[Mapbender-commits] r5789 - branches/2.6
svn_mapbender at osgeo.org
Tue Mar 16 12:39:48 EDT 2010
Author: astrid_emde
Date: 2010-03-16 12:39:45 -0400 (Tue, 16 Mar 2010)
New Revision: 5789
branches/2.6/Changes.txt
changelog 2.6.1
Modified: branches/2.6/Changes.txt
--- branches/2.6/Changes.txt 2010-03-16 16:30:19 UTC (rev 5788)
+++ branches/2.6/Changes.txt 2010-03-16 16:39:45 UTC (rev 5789)
@@ -3,16 +3,165 @@
http://www.mapbender.org/index.php/Version_History
Also have a look in the trac for detailed informations:
-http://trac.osgeo.org/mapbender/query?status=closed&milestone=2.5.1+release
-Changelog 2.6
-see
+Changelog 2.6.1
+http://trac.osgeo.org/mapbender/report/51
-http://trac.osgeo.org/mapbender/query?status=closed&group=type&milestone=2.6+release&order=priority
+#543 session_write_closed called in wrong places
+#546 Allow only unique features in digitize feature list
+#528 Black background in legend PDF-output
+#548 treeGDE: Interaction between activated sublayers and WMS checkbox/folder on load
+#535 mousewheel scrolling - no zoom when the user scolls in a list treeGDE, legend, whole browser
+#554 Mapframe colored from body
+#553 resizeMapsize mode auto causes distorted map image
+#564 MeetingPoint: Highlight image disappears after map request
+#565 PrintPDF: Print temporary highlight objects
+#562 provide an update script to update the user defined applications
+#580 Meetingpoint: email Link stops at |
+#552 treeGDE - element_var openfolder does not have any effect on treeGDE
+#561 getMap-Request STYLE=undefined when Layer-name contains spaces (SLD)
+#583 Missing mod_add_SLD breaks use of mb_vendorspecific array
+#567 add Dokumentation_mapbender26_de.pdf to the next version (german Documentation)
+#568 addWMSfromfilteredList - does not add a WMS to an application
+#557 EPSG 4326: rounding in showCoords_div
+#585 mousewheel and classic zoom functions..
+#560 mysql_connect() instead mysql_dconnect() in database-mysql.php
+#581 WFS Gazetteer returns no result ("Arranging search results" message is never removed)
+#566 update wms - layer-update isn't correct
+#591 WFS mod_digitize_tab.php - error on display field entries of selected features with selectboxes
+Changelog 2.6
+http://trac.osgeo.org/mapbender/report/42
+ Summary
+#245 Update OSGeo Mapbender Wiki page
+#442 Wrong quotes in WFS tooltip element var SQL
+#507 MySQL / ISO translation of the update scripts
+#491 BBox out of range
+#171 Umlaute wrong in 'Add WMS from Filtered List'
+#515 IE: wrong calculated click pos when browser window has scrollbars (spatial request, digitize)
+#227 load WMS without getFeatureInfo-Request is not possible
+#242 admin tool to edit an application visually
+#257 Digitize: Saving of attributes of digitize object fails when id of attribute field is a javascript keyword
+#307 balloon style popups with popup.js
+#392 load wmc fails
+#26 Titled GUIs (new zebra)
+#54 How to compress all relevant JS files?
+#153 changing the php header (license)
+#174 Meta-Data-Search underruns security
+#203 OGC WFS 1.1 Support
+#208 copy gui
+#220 module addWMSfromfilteredList_ajax does not work with IE
+#231 Splash screen for Mapbender
+#232 add other languages .po files to release
+#236 wms capabilites load: remove duplicates in various elements
+#243 mousewheel-zomm (in/out)
+#247 Mod Pan: cursor pointer if you choose pan function
+#252 incorrect Mapview on switch background/foreground Layers
+#253 Problem with Digitize using GeoServer 1.6.3
+#267 Define NOT_PROXY_HOSTS in mapbender.conf
+#270 AddWMSfromFilteredList: Handling of added WMS (from another Gui) is not user-friendly
+#274 Digitize: Define search result style in element var text css
+#275 Digitize: Define search result style in element var text css
+#279 switchLocale_noreloead - Default-Language
+#287 Digitizing: Split and merge polygons
+#290 myMapIds is not defined
+#291 top.ie may be unreachable
+#292 i18n - .po - File
+#296 WFS Gazetteer and GeoServer 1.6.3/1.6.4
+#305 Digitizing: Polygons with holes
+#306 Digitizing: Compute difference between polygons, and create polygons with holes
+#318 Store scope along with registered functions
+#319 Mousewheel zoom not working in IE
+#323 Convert global map functions to map object methods
+#324 CURL: Request fails, URL not properly encoded
+#334 Missing argument 4 for Mapbender_point
+#335 Tooltip: Tooltip popup should disappear onmouseout
