[Mapbender-commits] r6372 - in trunk/mapbender: http/plugins lib
svn_mapbender at osgeo.org
Fri Jun 18 10:45:57 EDT 2010
Author: christoph
Date: 2010-06-18 14:45:57 +0000 (Fri, 18 Jun 2010)
New Revision: 6372
trunk/mapbender/http/plugins/mb_wizard.js
trunk/mapbender/lib/wizard.js
Modified: trunk/mapbender/http/plugins/mb_wizard.js
--- trunk/mapbender/http/plugins/mb_wizard.js 2010-06-18 14:44:20 UTC (rev 6371)
+++ trunk/mapbender/http/plugins/mb_wizard.js 2010-06-18 14:45:57 UTC (rev 6372)
@@ -7,17 +7,19 @@
onClickLink: new Mapbender.Event()
- if (o.$target.size() > 0) {
- $wizard.append(o.$target).wizard({
- fade: true,
- startWith: o.$target.eq(0),
- onClickLink: function ($targets) {
- that.events.onClickLink.trigger({
- path: $targets
+ Mapbender.events.init.register(function () {
+ if (o.$target.size() > 0) {
+ $wizard.append(o.$target).wizard({
+ fade: true,
+ startWith: o.$target.eq(0),
+ onClickLink: function ($targets) {
+ that.events.onClickLink.trigger({
+ path: $targets
$wizard.mapbender(new WizardApi(options));
Modified: trunk/mapbender/lib/wizard.js
--- trunk/mapbender/lib/wizard.js 2010-06-18 14:44:20 UTC (rev 6371)
+++ trunk/mapbender/lib/wizard.js 2010-06-18 14:45:57 UTC (rev 6372)
@@ -17,6 +17,7 @@
}, options || {});
var getPath = function ($t) {
+ console.log($t);
var m = $t.metadata({
type: "attr",
More information about the Mapbender_commits
