voicetelephone = $voicetelephone;
+ $changes->facsimiletelephone = $facsimiletelephone;
+ $changes->email = $email;
+ $changes->logo_path = $logo_path;
+ $group->change($changes);
+ $group->create();
+ $selected_group = $group->getId();
+#update
+if ($action == 'update') {
+ if (!is_null($group) && intval($group->getId()) !== intval($selected_group)) {
+ echo "<script type='text/javascript'>alert('Groupname must be unique!');</script>";
+ else {
+ $group->commit();
+if (!isset($name) || $selected_group == 'new'){
+ $name = "";
+ $owner_id = Mapbender::session()->get("mb_user_id");
+ $owner = new User(intval($owner_id));
+ $owner_name = $owner->name;
+ $description = "";
+ $title = "";
+ $address = "";
+ $postcode = "";
+ $city = "";
+ $stateorprovince = "";
+ $country = "";
+ $voicetelephone = "";
+ $facsimiletelephone = "";
+ $email = "";
+ $logo_path = "";
+/*HTML*****************************************************************************************************/
+echo "<form name='form1' action='" . $self ."' method='post'>";
+echo "<table border='0'>";
+#User
+echo "<tr>";
+ echo "<td>";
+ echo "Group: ";
+ echo "</td>";
+echo "<td>";
+echo "<select name='selected_group' onchange='submit()'>";
+ echo "<option value='new'>NEW...</option>";
+ $filter = new stdClass();
+ if (isset($myGroup) && $myGroup) {
+ $filter->owner = Mapbender::session()->get("mb_user_id");
+ $groupArray = Group::getList($filter);
+ foreach ($groupArray as $group) {
+ echo "<option value='" .
+ htmlentities($group->getId(), ENT_QUOTES. "UTF-8") . "' ";
+ if ($selected_group && intval($selected_group) == $group->getId()) {
+ echo "selected";
+ echo ">" .
+ htmlentities($group->name, ENT_QUOTES, "UTF-8") . "</option>";
+ echo "</select>";
+ echo "</td>";
+echo "</tr>";
+if(isset($selected_group) && $selected_group != 0){
+ $data = $group->getFields();
+ if ($group->isValid()) {
+ $name = $data["name"];
+ $owner_id = $data["owner"];
+ $description = $data["description"];
+ $title = $data["title"];
+ $address = $data["address"];
+ $postcode = $data["postcode"];
+ $city = $data["city"];
+ $stateorprovince = $data["stateorprovince"];
+ $country = $data["country"];
+ $voicetelephone = $data["voicetelephone"];
+ $facsimiletelephone = $data["facsimiletelephone"];
+ $email = $data["email"];
+ $logo_path = $data["logo_path"];
+ if ($owner->isValid()) {
+#name
+echo "<tr>";
+ echo "<td>"._mb("Name").":</td>";
+ echo "<td>";
+ echo "<input type='text' size='30' name='name' value='" .
+ htmlentities($name, ENT_QUOTES, "UTF-8") . "'>";
+ echo "</td>";
+echo "</tr>";
+#title
+echo "<tr>";
+ echo "<td>"._mb("Title").":</td>";
+ echo "<td>";
+ echo "<input type='text' size='30' name='title' value='" .
+ htmlentities($title, ENT_QUOTES, "UTF-8") . "'>";
+ echo "</td>";
+echo "</tr>";
+#owner
+echo "<tr>";
+ echo "<td>"._mb("Owner").": </td>";
+ echo "<td>";
+ echo "<input type='text' size='30' name='owner_name' value='" .
+ htmlentities($owner_name, ENT_QUOTES, "UTF-8") . "' readonly>";
+ echo "<input type='hidden' size='30' name='owner_id' value='" .
+ htmlentities($owner_id, ENT_QUOTES, "UTF-8") . "' readonly>";
+ echo "</td>";
+echo "</tr>";
+#description
+echo "<tr>";
+ echo "<td>"._mb("Description").": </td>";
+ echo "<td>";
+ echo "<input type='text' size='30' name='description' value='" .
