[Mapbender-commits] r5818 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Fri Mar 19 11:35:50 EDT 2010
Author: verenadiewald
Date: 2010-03-19 11:35:50 -0400 (Fri, 19 Mar 2010)
New Revision: 5818
trunk/mapbender/http/javascripts/mod_featureInfoTunnel.php
a progressWheel for featureInfo
Modified: trunk/mapbender/http/javascripts/mod_featureInfoTunnel.php
--- trunk/mapbender/http/javascripts/mod_featureInfoTunnel.php 2010-03-19 15:33:27 UTC (rev 5817)
+++ trunk/mapbender/http/javascripts/mod_featureInfoTunnel.php 2010-03-19 15:35:50 UTC (rev 5818)
@@ -28,7 +28,9 @@
if(typeof(featureInfoPopupWidth)==='undefined')
var featureInfoPopupWidth = '270';
if(typeof(featureInfoPopupPosition)==='undefined')
- var featureInfoPopupPosition = 'center';
+ var featureInfoPopupPosition = 'center';
+if(typeof(featureInfoNoResultPopup)==='undefined')
+ var featureInfoNoResultPopup = 'false';
var mod_featureInfoTunnel_elName = "featureInfoTunnel";
var mod_featureInfoTunnel_frameName = "";
@@ -61,9 +63,25 @@
mod_featureInfoTunnel_map.getDomElement().onclick = null;
mod_featureInfoTunnel_map.getDomElement().style.cursor = "default";
+function removeProgressWheel () {
+ $("#" + mod_featureInfoTunnel_map.elementName + "_progressWheel").empty();
+ $("#" + mod_featureInfoTunnel_map.elementName + "_progressWheel").css("visibility","hidden");
function mod_featureInfoTunnel_event(e){
+ //mod_featureInfoTunnel_map.getDomElement().ownerDocument.getElementById('permanent').style.left;
eventBeforeFeatureInfo.trigger({"fName":mod_featureInfoTunnel_target});
+ //create progress wheel element
+ var map_el = mod_featureInfoTunnel_map.getDomElement();
+ if (!map_el.ownerDocument.getElementById(mod_featureInfoTunnel_map.elementName + "_progressWheel")) {
+ var $div = $("<div id='" + mod_featureInfoTunnel_map.elementName + "_progressWheel'></div>");
+ map_el.appendChild($div.get(0));
var point = mod_featureInfoTunnel_map.getMousePos(e);
var path = '../extensions/ext_featureInfoTunnel.php';
@@ -82,32 +100,56 @@
if(urls){
for(var i=0;i<urls.length;i++){
(function () {
+ var currentMapObjWidth = point.x;
+ var currentMapObjHeight = point.y;
+ $("#" + mod_featureInfoTunnel_map.elementName + "_progressWheel").html("<img src='../img/indicator_wheel.gif'/>");
+ $("#" + mod_featureInfoTunnel_map.elementName + "_progressWheel").css({
+ position: "absolute",
+ top: currentMapObjHeight,
+ left: currentMapObjWidth,
+ visibility: "visible",
+ zIndex: 100
+ window.setTimeout("removeProgressWheel()", 10000);
var currentRequest = urls[i];
var cnt = i;
+ $(".fiResultFrame").remove();
mb_ajax_post(path, {'url':currentRequest},function(js_code,status){
if(js_code){
if(featureInfoLayerPopup == 'true') {
- $("<iframe id='featureInfo_"+ i + "' title='<?php echo _mb("Information");?>' src='" + path + "?url=" + encodeURIComponent(currentRequest) + "'></iframe>").dialog({
+ $("<iframe class='fiResultFrame' id='featureInfo_"+ i + "' title='<?php echo _mb("Information");?>' src='" + path + "?url=" + encodeURIComponent(currentRequest) + "'></iframe>").dialog({
bgiframe: true,
autoOpen: true,
modal: false,
width:parseInt(featureInfoPopupWidth, 10),
height:parseInt(featureInfoPopupHeight, 10),
position:featureInfoPopupPosition,
- buttons: {
- "Ok": function(){
- $(this).dialog('close').remove();
+ close: function() {
+ $(this).remove();
+ $(".noResultFound").dialog("close");
- else {
- window.open(path+"?url="+encodeURIComponent(currentRequest), "" , "width="+featureInfoPopupWidth+",height="+featureInfoPopupHeight+",scrollbars=yes,resizable=yes");
+ else{
+ window.open(path+"?url=" + encodeURIComponent(currentRequest), "" , "width="+featureInfoPopupWidth+",height="+featureInfoPopupHeight+",scrollbars=yes,resizable=yes");
- else{
- var e = new Mb_exception("No featureInfo results.");
+ if(featureInfoNoResultPopup == 'true' && featureInfoLayerPopup == 'true') {
+ if($(".fiResultFrame").size() === 0) {
+ $("<div class='noResultFound'><?php echo _mb("No result");?></div>").dialog({
+ bgiframe: true,
+ title: "<?php echo _mb("Information");?>",
+ autoOpen: true,
+ modal: false,
+ width:300,
+ height:200,
+ position:[600,200]
+ removeProgressWheel();
More information about the Mapbender_commits
