[Mapbender-commits] r6607 - branches/2.6/http/php
svn_mapbender at osgeo.org
Thu Jul 22 04:14:33 EDT 2010
Author: tbaschetti
Date: 2010-07-22 08:14:33 +0000 (Thu, 22 Jul 2010)
New Revision: 6607
branches/2.6/http/php/mod_editGuiWms.php
branches/2.6/http/php/mod_editWMS_Metadata.php
branches/2.6/http/php/mod_loadCapabilitiesList.php
quote wms_abstract
http://trac.osgeo.org/mapbender/ticket/662
Modified: branches/2.6/http/php/mod_editGuiWms.php
--- branches/2.6/http/php/mod_editGuiWms.php 2010-07-19 15:18:12 UTC (rev 6606)
+++ branches/2.6/http/php/mod_editGuiWms.php 2010-07-22 08:14:33 UTC (rev 6607)
@@ -1,744 +1,744 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/mod_editGuiWms.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-import_request_variables("PG");
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/mod_editGuiWms.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+import_request_variables("PG");
$e_id="editGUI_WMS";
-require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
-require_once(dirname(__FILE__)."/../classes/class_wms.php");
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>Edit GUI WMS</title>
-<?php
-include_once '../include/dyn_css.php';
-function toImage($text) {
- $angle = 90;
- if (extension_loaded("gd2")) {
- return "<img src='../php/createImageFromText.php?text=" . urlencode($text) . "&angle=" . $angle . "'>";
- return $text;
-<script language="JavaScript">
-function edit_gaz(gui,wms,layer){
- window.open("../php/mod_wfsLayerObj_conf.php?gui="+gui+"&wms="+wms+"&layer="+layer);
-function validate(wert){
- if(wert == 'delete_wms'){
- if(document.form1.wmsList.selectedIndex == -1){
- document.form1.wmsList.style.background = '#ff0000';
- }else{
- var secure = confirm("Remove WMS in this GUI ?");
- if(secure == true){
- document.form1.del.value='true';
- document.form1.submit();
- if(wert == 'up_wms'){
- }else{
- if (document.form1.wmsList.selectedIndex>0){
- document.form1.up.value='true';
- if(wert == 'down_wms'){
- }else{
- if (document.form1.wmsList.selectedIndex<document.form1.wmsList.length-1){
- document.form1.down.value='true';
-function checkBoxValue(){
- for(var i=0; i<document.forms[0].elements.length; i++){
- if(document.forms[0].elements[i].type == 'checkbox'){
- if(document.forms[0].elements[i].checked == true){
- document.forms[0].elements[i].value = '1';
- else{
- document.forms[0].elements[i].value = '0';
- document.forms[0].elements[i].checked = true;
- if(document.forms[0].elements[i].type == 'text' && ( document.forms[0].elements[i].name.indexOf("minscale") > -1 || document.forms[0].elements[i].name.indexOf("maxscale") > -1 )){
- var nr = parseInt(document.forms[0].elements[i].value);
- if(isNaN(nr) == true){document.forms[0].elements[i].value = 0;}
- else{document.forms[0].elements[i].value = nr;}
- document.forms[0].update_content.value=1;
- document.forms[0].submit();
-function getAllLayer(){
- var arrayLayer = new Array();
- var cntLayer = 0;
- if(document.forms[0].elements[i].name.indexOf("layer_id") > -1){
- arrayLayer[cntLayer] = document.forms[0].elements[i].value;
- cntLayer++;
- return arrayLayer;
-function setSubs(){
- var arrayLayer = getAllLayer();
- for(var i=0; i<arrayLayer.length; i++){
- if(parseInt(eval("document.forms[0].L_" + arrayLayer[i] + "___layer_parent.value")) > 0){
- eval("document.forms[0].L_" + arrayLayer[i] + "___gui_layer_status.checked = false");
-function setLayer(def,status){
- if(def == 'querylayer'){
- for(var i=1; i<arrayLayer.length; i++){
- if(eval("document.forms[0].L_" + arrayLayer[i] + "___gui_layer_querylayer.disabled == false")){
- eval("document.forms[0].L_" + arrayLayer[i] + "___gui_layer_querylayer.checked = " + status);
- if(def == 'visible'){
- eval("document.forms[0].L_" + arrayLayer[i] + "___gui_layer_visible.checked = " + status);
-function showSld(origUrl){
- var url = document.getElementById("this_gui_wms_sldurl").value;
- if(url==""){
- if(origUrl=="")
- return;
- url=origUrl;
- window.open(url);
-</script>
-</head>
-<body>
-<?php
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-$con = db_connect($DBSERVER,$OWNER,$PW);
-db_select_db(DB,$con);
-$mb_user_id=$_SESSION["mb_user_id"];
-#delete gui_wms from gui
-if($del && $del == 'true'){
- $sql="SELECT DISTINCT gui_wms_position from gui_wms WHERE fkey_gui_id = $1 and fkey_wms_id = $2";
- $v = array($guiList,$wmsList);
- $t = array('s','i');
- $res = db_prep_query($sql,$v,$t);
- $cnt = 0;
- while($row = db_fetch_array($res)){
- $wms_position = $row["gui_wms_position"];
- $cnt++;
- #if($cnt > 1){die("Error: WMS (ID) not unique!");}
- $sql = "Delete from gui_wms where fkey_gui_id = $1 and fkey_wms_id = $2 ";
- $sql = "Delete from gui_layer where fkey_gui_id = $1 and gui_layer_wms_id = $2";
- $del='false';
- $sql = "UPDATE gui_wms SET gui_wms_position = (gui_wms_position - 1) WHERE gui_wms_position > $1";
- $sql .= " AND fkey_gui_id = $2 ";
- $v = array($wms_position,$guiList);
- $t = array('i','s');
- unset($wmsList);
-#update gui_wms_position
-if($up && $up == 'true'){
- if ($wmsList!=""){
- $sql = "SELECT gui_wms_position ";
- $sql .= "FROM gui_wms WHERE fkey_gui_id = $1 AND fkey_wms_id = $2";
- if($row = db_fetch_array($res)){
- if($wms_position > 0){
- $sql = "UPDATE gui_wms SET ";
- $sql .= "gui_wms_position = $1";
- $sql .= " WHERE fkey_gui_id = $2 AND fkey_wms_id = $3";
- $v = array(($wms_position - 1),$guiList,$wmsList);
- $t = array('i','s','i');
- $sql .= " WHERE gui_wms_position = $2 AND fkey_gui_id = $3 AND fkey_wms_id <> $4 ";
- $v = array($wms_position,($wms_position - 1),$guiList,$wmsList);
- $t = array('i','i','s','i');
-if($down && $down == 'true'){
- $max = 0;
- $sql = "SELECT MAX(gui_wms_position) as max FROM gui_wms WHERE fkey_gui_id = $1 ";
- $v = array($guiList);
- $t = array('s');
- $max = $row["max"];
- if($wms_position < $max){
- $v = array(($wms_position + 1),$guiList,$wmsList);
- $sql .= " WHERE gui_wms_position = $2 AND fkey_gui_id = $3 AND fkey_wms_id <> $4";
- $v = array($wms_position,($wms_position + 1),$guiList,$wmsList);
-/*handle Updates*/
-if(isset($update_content) && $update_content == "1"){
- if(isset($this_gui_wms_epsg)){
- $sql = "UPDATE gui_wms set gui_wms_epsg = $1, gui_wms_mapformat = $2, ";
- $sql .= "gui_wms_featureinfoformat = $3, gui_wms_exceptionformat = $4, ";
- $sql .= "gui_wms_visible = $5, gui_wms_opacity = $6, gui_wms_sldurl = $7 ";
- $sql .= "WHERE fkey_gui_id = $8 AND fkey_wms_id = $9";
- $v = array($this_gui_wms_epsg,$this_gui_wms_mapformat,$this_gui_wms_featureinfoformat,$this_gui_wms_exceptionformat,$this_gui_wms_visible,$this_gui_wms_opacity,$this_gui_wms_sldurl,$this_gui,$this_wms);
- $t = array('s','s','s','s','i','i','s','s','i');
- else{
- $sql = "UPDATE gui_wms set gui_wms_mapformat = $1, ";
- $sql .= "gui_wms_featureinfoformat = $2, gui_wms_exceptionformat = $3, ";
- $sql .= "gui_wms_visible = $4, gui_wms_opacity = $5, gui_wms_sldurl = $6 ";
- $sql .= "WHERE fkey_gui_id = $7 AND fkey_wms_id = $8";
- $v = array($this_gui_wms_mapformat,$this_gui_wms_featureinfoformat,$this_gui_wms_exceptionformat,$this_gui_wms_visible,$this_gui_wms_opacity,$this_gui_wms_sldurl,$this_gui,$this_wms);
- $t = array('s','s','s','i','i','s','s','i');
- $cnt = 0;
- while(list($key,$val) = each($_REQUEST)){
- if(preg_match("/___/", $key)){
- $myKey = explode("___", $key);
- if($myKey[1]!="layer_parent" && $myKey[1]!='layer_id' ){
- $sql = "UPDATE gui_layer SET ".$myKey[1]." = $1 WHERE fkey_gui_id = $2 AND fkey_layer_id = $3";
- $v = array($val,$this_gui,preg_replace("/L_/","",$myKey[0]));
- if($myKey[1]=='gui_layer_style'){
- $t = array('s','s','i');
- else{
- if(!$res = db_prep_query($sql,$v,$t)){
- echo "FEHLER in ZEILE 288";
-echo "<form name='form1' action='" . $self ."' method='post'>";
