[Mapbender-commits] r5830 - in trunk/mapbender/http: extensions
extensions/RaphaelJS javascripts
svn_mapbender at osgeo.org
Wed Mar 24 09:48:03 EDT 2010
Author: christoph
Date: 2010-03-24 09:47:59 -0400 (Wed, 24 Mar 2010)
New Revision: 5830
Added:
trunk/mapbender/http/extensions/RaphaelJS/
trunk/mapbender/http/extensions/RaphaelJS/raphael-min.js
trunk/mapbender/http/javascripts/geometry.js
Highlight uses SVG if Raphael is available. Use this SQL to add it to your application
INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('<appId>','raphaelJs',1,1,'','','','','',NULL ,NULL ,NULL ,NULL ,NULL ,'','','','','../extensions/RaphaelJS/raphael-min.js','','','');
Added: trunk/mapbender/http/extensions/RaphaelJS/raphael-min.js
--- trunk/mapbender/http/extensions/RaphaelJS/raphael-min.js (rev 0)
+++ trunk/mapbender/http/extensions/RaphaelJS/raphael-min.js 2010-03-24 13:47:59 UTC (rev 5830)
@@ -0,0 +1,7 @@
+ * Raphael 1.3.2 - JavaScript Vector Library
+ * Copyright (c) 2009 Dmitry Baranovskiy (http://raphaeljs.com)
+ * Licensed under the MIT (http://www.opensource.org/licenses/mit-license.php) license.
+Raphael=(function(){var a=/[, ]+/,aY=/^(circle|rect|path|ellipse|text|image)$/,a9="prototype",W="hasOwnProperty",P=document,aB=window,m={was:Object[a9][W].call(aB,"Raphael"),is:aB.Raphael},au=function(){if(au.is(arguments[0],"array")){var d=arguments[0],e=z[a7](au,d.splice(0,3+au.is(d[0],aq))),S=e.set();for(var R=0,bc=d[n];R<bc;R++){var E=d[R]||{};aY.test(E.type)&&S[f](e[E.type]().attr(E));}return S;}return z[a7](au,arguments);},a4=function(){},aU="appendChild",a7="apply",a2="concat",aA="",at=" ",C="split",J="click dblclick mousedown mousemove mouseout mouseover mouseup"[C](at),aH="join",n="length",bb=String[a9].toLowerCase,af=Math,h=af.max,aR=af.min,aq="number",aJ="toString",aE=Object[a9][aJ],a0={},aV=af.pow,f="push",a5=/^(?=[\da-f]$)/,c=/^url\(['"]?([^\)]+?)['"]?\)$/i,A=/^\s*((#[a-f\d]{6})|(#[a-f\d]{3})|rgb\(\s*([\d\.]+\s*,\s*[\d\.]+\s*,\s*[\d\.]+)\s*\)|rgb\(\s*([\d\.]+%\s*,\s*[\d\.]+%\s*,\s*[\d\.]+%)\s*\)|hs[bl]\(\s*([\d\.]+\s*,\s*[\d\.]+\s*,\s*[\d\.]+)\s*\)|hs[bl]\(\s*([\d\.]+%\s*,\s*[\d\.]+%\s*,\s*[\d\.]+%)\s*\))\s*$/i,U=af.round,y="setAttribute",aa=parseFloat,K=parseInt,aX=String[a9].toUpperCase,k={blur:0,"clip-rect":"0 0 1e9 1e9",cursor:"default",cx:0,cy:0,fill:"#fff","fill-opacity":1,font:'10px "Arial"',"font-family":'"Arial"',"font-size":"10","font-style":"normal","font-weight":400,gradient:0,height:0,href:"http://raphaeljs.com/",opacity:1,path:"M0,0",r:0,rotation:0,rx:0,ry:0,scale:"1 1",src:"",stroke:"#000","stroke-dasharray":"","stroke-linecap":"butt","stroke-linejoin":"butt","stroke-miterlimit":0,"stroke-opacity":1,"stroke-width":1,target:"_blank","text-anchor":"middle",title:"Raphael",translation:"0 0",width:0,x:0,y:0},ad={along:"along",blur:aq,"clip-rect":"csv",cx:aq,cy:aq,fill:"colour","fill-opacity":aq,"font-size":aq,height:aq,opacity:aq,path:"path",r:aq,rotation:"csv",rx:aq,ry:aq,scale:"csv",stroke:"colour","stroke-opacity":aq,"stroke-width":aq,translation:"csv",width:aq,x:aq,y:aq},aZ="replace";au.version="1.3.2";au.type=(aB.SVGAngle||P.implementation.hasFeature("http://www.w3.org/TR/SVG11/feature#BasicStructure","1.1")?"SVG":"VML");if(au.type=="VML"){var ak=P.createElement("div");ak.innerHTML="<!