+ htmlentities($description, ENT_QUOTES, "UTF-8") . "'>";
+ echo "</td>";
+echo "</tr>";
+#address
+echo "<tr>";
+ echo "<td>"._mb("Address").": </td>";
+ echo "<td>";
+ echo "<input type='text' size='30' name='address' value='" .
+ htmlentities($address, ENT_QUOTES, "UTF-8") . "'>";
+ echo "</td>";
+echo "</tr>";
+#postcode
+echo "<tr>";
+ echo "<td>"._mb("Postcode").": </td>";
+ echo "<td>";
+ echo "<input type='text' size='30' name='postcode' value='" .
+ htmlentities($postcode, ENT_QUOTES, "UTF-8") . "'>";
+ echo "</td>";
+echo "</tr>";
+#city
+echo "<tr>";
+ echo "<td>"._mb("City").": </td>";
+ echo "<td>";
+ echo "<input type='text' size='30' name='city' value='" .
+ htmlentities($city, ENT_QUOTES, "UTF-8") . "'>";
+ echo "</td>";
+echo "</tr>";
+#provice
+echo "<tr>";
+ echo "<td>"._mb("Province").": </td>";
+ echo "<td>";
+ echo "<input type='text' size='30' name='stateorprovince' value='" .
+ htmlentities($stateorprovince, ENT_QUOTES, "UTF-8") . "'>";
+ echo "</td>";
+echo "</tr>";
+#country
+echo "<tr>";
+ echo "<td>"._mb("Country").": </td>";
+ echo "<td>";
+ echo "<input type='text' size='30' name='country' value='" .
+ htmlentities($country, ENT_QUOTES, "UTF-8") . "'>";
+ echo "</td>";
+echo "</tr>";
+#voicetelephone
+echo "<tr>";
+ echo "<td>"._mb("Voicetelephone").": </td>";
+ echo "<td>";
+ echo "<input type='text' size='30' name='voicetelephone' value='" .
+ htmlentities($voicetelephone, ENT_QUOTES, "UTF-8") . "'>";
+ echo "</td>";
+echo "</tr>";
+#facsimiletelephone
+echo "<tr>";
+ echo "<td>"._mb("Facsimiletelephone").": </td>";
+ echo "<td>";
+ echo "<input type='text' size='30' name='facsimiletelephone' value='" .
+ htmlentities($facsimiletelephone, ENT_QUOTES, "UTF-8") . "'>";
+ echo "</td>";
+echo "</tr>";
+#email
+echo "<tr>";
+ echo "<td>Email: </td>";
+ echo "<td>";
+ echo "<input type='text' size='30' name='email' value='" .
+ htmlentities($email, ENT_QUOTES, "UTF-8") . "'>";
+ echo "</td>";
+echo "</tr>";
+#logo
+echo "<tr>";
+ echo "<td>Logo: </td>";
+ echo "<td>";
+ echo "<input type='text' size='30' name='logo_path' value='" .
+ htmlentities($logo_path, ENT_QUOTES, "UTF-8") . "'>";
+ echo "</td>";
+echo "</tr>";
+# blank row
+echo "<tr>";
+ echo "<td colspan='2'> </td>";
+echo "</tr>";
+# send form
+echo "<tr>";
+ echo "<td> </td>";
+ echo "<td>";
+ if($selected_group == 'new' || !isset($selected_group)){
+ echo "<input type='button' value='save' onclick='validate(\"save\")'>";
+ if(Mapbender::session()->get("mb_user_id") == $owner_id && $selected_group != 'new' && $selected_group != '' ){
+ echo "<input type='button' value='save' onclick='validate(\"update\")'>";
+ echo "<input type='button' value='delete' onclick='validate(\"delete\")'>";
+ echo "</td>";
+echo "</tr>";
+echo"</table>";
+<input type='hidden' name='action' value=''>
+</form>
+</body>
+</html>
More information about the Mapbender_commits