-echo "<table cellpadding='3' cellspacing='3' border='0' class='table_top'>";
-echo "<tr>";
-echo "<td>";
-echo "GUI";
-echo "</td>";
-echo "<td>";
-echo "WMS-TITLE";
-echo "</td>";
-echo "<td>";
-echo "</td>";
-echo "<tr>";
-echo "<td>";
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
-$admin = new administration();
-$ownguis = $admin->getGuisByOwner($_SESSION["mb_user_id"],true);
-$gui_id =array();
-if (count($ownguis)>0){
- for($i=0; $i<count($ownguis); $i++){
- $gui_id[$i]=$ownguis[$i];
-echo"<select size='8' name='guiList' onchange='document.form1.wmsList.selectedIndex = -1;submit()'>";
-$selected_gui_id="";
-for ($i=0; $i<count($ownguis);$i++){
- echo "<option value='".$gui_id[$i]."' ";
- if($guiList && $guiList == $gui_id[$i]){
- echo "selected";
- $selected_gui_id=$gui_id[$i];
- else{
- if ($i==0){
- echo "selected";
- echo ">".$gui_id[$i]."</option>";
-echo "</select>";
-echo "</td>";
-echo "<td>";
-$sql = "SELECT * from gui_wms JOIN gui ON gui_wms.fkey_gui_id = gui.gui_id JOIN wms ON ";
-$sql .= "gui_wms.fkey_wms_id = wms.wms_id AND gui_wms.fkey_gui_id=gui.gui_id WHERE gui.gui_id = $1 ORDER BY gui_wms_position";
-$v = array($selected_gui_id);
-$t = array('s');
-$res = db_prep_query($sql,$v,$t);
-$count_wms = 0;
-echo "<select size='8' name='wmsList' style='width:200px' onchange='submit()'>";
-while($row = db_fetch_array($res)){
- echo "<option title='".$row["wms_abstract"]."' value='".$row["wms_id"]."' ";
- if(isset($wmsList) && $wmsList == $row["wms_id"]){
- echo "selected";
- echo ">".$row["gui_wms_position"]." - ".$row["wms_title"]."</option>";
- $count_wms++;
-echo "</select>";
-echo "</td><td>";
-echo "<input class='myButton' type='button' name='up_wms' value=' up ' onClick='validate(\"up_wms\")'>";
-echo "<input type='hidden' name='up' value=''><br><br>";
-echo "<input class='myButton' type='button' name='down_wms' value='down' onClick='validate(\"down_wms\")'>";
-echo "<input type='hidden' name='down' value=''><br><br>";
-echo "<input class='myButton' type='button' name='delete_wms' value='remove' onClick='validate(\"delete_wms\")'>";
-echo "<input type='hidden' name='del' value=''>";
-echo "</td>";
-echo "</tr>";
-echo "</table>";
-if(isset($wmsList)){
-#gui_wms
-$sql_gw = "SELECT * FROM gui_wms WHERE fkey_gui_id = $1 AND fkey_wms_id = $2";
-$v = array($guiList,$wmsList);
-$t = array('s','i');
-$res_gw = db_prep_query($sql_gw,$v,$t);
-$cnt_gw = 0;
-while($row = db_fetch_array($res_gw)){
- $gui_wms_position[$cnt_gw] = $row["gui_wms_position"];
- $gui_wms_mapformat[$cnt_gw] = $row["gui_wms_mapformat"];
- $gui_wms_featureinfoformat[$cnt_gw] = $row["gui_wms_featureinfoformat"];
- $gui_wms_exceptionformat[$cnt_gw] = $row["gui_wms_exceptionformat"];
- $gui_wms_epsg[$cnt_gw] = $row["gui_wms_epsg"];
- $gui_wms_visible[$cnt_gw] = $row["gui_wms_visible"];
- $gui_wms_opacity[$cnt_gw] = $row["gui_wms_opacity"];
- $gui_wms_sldurl[$cnt_gw] = $row["gui_wms_sldurl"]; # sld url
- $cnt_gw++;
-#wms
-$sql_w = "SELECT * FROM wms WHERE wms_id = $1";
-$v = array($wmsList);
-$t = array('i');
-$res_w = db_prep_query($sql_w,$v,$t);
-$cnt_w = 0;
-while($row = db_fetch_array($res_w)){
- $wms_id[$cnt_w] = $row["wms_id"];
- $wms_version[$cnt_w] = $row["wms_version"];
- $wms_title[$cnt_w] = $row["wms_title"];
- $wms_abstract[$cnt_w] = $row["wms_abstract"];
- $wms_getcapabilities[$cnt_w] = $row["wms_getcapabilities"];
- $wms_supportsld[$cnt_w] = $row["wms_supportsld"]; # Buttons zum sld support anzeigen?
- $cnt_w++;
-#wms_format
-$sql_wf = "SELECT * FROM wms_format WHERE fkey_wms_id = $1";
-$t = array('i');
-$res_wf = db_prep_query($sql_wf,$v,$t);
-$cnt_wf = 0;
-while($row = db_fetch_array($res_wf)){
- $data_type[$cnt_wf] = $row["data_type"];
- $data_format[$cnt_wf] = $row["data_format"];
- $cnt_wf++;
-#gui_layer
-$sql_gl = "SELECT l.*, gl.*, sld.sld_user_layer_id, sld.use_sld FROM layer AS l, gui_layer AS gl left outer join sld_user_layer AS sld on sld.fkey_layer_id = gl.fkey_layer_id WHERE l.layer_id = gl.fkey_layer_id AND gl.gui_layer_wms_id = $1 AND gl.fkey_gui_id = $2 AND (sld.fkey_gui_id = $3 or sld.fkey_gui_id is NULL) AND (sld.fkey_mb_user_id = $4 or sld.fkey_mb_user_id is NULL) ORDER BY l.layer_pos";
-$v = array($wmsList,$guiList,$guiList,$mb_user_id);
-$t = array('i','s','s','i');
-$res_gl = db_prep_query($sql_gl,$v,$t);
-$gui_layer_status = array();
-$gui_layer_selectable = array();
-$gui_layer_visible = array();
-$gui_layer_queryable = array();
-$gui_layer_querylayer = array();
-$gui_layer_minscale = array();
-$gui_layer_maxscale = array();
-$gui_layer_priority = array();
-$gui_layer_style = array();
-$gui_layer_wfs_featuretype = array();
-$layer_maxscale = array();
-$layer_id = array();
-$layer_parent = array();
-$layer_name = array();
-$layer_title = array();
-$layer_queryable = array();
-$layer_minscale = array();
-$sld_user_layer_id = array();
-$use_sld = array();
-while($row = db_fetch_array($res_gl)){
- array_push($gui_layer_status, $row["gui_layer_status"]);
- array_push($gui_layer_selectable, $row["gui_layer_selectable"]);
- array_push($gui_layer_visible, $row["gui_layer_visible"]);
- array_push($gui_layer_queryable, $row["gui_layer_queryable"]);
- array_push($gui_layer_querylayer, $row["gui_layer_querylayer"]);
- array_push($gui_layer_minscale, $row["gui_layer_minscale"]);
- array_push($gui_layer_maxscale, $row["gui_layer_maxscale"]);
- array_push($gui_layer_priority, $row["gui_layer_priority"]);
- array_push($gui_layer_style, $row["gui_layer_style"]);
- array_push($gui_layer_wfs_featuretype, $row["gui_layer_wfs_featuretype"]);
- array_push($layer_id, $row["layer_id"]);
- array_push($layer_parent, $row["layer_parent"]);
- array_push($layer_name, $row["layer_name"]);
- array_push($layer_title, $row["layer_title"]);
- array_push($layer_queryable, $row["layer_queryable"]);
- array_push($layer_minscale, $row["layer_minscale"]);
- array_push($layer_maxscale, $row["layer_maxscale"]);
- array_push($sld_user_layer_id, $row["sld_user_layer_id"]);
- array_push($use_sld, $row["use_sld"]);
-#layer_epsg
-$sql_le = "SELECT * FROM layer_epsg WHERE fkey_layer_id = $1";
-$v = array($layer_id[0]);
-$t = array('i');
-$res_le = db_prep_query($sql_le,$v,$t);
-$cnt_le = 0;
-while($row = db_fetch_array($res_le)){
- $epsg[$cnt_le] = $row["epsg"];
- $cnt_le++;
-echo "<div style='position:absolute;left:590px; top:180px;' ><input type='button' style='width:100px;height:100px;background-color:#0066cc' value='save' onclick='checkBoxValue()'></div>";
-echo "<table class='table_top'>";
-echo "<tr>";
-echo "<td colspan='2'>";
-echo "<a href='".$wms_getcapabilities[0];
-echo wms::getConjunctionCharacter($wms_getcapabilities[0]);
-if ($wms_version[0] == "1.0.0") {
- echo "WMTVER=". $wms_version[0]."&REQUEST=capabilities";
-else {
- echo "VERSION=". $wms_version[0]."&REQUEST=GetCapabilities&SERVICE=WMS";
-echo "' style='font-size:14px' target='_blank'>LINK: Capabilities</a>";
-echo "</td>";
-echo "<td align = right>WMS ID: " . $wms_id[0] . "</td>";
-echo "<tr>";
-#epsg
-if($gui_wms_position[0] == 0){
- echo "<tr>";
- echo "<td>EPSG: </td><td>";
- echo "<select class='mySelect' name='this_gui_wms_epsg'>";
- for($i=0; $i<count($epsg); $i++){
- echo "<option value='".$epsg[$i]."' ";
- if($epsg[$i] == $gui_wms_epsg[0]){ echo "selected";}
- echo ">".$epsg[$i]."</option>";
- echo "</select>";
- echo "</td>";
- echo "</tr>";
-#format
-echo "<tr>";
- echo "<td>Mapformat: </td><td>";
- echo "<select class='mySelect' name='this_gui_wms_mapformat'>";
- for($i=0; $i<count($data_format); $i++){
- if($data_type[$i] == 'map'){
- echo "<option value='".$data_format[$i]."' ";
- if($data_format[$i] == $gui_wms_mapformat[0]){ echo "selected";}
- echo ">".$data_format[$i]."</option>";
- echo "</select>";
- echo "</td>";
-echo "</tr>";
-echo "<tr>";
- echo "<td>Infoformat: </td><td>";
