[Mapbender-commits] r6462 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jun 29 11:06:22 EDT 2010
Author: kmq
Date: 2010-06-29 15:06:22 +0000 (Tue, 29 Jun 2010)
New Revision: 6462
Added:
   trunk/mapbender/http/plugins/mb_selectorwizard.js
   trunk/mapbender/http/plugins/mb_wfsGazetteer.js
new containerplugin, new gazetteer now displays search results in resultList
Added: trunk/mapbender/http/plugins/mb_selectorwizard.js
--- trunk/mapbender/http/plugins/mb_selectorwizard.js	                        (rev 0)
+++ trunk/mapbender/http/plugins/mb_selectorwizard.js	2010-06-29 15:06:22 UTC (rev 6462)
@@ -0,0 +1,49 @@
+var $wizard = $(this);
+var WizardApi = function (o) {
+	var that = this;
+	this.events = {
+		onBeforeClickLink: new Mapbender.Event(),
+		onClickLink: new Mapbender.Event(),
+		onNavigate : new Mapbender.Event()
+	$select = $('<select></select>');
+	Mapbender.events.init.register(function () {
+		if (o.$target.size() > 0) {
+			$wizard.append(o.$target).wizard({
+				fade: true,
+				startWith: o.$target.eq(0),
+				onClickLink: function ($targets) {
+					that.events.onClickLink.trigger({
+						path: $targets
+				onBeforeClickLink: function (evt, $link) {
+					var proceed = that.events.onBeforeClickLink.trigger({
+						evt: evt,
+						$link: $link
+					}, "AND");
+					return proceed;
+				onNavigate: function($target){
+					$select.val($target.attr('id'));
+	$wizard.prepend($select);
+	o.$target.each(function(){
+		$option = $('<option></option>').attr('value',this.id).text($(this).attr('title'));
+		$select.append($option);
+	$select.change(function(){
+		$wizard.wizard('to',$('#' + $(this).val()));
+$wizard.mapbender(new WizardApi(options));
Modified: trunk/mapbender/http/plugins/mb_wfsGazetteer.js
--- trunk/mapbender/http/plugins/mb_wfsGazetteer.js	2010-06-29 15:00:29 UTC (rev 6461)
+++ trunk/mapbender/http/plugins/mb_wfsGazetteer.js	2010-06-29 15:06:22 UTC (rev 6462)
@@ -6,7 +6,15 @@
 }, function(json, status) {
 	var wfsConf = $.parseJSON(json);
 	$gazetteer.wfsGazetteer({
-		wfsConf: wfsConf[options.wfsConf]
+		wfsConf: wfsConf[options.wfsConf],
+		receivefeaturecollection : function(e,data){
+			// trigger compatibility event for wfsGazeteer ?
+			var resultList = Mapbender.modules.resultList;
+			resultList.clear();
+			resultList.setTitle(data.wfsConf.wfs_conf_abstract);
+			resultList.setWFSconf(data.wfsConf);
+			resultList.addFeatureCollection(data.featureCollection);
+			resultList.show();
More information about the Mapbender_commits mailing list
