[Mapbender-commits] r6618 - branches/2.6/resources/db
svn_mapbender at osgeo.org
Fri Jul 23 05:25:29 EDT 2010
Author: christoph
Date: 2010-07-23 09:25:29 +0000 (Fri, 23 Jul 2010)
New Revision: 6618
branches/2.6/resources/db/install_2.6.sh
latest updates for 2.6.2
* changelog, version number
* (hopefully) improved install.sh
Modified: branches/2.6/resources/db/install_2.6.sh
--- branches/2.6/resources/db/install_2.6.sh 2010-07-23 09:24:46 UTC (rev 6617)
+++ branches/2.6/resources/db/install_2.6.sh 2010-07-23 09:25:29 UTC (rev 6618)
@@ -6,7 +6,6 @@
function show_disclaimer() {
# Disclaimer
echo ""
- echo "DISCLAIMER: Mapbender database setup script. USE AT YOUR OWN RISK!"
echo "The script will create a database for you and will import the Mapbender data to the new database"
echo "It will also compile the Mapbender.mo files"
echo ""
@@ -16,7 +15,7 @@
# echo " * write access to mapbender/log"
# echo " * write access to mapbender/http/tmp"
# echo " * write access to mapbender/resources/locale/ and subdirectories"
- echo " * provide a database user that can create a database"
+ echo " * provide a database user that is a superuser"
echo ""
echo ""
echo "If everything is prepared you can continue."
@@ -123,30 +122,40 @@
echo ""
exit 1;
fi
- echo "Your password will be asked several times, this is normal (unless .pgpass is used)"
+ echo "Your password will be asked twice, this is normal (unless .pgpass is used)"
echo "creating database"
- createdb -U $DBUSER -h $DBHOST -p $DBPORT -E $DBENCODING $DBNAME -T $DBTEMPLATE
- echo "creating schema"
- psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/pgsql_schema_2.5.sql $DBNAME > log_schema.txt 2> err_schema.txt
- echo "loading data"
- psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/pgsql_data_2.5.sql $DBNAME > log_data.txt 2> err_data.txt
- echo "setting sequences"
- psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/pgsql_serial_set_sequences_2.5.sql $DBNAME > log_sequences.txt 2> err_squences.txt
- echo "update to 2.5.1rc1"
- psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.5_to_2.5.1rc1_pgsql_$DBENCODING.sql $DBNAME > log_update.txt 2> err_update.txt
- echo "update to 2.5.1"
- psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.5.1rc1_to_2.5.1_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
- echo "update to 2.6rc1"
- psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.5.1_to_2.6rc1_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
- echo "update to 2.6"
- psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.6rc1_to_2.6_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
- echo "update to 2.6.1"
- psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.6_to_2.6.1_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
- echo "update to 2.6.2"
- psql -U $DBUSER -h $DBHOST -p $DBPORT -f pgsql/$DBENCODING/update/update_2.6.1_to_2.6.2_pgsql_$DBENCODING.sql $DBNAME >> log_update.txt 2>> err_update.txt
+# createdb -U $DBUSER -h $DBHOST -p $DBPORT -E $DBENCODING $DBNAME -T $DBTEMPLATE
+ cat pgsql/pgsql_schema_2.5.sql pgsql/$DBENCODING/pgsql_data_2.5.sql pgsql/pgsql_serial_set_sequences_2.5.sql pgsql/$DBENCODING/update/update_2.5_to_2.5.1rc1_pgsql_$DBENCODING.sql pgsql/$DBENCODING/update/update_2.5.1rc1_to_2.5.1_pgsql_$DBENCODING.sql pgsql/$DBENCODING/update/update_2.5.1_to_2.6rc1_pgsql_$DBENCODING.sql pgsql/$DBENCODING/update/update_2.6rc1_to_2.6_pgsql_$DBENCODING.sql pgsql/$DBENCODING/update/update_2.6_to_2.6.1_pgsql_$DBENCODING.sql pgsql/$DBENCODING/update/update_2.6.1_to_2.6.2_pgsql_$DBENCODING.sql > 2.6.sql
+ echo "inserting data (this might take a few minutes)"
+# psql -U $DBUSER -h $DBHOST -p $DBPORT -f 2.6.sql $DBNAME > log_schema.txt 2> error.log
+ rm 2.6.sql
+ echo ""
+function update_mapbender_conf(){
+ # creating mapbender.conf
+ if [ -f ../../conf/mapbender.conf ]
+ then
+ echo "mapbender.conf already exists, not changed"
+ else
+ echo "Creating mapbender.conf..."
+ echo -n "Please enter the password for user $DBUSER: "
+ stty -echo
+ read password
+ stty echo
+ echo ""
+ sed -e "s/%%DBSERVER%%/$DBHOST/g" -e "s/%%DBPORT%%/$DBPORT/g" -e "s/%%DBNAME%%/$DBNAME/g" -e "s/%%DBOWNER%%/$DBUSER/g" -e "s/%%DBPASSWORD%%/$password/g" ../../conf/mapbender.conf-dist >../../conf/mapbender.conf
+ fi
+ echo ""
function set_permissions(){
echo "The installer can set the permissions to the files"
echo "and directory for you. If you want the installer to"
@@ -173,15 +182,6 @@
chmod -R o+rw ../locale
echo "setting execute rights on mapbender/tools/i18n_update_mo.sh"
chmod -R o+rx ../../tools/i18n_update_mo.sh
- # creating mapbender.conf
- if [ -f ../../conf/mapbender.conf ]
- then
- echo "mapbender.conf already exists, not changed"
- else
- cp ../../conf/mapbender.conf-dist ../../conf/mapbender.conf
- fi
- echo ""
- echo "please check and edit the entries in your mapbender.conf manually!"
fi
@@ -230,11 +230,10 @@
echo "Creating Mapbender administration database"
create_pgsql_db;
+update_mapbender_conf;
set_permissions;
compile_po;
-echo ""
echo "Finished...check the log and error files to see if an error occured.";
More information about the Mapbender_commits