- echo "<select class='mySelect' name='this_gui_wms_featureinfoformat'>";
- echo "<option value='text/html'>text/html</option>";
- if($data_type[$i] == 'featureinfo'){
- if($data_format[$i] == $gui_wms_featureinfoformat[0]){ echo "selected";}
- echo "</select>";
- echo "</td>";
-echo "</tr>";
-echo "<tr>";
- echo "<td>Exceptionformat: </td><td>";
- echo "<select class='mySelect' name='this_gui_wms_exceptionformat'>";
- if($data_type[$i] == 'exception'){
- if($data_format[$i] == $gui_wms_exceptionformat[0]){ echo "selected";}
- echo "</select>";
- echo "</td>";
-echo "</tr><br>";
-# visibility
-echo "<tr>";
- echo "<td>Visibility: </td><td>";
- echo "<select class='mySelect' name='this_gui_wms_visible'>";
- for($i=0; $i<3; $i++){
- echo "<option value='".$i."' ";
- if($i == $gui_wms_visible[0]){ echo "selected";}
- echo ">";
- if($i == '0'){
- echo "hidden";
- if($i == '1'){
- echo "visible";
- echo "</option>";
- echo "</select>";
- echo "</td>";
-echo "</tr>";
-# opacity
-echo "<tr>";
- echo "<td>Opacity: </td><td>";
- echo "<select class='mySelect' name='this_gui_wms_opacity'>";
- for($i=0; $i<=100; $i+=10){
- if($i - $gui_wms_opacity[0]<=5&&$i - $gui_wms_opacity[0]>=-4){ echo "selected";}
- echo ">";
- echo $i."%";
- echo "</option>";
- echo "</select>";
- echo "</td>";
-echo "</tr>";
-# sld support
-if($wms_supportsld[0]) {
- echo "<tr>";
- echo "<td>SLD-URL: </td><td>";
- echo "<input type='text' class='myText' name='this_gui_wms_sldurl' id='this_gui_wms_sldurl' title='".$gui_wms_sldurl[0]."' value='".$gui_wms_sldurl[0]."'>";
- #echo "<a href='' onclick='return window.open(\"editor-start.php\");'><img src='sld_editor.png' border=0></a>";
- #$layer_names = implode(",", $layer_name);
- echo " <a href='javascript:showSld(\"".$gui_wms_sldurl[0]."\");'>SLD laden/anzeigen</a>";
- echo "</td>";
- echo "</tr>";
-} else {
- echo "<input type='hidden' value='' name='this_gui_wms_sldurl'>";
-echo "</table><br>";
-echo "<table border='1' cellpadding='1'>";
- echo "<tr>";
- echo "<td>Nr.</td>";
- echo "<td>ID</td>";
- echo "<td>" . toImage('Parent') . "</td>";
- echo "<td>Name</td>";
- echo "<td>Title</td>";
- echo "<td>" . toImage('on/off') . "</td>";
- echo "<td>" . toImage('sel') . "</td>";
- echo "<td>" . toImage('sel_default') . "</td>";
- echo "<td>" . toImage('info') . "</td>";
- echo "<td>" . toImage('info_default') . "</td>";
- echo "<td>" . toImage('minScale 1:') . "</td>";
- echo "<td>" . toImage('maxScale 1:') . "</td>";
- echo "<td>" . toImage('Style') . "</td>";
- echo "<td>" . toImage('Prio') . "</td>";
- echo "<td>" . toImage('setWFS') . "</td>";
- if($wms_supportsld[0]) {echo "<td>" . toImage('SLD') . "</td>";}
- echo "</tr>";
-#echo "<tr><td>Nr.</td><td>ID</td><td>Parent</td><td>Name</td><td>Title</td><td>on/off</td><td>sel</td><td>sel_default</td><td>info</td><td>info_default</td><td>minScale 1:</td><td>maxScale 1:</td><td>Prio</td><td>setWFS</td></tr>";
-echo "<tr><td></td><td></td><td></td><td></td><td></td><td>";
-echo "<input type='button' class='LButton' value='Sublayer\noff' onclick='setSubs()'>";
-echo "</td><td></td><td>";
-echo "<nobr><input type='button' class='button_on_off' value='off' onclick='setLayer(\"visible\",false)'> ";
-echo "<input type='button' class='button_on_off' value='on' onclick='setLayer(\"visible\",true)'></nobr>";
-echo"</td><td></td><td>";
-echo "<nobr><input type='button' class='button_on_off' value='off' onclick='setLayer(\"querylayer\",false)'> ";
-echo "<input type='button' class='button_on_off' value='on' onclick='setLayer(\"querylayer\",true)'></nobr>";
-echo "</td><td></td><td></td><td></td></tr>";
-for($i=0; $i<count($layer_id); $i++){
-#layer_styles
-$sql_styles = "SELECT * FROM layer_style WHERE fkey_layer_id = $1";
-$v = array($layer_id[$i]);
-$t = array('i');
-$res_styles = db_prep_query($sql_styles,$v,$t);
-$cnt_styles= 0;
-$style = array();
-while($row = db_fetch_array($res_styles)){
- $style[$cnt_styles] = $row["name"];
- $cnt_styles++;
- echo "<tr align='center'>";
- echo "<td><input type='text' size='1' name='L_".$layer_id[$i]."___layer_nr' disabled value='".$i."'></td>";
- echo "<td style='background:lightgrey'><input type='text' size='2' name='L_".$layer_id[$i]."___layer_id' value='".$layer_id[$i]."' readonly></td>";
- echo "<td><input type='text' size='1' name='L_".$layer_id[$i]."___layer_parent' value='".$layer_parent[$i]."' readonly></td>";
- echo "<td style='background:lightgrey'><input type='text' size='7' value='".$layer_name[$i]."' readonly></td>";
- echo "<td><input type='text' name='".$layer_title[$i]."' size='12' value='".$layer_title[$i]."' ></td>";
- echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_status' type='checkbox' ";
- if($gui_layer_status[$i] == 1){ echo "checked";}
- echo "></td>";
- echo "<td><input name='L_".$layer_id[$i]."___gui_layer_selectable' type='checkbox' ";
- if($gui_layer_selectable[$i] == 1){ echo "checked";}
- echo "></td>";
- echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_visible' type='checkbox' ";
- if($gui_layer_visible[$i] == 1){ echo "checked";}
- echo "></td>";
- echo "<td><input name='L_".$layer_id[$i]."___gui_layer_queryable' type='checkbox' ";
- if($gui_layer_queryable[$i] == 1){ echo "checked";}
- if($layer_queryable[$i] == 0){ echo "disabled";}
- echo "></td>";
- echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_querylayer' type='checkbox' ";
- if($gui_layer_querylayer[$i] == 1){ echo "checked";}
- echo "></td>";
- echo "<td><input name='L_".$layer_id[$i]."___gui_layer_minscale' type='text' size='5' value='".$gui_layer_minscale[$i]."'></td>";
- echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_maxscale' type='text' size='5' value='".$gui_layer_maxscale[$i]."'></td>";
- echo "<td>\n";
- echo "<select class='select_short' name='L_".$layer_id[$i]."___gui_layer_style'>\n";
- echo "<option value=''";
- if(count($style) ==0){ echo "selected";}
- echo ">---</option>\n";
- for($j=0;$j<count($style); $j++){
- echo "<option value='".$style[$j]."'";
- if($style[$j] == $gui_layer_style[$i]){ echo "selected";}
- echo ">".$style[$j]."</option>\n";
- echo "</select></td>\n";
- echo "<td><select class='select_short' name='L_".$layer_id[$i]."___gui_layer_priority'>";
- for($j=0; $j<count($gui_layer_priority); $j++){
- echo "<option value='".$j."'";
- if($j == $gui_layer_priority[$i]){echo "selected";}
- echo ">".$j;
- echo "</option>";
- /* wfs configuration */
- echo "<td>";
- if ($i > 0) {
- echo "<input class='button_wfs'name='gui_layer_gaz' type='button' onclick='edit_gaz(\"".$guiList."\",".$wmsList.",".$layer_id[$i].")' value='";
- if($gui_layer_wfs_featuretype[$i] == ""){
- echo "setWFS";
- else{
- echo "wfs ".$gui_layer_wfs_featuretype[$i];
- echo "'>";
- echo "</td>";
- echo "<td>";
- if ($i > 0) {
- echo "<input class='button3' name='gui_layer_sld' type='button' onclick='window.open(\"../sld/sld_main.php?".$urlParameters."&sld_gui_id=".$guiList."&sld_wms_id=".$wms_id[0]."&sld_layer_name=".$layer_name[$i]."\");' value='";
- if ($sld_user_layer_id[$i] != "")
- echo "sld:".$sld_user_layer_id[$i]."(".$use_sld[$i].")";
- else
- echo "SLD";
- echo "'>";
- echo "</td>";
- echo "</tr>\n";
- if($i == 0){ echo "<tr><td colspan='16'><hr></td></tr>";}
-echo "</table>\n";
-echo "<input type='hidden' name='this_gui' value='".$guiList."'>\n";
-echo "<input type='hidden' name='this_wms' value='".$wmsList."'>\n";
-echo "<input type='hidden' name='this_layer_count' value='".$cnt_l."'>\n";
-echo "<input type='hidden' name='update_content' value=''>\n";
-echo "</form>\n";
-</body>
-</html>
+require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+require_once(dirname(__FILE__)."/../classes/class_wms.php");
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>Edit GUI WMS</title>
+<?php
+include_once '../include/dyn_css.php';
