[Mapbender-commits] r6322 - trunk/mapbender/lib
svn_mapbender at osgeo.org
Fri Jun 18 04:36:59 EDT 2010
Author: christoph
Date: 2010-06-18 08:36:59 +0000 (Fri, 18 Jun 2010)
New Revision: 6322
trunk/mapbender/lib/wizard.js
Modified: trunk/mapbender/lib/wizard.js
--- trunk/mapbender/lib/wizard.js 2010-06-18 08:30:14 UTC (rev 6321)
+++ trunk/mapbender/lib/wizard.js 2010-06-18 08:36:59 UTC (rev 6322)
@@ -26,14 +26,32 @@
return this.each(function () {
var wizardInstance = this;
+ $(wizardInstance).data("isWizard", true);
$("a.wizard").live("click", function (e) {
var href = $(this).attr("href");
var $target = $(href);
- console.log(wizardInstance);
- console.log($target.parents());
- if ($target.size() === 0 || wizardInstance !== $target.parent().get(0)) {
+ var found = false;
+ var abort = false;
+ $target.parents().each(function () {
+ if (abort || found) {
+ return;
+ var $currentElement = $(this);
+ // not this target's wizard
+ if ($(this).data("isWizard") && this !== wizardInstance) {
+ abort = true;
+ return;
+ // this target's wizard
+ if ($(this).data("isWizard") && this === wizardInstance) {
+ found = true;
+ return;
+ if (abort || !found) {
return;
new Mapbender.Warning("Clicked link " + href + " in wizard " + wizardInstance.id);
clickHandler(e, $target);
More information about the Mapbender_commits
