[Mapbender-commits] r6642 - trunk/mapbender/http/plugins
    svn_mapbender at osgeo.org
    Mon Jul 26 10:04:48 EDT 2010
Author: verenadiewald
Date: 2010-07-26 14:04:48 +0000 (Mon, 26 Jul 2010)
New Revision: 6642
Added:
   trunk/mapbender/http/plugins/mb_checkDigitizeDataDialog.js
new module to checkDigitizeData before saving
Added: trunk/mapbender/http/plugins/mb_checkDigitizeDataDialog.js
--- trunk/mapbender/http/plugins/mb_checkDigitizeDataDialog.js	                        (rev 0)
+++ trunk/mapbender/http/plugins/mb_checkDigitizeDataDialog.js	2010-07-26 14:04:48 UTC (rev 6642)
@@ -0,0 +1,120 @@
+ * Package: checkDigitizeDataDialog
+ * Description:
+ * Shows dialog for controlling inserted attribute data
+ * before saving new digitize object
+ * Files:
+ *  - http/plugins/mb_checkDigitizeDataDialog.js
+ * SQL:
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height,
+ * > e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod,
+ * > e_target, e_requires, e_url) VALUES('<app_id>','checkDigitizeDataDialog',3,1,
+ * > 'shows dialog before saving new digitize object','','div','','',NULL ,
+ * > NULL ,NULL ,NULL ,NULL ,'','','div','../plugins/mb_checkDigitizeDataDialog.js',
+ * > '','digitize','','');
+ * Help:
+ * http://www.mapbender.org/
+ * Maintainer:
+ * http://www.mapbender.org/User:Verena_Diewald
+ * Parameters:
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+Mapbender.events.init.register(function () {
+	var attachEventsToDigitize = function () {
+		Mapbender.modules[options.target].dataCheck = true;
+		Mapbender.modules[options.target].events.beforeUpdateOrInsert.register(function (obj) {
+			var currentFeature = obj.feature;
+			var currentWfsConf = obj.wfsConf;
+			var digitizeData = [];
+			for (var i=0; i < currentWfsConf.element.length; i++) {
+				if (currentWfsConf.element[i].f_edit != 1) {
+					continue;
+				digitizeData.push({
+					key: currentWfsConf.element[i].f_label,
+					value: currentFeature.e.getElementValueByName(currentWfsConf.element[i].element_name)
+			if(Mapbender.modules[options.target].dataCheck) {
+				var tableHtml = "<table>";
+				for (var j=0; j < digitizeData.length; j++) {
+					tableHtml += "<tr>";
+					tableHtml += "<td>" + digitizeData[j].key + "</td>";
+					tableHtml += "<td>" + digitizeData[j].value + "</td>";
+					tableHtml += "</tr>";
+				tableHtml += "</table>";
+				$("<div>" + tableHtml + "</div>").dialog({
+					bgiframe: true,
+					autoOpen: true,
+					title: 'Kontrolle der eingegebenen Sachdaten:',
+					modal: true,
+					width: 400,
+					height: 400,
+					position: [200,200],
+					buttons: {
+						Speichern: function() {
+							Mapbender.modules[options.target].dataCheck = false;
+							var currentFeatureId = currentFeature.e.getElementValueByName("fid");
+							var featureGIndex = -1;
+							if (currentFeature !== null && currentFeatureId !== false && currentFeatureId !== undefined) {
+								featureGIndex = obj.geometryIndex;
+								currentFeature.e.setElement("fid", currentFeatureId);
+							window.frames[options.target].dbGeom(obj.method, featureGIndex, function () {}, currentWfsConf.wfs_conf_id);
+							$(this).dialog('close');
+						Korrektur: function() {
+							if (obj.method == "insert") {
+								window.frames[options.target].wfsWindow.document.getElementById("featureTypeElementForm").saveButton.disabled = false;
+							else {
+								window.frames[options.target].wfsWindow.document.getElementById("featureTypeElementForm").updateButton.disabled = false;
+			return false;
+		Mapbender.modules[options.target].events.afterWfs.register(function (obj) {
+	var tryToAttachEventsToDigitize = function () {
+		if (typeof Mapbender.modules[options.target].events === "undefined") {
+			setTimeout(tryToAttachEventsToDigitize, 3000);
+		else {
+			attachEventsToDigitize();
+	tryToAttachEventsToDigitize();
\ No newline at end of file
More information about the Mapbender_commits