+function toImage($text) {
+ $angle = 90;
+ if (extension_loaded("gd2")) {
+ return "<img src='../php/createImageFromText.php?text=" . urlencode($text) . "&angle=" . $angle . "'>";
+ return $text;
+<script language="JavaScript">
+function edit_gaz(gui,wms,layer){
+ window.open("../php/mod_wfsLayerObj_conf.php?gui="+gui+"&wms="+wms+"&layer="+layer);
+function validate(wert){
+ if(wert == 'delete_wms'){
+ if(document.form1.wmsList.selectedIndex == -1){
+ document.form1.wmsList.style.background = '#ff0000';
+ }else{
+ var secure = confirm("Remove WMS in this GUI ?");
+ if(secure == true){
+ document.form1.del.value='true';
+ document.form1.submit();
+ if(wert == 'up_wms'){
+ }else{
+ if (document.form1.wmsList.selectedIndex>0){
+ document.form1.up.value='true';
+ if(wert == 'down_wms'){
+ }else{
+ if (document.form1.wmsList.selectedIndex<document.form1.wmsList.length-1){
+ document.form1.down.value='true';
+function checkBoxValue(){
+ for(var i=0; i<document.forms[0].elements.length; i++){
+ if(document.forms[0].elements[i].type == 'checkbox'){
+ if(document.forms[0].elements[i].checked == true){
+ document.forms[0].elements[i].value = '1';
+ else{
+ document.forms[0].elements[i].value = '0';
+ document.forms[0].elements[i].checked = true;
+ if(document.forms[0].elements[i].type == 'text' && ( document.forms[0].elements[i].name.indexOf("minscale") > -1 || document.forms[0].elements[i].name.indexOf("maxscale") > -1 )){
+ var nr = parseInt(document.forms[0].elements[i].value);
+ if(isNaN(nr) == true){document.forms[0].elements[i].value = 0;}
+ else{document.forms[0].elements[i].value = nr;}
+ document.forms[0].update_content.value=1;
+ document.forms[0].submit();
+function getAllLayer(){
+ var arrayLayer = new Array();
+ var cntLayer = 0;
+ if(document.forms[0].elements[i].name.indexOf("layer_id") > -1){
+ arrayLayer[cntLayer] = document.forms[0].elements[i].value;
+ cntLayer++;
+ return arrayLayer;
+function setSubs(){
+ var arrayLayer = getAllLayer();
+ for(var i=0; i<arrayLayer.length; i++){
+ if(parseInt(eval("document.forms[0].L_" + arrayLayer[i] + "___layer_parent.value")) > 0){
+ eval("document.forms[0].L_" + arrayLayer[i] + "___gui_layer_status.checked = false");
+function setLayer(def,status){
+ if(def == 'querylayer'){
+ for(var i=1; i<arrayLayer.length; i++){
+ if(eval("document.forms[0].L_" + arrayLayer[i] + "___gui_layer_querylayer.disabled == false")){
+ eval("document.forms[0].L_" + arrayLayer[i] + "___gui_layer_querylayer.checked = " + status);
+ if(def == 'visible'){
+ eval("document.forms[0].L_" + arrayLayer[i] + "___gui_layer_visible.checked = " + status);
+function showSld(origUrl){
+ var url = document.getElementById("this_gui_wms_sldurl").value;
+ if(url==""){
+ if(origUrl=="")
+ return;
+ url=origUrl;
+ window.open(url);
+</script>
+</head>
+<body>
+<?php
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+$con = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db(DB,$con);
+$mb_user_id=$_SESSION["mb_user_id"];
+#delete gui_wms from gui
+if($del && $del == 'true'){
+ $sql="SELECT DISTINCT gui_wms_position from gui_wms WHERE fkey_gui_id = $1 and fkey_wms_id = $2";
+ $v = array($guiList,$wmsList);
+ $t = array('s','i');
+ $res = db_prep_query($sql,$v,$t);
+ $cnt = 0;
+ while($row = db_fetch_array($res)){
+ $wms_position = $row["gui_wms_position"];
+ $cnt++;
+ #if($cnt > 1){die("Error: WMS (ID) not unique!");}
+ $sql = "Delete from gui_wms where fkey_gui_id = $1 and fkey_wms_id = $2 ";
+ $sql = "Delete from gui_layer where fkey_gui_id = $1 and gui_layer_wms_id = $2";
+ $del='false';
+ $sql = "UPDATE gui_wms SET gui_wms_position = (gui_wms_position - 1) WHERE gui_wms_position > $1";
+ $sql .= " AND fkey_gui_id = $2 ";
+ $v = array($wms_position,$guiList);
+ $t = array('i','s');
+ unset($wmsList);
+#update gui_wms_position
+if($up && $up == 'true'){
+ if ($wmsList!=""){
+ $sql = "SELECT gui_wms_position ";
+ $sql .= "FROM gui_wms WHERE fkey_gui_id = $1 AND fkey_wms_id = $2";
+ if($row = db_fetch_array($res)){
+ if($wms_position > 0){
+ $sql = "UPDATE gui_wms SET ";
+ $sql .= "gui_wms_position = $1";
+ $sql .= " WHERE fkey_gui_id = $2 AND fkey_wms_id = $3";
+ $v = array(($wms_position - 1),$guiList,$wmsList);
+ $t = array('i','s','i');
+ $sql .= " WHERE gui_wms_position = $2 AND fkey_gui_id = $3 AND fkey_wms_id <> $4 ";
+ $v = array($wms_position,($wms_position - 1),$guiList,$wmsList);
+ $t = array('i','i','s','i');
+if($down && $down == 'true'){
+ $max = 0;
+ $sql = "SELECT MAX(gui_wms_position) as max FROM gui_wms WHERE fkey_gui_id = $1 ";
+ $v = array($guiList);
+ $t = array('s');
+ $max = $row["max"];
+ if($wms_position < $max){
+ $v = array(($wms_position + 1),$guiList,$wmsList);
+ $sql .= " WHERE gui_wms_position = $2 AND fkey_gui_id = $3 AND fkey_wms_id <> $4";
+ $v = array($wms_position,($wms_position + 1),$guiList,$wmsList);
+/*handle Updates*/
+if(isset($update_content) && $update_content == "1"){
+ if(isset($this_gui_wms_epsg)){
+ $sql = "UPDATE gui_wms set gui_wms_epsg = $1, gui_wms_mapformat = $2, ";
+ $sql .= "gui_wms_featureinfoformat = $3, gui_wms_exceptionformat = $4, ";
+ $sql .= "gui_wms_visible = $5, gui_wms_opacity = $6, gui_wms_sldurl = $7 ";
+ $sql .= "WHERE fkey_gui_id = $8 AND fkey_wms_id = $9";
+ $v = array($this_gui_wms_epsg,$this_gui_wms_mapformat,$this_gui_wms_featureinfoformat,$this_gui_wms_exceptionformat,$this_gui_wms_visible,$this_gui_wms_opacity,$this_gui_wms_sldurl,$this_gui,$this_wms);
+ $t = array('s','s','s','s','i','i','s','s','i');
+ else{
+ $sql = "UPDATE gui_wms set gui_wms_mapformat = $1, ";
+ $sql .= "gui_wms_featureinfoformat = $2, gui_wms_exceptionformat = $3, ";
+ $sql .= "gui_wms_visible = $4, gui_wms_opacity = $5, gui_wms_sldurl = $6 ";
+ $sql .= "WHERE fkey_gui_id = $7 AND fkey_wms_id = $8";
+ $v = array($this_gui_wms_mapformat,$this_gui_wms_featureinfoformat,$this_gui_wms_exceptionformat,$this_gui_wms_visible,$this_gui_wms_opacity,$this_gui_wms_sldurl,$this_gui,$this_wms);
+ $t = array('s','s','s','i','i','s','s','i');
+ $cnt = 0;
+ while(list($key,$val) = each($_REQUEST)){
+ if(preg_match("/___/", $key)){
+ $myKey = explode("___", $key);
+ if($myKey[1]!="layer_parent" && $myKey[1]!='layer_id' ){
+ $sql = "UPDATE gui_layer SET ".$myKey[1]." = $1 WHERE fkey_gui_id = $2 AND fkey_layer_id = $3";
+ $v = array($val,$this_gui,preg_replace("/L_/","",$myKey[0]));
+ if($myKey[1]=='gui_layer_style'){
+ $t = array('s','s','i');
+ else{
+ if(!$res = db_prep_query($sql,$v,$t)){
+ echo "FEHLER in ZEILE 288";
+echo "<form name='form1' action='" . $self ."' method='post'>";
+echo "<table cellpadding='3' cellspacing='3' border='0' class='table_top'>";
+echo "<tr>";
+echo "<td>";
+echo "GUI";
+echo "</td>";
+echo "<td>";
+echo "WMS-TITLE";
+echo "</td>";
+echo "<td>";
+echo "</td>";
+echo "<tr>";
+echo "<td>";
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+$admin = new administration();
+$ownguis = $admin->getGuisByOwner($_SESSION["mb_user_id"],true);
+$gui_id =array();
+if (count($ownguis)>0){
+ for($i=0; $i<count($ownguis); $i++){
+ $gui_id[$i]=$ownguis[$i];
+echo"<select size='8' name='guiList' onchange='document.form1.wmsList.selectedIndex = -1;submit()'>";
+$selected_gui_id="";
+for ($i=0; $i<count($ownguis);$i++){
+ echo "<option value='".$gui_id[$i]."' ";
+ if($guiList && $guiList == $gui_id[$i]){
+ echo "selected";
+ $selected_gui_id=$gui_id[$i];
+ else{
+ if ($i==0){
+ echo "selected";
+ echo ">".$gui_id[$i]."</option>";
+echo "</select>";
+echo "</td>";
+echo "<td>";
+$sql = "SELECT * from gui_wms JOIN gui ON gui_wms.fkey_gui_id = gui.gui_id JOIN wms ON ";
+$sql .= "gui_wms.fkey_wms_id = wms.wms_id AND gui_wms.fkey_gui_id=gui.gui_id WHERE gui.gui_id = $1 ORDER BY gui_wms_position";
+$v = array($selected_gui_id);
+$t = array('s');
+$res = db_prep_query($sql,$v,$t);
