[Mapbender-commits] r5798 - trunk/mapbender/lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Mar 17 05:49:55 EDT 2010
Author: christoph
Date: 2010-03-17 05:49:54 -0400 (Wed, 17 Mar 2010)
New Revision: 5798
   trunk/mapbender/lib/basic.js
Modified: trunk/mapbender/lib/basic.js
--- trunk/mapbender/lib/basic.js	2010-03-17 09:45:07 UTC (rev 5797)
+++ trunk/mapbender/lib/basic.js	2010-03-17 09:49:54 UTC (rev 5798)
@@ -170,4 +170,155 @@
 		return "&";
 	return "?";
\ No newline at end of file
+Mapbender.sprintf = function () {
+    // http://kevin.vanzonneveld.net
+    // +   original by: Ash Searle (http://hexmen.com/blog/)
+    // + namespaced by: Michael White (http://getsprink.com)
+    // +    tweaked by: Jack
+    // +   improved by: Kevin van Zonneveld (http://kevin.vanzonneveld.net)
+    // +      input by: Paulo Ricardo F. Santos
+    // +      input by: Brett Zamir (http://brett-zamir.me)
+    // *     example 1: sprintf("%01.2f", 123.1);
+    // *     returns 1: 123.10
+    // *     example 2: sprintf("[%10s]", 'monkey');
+    // *     returns 2: '[    monkey]'
+    // *     example 3: sprintf("[%'#10s]", 'monkey');
+    // *     returns 3: '[####monkey]'
+    var regex = /%%|%(\d+\$)?([-+\'#0 ]*)(\*\d+\$|\*|\d+)?(\.(\*\d+\$|\*|\d+))?([scboxXuidfegEG])/g;
+    var a = arguments, i = 0, format = a[i++];
+    // pad()
+    var pad = function (str, len, chr, leftJustify) {
+        if (!chr) {chr = ' ';}
+        var padding = (str.length >= len) ? '' : Array(1 + len - str.length >>> 0).join(chr);
+        return leftJustify ? str + padding : padding + str;
+    // justify()
+    var justify = function (value, prefix, leftJustify, minWidth, zeroPad, customPadChar) {
+        var diff = minWidth - value.length;
+        if (diff > 0) {
+            if (leftJustify || !zeroPad) {
+                value = pad(value, minWidth, customPadChar, leftJustify);
+            } else {
+                value = value.slice(0, prefix.length) + pad('', diff, '0', true) + value.slice(prefix.length);
+        return value;
+    // formatBaseX()
+    var formatBaseX = function (value, base, prefix, leftJustify, minWidth, precision, zeroPad) {
+        // Note: casts negative numbers to positive ones
+        var number = value >>> 0;
+        prefix = prefix && number && {'2': '0b', '8': '0', '16': '0x'}[base] || '';
+        value = prefix + pad(number.toString(base), precision || 0, '0', false);
+        return justify(value, prefix, leftJustify, minWidth, zeroPad);
+    // formatString()
+    var formatString = function (value, leftJustify, minWidth, precision, zeroPad, customPadChar) {
+        if (precision != null) {
+            value = value.slice(0, precision);
+        return justify(value, '', leftJustify, minWidth, zeroPad, customPadChar);
+    // doFormat()
+    var doFormat = function (substring, valueIndex, flags, minWidth, _, precision, type) {
+        var number;
+        var prefix;
+        var method;
+        var textTransform;
+        var value;
+        if (substring == '%%') {return '%';}
+        // parse flags
+        var leftJustify = false, positivePrefix = '', zeroPad = false, prefixBaseX = false, customPadChar = ' ';
+        var flagsl = flags.length;
+        for (var j = 0; flags && j < flagsl; j++) {
+            switch (flags.charAt(j)) {
+                case ' ': positivePrefix = ' '; break;
+                case '+': positivePrefix = '+'; break;
+                case '-': leftJustify = true; break;
+                case "'": customPadChar = flags.charAt(j+1); break;
+                case '0': zeroPad = true; break;
+                case '#': prefixBaseX = true; break;
+        // parameters may be null, undefined, empty-string or real valued
+        // we want to ignore null, undefined and empty-string values
+        if (!minWidth) {
+            minWidth = 0;
+        } else if (minWidth == '*') {
+            minWidth = +a[i++];
+        } else if (minWidth.charAt(0) == '*') {
+            minWidth = +a[minWidth.slice(1, -1)];
+        } else {
+            minWidth = +minWidth;
+        // Note: undocumented perl feature:
+        if (minWidth < 0) {
+            minWidth = -minWidth;
+            leftJustify = true;
+        if (!isFinite(minWidth)) {
+            throw new Error('sprintf: (minimum-)width must be finite');
+        if (!precision) {
+            precision = 'fFeE'.indexOf(type) > -1 ? 6 : (type == 'd') ? 0 : undefined;
+        } else if (precision == '*') {
+            precision = +a[i++];
+        } else if (precision.charAt(0) == '*') {
+            precision = +a[precision.slice(1, -1)];
+        } else {
+            precision = +precision;
+        // grab value using valueIndex if required?
+        value = valueIndex ? a[valueIndex.slice(0, -1)] : a[i++];
+        switch (type) {
+            case 's': return formatString(String(value), leftJustify, minWidth, precision, zeroPad, customPadChar);
+            case 'c': return formatString(String.fromCharCode(+value), leftJustify, minWidth, precision, zeroPad);
+            case 'b': return formatBaseX(value, 2, prefixBaseX, leftJustify, minWidth, precision, zeroPad);
+            case 'o': return formatBaseX(value, 8, prefixBaseX, leftJustify, minWidth, precision, zeroPad);
+            case 'x': return formatBaseX(value, 16, prefixBaseX, leftJustify, minWidth, precision, zeroPad);
+            case 'X': return formatBaseX(value, 16, prefixBaseX, leftJustify, minWidth, precision, zeroPad).toUpperCase();
+            case 'u': return formatBaseX(value, 10, prefixBaseX, leftJustify, minWidth, precision, zeroPad);
+            case 'i':
+            case 'd':
+                number = parseInt(+value, 10);
+                prefix = number < 0 ? '-' : positivePrefix;
+                value = prefix + pad(String(Math.abs(number)), precision, '0', false);
+            case 'e':
+            case 'E':
+            case 'f':
+            case 'F':
+            case 'g':
+            case 'G':
+                number = +value;
+                method = ['toExponential', 'toFixed', 'toPrecision']['efg'.indexOf(type.toLowerCase())];
+                textTransform = ['toString', 'toUpperCase']['eEfFgG'.indexOf(type) % 2];
+                value = prefix + Math.abs(number)[method](precision);
+                return justify(value, prefix, leftJustify, minWidth, zeroPad)[textTransform]();
+            default: return substring;
+    return format.replace(regex, doFormat);
More information about the Mapbender_commits mailing list
