[Mapbender-commits] r6615 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Thu Jul 22 10:53:28 EDT 2010
Author: verenadiewald
Date: 2010-07-22 14:53:28 +0000 (Thu, 22 Jul 2010)
New Revision: 6615
trunk/mapbender/http/javascripts/map_obj.js
new functions setCrs, transformExtent, some changes for new get api in functions zoom and setSrs
Modified: trunk/mapbender/http/javascripts/map_obj.js
--- trunk/mapbender/http/javascripts/map_obj.js 2010-07-22 14:51:34 UTC (rev 6614)
+++ trunk/mapbender/http/javascripts/map_obj.js 2010-07-22 14:53:28 UTC (rev 6615)
@@ -288,7 +288,7 @@
* converts the extent of the mapobject so that the maximum extent will be displayed
this.calculateExtent = function(ext){
- var relation_px_x = this.getWidth() / this.getHeight();
+ var relation_px_x = this.getWidth() / this.getHeight();
var relation_px_y = this.getHeight() / this.getWidth();
var relation_bbox_x = ext.extentx / ext.extenty;
var oldMin = ext.getSouthWest();
@@ -366,8 +366,75 @@
return ignoredWms;
+ this.transformExtent = function (options) {
+ if (typeof options !== 'object') {
+ return false;
+ if (this.epsg !== options.crs) {
+ var source = new Proj4js.Proj(options.crs);
+ var dest = new Proj4js.Proj(this.epsg);
+ var intervalId = setInterval(function() {
+ if(source.readyToUse && dest.readyToUse) {
+ clearInterval(intervalId);
+ var o = {
+ source : source,
+ dest : dest,
+ extent : options.extent
+ that.extent.setCrs(o);
+ that.calculateExtent(that.extent);
+ that.setMapRequest();
+ }, 200);
+ this.setCrs = function (options) {
+ return false;
+ var source = new Proj4js.Proj(this.epsg);
+ var dest = new Proj4js.Proj(options.crs);
+ var o = {
+ source : source,
+ dest : dest
+ setCrsMap(o);
+ setCrsWms(o);
+ checkSupportedWms({
+ srs : options.crs
+ that.epsg = options.crs;
+ srsHasChanged = true;
+ options.callback();
+ }, 200);
+ var setCrsMap = function (options) {
+ that.extent.setCrs(options);
+ var setCrsWms = function (options) {
+ for (j = 0; j < that.wms.length; j++) {
+ that.wms[j].setCrs(options);
this.setSrs = function(options){
- if (typeof options.srs !== "string") {
+ if (typeof options.srs !== "string") {
new Mb_exception("Mapbender.Map.setSrs: SRS is not a string: " + options.srs);
return null;
@@ -376,50 +443,59 @@
return null;
if (this.epsg !== options.srs) {
- // check which WMS support the new SRS
- undoIgnoreWms();
- for (var i = 0; i < this.wms.length; i++) {
- var found = false;
- for (var j = 0; j < this.wms[i].gui_epsg.length; j++) {
- if (options.srs === this.wms[i].gui_epsg[j] && this.wms[i].gui_epsg_supported[j]) {
- found = true;
- break;
+ // actually set the new values and return extent
+ checkSupportedWms(options);
+ this.epsg = options.srs;
+ return this.calculateExtent(options.extent);
+ return this.extent;
+ var checkSupportedWms = function (o) {
+ var defaultOptions = {
+ displayWarning : false,
+ srs : null
+ var options = $.extend(defaultOptions, o);
+ // check which WMS support the new SRS
+ undoIgnoreWms();
+ for (var i = 0; i < that.wms.length; i++) {
+ var found = false;
+ for (var j = 0; j < that.wms[i].gui_epsg.length; j++) {
+ if (options.srs === that.wms[i].gui_epsg[j] && that.wms[i].gui_epsg_supported[j]) {
+ found = true;
+ break;
- if (!found) {
- ignoreWms(this.wms[i]);
- var ignoredWms = getIgnoredWms();
+ if (!found) {
+ ignoreWms(that.wms[i]);
+ var ignoredWms = getIgnoredWms();
+ // ...and optionally display a message
+ if (options.displayWarning && ignoredWms.length > 0) {
+ var msg = mapMsgObj.srsNotSupported + ": <br><br>";
- // ...and optionally display a message
- if (options.displayWarning && ignoredWms.length > 0) {
- var msg = mapMsgObj.srsNotSupported + ": <br><br>";
- for (var key in ignoredWms) {
- msg += "<b>" + ignoredWms[key].title + "</b><br>";
- try {
- Mapbender.modules.dialogManager.openDialog({
- content: msg,
- modal: false,
- effectShow: 'puff'
- catch (e) {
- new Mb_warning(e.message + ". " + msg);
+ for (var key in ignoredWms) {
+ msg += "<b>" + ignoredWms[key].title + "</b><br>";
- // actually set the new values and return extent
- this.epsg = options.srs;
+ try {
+ Mapbender.modules.dialogManager.openDialog({
+ content: msg,
+ modal: false,
+ effectShow: 'puff'
+ catch (e) {
+ new Mb_warning(e.message + ". " + msg);
- srsHasChanged = true;
- return this.calculateExtent(options.extent);
this.setWms = function(wms_index){
this.wms = [];
var index = 0;
@@ -706,10 +782,21 @@
* @param {float} x center to x-position
* @param {float} y center to y-position
- this.zoom = function(in_, factor, x, y){
- this.setExtent(this.calculateExtentAfterZoom(in_, factor, x, y));
- this.setMapRequest();
+ this.zoom = function(in_, factor, x, y, crs){
+ if (crs) {
+ if (this.epsg !== crs) {
+ var zoomPoint = new Mapbender.Point(x, y);
+ var newPoint = zoomPoint.transform(crs, this.epsg, function (p) {
+ that.setExtent(that.calculateExtentAfterZoom(in_, factor, p.x, p.y));
+ else {
+ this.setExtent(this.calculateExtentAfterZoom(in_, factor, x, y));
+ this.setMapRequest();
this.convertPixelToReal = function(aPoint, referenceExtent){
var arrayBBox;
More information about the Mapbender_commits
