[Mapbender-commits] r6604 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Thu Jul 15 13:17:47 EDT 2010
Author: christoph
Date: 2010-07-15 17:17:47 +0000 (Thu, 15 Jul 2010)
New Revision: 6604
Added:
trunk/mapbender/http/plugins/mb_measure.js
new version
Added: trunk/mapbender/http/plugins/mb_measure.js
--- trunk/mapbender/http/plugins/mb_measure.js (rev 0)
+++ trunk/mapbender/http/plugins/mb_measure.js 2010-07-15 17:17:47 UTC (rev 6604)
@@ -0,0 +1,330 @@
+var $measure = $(this);
+var MeasureApi = function (o) {
+ var measureDialog,
+ measurePoints = [],
+ button,
+ canvases = {},
+ that = this,
+ opacity = 0.4,
+ srs;
+ var hideMeasureData = function () {
+ measureDialog.find(".mb-measure-clicked-point").parent().hide();
+ measureDialog.find(".mb-measure-current-point").parent().hide();
+ measureDialog.find(".mb-measure-distance").parent().hide();
+ measureDialog.find(".mb-measure-area").parent().hide();
+ var create = function () {
+ // Initialise measure dialog
+ var html = "<div>" +
+ "<p class='mb-measure-text'>Fahren Sie mit der Maus über die Karte, um die Koordinaten anzuzeigen.<br> Klicken Sie, um eine Messung zu starten</p>" +
+ "<p>Letzter Punkt: <span class='mb-measure-clicked-point' /></p>" +
+ "<p>Aktuelle Koordinaten: <span class='mb-measure-current-point' /></p>" +
+ "<p>Distanz: <span class='mb-measure-distance' /> m</p>" +
+ "<p>Fläche: <span class='mb-measure-area' /> <span class='mb-measure-area-unit' /></p>" +
+ "</div>";
+ measureDialog = $(html).appendTo(o.$target);
+ measureDialog.dialog({
+ autoOpen: false
+ }).bind("dialogclose", function () {
+ button.stop();
+ // Initialise Raphael canvas
+ Mapbender.events.init.register(function () {
+ o.$target.each(function () {
+ var map = $(this).mapbender();
+ var $canvas = $("<div />").css({
+ "z-index": 100,
+ "position": "relative"
+ }).appendTo(this);
+ canvases[map.elementName] =
+ Raphael($canvas.get(0), map.getWidth(), map.getHeight());
+ // Initialise button
+ button = new Mapbender.Button({
+ domElement: $measure.get(0),
+ over: o.src.replace(/_off/, "_over"),
+ on: o.src.replace(/_off/, "_on"),
+ off: o.src,
+ name: o.id,
+ go: that.activate,
+ stop: that.deactivate
+ var draw = function (map, pos) {
+ var canvas = canvases[map.elementName];
+ canvas.clear();
+ var str_path = "";
+ measurePoints.push(pos);
+ var len = measurePoints.length;
+ if (len > 0){
+ for (var k=0; k < len; k++) {
+ var pk = measurePoints[k];
+ var q = map.convertRealToPixel(pk);
+ if (k === 0) {
+ str_path += 'M';
+ else {
+ str_path += 'L';
+ str_path += q.x + ' ' + q.y;
+ var circle = canvas.circle(q.x, q.y, 3);
+ if (k === 0) {
+ circle.attr({
+ fill: "#f00",
+ stroke: "none",
+ opacity: opacity
+ else {
+ circle.attr({
+ fill: "#f00",
+ stroke: "none",
+ opacity: opacity
+ measurePoints.pop();
+ if (isPolygon(measurePoints, pos)) {
+ var poly = canvas.path(str_path + 'Z');
+ poly.attr({
+ fill: "#0f0",
+ opacity: opacity
+ var line = canvas.path(str_path);
+ line.attr({
+ stroke: "#00f",
+ "stroke-width": 2,
+ opacity: opacity
+ line.toFront();
+ var updateCurrentPoint = function (p) {
+ measureDialog.find(".mb-measure-current-point").text(
+ p.x + " " + p.y
+ ).parent().show();
+ var updateClickedPoint = function (p) {
+ measureDialog.find(".mb-measure-clicked-point").text(
+ p.x + " " + p.y
+ var updateDistance = function (dist) {
+ if (!dist) {
+ return;
+ measureDialog.find(".mb-measure-distance").text(Math.abs(dist)).parent().show();
+ var updateArea = function (area) {
+ if (area === null) {
+ return;