+$count_wms = 0;
+echo "<select size='8' name='wmsList' style='width:200px' onchange='submit()'>";
+while($row = db_fetch_array($res)){
+ echo "<option title='".htmlentities($row["wms_abstract"],ENT_QUOTES,"UTF-8")."' value='".$row["wms_id"]."' ";
+ if(isset($wmsList) && $wmsList == $row["wms_id"]){
+ echo "selected";
+ echo ">".$row["gui_wms_position"]." - ".$row["wms_title"]."</option>";
+ $count_wms++;
+echo "</select>";
+echo "</td><td>";
+echo "<input class='myButton' type='button' name='up_wms' value=' up ' onClick='validate(\"up_wms\")'>";
+echo "<input type='hidden' name='up' value=''><br><br>";
+echo "<input class='myButton' type='button' name='down_wms' value='down' onClick='validate(\"down_wms\")'>";
+echo "<input type='hidden' name='down' value=''><br><br>";
+echo "<input class='myButton' type='button' name='delete_wms' value='remove' onClick='validate(\"delete_wms\")'>";
+echo "<input type='hidden' name='del' value=''>";
+echo "</td>";
+echo "</tr>";
+echo "</table>";
+if(isset($wmsList)){
+#gui_wms
+$sql_gw = "SELECT * FROM gui_wms WHERE fkey_gui_id = $1 AND fkey_wms_id = $2";
+$v = array($guiList,$wmsList);
+$t = array('s','i');
+$res_gw = db_prep_query($sql_gw,$v,$t);
+$cnt_gw = 0;
+while($row = db_fetch_array($res_gw)){
+ $gui_wms_position[$cnt_gw] = $row["gui_wms_position"];
+ $gui_wms_mapformat[$cnt_gw] = $row["gui_wms_mapformat"];
+ $gui_wms_featureinfoformat[$cnt_gw] = $row["gui_wms_featureinfoformat"];
+ $gui_wms_exceptionformat[$cnt_gw] = $row["gui_wms_exceptionformat"];
+ $gui_wms_epsg[$cnt_gw] = $row["gui_wms_epsg"];
+ $gui_wms_visible[$cnt_gw] = $row["gui_wms_visible"];
+ $gui_wms_opacity[$cnt_gw] = $row["gui_wms_opacity"];
+ $gui_wms_sldurl[$cnt_gw] = $row["gui_wms_sldurl"]; # sld url
+ $cnt_gw++;
+#wms
+$sql_w = "SELECT * FROM wms WHERE wms_id = $1";
+$v = array($wmsList);
+$t = array('i');
+$res_w = db_prep_query($sql_w,$v,$t);
+$cnt_w = 0;
+while($row = db_fetch_array($res_w)){
+ $wms_id[$cnt_w] = $row["wms_id"];
+ $wms_version[$cnt_w] = $row["wms_version"];
+ $wms_title[$cnt_w] = $row["wms_title"];
+ $wms_abstract[$cnt_w] = htmlentities($row["wms_abstract"],ENT_QUOTES,"UTF-8");
+ $wms_getcapabilities[$cnt_w] = $row["wms_getcapabilities"];
+ $wms_supportsld[$cnt_w] = $row["wms_supportsld"]; # Buttons zum sld support anzeigen?
+ $cnt_w++;
+#wms_format
+$sql_wf = "SELECT * FROM wms_format WHERE fkey_wms_id = $1";
+$t = array('i');
+$res_wf = db_prep_query($sql_wf,$v,$t);
+$cnt_wf = 0;
+while($row = db_fetch_array($res_wf)){
+ $data_type[$cnt_wf] = $row["data_type"];
+ $data_format[$cnt_wf] = $row["data_format"];
+ $cnt_wf++;
+#gui_layer
+$sql_gl = "SELECT l.*, gl.*, sld.sld_user_layer_id, sld.use_sld FROM layer AS l, gui_layer AS gl left outer join sld_user_layer AS sld on sld.fkey_layer_id = gl.fkey_layer_id WHERE l.layer_id = gl.fkey_layer_id AND gl.gui_layer_wms_id = $1 AND gl.fkey_gui_id = $2 AND (sld.fkey_gui_id = $3 or sld.fkey_gui_id is NULL) AND (sld.fkey_mb_user_id = $4 or sld.fkey_mb_user_id is NULL) ORDER BY l.layer_pos";
+$v = array($wmsList,$guiList,$guiList,$mb_user_id);
+$t = array('i','s','s','i');
+$res_gl = db_prep_query($sql_gl,$v,$t);
+$gui_layer_status = array();
+$gui_layer_selectable = array();
+$gui_layer_visible = array();
+$gui_layer_queryable = array();
+$gui_layer_querylayer = array();
+$gui_layer_minscale = array();
+$gui_layer_maxscale = array();
+$gui_layer_priority = array();
+$gui_layer_style = array();
+$gui_layer_wfs_featuretype = array();
+$layer_maxscale = array();
+$layer_id = array();
+$layer_parent = array();
+$layer_name = array();
+$layer_title = array();
+$layer_queryable = array();
+$layer_minscale = array();
+$sld_user_layer_id = array();
+$use_sld = array();
+while($row = db_fetch_array($res_gl)){
+ array_push($gui_layer_status, $row["gui_layer_status"]);
+ array_push($gui_layer_selectable, $row["gui_layer_selectable"]);
+ array_push($gui_layer_visible, $row["gui_layer_visible"]);
+ array_push($gui_layer_queryable, $row["gui_layer_queryable"]);
+ array_push($gui_layer_querylayer, $row["gui_layer_querylayer"]);
+ array_push($gui_layer_minscale, $row["gui_layer_minscale"]);
+ array_push($gui_layer_maxscale, $row["gui_layer_maxscale"]);
+ array_push($gui_layer_priority, $row["gui_layer_priority"]);
+ array_push($gui_layer_style, $row["gui_layer_style"]);
+ array_push($gui_layer_wfs_featuretype, $row["gui_layer_wfs_featuretype"]);
+ array_push($layer_id, $row["layer_id"]);
+ array_push($layer_parent, $row["layer_parent"]);
+ array_push($layer_name, $row["layer_name"]);
+ array_push($layer_title, $row["layer_title"]);
+ array_push($layer_queryable, $row["layer_queryable"]);
+ array_push($layer_minscale, $row["layer_minscale"]);
+ array_push($layer_maxscale, $row["layer_maxscale"]);
+ array_push($sld_user_layer_id, $row["sld_user_layer_id"]);
+ array_push($use_sld, $row["use_sld"]);
+#layer_epsg
+$sql_le = "SELECT * FROM layer_epsg WHERE fkey_layer_id = $1";
+$v = array($layer_id[0]);
+$t = array('i');
+$res_le = db_prep_query($sql_le,$v,$t);
+$cnt_le = 0;
+while($row = db_fetch_array($res_le)){
+ $epsg[$cnt_le] = $row["epsg"];
+ $cnt_le++;
+echo "<div style='position:absolute;left:590px; top:180px;' ><input type='button' style='width:100px;height:100px;background-color:#0066cc' value='save' onclick='checkBoxValue()'></div>";
+echo "<table class='table_top'>";
+echo "<tr>";
+echo "<td colspan='2'>";
+echo "<a href='".$wms_getcapabilities[0];
+echo wms::getConjunctionCharacter($wms_getcapabilities[0]);
+if ($wms_version[0] == "1.0.0") {
+ echo "WMTVER=". $wms_version[0]."&REQUEST=capabilities";
+else {
+ echo "VERSION=". $wms_version[0]."&REQUEST=GetCapabilities&SERVICE=WMS";
+echo "' style='font-size:14px' target='_blank'>LINK: Capabilities</a>";
+echo "</td>";
+echo "<td align = right>WMS ID: " . $wms_id[0] . "</td>";
+echo "<tr>";
+#epsg
+if($gui_wms_position[0] == 0){
+ echo "<tr>";
+ echo "<td>EPSG: </td><td>";
+ echo "<select class='mySelect' name='this_gui_wms_epsg'>";
+ for($i=0; $i<count($epsg); $i++){
+ echo "<option value='".$epsg[$i]."' ";
+ if($epsg[$i] == $gui_wms_epsg[0]){ echo "selected";}
+ echo ">".$epsg[$i]."</option>";
+ echo "</select>";
+ echo "</td>";
+ echo "</tr>";
+#format
+echo "<tr>";
+ echo "<td>Mapformat: </td><td>";
+ echo "<select class='mySelect' name='this_gui_wms_mapformat'>";
+ for($i=0; $i<count($data_format); $i++){
+ if($data_type[$i] == 'map'){
+ echo "<option value='".$data_format[$i]."' ";
+ if($data_format[$i] == $gui_wms_mapformat[0]){ echo "selected";}
+ echo ">".$data_format[$i]."</option>";
+ echo "</select>";
+ echo "</td>";
+echo "</tr>";
+echo "<tr>";
+ echo "<td>Infoformat: </td><td>";
+ echo "<select class='mySelect' name='this_gui_wms_featureinfoformat'>";
+ echo "<option value='text/html'>text/html</option>";
+ if($data_type[$i] == 'featureinfo'){
+ if($data_format[$i] == $gui_wms_featureinfoformat[0]){ echo "selected";}
+ echo "</select>";
+ echo "</td>";
+echo "</tr>";
+echo "<tr>";
+ echo "<td>Exceptionformat: </td><td>";
+ echo "<select class='mySelect' name='this_gui_wms_exceptionformat'>";
+ if($data_type[$i] == 'exception'){
+ if($data_format[$i] == $gui_wms_exceptionformat[0]){ echo "selected";}
+ echo "</select>";
+ echo "</td>";
+echo "</tr><br>";
+# visibility
+echo "<tr>";
+ echo "<td>Visibility: </td><td>";
+ echo "<select class='mySelect' name='this_gui_wms_visible'>";
+ for($i=0; $i<3; $i++){
+ echo "<option value='".$i."' ";
+ if($i == $gui_wms_visible[0]){ echo "selected";}
+ echo ">";
+ if($i == '0'){
+ echo "hidden";
+ if($i == '1'){
+ echo "visible";
+ echo "</option>";
+ echo "</select>";
+ echo "</td>";
+echo "</tr>";
+# opacity
+echo "<tr>";
+ echo "<td>Opacity: </td><td>";
+ echo "<select class='mySelect' name='this_gui_wms_opacity'>";
+ for($i=0; $i<=100; $i+=10){
