[Mapbender-commits] r6432 - trunk/mapbender/lib
svn_mapbender at osgeo.org
Tue Jun 29 05:32:43 EDT 2010
Author: christoph
Date: 2010-06-29 09:32:43 +0000 (Tue, 29 Jun 2010)
New Revision: 6432
trunk/mapbender/lib/wizard.js
Modified: trunk/mapbender/lib/wizard.js
--- trunk/mapbender/lib/wizard.js 2010-06-29 09:28:22 UTC (rev 6431)
+++ trunk/mapbender/lib/wizard.js 2010-06-29 09:32:43 UTC (rev 6432)
@@ -5,120 +5,118 @@
$.widget("mb.wizard", {
_create: function () {
var args = arguments;
- return this.each(function () {
- var getPath = function ($t) {
- var m = $t.metadata({
- type: "attr",
- name: "data"
- var p = [];
- if (m && m.path) {
- p = m.path.split("/");
- o.onClickLink(p);
- var navigate = function ($t) {
- if (o.fade) {
- $t.siblings("div").fadeOut(function () {
- $t.fadeIn();
- else {
- $t.siblings("div").hide();
- $t.show();
- var clickHandler = function (e, $t) {
- getPath($t);
- navigate($t);
- if (e) {
- e.preventDefault();
+ var getPath = function ($t) {
+ var m = $t.metadata({
+ type: "attr",
+ name: "data"
+ var p = [];
+ if (m && m.path) {
+ p = m.path.split("/");
+ o.onClickLink(p);
- var to = function () {
- if (arguments.length === 2) {
- var $target = arguments[1];
- var href = "#" + $target.attr("id");
- var me = null;
- var e = null;
- else {
- var href = $(this).attr("href");
- var $target = $(href);
- var me = this;
- var e = arguments[0];
- var found = false;
- var abort = false;
- $target.parents().each(function () {
- if (abort || found) {
- return;
- var $currentElement = $(this);
- // not this target's wizard
- if ($(this).data("isWizard") && this !== wizardInstance) {
- abort = true;
- return;
- // this target's wizard
- if ($(this).data("isWizard") && this === wizardInstance) {
- found = true;
- return;
+ var navigate = function ($t) {
+ if (o.fade) {
+ $t.siblings("div").fadeOut(function () {
+ $t.fadeIn();
- if (abort || !found) {
- new Mapbender.Warning("not this target's wizard, or not found, aborting");
- return;
+ else {
+ $t.siblings("div").hide();
+ $t.show();
+ var clickHandler = function (e, $t) {
+ getPath($t);
+ navigate($t);
+ if (e) {
+ e.preventDefault();
- var proceed = me === null ? true : o.onBeforeClickLink(e, $(me));
- if (proceed === false) {
- new Mapbender.Warning("Clicked link " + href + " in wizard " + wizardInstance.id + " aborted!");
+ var to = function () {
+ if (arguments.length === 2) {
+ var $target = arguments[1];
+ var href = "#" + $target.attr("id");
+ var me = null;
+ var e = null;
+ else {
+ var href = $(this).attr("href");
+ var $target = $(href);
+ var me = this;
+ var e = arguments[0];
+ var found = false;
+ var abort = false;
+ $target.parents().each(function () {
+ if (abort || found) {
return;
- new Mapbender.Warning("Clicked link " + href + " in wizard " + wizardInstance.id);
- clickHandler(e, $target);
- if (typeof options === "string") {
- if (!$(this).data("isWizard")) {
+ var $currentElement = $(this);
+ // not this target's wizard
+ if ($(this).data("isWizard") && this !== wizardInstance) {
+ abort = true;
return;
- var wizardInstance = this;
- var o = $(this).data("wizardOptions");
- if (options === "to" && args.length === 2) {
- return to(null, args[1]);
+ // this target's wizard
+ if ($(this).data("isWizard") && this === wizardInstance) {
+ found = true;
+ return;
+ if (abort || !found) {
+ new Mapbender.Warning("not this target's wizard, or not found, aborting");
return;
- var $wiz = $(wizardInstance);
- $wiz.data("isWizard", true);
- var o = $.extend({
- fade: false,
- onClickLink: function () {
- return true;
- onBeforeClickLink: function () {
- return true;
- }, options || {});
- $wiz.data("wizardOptions", o);
+ var proceed = me === null ? true : o.onBeforeClickLink(e, $(me));
+ if (proceed === false) {
+ new Mapbender.Warning("Clicked link " + href + " in wizard " + wizardInstance.id + " aborted!");
+ return;
- if (o.startWith) {
- getPath(o.startWith);
+ new Mapbender.Warning("Clicked link " + href + " in wizard " + wizardInstance.id);
+ clickHandler(e, $target);
+ if (typeof options === "string") {
+ if (!$(this).data("isWizard")) {
+ return;
- $("a.wizard").live("click", function (e) {
- to.apply($(this), [e]);
+ var wizardInstance = this;
+ var o = $(this).data("wizardOptions");
+ if (options === "to" && args.length === 2) {
+ return to(null, args[1]);
+ return;
+ var $wiz = $(wizardInstance);
+ $wiz.data("isWizard", true);
+ var o = $.extend({
+ fade: false,
+ onClickLink: function () {
+ return true;
+ onBeforeClickLink: function () {
+ return true;
+ }, options || {});
+ $wiz.data("wizardOptions", o);
+ if (o.startWith) {
+ getPath(o.startWith);
+ $("a.wizard").live("click", function (e) {
+ to.apply($(this), [e]);
More information about the Mapbender_commits