+ var areaUnit = "m²";
+ if (area > 10000000){
+ area /= 1000000;
+ areaUnit = "km²";
+ else if (area > 100000){
+ area /= 10000;
+ areaUnit = "ha";
+ area = Math.round(area*10)/10;
+ measureDialog.find(".mb-measure-area-unit").html(areaUnit);
+ measureDialog.find(".mb-measure-area").text(area).parent().show();
+ var calculateDistanceGeographic = function (a, b) {
+ var lon_from = (a.x * Math.PI) / 180;
+ var lat_from = (a.y * Math.PI) / 180;
+ var lon_to = (b.x * Math.PI) / 180;
+ var lat_to = (b.y * Math.PI) / 180;
+ return Math.abs(6371229 * Math.acos(
+ Math.sin(lat_from) * Math.sin(lat_to) +
+ Math.cos(lat_from) * Math.cos(lat_to) *
+ Math.cos(lon_from - lon_to)
+ var calculateDistanceMetric = function (a, b) {
+ return Math.abs(Math.sqrt(
+ Math.pow(Math.abs(b.x - a.x), 2) +
+ Math.pow(Math.abs(b.y - a.y), 2)
+ var calculateDistance = function (map, a, b) {
+ if (a !== null && b !== null) {
+ switch (map.getSrs()) {
+ case "EPSG:4326":
+ return calculateDistanceGeographic(a, b);
+ default:
+ return calculateDistanceMetric(a, b);
+ return null;
+ var calculateArea = function (pos) {
+ if (measurePoints.length < 2) {
+ return null;
+ var area = 0;
+ var p0 = measurePoints[0], pi, pj;
+ for (var i = 0; i < measurePoints.length - 1; i++) {
+ pi = measurePoints[i];
+ pj = measurePoints[i + 1];
+ area += (pi.y + pj.y) * (pi.x - pj.x) / 2;
+ area += (p0.y + pj.y) * (p0.x - pj.x) / 2;
+ return Math.abs(area);
+ var isPolygon = function (measurePoints, pos) {
+ if (len < 2) {
+ return false;
+ var pn = measurePoints[len - 1];
+ for (var i = 0; i < measurePoints.length - 2; i++) {
+ var p1 = measurePoints[i];
+ var p2 = measurePoints[i + 1];
+ if (lineIntersect(p1.x, p1.y, p2.x, p2.y, pn.x, pn.y, pos.x, pos.y)) {
+ return false;
+ return true;
+ var lineIntersect = function ( a1, a2, b1, b2, c1, c2, d1, d2 ) {
+ var s, t, N = (b1-a1)*(d2-c2)-(b2-a2)*(d1-c1);
+ if (N === 0) {
+ // parallel
+ return false;
+ s = ((c1-a1)*(d2-c2)-(c2-a2)*(d1-c1)) / N;
+ t = (a1-c1 + s*(b1-a1)) / (d1-c1);
+ if (s <= 1 && s>=0 && t <= 1 && t>=0) {
+ return true;
+ return false;
+ var measure = function (e) {
+ var map = $(e.currentTarget).mapbender();
+ if (srs !== map.getSrs()){
+ button.stop();
+ return;
+ var pos = map.convertPixelToReal(map.getMousePosition(e));
+ updateCurrentPoint(pos);
+ var previousPoint = measurePoints.length > 0 ?
+ measurePoints[measurePoints.length - 1] : null;
+ var distance = calculateDistance(map, previousPoint, pos);
+ updateDistance(distance);
+ updateArea(calculateArea(pos));
+ draw(map, pos);
+ var addPoint = function (e) {
+ updateClickedPoint(pos);
+ draw(map, pos);
+ var addLastPoint = function (e) {
+ if ($(e.currentTarget).size() > 0) {
+ $(e.currentTarget).unbind("mousedown", addPoint)
+ .unbind("dblclick", addLastPoint)
+ .unbind("mousemove", measure);
+ $(e.currentTarget).css("cursor", "auto");
+ addPoint(e);
+ this.activate = function () {
+ if (o.$target.size() > 0) {
+ o.$target.bind("mousedown", addPoint)
+ .bind("dblclick", addLastPoint)
+ .bind("mousemove", measure);
+ o.$target.css("cursor", "crosshair");
+ srs = o.$target.mapbender().getSrs();
+ measureDialog.dialog("open");
+ this.deactivate = function () {
+ o.$target.unbind("mousedown", addPoint)
+ o.$target.css("cursor", "auto");
+ srs = undefined;
+ for (var i in canvases) {
+ canvases[i].clear();
+ measurePoints = [];
+ hideMeasureData();
+ measureDialog.dialog("close");
+ button.stop();
+ create();
+$measure.mapbender(new MeasureApi(options));
More information about the Mapbender_commits