+ if($i - $gui_wms_opacity[0]<=5&&$i - $gui_wms_opacity[0]>=-4){ echo "selected";}
+ echo ">";
+ echo $i."%";
+ echo "</option>";
+ echo "</select>";
+ echo "</td>";
+echo "</tr>";
+# sld support
+if($wms_supportsld[0]) {
+ echo "<tr>";
+ echo "<td>SLD-URL: </td><td>";
+ echo "<input type='text' class='myText' name='this_gui_wms_sldurl' id='this_gui_wms_sldurl' title='".$gui_wms_sldurl[0]."' value='".$gui_wms_sldurl[0]."'>";
+ #echo "<a href='' onclick='return window.open(\"editor-start.php\");'><img src='sld_editor.png' border=0></a>";
+ #$layer_names = implode(",", $layer_name);
+ echo " <a href='javascript:showSld(\"".$gui_wms_sldurl[0]."\");'>SLD laden/anzeigen</a>";
+ echo "</td>";
+ echo "</tr>";
+} else {
+ echo "<input type='hidden' value='' name='this_gui_wms_sldurl'>";
+echo "</table><br>";
+echo "<table border='1' cellpadding='1'>";
+ echo "<tr>";
+ echo "<td>Nr.</td>";
+ echo "<td>ID</td>";
+ echo "<td>" . toImage('Parent') . "</td>";
+ echo "<td>Name</td>";
+ echo "<td>Title</td>";
+ echo "<td>" . toImage('on/off') . "</td>";
+ echo "<td>" . toImage('sel') . "</td>";
+ echo "<td>" . toImage('sel_default') . "</td>";
+ echo "<td>" . toImage('info') . "</td>";
+ echo "<td>" . toImage('info_default') . "</td>";
+ echo "<td>" . toImage('minScale 1:') . "</td>";
+ echo "<td>" . toImage('maxScale 1:') . "</td>";
+ echo "<td>" . toImage('Style') . "</td>";
+ echo "<td>" . toImage('Prio') . "</td>";
+ echo "<td>" . toImage('setWFS') . "</td>";
+ if($wms_supportsld[0]) {echo "<td>" . toImage('SLD') . "</td>";}
+ echo "</tr>";
+#echo "<tr><td>Nr.</td><td>ID</td><td>Parent</td><td>Name</td><td>Title</td><td>on/off</td><td>sel</td><td>sel_default</td><td>info</td><td>info_default</td><td>minScale 1:</td><td>maxScale 1:</td><td>Prio</td><td>setWFS</td></tr>";
+echo "<tr><td></td><td></td><td></td><td></td><td></td><td>";
+echo "<input type='button' class='LButton' value='Sublayer\noff' onclick='setSubs()'>";
+echo "</td><td></td><td>";
+echo "<nobr><input type='button' class='button_on_off' value='off' onclick='setLayer(\"visible\",false)'> ";
+echo "<input type='button' class='button_on_off' value='on' onclick='setLayer(\"visible\",true)'></nobr>";
+echo"</td><td></td><td>";
+echo "<nobr><input type='button' class='button_on_off' value='off' onclick='setLayer(\"querylayer\",false)'> ";
+echo "<input type='button' class='button_on_off' value='on' onclick='setLayer(\"querylayer\",true)'></nobr>";
+echo "</td><td></td><td></td><td></td></tr>";
+for($i=0; $i<count($layer_id); $i++){
+#layer_styles
+$sql_styles = "SELECT * FROM layer_style WHERE fkey_layer_id = $1";
+$v = array($layer_id[$i]);
+$t = array('i');
+$res_styles = db_prep_query($sql_styles,$v,$t);
+$cnt_styles= 0;
+$style = array();
+while($row = db_fetch_array($res_styles)){
+ $style[$cnt_styles] = $row["name"];
+ $cnt_styles++;
+ echo "<tr align='center'>";
+ echo "<td><input type='text' size='1' name='L_".$layer_id[$i]."___layer_nr' disabled value='".$i."'></td>";
+ echo "<td style='background:lightgrey'><input type='text' size='2' name='L_".$layer_id[$i]."___layer_id' value='".$layer_id[$i]."' readonly></td>";
+ echo "<td><input type='text' size='1' name='L_".$layer_id[$i]."___layer_parent' value='".$layer_parent[$i]."' readonly></td>";
+ echo "<td style='background:lightgrey'><input type='text' size='7' value='".$layer_name[$i]."' readonly></td>";
+ echo "<td><input type='text' name='".$layer_title[$i]."' size='12' value='".$layer_title[$i]."' ></td>";
+ echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_status' type='checkbox' ";
+ if($gui_layer_status[$i] == 1){ echo "checked";}
+ echo "></td>";
+ echo "<td><input name='L_".$layer_id[$i]."___gui_layer_selectable' type='checkbox' ";
+ if($gui_layer_selectable[$i] == 1){ echo "checked";}
+ echo "></td>";
+ echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_visible' type='checkbox' ";
+ if($gui_layer_visible[$i] == 1){ echo "checked";}
+ echo "></td>";
+ echo "<td><input name='L_".$layer_id[$i]."___gui_layer_queryable' type='checkbox' ";
+ if($gui_layer_queryable[$i] == 1){ echo "checked";}
+ if($layer_queryable[$i] == 0){ echo "disabled";}
+ echo "></td>";
+ echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_querylayer' type='checkbox' ";
+ if($gui_layer_querylayer[$i] == 1){ echo "checked";}
+ echo "></td>";
+ echo "<td><input name='L_".$layer_id[$i]."___gui_layer_minscale' type='text' size='5' value='".$gui_layer_minscale[$i]."'></td>";
+ echo "<td style='background:lightgrey'><input name='L_".$layer_id[$i]."___gui_layer_maxscale' type='text' size='5' value='".$gui_layer_maxscale[$i]."'></td>";
+ echo "<td>\n";
+ echo "<select class='select_short' name='L_".$layer_id[$i]."___gui_layer_style'>\n";
+ echo "<option value=''";
+ if(count($style) ==0){ echo "selected";}
+ echo ">---</option>\n";
+ for($j=0;$j<count($style); $j++){
+ echo "<option value='".$style[$j]."'";
+ if($style[$j] == $gui_layer_style[$i]){ echo "selected";}
+ echo ">".$style[$j]."</option>\n";
+ echo "</select></td>\n";
+ echo "<td><select class='select_short' name='L_".$layer_id[$i]."___gui_layer_priority'>";
+ for($j=0; $j<count($gui_layer_priority); $j++){
+ echo "<option value='".$j."'";
+ if($j == $gui_layer_priority[$i]){echo "selected";}
+ echo ">".$j;
+ echo "</option>";
+ /* wfs configuration */
+ echo "<td>";
+ if ($i > 0) {
+ echo "<input class='button_wfs'name='gui_layer_gaz' type='button' onclick='edit_gaz(\"".$guiList."\",".$wmsList.",".$layer_id[$i].")' value='";
+ if($gui_layer_wfs_featuretype[$i] == ""){
+ echo "setWFS";
+ else{
+ echo "wfs ".$gui_layer_wfs_featuretype[$i];
+ echo "'>";
+ echo "</td>";
+ echo "<td>";
+ if ($i > 0) {
+ echo "<input class='button3' name='gui_layer_sld' type='button' onclick='window.open(\"../sld/sld_main.php?".$urlParameters."&sld_gui_id=".$guiList."&sld_wms_id=".$wms_id[0]."&sld_layer_name=".$layer_name[$i]."\");' value='";
+ if ($sld_user_layer_id[$i] != "")
+ echo "sld:".$sld_user_layer_id[$i]."(".$use_sld[$i].")";
+ else
+ echo "SLD";
+ echo "'>";
+ echo "</td>";
+ echo "</tr>\n";
+ if($i == 0){ echo "<tr><td colspan='16'><hr></td></tr>";}
+echo "</table>\n";
+echo "<input type='hidden' name='this_gui' value='".$guiList."'>\n";
+echo "<input type='hidden' name='this_wms' value='".$wmsList."'>\n";
+echo "<input type='hidden' name='this_layer_count' value='".$cnt_l."'>\n";
+echo "<input type='hidden' name='update_content' value=''>\n";
+echo "</form>\n";
+</body>
+</html>
Modified: branches/2.6/http/php/mod_editWMS_Metadata.php
--- branches/2.6/http/php/mod_editWMS_Metadata.php 2010-07-19 15:18:12 UTC (rev 6606)
+++ branches/2.6/http/php/mod_editWMS_Metadata.php 2010-07-22 08:14:33 UTC (rev 6607)
@@ -17,7 +17,7 @@
-$e_id="EditWMSMetadata";
+$e_id="EditWMSMetadata";
require_once(dirname(__FILE__)."/mb_validatePermission.php");
@@ -350,7 +350,7 @@
<input type='text' name='wms_title_box' value='<?php echo $selected_row["wms_title"];?>' /><td/>
<td>WMS- Abstract:<td><td/>
- <input type='text' name='wms_abstract_box' value='<?php echo $selected_row["wms_abstract"];?>' /><td/>
+ <input type='text' name='wms_abstract_box' value='<?php echo htmlentities($selected_row["wms_abstract"],ENT_QUOTES,"UTF-8");?>' /><td/>
<td >Fees:<td><td/>
<input type='text' name='fees_box' value='<?php echo $selected_row["fees"]?>'/><td/>
@@ -432,7 +432,7 @@
<td><input type='text' size='15' name='L_<?php echo $layer_row['layer_id']?>___layer_title'
value='<?php echo $layer_row['layer_title']?>' readonly></td>
<td><input type='text' size='42' name='L_<?php echo $layer_row['layer_id']?>___layer_abstract'
- value='<?php echo $layer_row['layer_abstract']?>'>
+ value='<?php echo htmlentities($layer_row['layer_abstract'],ENT_QUOTES,"UTF-8")?>'>
<?php
$keyword_sql = "SELECT keyword FROM keyword, layer_keyword, layer " .
