[Mapbender-commits] r5723 - in trunk/mapbender/http: classes
javascripts php
svn_mapbender at osgeo.org
Wed Mar 3 10:03:53 EST 2010
Author: armin11
Date: 2010-03-03 10:03:52 -0500 (Wed, 03 Mar 2010)
New Revision: 5723
Added:
trunk/mapbender/http/php/mod_wfsMetadata.php
trunk/mapbender/http/classes/class_cswrecord.php
trunk/mapbender/http/javascripts/mod_searchCSW_ajax.php
trunk/mapbender/http/php/mod_wmc2ol.php
bugfixing csw, wmc2ol
Modified: trunk/mapbender/http/classes/class_cswrecord.php
--- trunk/mapbender/http/classes/class_cswrecord.php 2010-03-03 14:08:03 UTC (rev 5722)
+++ trunk/mapbender/http/classes/class_cswrecord.php 2010-03-03 15:03:52 UTC (rev 5723)
@@ -252,7 +252,9 @@
//return abstract
public function getAbstract(){
+ $this->abstract = substr($this->abstract,0,150)."...";
return $this->abstract;
public function getModified(){
Modified: trunk/mapbender/http/javascripts/mod_searchCSW_ajax.php
--- trunk/mapbender/http/javascripts/mod_searchCSW_ajax.php 2010-03-03 14:08:03 UTC (rev 5722)
+++ trunk/mapbender/http/javascripts/mod_searchCSW_ajax.php 2010-03-03 15:03:52 UTC (rev 5723)
@@ -281,7 +281,7 @@
setTableHeader(CatTitle, CatName, CatAbstract, RecId);
for (var i = 0; i < catarray.length; i++) {
- var recordLink = '<a href=\''+catarray[i].url+'?request=GetRecordById&service=CSW&version=2.0.2&Id=';
+ var recordLink = '<a href=\''+catarray[i].url+'?request=GetRecordById&service=CSW&version=2.0.2&ElementSetName=full&Id=';
//var recordLink = '<a href=\''+catarray[i].url+'?request=GetRecordById&id=';
recordLink = recordLink+catarray[i].identifier+'';
Added: trunk/mapbender/http/php/mod_wfsMetadata.php
--- trunk/mapbender/http/php/mod_wfsMetadata.php (rev 0)
+++ trunk/mapbender/http/php/mod_wfsMetadata.php 2010-03-03 15:03:52 UTC (rev 5723)
@@ -0,0 +1,120 @@
+<?php
+# http://www.mapbender.org/index.php/Administration
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once dirname(__FILE__) . "/../../core/globalSettings.php";
+$con = db_connect(DBSERVER,OWNER,PW);
+db_select_db(DB,$con);
+function display_text($string) {
+ $string = eregi_replace("[[:alpha:]]+://[^<>[:space:]]+[[:alnum:]/]", "<a href=\"\\0\" target=_blank>\\0</a>", $string);
+ $string = eregi_replace("^[_a-z0-9-]+(\.[_a-z0-9-]+)*@([0-9a-z](-?[0-9a-z])*\.)+[a-z]{2}([zmuvtg]|fo|me)?$", "<a href=\"mailto:\\0\" target=_blank>\\0</a>", $string);
+ $string = eregi_replace("\n", "<br>", $string);
+ return $string;
+<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="de">
+ <head>
+ <title>WFS Metadata</title>
+ <meta name="description" content="Metadata" xml:lang="de" />
+ <meta name="keywords" content="Metadata" xml:lang="de" />
+ <meta http-equiv="cache-control" content="no-cache">
+ <meta http-equiv="pragma" content="no-cache">
+ <meta http-equiv="expires" content="0">
+ <meta http-equiv="content-language" content="de" />
+ <meta http-equiv="content-style-type" content="text/css" />
+<?php
+ echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+ </head>
+ <body id="top">
+ <div>
+ <a href="javascript:window.print()">Print <img src="../../../portal/fileadmin/design/images/icon_print.gif" width="14" height="14" alt="" /></a>
