[Mapbender-commits] r6454 - trunk/mapbender/lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jun 29 10:00:42 EDT 2010
Author: christoph
Date: 2010-06-29 14:00:42 +0000 (Tue, 29 Jun 2010)
New Revision: 6454
   trunk/mapbender/lib/wizard.js
Modified: trunk/mapbender/lib/wizard.js
--- trunk/mapbender/lib/wizard.js	2010-06-29 13:33:34 UTC (rev 6453)
+++ trunk/mapbender/lib/wizard.js	2010-06-29 14:00:42 UTC (rev 6454)
@@ -37,8 +37,7 @@
 	_clickHandler: function (e, $t) {
 		this._getPath($t);
 		this._navigate($t);
-		console.log("to" + $t.attr("id"));
-		this._trigger("wizardto" + $t.attr("id"), [true]);
+		this._trigger("to" + $t.attr("id"), e, {});
 		if (e) {
 			e.preventDefault();
@@ -57,22 +56,23 @@
 		var found = false;
 		var abort = false;
-		var wizardInstance = this.element;
+		var wizardInstance = this;
 		$target.parents().each(function () {
 			if (abort || found) {
 				return;
 			var $currentElement = $(this);
 			// not this target's wizard
-			if ($currentElement.data("isWizard") && $currentElement.get(0) !== wizardInstance.get(0)) {
+			if (!$currentElement.data("wizard")) {
+				return;
+			if ($currentElement.data("wizard") !== wizardInstance) {
 				abort = true;
 				return;
 			// this target's wizard
-			if ($currentElement.data("isWizard") && $currentElement.get(0) === wizardInstance.get(0)) {
-				found = true;
-				return;
+			found = true;
+			return;
 		if (abort || !found) {
 			new Mapbender.Warning("not this target's wizard, or not found, aborting");
@@ -91,7 +91,7 @@
 	_create: function () {
 		var $wiz = wizardInstance.element;
-		$wiz.data("isWizard", true);
+		$wiz.data("wizard", wizardInstance);
 		if (this.options.startWith) {
 			this._getPath(this.options.startWith);
More information about the Mapbender_commits mailing list
