[Mapbender-commits] r5824 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Mon Mar 22 09:19:10 EDT 2010
Author: christoph
Date: 2010-03-22 09:19:10 -0400 (Mon, 22 Mar 2010)
New Revision: 5824
trunk/mapbender/http/javascripts/mod_legend.php
set element ID hard wired, validation changed to "Permission"
Modified: trunk/mapbender/http/javascripts/mod_legend.php
--- trunk/mapbender/http/javascripts/mod_legend.php 2010-03-22 13:18:00 UTC (rev 5823)
+++ trunk/mapbender/http/javascripts/mod_legend.php 2010-03-22 13:19:10 UTC (rev 5824)
@@ -16,8 +16,9 @@
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+$e_id = "legend";
+require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
@@ -33,9 +34,9 @@
<?php
include '../include/dyn_css.php';
-$sql = "SELECT DISTINCT e_target, e_width, e_height FROM gui_element WHERE e_id = '".$_REQUEST["e_id_css"]."' AND fkey_gui_id = $1";
-$v = array($gui_id);
-$t = array('s');
+$sql = "SELECT DISTINCT e_target, e_width, e_height FROM gui_element WHERE e_id = $1 AND fkey_gui_id = $2";
+$v = array($e_id, $gui_id);
+$t = array('s', 's');
$res = db_prep_query($sql, $v, $t);
$cnt = 0;
while($row = db_fetch_array($res)){
@@ -46,9 +47,9 @@
echo "alert('legend: ID not unique!');";
-$sql2 = "SELECT e_left,e_top,e_width,e_height FROM gui_element WHERE e_id = '".$e_target."' AND fkey_gui_id = $1";
-$t = array('s');
+$sql2 = "SELECT e_left,e_top,e_width,e_height FROM gui_element WHERE e_id = $1 AND fkey_gui_id = $2";
+$v = array($e_target, $gui_id);
+$t = array('s','s');
$res2 = db_prep_query($sql2, $v, $t);
echo "<script type='text/javascript'>\n";
echo "var mod_legend_target = '".$e_target."';\n";
More information about the Mapbender_commits