+ <a href="javascript:window.close()">Close <img src="../../../portal/fileadmin/design/images/icon_close.gif" width="14" height="14" alt="" /></a>
+ </div>
+ <div></div>
+ <div></div>
+ <div>
+<?php
+ $wfs_conf_id = $_GET['wfs_conf_id'];
+ //for testing only
+ #$wfs_conf_id = 1;
+ $wfs_id = $_GET['wfs_id'];
+ #$wfs_id = 1;
+ $sql_id = "SELECT * FROM wfs WHERE wfs_id = $1";
+ $v_id = array($wfs_id);
+ $t_id = array('i');
+ $res_wfs = db_prep_query($sql_id,$v_id,$t_id);
+ $row_wfs = db_fetch_array($res_wfs);
+ $wfs = array();
+ $sql_dep = "SELECT mb_group_name FROM mb_group AS a, mb_user AS b, mb_user_mb_group AS c WHERE b.mb_user_id = $1 AND b.mb_user_id = c.fkey_mb_user_id AND c.fkey_mb_group_id = a.mb_group_id AND b.mb_user_department = a.mb_group_description LIMIT 1";
+ $v_dep = array($row_wfs['wfs_owner']);
+ $t_dep = array('i');
+ $res_dep = db_prep_query($sql_dep, $v_dep, $t_dep);
+ $row_dep = db_fetch_array($res_dep);
+ $wfs['WFS ID'] = $row_wfs['wfs_id'];
+ $wfs['WFS Titel'] = $row_wfs['wfs_title'];
+ $wfs['WFS Zusammenfassung'] = $row_wfs['wfs_abstract'];
+ //$featuretype['Koordinatensysteme'] = $row_wfs['featuretype_srs'];
+ //$featuretype['Geometrietyp'] = $geomType;
+ $wfs['Capabilities-Dokument'] = "<a href = '../x_geoportal/getCapabilities_wfs.php?wfs_id=".$row_wfs['wfs_id']."' target=_blank>Capabilities-Dokument</a>";
+ //$featuretype['DescribeFeature-Dokument'] = "<a href = '../x_geoportal/describeFeatureType_wfs.php?wfs_id=".$row['wfs_id']."&featureType_id=".$row['featuretype_id']."' target=_blank>DescribeFeature-Dokument</a>";
+ if ($row_wfs['wfs_timestamp']) {
+ $layer['Datum der Registrierung'] = date("d.m.Y",$row_wfs['wfs_timestamp']);
+ else {
+ $layer['Datum der Registrierung'] = "Keine Angabe";
+ $wfs['Registrierende Stelle'] = $row_dep['mb_group_name'];
+ $wfs['Gebühren'] = $row_wfs['fees'];
+ $wfs['Zugriffsbeschränkung'] = $row_wfs['accessconstraints'];
+ $wfs['Ansprechpartner'] = $row_wfs['individualname'];
+ $wfs['Organisation'] = $row_wfs['providername'];
+ $wfs['Adresse'] = $row_wfs['deliverypoint'];
+ $wfs['Stadt'] = $row_wfs['city'];
+ $wfs['PLZ'] = $row_wfs['postalcode'];
+ $wfs['Telefon'] = $row_wfs['voice'];
+ $wfs['Fax'] = $row_wfs['facsimile'];
+ $wfs['E-Mail'] = $row_wfs['electronicmailaddress'];
+ $wfs['Land'] = $row_wfs['country'];
+ echo "<table class='contenttable-0-wide'>\n";
+ $t_a = "\t<tr>\n\t\t<th>\n\t\t\t";
+ $t_b = "\n\t\t</th>\n\t\t<td>\n\t\t\t";
+ $t_c = "\n\t\t</td>\n\t</tr>\n";
+ $keys = array_keys($wfs);
+ for ($j=0; $j<count($wfs); $j++) {
+ echo $t_a . utf8_encode($keys[$j]) . $t_b . display_text($wfs[$keys[$j]]) . $t_c;
+ echo "</td></tr></table>\n";
+ </div>
+ <div></div>
+ </body>
+</html>
Modified: trunk/mapbender/http/php/mod_wmc2ol.php
--- trunk/mapbender/http/php/mod_wmc2ol.php 2010-03-03 14:08:03 UTC (rev 5722)
+++ trunk/mapbender/http/php/mod_wmc2ol.php 2010-03-03 15:03:52 UTC (rev 5723)
@@ -284,7 +284,7 @@
$format=$current_format;
- $format=str_replace('image/','',$format);
+ #$format=str_replace('image/','',$format);
$html.="format: \"".$format."\",\n";
$html.="transparent: \"On\"\n";
$html.="},\n";
@@ -334,7 +334,7 @@
$html.="transparent: \"TRUE\"\n";
$html.="},\n";
More information about the Mapbender_commits
