[Mapbender-commits] r5739 -
	trunk/mapbender/resources/db/pgsql/UTF-8/update
    svn_mapbender at osgeo.org
    Tue Mar  9 11:21:28 EST 2010
Author: verenadiewald
Date: 2010-03-09 11:21:26 -0500 (Tue, 09 Mar 2010)
New Revision: 5739
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
jq_ui_theme as body element var for ui theme roller css, removed jquery_UI, was duplicate entry
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql	2010-03-09 14:17:02 UTC (rev 5738)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.1_to_2.7rc1_pgsql_UTF-8.sql	2010-03-09 16:21:26 UTC (rev 5739)
@@ -647,14 +647,8 @@
 NOT IN (SELECT fkey_gui_id FROM gui_element
 WHERE e_id = 'jq_upload');
--- jQuery CSS in Body
+-- jQuery datatables CSS in Body
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
-SELECT gui_element.fkey_gui_id, 'body', 'jquery_UI', '../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css', '' ,'file/css'
-FROM gui_element WHERE gui_element.e_id = 'body' AND gui_element.fkey_gui_id = 'gui1' AND gui_element.fkey_gui_id
-NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'jquery_UI'
-AND fkey_e_id = 'body');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
 SELECT gui_element.fkey_gui_id, 'body', 'jquery_datatables', '../extensions/dataTables-1.5/media/css/demo_table_jui.css', '' ,'file/css'
 NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE var_name = 'jquery_datatables'
More information about the Mapbender_commits