@@ -495,4 +495,4 @@
</html>
<?php
\ No newline at end of file
Modified: branches/2.6/http/php/mod_loadCapabilitiesList.php
--- branches/2.6/http/php/mod_loadCapabilitiesList.php 2010-07-19 15:18:12 UTC (rev 6606)
+++ branches/2.6/http/php/mod_loadCapabilitiesList.php 2010-07-22 08:14:33 UTC (rev 6607)
@@ -1,308 +1,308 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/Administration
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/Administration
$e_id="loadWMSList";
-require(dirname(__FILE__)."/../php/mb_validatePermission.php");
-<html>
-<head>
-<?php
-<title>Load WMS from Catalog</title>
-<?php
-include '../include/dyn_css.php';
-<style type="text/css">
- body{
- background-color: #ffffff;
- font-family: Arial, Helvetica, sans-serif;
- font-size : 12px;
- color: #808080
- .list_guis{
- font-size : 12px;
- color: #808080;
-.text1{
- font-size : 15px;
- position:absolute;
- top:190px;
-.select1{
- top:210px;
- width:270px;
-.text2{
- font-size : 15px;
- top:190px;
- left:300px;
-.select2{
- top:210px;
- left:300px;
-.getcapabilities{
- font-size : 15px;
- top:570px;
-</style>
- if(wert == 'guiList'){
- var listIndex = document.form1.guiList.selectedIndex;
- if(listIndex<0){
- alert("Please select a GUI.");
- return false;
- else{
- var gui_id=document.form1.guiList.options[listIndex].value;
- document.form1.action='../php/mod_loadwms.php<?php echo SID;?>';
-function load(){
- if(document.form1.guiList.selectedIndex<0){
- return false;
- var gui_ind = document.form1.guiList.selectedIndex;
- var ind = document.form1.wmsID.selectedIndex;
- var ind2 = document.form1.guiID_.selectedIndex;
- var indexWMSList = document.form1.wmsID.selectedIndex;
- var permission = true;
- var selectedWmsId = document.form1.wmsID.options[document.form1.wmsID.selectedIndex].value;
- for (i = 0; i < document.form1.wmsList.length; i++) {
- if (document.form1.wmsList.options[i].value == selectedWmsId){
- permission = false;
- alert ('The WMS (' + selectedWmsId + ') is already loaded in this application.');
- break;
- if (permission) { // only check if permission is not false
- var loadConfirmed = confirm("Load " + document.form1.wmsID.options[ind].text + " FROM " + document.form1.guiID_.options[ind2].value + " INTO "+document.form1.guiList.options[gui_ind].value+" ?");
- if(loadConfirmed){
- else{
- document.form1.guiID_.selectedIndex = -1;
-</script>
-</head>
-<body>
-<?php
-###INSERT
-if(isset($wmsID) && isset($guiID_)){
- $sql_pos = "SELECT MAX(gui_wms_position) AS my_gui_wms_position FROM gui_wms WHERE fkey_gui_id = $1";
- $t = array('s');
- $res_pos = db_prep_query($sql_pos,$v,$t);
- if(db_result($res_pos,0,"my_gui_wms_position") > -1){
- $gui_wms_position = db_result($res_pos,0,"my_gui_wms_position") + 1;
- else{
- $gui_wms_position = 0;
- $sql = "SELECT * FROM gui_wms WHERE fkey_gui_id = $1 AND fkey_wms_id = $2";
- $v = array($guiID_,$wmsID);
- $cnt = 0;
- $sql_ins = "INSERT INTO gui_wms (fkey_gui_id,fkey_wms_id,gui_wms_position,gui_wms_mapformat,";
- $sql_ins .= "gui_wms_featureinfoformat,gui_wms_exceptionformat,gui_wms_epsg,gui_wms_visible,gui_wms_opacity,gui_wms_sldurl) ";
- $sql_ins .= "VALUES ($1,$2,$3,$4,$5,$6,$7,$8,$9,$10)";
- $v = array($guiList,$wmsID,$gui_wms_position,$row["gui_wms_mapformat"],$row["gui_wms_featureinfoformat"],
- $row["gui_wms_exceptionformat"],$row["gui_wms_epsg"],$row["gui_wms_visible"],$row["gui_wms_opacity"],$row["gui_wms_sldurl"]);
- $t = array('s','i','i','s','s','s','s','i','i','s');
- db_prep_query($sql_ins,$v,$t);
- $cnt++;
- $sql = "SELECT * FROM gui_layer WHERE fkey_gui_id = $1 AND gui_layer_wms_id = $2";
- $v = array($guiID_, $wmsID);
- $t = array("s", "i");
- $res = db_prep_query($sql, $v, $t);
- $cnt = 0;
- $sql_ins = "INSERT INTO gui_layer (fkey_gui_id,fkey_layer_id,gui_layer_wms_id,gui_layer_status,gui_layer_selectable,";
- $sql_ins .= "gui_layer_visible,gui_layer_queryable,gui_layer_querylayer,gui_layer_minscale,gui_layer_maxscale,gui_layer_priority,gui_layer_style,gui_layer_wfs_featuretype) ";
- $sql_ins .= "VALUES ($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13)";
- $v = array($guiList,$row["fkey_layer_id"],$wmsID,$row["gui_layer_status"],$row["gui_layer_selectable"],
- $row["gui_layer_visible"],$row["gui_layer_queryable"],$row["gui_layer_querylayer"],$row["gui_layer_minscale"],
- $row["gui_layer_maxscale"],$row["gui_layer_priority"],$row["gui_layer_style"],$row["gui_layer_wfs_featuretype"]);
- $t = array('s','i','i','i','i','i','i','i','i','i','i','s','s');
- $cnt++;
-echo "<form name='form1' action='" . $self."' method='post'>";
-echo "<table cellpadding='0' cellspacing='0' border='0'>";
-echo "<tr>";
-echo "<td>";
- echo"GUI";
- echo"<br>";
- $sql = "SELECT * FROM gui WHERE gui_id IN (";
- $v = $ownguis;
- $t = array();
- for ($i = 1; $i <= count($ownguis); $i++){
- if ($i > 1) {
- $sql .= ",";
- $sql .= "$".$i;
- array_push($t, "s");
- $sql .= ") ORDER BY gui_name";
- $count=0;
- echo"<select size='8' name='guiList' style='width:200px' onClick='submit()'>";
- $gui_name[$count]=$row["gui_name"];
- $gui_description[$count]=$row["gui_description"];
- $count++;
- echo "<option value='".$row["gui_id"]."' ";
- if($guiList && $guiList == $row["gui_name"]){
- echo "selected";
- echo ">".$row["gui_name"]."</option>";
- $arrayGUIs=$_SESSION["mb_user_guis"];
- echo count($arrayGUIs);
- echo "</select><br><br>";
- echo "</td>";
- echo "<td>";
- echo"WMS";
- echo"<br>";
- if(isset($guiList) && $guiList!=""){
- $sql = "SELECT DISTINCT wms_id, wms.wms_abstract, wms.wms_title, gui_wms_position FROM gui_wms ";
- $sql .= "JOIN gui ON gui_wms.fkey_gui_id = gui.gui_id JOIN wms ON gui_wms.fkey_wms_id=wms.wms_id ";
- $sql .= "AND gui_wms.fkey_gui_id=gui.gui_id WHERE gui.gui_name = $1 ORDER BY gui_wms_position";
- $t = array('s');
- $count=0;
- echo"<select size='8' name='wmsList' style='width:200px'>";
- if ($row["wms_title"]!=""){
- echo ">".$row["wms_title"]."</option>";
- $count++;
- }else{
- echo"<select size='8' name='wmsList' style='width:200px' on Click='submit()'>";
- echo "</td>";
- echo "<tr></table><br>";
- echo"<div class='text1'>Load WMS</div>";
- $sql = "SELECT DISTINCT wms.wms_id,wms.wms_title,wms.wms_abstract,wms.wms_owner FROM gui_wms JOIN wms ON ";
- $sql .= "wms.wms_id = gui_wms.fkey_wms_id WHERE gui_wms.fkey_gui_id IN(";
- $v = $arrayGUIs;
- $t = array();
- for ($i = 1; $i <= count($arrayGUIs); $i++){
- if ($i > 1) {
- $sql .= ",";
- $sql .= "$" . $i;
- $sql .= ") ORDER BY wms.wms_title";
- echo "<select class='select1' name='wmsID' size='20' onchange='submit()'>";
- $cnt = 0;
- if($row["wms_owner"] == $_SESSION["mb_user_id"]){
- echo "style='color:green' ";
- else{
- echo "style='color:red' ";
- if(isset($wmsID) && $wmsID == $row["wms_id"]){
- echo "selected";
- $wms_getcapabilities = $row["wms_getcapabilities"];
- $cnt++;
- echo "</select>";
- if(isset($wmsID)){
- echo "<div class='text2'>FROM:</div>";
- $sql = "SELECT * from gui_wms WHERE fkey_wms_id = $1 ORDER BY fkey_gui_id";
- $v = array($wmsID);
- $t = array("s");
- echo "<select class='select2' name='guiID_' size='20' onchange='load()'>";
- $cnt = 0;
- echo "<option value='".$row["fkey_gui_id"]."' ";
- echo ">".$row["fkey_gui_id"]."</option>";
- $cnt++;