+#336 target hard wired in wfs.js
+#339 WFS Gazetteer: Configuring search fields as selectboxes or checkboxes
+#340 configure EPSG-List in mod_changeEPSG.php
+#342 Admin applications have to be initialised by init(), not mod_adminNavigation_init()
+#347 incorrect geometry parsed in GML class
+#348 Monitoring with diff-like capability
+#350 enable an event to concatenate the return values of its string output on trigger
+#355 "Remove from database" button after digitize error
+#360 replace iframes in map applications by div tags
+#363 Legend incorrect for grouped layers after add WMS
+#371 sorting WFS results with jquery
+#375 Find blog software with automail functionality
+#379 Digitize: Problems with whitespaces in formElementHtml of wfs_conf
+#381 spash screen
+#383 i18n for gazetteerWFS
+#390 tab-elements - increase the framesize onmouseover
+#391 mod_setBackground_change is not defined
+#393 Featuretype namespace not found for WFS 1.0.0
+#395 new overview div does not show the rectangle which is shown in mapframe1
+#396 WFS - update WFS
+#398 Link to Mapbender help in gui
+#399 Mapbender does not save the upload URL anymore
+#400 admin2_de - WMS GUI Einstellungen - style selectbox style and prio
+#403 .sh to add_translations to Mapbender.po
+#404 .sh to update your Mapbender.mo files
+#406 Highlight colour of WFS results
+#409 Meetingpoint produces error
+#410 Update OSGeo Logo to new version
+#411 Update portal start page wording
+#413 clearFilterButtonLabel undefined
+#414 possibly wrong comment or incomplete code
+#415 treeGDE: the declaration of an alternative css-file takes no effect
+#416 highlightPOI incompatible to map div
+#417 meeting point incompatible to map div
+#419 too many hits in gazetteer because of built-in *
+#420 Geometry edit in div tag doesn't work
+#421 navigation during digitize works but creates new basepoints
+#422 tabs wideout
+#423 WFS Configuration: Problems with German Umlaute
+#425 Allow the same JavaScript to be loaded multiple times
+#427 Mapbender copyright does not show up
+#430 scalebar is not displayed
+#435 SQL-Export of GUI elements, emty null-Values
+#445 parser error: GML3 contains GML2 syntax
+#446 add short comments to *.conf files
+#449 sticky legend hardcoded
+#452 Tooltips for Measure Buttons don´t show up
+#461 element vars of featureInfoTunnel doesn' take an effect...
+#462 Digitize: Handling of Select boxes and mandatory attribute does not work properly
+#464 WFS configuration: HTML input is not working.
+#465 WFS configuration: HTML input is not working.
+#466 Zoom To Coordinates doesn't work
+#467 Zoom To Coordinates doesn't work
+#469 Legends from Geoserver do not show up
+#473 undefined default GUI values
+#475 gazetteerWFS: Add possibility to configure the wfsInfo, wfsGeomType and removeWfsConf icons
+#477 layout in IE6/7 is broken
+#479 Overview: wms[i].objLayers[ii] is not defined
+#480 MB2.6 Installation - some guis not loading
+#482 gazetteerWFS: Add possibility to configure spatialRequestHint and progressIndicator infos
+#483 UseMap Module doesn't work.
+#488 Spatial search doesn't work
+#494 gazetteerWFS: If no params are defined as showDetail infos, don't show detailPopup
+#432 allow https connection in class connector
+#495 Measure tool's mapframe button not working in Mapbender 2.6
+#509 Problem with OWS proxy and GetFeatureinfo
+#496 tooltip Demo doesn't work
+#492 getMap Error with Intergraph WMS
+#508 PostgreSQL 8.4 does not work with pgsql_data_2.5.sql
+#510 Bug in Module "SelectMapsize"
+#514 favicon for Mapbender GUI
+#490 Digitizing doesn't work in IE 7/8
+#513 log module doesn´t work in branch-version
+#429 Print - new font LiberationSans-Regular causes error
+#472 treeGDE - incorrect WMS Status at GUI Start
+#463 titling in wfs-conf selection
+#532 class_connector: Sending http post data using curl
+#502 Querystring preperation doesn't fail nicely when a placeholder is not found
+#516 set focus on print-window and on digitize-window
+#511 Unable to delete digitized polygon
+#443 WFS 1.1.0
Changelog 2.5.1
@@ -49,4 +198,4 @@
332 element_var and line-break leads to errors
346 mod_editGuiWms.php - getCapabilities Request Link
356 "update" and "delete" button after a digitize error
-313 'ZoomFull' has CloseTag img
\ No newline at end of file
+313 'ZoomFull' has CloseTag img
More information about the Mapbender_commits
