[Mapbender-commits] r6277 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Wed Jun 16 09:43:23 EDT 2010
Author: kmq
Date: 2010-06-16 13:43:23 +0000 (Wed, 16 Jun 2010)
New Revision: 6277
trunk/mapbender/http/plugins/mb_loadkmlgeorss.js
added basic dialog, changed some handling when multiple feeds are present
Modified: trunk/mapbender/http/plugins/mb_loadkmlgeorss.js
--- trunk/mapbender/http/plugins/mb_loadkmlgeorss.js 2010-06-16 12:37:16 UTC (rev 6276)
+++ trunk/mapbender/http/plugins/mb_loadkmlgeorss.js 2010-06-16 13:43:23 UTC (rev 6277)
@@ -76,6 +76,7 @@
var that = this;
that.feeds = [];
+that.$popup = $('<div></div>').dialog({autoOpen : false, height: 500});
$('<div id="'+ options.id +'_dialog"><label>GeoRSS <input type="radio" name="type" value="GeoRSS" checked="checked"/></label>'+
'<label>KML<input type="radio" name="type" value="KML"></label><br />'+
@@ -112,7 +113,6 @@
var $map = $('#mapframe1').mapbender();
var markers = [];
var title = "";
- var popup = null;
$("table", $dialog).remove();
var $table = $("<table><thead><tr><th class='labelName'>"+ translatedI18nObject.labelName +"</th></tr></thead><tbody></tbody></table>");
@@ -135,42 +135,51 @@
"z-index": "80" },1);
for(var i =0; i < geomArray.count(); i++){
g = geomArray.get(i);
// per feature stuff
- //g.e.setElement("Mapbender:icon", options.img.url); //? where to get, let the server do it ?
- //g.e.setElement("Mapbender:iconOffsetX", options.img.offset.x);
- //g.e.setElement("Mapbender:iconOffsetY", options.img.offset.y);
- //g.e.setElement("Mapbender:iconZIndex", options.img.offset.y);
+ g.e.setElement("Mapbender:icon","http://localhost:8080/trunk/http/img/marker/red.png");
+ // THIS NEEDS AN OFFSET!
+ title = g.e.getElementValueByName("title");
+ name = g.e.getElementValueByName("name");
+ // kml uses name
+ title = name? name : title;
+ description = g.e.getElementValueByName("description");
+ $row = $("<tr><td>"+ title +"</td></tr>");
+ $row.css("cursor","pointer");
+ $row.click((function(title,description){
+ return function(){
+ $("*",that.$popup).remove();
+ that.$popup.append($("<div><h1>"+title+"</h1><p>"+description +"</p></div>")).dialog('open');
+ })(title,description));
+ $("tbody",$table).append($row);
h.add(g);
+ title = "";
+ name = "";
h.paint();
map.events.afterMapRequest.register(function () {
h.paint();
- var index = that.feeds.push({
- url: url,
+ that.feeds[url] = {
geomArray: geomArray,
- highlight: h,
- index--; //push returns the length
+ highlight: h
var $tableDialog = $("<div></div>").dialog({
width: "450",
height: "500",
position: options.position,
- beforeclose: function(){
- h.clean();
- for(var i in markers){
- markers[i].remove();
+ beforeclose: (function(url){
+ delete that.feeds[url];
+ h.clean();
+ })(url),
buttons: {"Close": function(){
$(this).dialog('close');
$(this).dialog('destroy');
@@ -178,6 +187,7 @@
$tableDialog.append($table);
Mapbender.languageId;
$table.dataTable({"bJQueryUI": true ,
"oLanguage":{
@@ -228,22 +238,42 @@
clickPoint: clickPoint.toText(),
geometries: requestGeometries
- callback: function(result, success, message){
+ callback: (function(geomArray){ return function(result, success, message){
if(!success){
return;
// this is basically an onclick handler, !intersects means
// the click didn't happen on the polygon
- if(!result.geometries){
+ if(!result.geometries || result.geometries.length < 1){
return;
- for(var i in geometries){
+ var $tabs = $("<ul></ul>");
+ // this iterates over an object where the keys are _not_ the incremential
+ // basically a sparse array. therefore I cannot be used to count the entries in the object
+ // this is why j is used
+ var j = 0;
+ for(i in result.geometries){
//TODO: add the popup handler
+ var g = geomArray.get(i);
+ $tabs.append('<li><a href="#rsspopup_'+ i +'">'+ title + '</a></li>');
+ that.$popup.append('<div id="rsspopup_'+ i +'"><h1>'+ title +'</h1><p>'+ description +'</p></h1>');
+ j++;
+ if(j > 1){
+ that.$popup.prepend($tabs);
+ $tabs.tabs();
+ that.$popup.dialog('open');
+ }})(feed.geomArray)
req.send();
+ requestGeometries = [];
More information about the Mapbender_commits