- echo "</select>";
-echo "</form>";
-}else{
- echo "There are no guis available for this user. Please create a gui first.";
-echo "<div class='getcapabilities'>" . $wms_getcapabilities . "</div>";
-</body>
-</html>
+require(dirname(__FILE__)."/../php/mb_validatePermission.php");
+<html>
+<head>
+<?php
+<title>Load WMS from Catalog</title>
+<?php
+include '../include/dyn_css.php';
+<style type="text/css">
+ body{
+ background-color: #ffffff;
+ font-family: Arial, Helvetica, sans-serif;
+ font-size : 12px;
+ color: #808080
+ .list_guis{
+ font-size : 12px;
+ color: #808080;
+.text1{
+ font-size : 15px;
+ position:absolute;
+ top:190px;
+.select1{
+ top:210px;
+ width:270px;
+.text2{
+ font-size : 15px;
+ top:190px;
+ left:300px;
+.select2{
+ top:210px;
+ left:300px;
+.getcapabilities{
+ font-size : 15px;
+ top:570px;
+</style>
+ if(wert == 'guiList'){
+ var listIndex = document.form1.guiList.selectedIndex;
+ if(listIndex<0){
+ alert("Please select a GUI.");
+ return false;
+ else{
+ var gui_id=document.form1.guiList.options[listIndex].value;
+ document.form1.action='../php/mod_loadwms.php<?php echo SID;?>';
+function load(){
+ if(document.form1.guiList.selectedIndex<0){
+ return false;
+ var gui_ind = document.form1.guiList.selectedIndex;
+ var ind = document.form1.wmsID.selectedIndex;
+ var ind2 = document.form1.guiID_.selectedIndex;
+ var indexWMSList = document.form1.wmsID.selectedIndex;
+ var permission = true;
+ var selectedWmsId = document.form1.wmsID.options[document.form1.wmsID.selectedIndex].value;
+ for (i = 0; i < document.form1.wmsList.length; i++) {
+ if (document.form1.wmsList.options[i].value == selectedWmsId){
+ permission = false;
+ alert ('The WMS (' + selectedWmsId + ') is already loaded in this application.');
+ break;
+ if (permission) { // only check if permission is not false
+ var loadConfirmed = confirm("Load " + document.form1.wmsID.options[ind].text + " FROM " + document.form1.guiID_.options[ind2].value + " INTO "+document.form1.guiList.options[gui_ind].value+" ?");
+ if(loadConfirmed){
+ else{
+ document.form1.guiID_.selectedIndex = -1;
+</script>
+</head>
+<body>
+<?php
+###INSERT
+if(isset($wmsID) && isset($guiID_)){
+ $sql_pos = "SELECT MAX(gui_wms_position) AS my_gui_wms_position FROM gui_wms WHERE fkey_gui_id = $1";
+ $t = array('s');
+ $res_pos = db_prep_query($sql_pos,$v,$t);
+ if(db_result($res_pos,0,"my_gui_wms_position") > -1){
+ $gui_wms_position = db_result($res_pos,0,"my_gui_wms_position") + 1;
+ else{
+ $gui_wms_position = 0;
+ $sql = "SELECT * FROM gui_wms WHERE fkey_gui_id = $1 AND fkey_wms_id = $2";
+ $v = array($guiID_,$wmsID);
+ $cnt = 0;
+ $sql_ins = "INSERT INTO gui_wms (fkey_gui_id,fkey_wms_id,gui_wms_position,gui_wms_mapformat,";
+ $sql_ins .= "gui_wms_featureinfoformat,gui_wms_exceptionformat,gui_wms_epsg,gui_wms_visible,gui_wms_opacity,gui_wms_sldurl) ";
+ $sql_ins .= "VALUES ($1,$2,$3,$4,$5,$6,$7,$8,$9,$10)";
+ $v = array($guiList,$wmsID,$gui_wms_position,$row["gui_wms_mapformat"],$row["gui_wms_featureinfoformat"],
+ $row["gui_wms_exceptionformat"],$row["gui_wms_epsg"],$row["gui_wms_visible"],$row["gui_wms_opacity"],$row["gui_wms_sldurl"]);
+ $t = array('s','i','i','s','s','s','s','i','i','s');
+ db_prep_query($sql_ins,$v,$t);
+ $cnt++;
+ $sql = "SELECT * FROM gui_layer WHERE fkey_gui_id = $1 AND gui_layer_wms_id = $2";
+ $v = array($guiID_, $wmsID);
+ $t = array("s", "i");
+ $res = db_prep_query($sql, $v, $t);
+ $cnt = 0;
+ $sql_ins = "INSERT INTO gui_layer (fkey_gui_id,fkey_layer_id,gui_layer_wms_id,gui_layer_status,gui_layer_selectable,";
+ $sql_ins .= "gui_layer_visible,gui_layer_queryable,gui_layer_querylayer,gui_layer_minscale,gui_layer_maxscale,gui_layer_priority,gui_layer_style,gui_layer_wfs_featuretype) ";
+ $sql_ins .= "VALUES ($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13)";
+ $v = array($guiList,$row["fkey_layer_id"],$wmsID,$row["gui_layer_status"],$row["gui_layer_selectable"],
+ $row["gui_layer_visible"],$row["gui_layer_queryable"],$row["gui_layer_querylayer"],$row["gui_layer_minscale"],
+ $row["gui_layer_maxscale"],$row["gui_layer_priority"],$row["gui_layer_style"],$row["gui_layer_wfs_featuretype"]);
+ $t = array('s','i','i','i','i','i','i','i','i','i','i','s','s');
+ $cnt++;
+echo "<form name='form1' action='" . $self."' method='post'>";
+echo "<table cellpadding='0' cellspacing='0' border='0'>";
+echo "<tr>";
+echo "<td>";
+ echo"GUI";
+ echo"<br>";
+ $sql = "SELECT * FROM gui WHERE gui_id IN (";
+ $v = $ownguis;
+ $t = array();
+ for ($i = 1; $i <= count($ownguis); $i++){
+ if ($i > 1) {
+ $sql .= ",";
+ $sql .= "$".$i;
+ array_push($t, "s");
+ $sql .= ") ORDER BY gui_name";
+ $count=0;
+ echo"<select size='8' name='guiList' style='width:200px' onClick='submit()'>";
+ $gui_name[$count]=$row["gui_name"];
+ $gui_description[$count]=$row["gui_description"];
+ $count++;
+ echo "<option value='".$row["gui_id"]."' ";
+ if($guiList && $guiList == $row["gui_name"]){
+ echo "selected";
+ echo ">".$row["gui_name"]."</option>";
+ $arrayGUIs=$_SESSION["mb_user_guis"];
+ echo count($arrayGUIs);
+ echo "</select><br><br>";
+ echo "</td>";
+ echo "<td>";
+ echo"WMS";
+ echo"<br>";
+ if(isset($guiList) && $guiList!=""){
+ $sql = "SELECT DISTINCT wms_id, wms.wms_abstract, wms.wms_title, gui_wms_position FROM gui_wms ";
+ $sql .= "JOIN gui ON gui_wms.fkey_gui_id = gui.gui_id JOIN wms ON gui_wms.fkey_wms_id=wms.wms_id ";
+ $sql .= "AND gui_wms.fkey_gui_id=gui.gui_id WHERE gui.gui_name = $1 ORDER BY gui_wms_position";
+ $t = array('s');
+ $count=0;
+ echo"<select size='8' name='wmsList' style='width:200px'>";
+ if ($row["wms_title"]!=""){
+ echo ">".$row["wms_title"]."</option>";
+ $count++;
+ }else{
+ echo"<select size='8' name='wmsList' style='width:200px' on Click='submit()'>";
+ echo "</td>";
+ echo "<tr></table><br>";
+ echo"<div class='text1'>Load WMS</div>";
+ $sql = "SELECT DISTINCT wms.wms_id,wms.wms_title,wms.wms_abstract,wms.wms_owner FROM gui_wms JOIN wms ON ";
+ $sql .= "wms.wms_id = gui_wms.fkey_wms_id WHERE gui_wms.fkey_gui_id IN(";
+ $v = $arrayGUIs;
+ $t = array();
+ for ($i = 1; $i <= count($arrayGUIs); $i++){
+ if ($i > 1) {
+ $sql .= ",";
+ $sql .= "$" . $i;
+ $sql .= ") ORDER BY wms.wms_title";
+ echo "<select class='select1' name='wmsID' size='20' onchange='submit()'>";
+ $cnt = 0;
+ if($row["wms_owner"] == $_SESSION["mb_user_id"]){
+ echo "style='color:green' ";
+ else{
+ echo "style='color:red' ";
+ if(isset($wmsID) && $wmsID == $row["wms_id"]){
+ echo "selected";
+ $wms_getcapabilities = $row["wms_getcapabilities"];
+ $cnt++;
+ echo "</select>";
+ if(isset($wmsID)){
+ echo "<div class='text2'>FROM:</div>";
+ $sql = "SELECT * from gui_wms WHERE fkey_wms_id = $1 ORDER BY fkey_gui_id";
+ $v = array($wmsID);
+ $t = array("s");
+ echo "<select class='select2' name='guiID_' size='20' onchange='load()'>";
+ $cnt = 0;
+ echo "<option value='".$row["fkey_gui_id"]."' ";
+ echo ">".$row["fkey_gui_id"]."</option>";
+ $cnt++;
+ echo "</select>";
+echo "</form>";
+}else{
+ echo "There are no guis available for this user. Please create a gui first.";
+echo "<div class='getcapabilities'>" . $wms_getcapabilities . "</div>";
+</body>
+</html>
More information about the Mapbender_commits