--[if vml]><br><br><![endif]-->";if(ak.childNodes[n]!=2){return au.type=null;}ak=null;}au.svg=!(au.vml=au.type=="VML");a4[a9]=au[a9];au._id=0;au._oid=0;au.fn={};au.is=function(e,d){d=bb.call(d);return((d=="object"||d=="undefined")&&typeof e==d)||(e==null&&d=="null")||bb.call(aE.call(e).slice(8,-1))==d;};au.setWindow=function(d){aB=d;P=aB.document;};var aM=function(e){if(au.vml){var d=/^\s+|\s+$/g;aM=an(function(R){var S;R=(R+aA)[aZ](d,aA);try{var bc=new aB.ActiveXObject("htmlfile");bc.write("<body>");bc.close();S=bc.body;}catch(be){S=aB.createPopup().document.body;}var i=S.createTextRange();try{S.style.color=R;var bd=i.queryCommandValue("ForeColor");bd=((bd&255)<<16)|(bd&65280)|((bd&16711680)>>>16);return"#"+("000000"+bd[aJ](16)).slice(-6);}catch(be){return"none";}});}else{var E=P.createElement("i");E.title="Rapha\xebl Colour Picker";E.style.display="none";P.body[aU](E);aM=an(function(i){E.style.color=i;return P.defaultView.getComputedStyle(E,aA).getPropertyValue("color");});}return aM(e);};var ao=function(){return"hsb("+[this.h,this.s,this.b]+")";},w=function(){return this.hex;};au.hsb2rgb=an(function(bf,bd,bj){if(au.is(bf,"object")&&"h" in bf&&"s" in bf&&"b" in bf){bj=bf.b;bd=bf.s;bf=bf.h;}var R,S,bk;if(bj==0){return{r:0,g:0,b:0,hex:"#000"};}if(bf>1||bd>1||bj>1){bf/=255;bd/=255;bj/=255;}var bc=~~(bf*6),bg=(bf*6)-bc,E=bj*(1-bd),e=bj*(1-(bd*bg)),bl=bj*(1-(bd*(1-bg)));R=[bj,e,E,E,bl,bj,bj][bc];S=[bl,bj,bj,e,E,E,bl][bc];bk=[E,E,bl,bj,bj,e,E][bc];R*=255;S*=255;bk*=255;var bh={r:R,g:S,b:bk,toString:w},d=(~~R)[aJ](16),be=(~~S)[aJ](16),bi=(~~bk)[aJ](16);d=d[aZ](a5,"0");be=be[aZ](a5,"0");bi=bi[aZ](a5,"0");bh.hex="#"+d+be+bi;return bh;},au);au.rgb2hsb=an(function(d,e,bd){if(au.is(d,"object")&&"r" in d&&"g" in d&&"b" in d){bd=d.b;e=d.g;d=d.r;}if(au.is(d,"string")){var bf=au.getRGB(d);d=bf.r;e=bf.g;bd=bf.b;}if(d>1||e>1||bd>1){d/=255;e/=255;bd/=255;}var bc=h(d,e,bd),i=aR(d,e,bd),R,E,S=bc;if(i==bc){return{h:0,s:0,b:bc};}else{var be=(bc-i);E=be/bc;if(d==bc){R=(e-bd)/be;}else{if(e==bc){R=2+((bd-d)/be);}else{R=4+((d-e)/be);}}R/=6;R<0&&R++;R>1&&R--;}return{h:R,s:E,b:S,toString:ao};},au);var aN=/,?([achlmqrstvxz]),?/gi;au._path2string=function(){return this.join(",")[aZ](aN,"$1");};function an(E,e,d){function i(){var R=Array[a9].slice.call(arguments,0),bc=R[aH]("\u25ba"),S=i.cache=i.cache||{},bd=i.count=i.count||[];if(S[W](bc)){return d?d(S[bc]):S[bc];}bd[n]>=1000&&delete S[bd.shift()];bd[f](bc);S[bc]=E[a7](e,R);return d?d(S[bc]):S[bc];}return i;}au.getRGB=an(function(d){if(!d||!!((d=d+aA).indexOf("-")+1)){return{r:-1,g:-1,b:-1,hex:"none",error:1};}if(d=="none"){return{r:-1,g:-1,b:-1,hex:"none"};}!(({hs:1,rg:1})[W](d.substring(0,2))||d.charAt()=="#")&&(d=aM(d));var S,i,E,be,bf,bc=d.match(A);if(bc){if(bc[2]){be=K(bc[2].substring(5),16);E=K(bc[2].substring(3,5),16);i=K(bc[2].substring(1,3),16);}if(bc[3]){be=K((bf=bc[3].charAt(3))+bf,16);E=K((bf=bc[3].charAt(2))+bf,16);i=K((bf=bc[3].charAt(1))+bf,16);}if(bc[4]){bc=bc[4][C](/\s*,\s*/);i=aa(bc[0]);E=aa(bc[1]);be=aa(bc[2]);}if(bc[5]){bc=bc[5][C](/\s*,\s*/);i=aa(bc[0])*2.55;E=aa(bc[1])*2.55;be=aa(bc[2])*2.55;}if(bc[6]){bc=bc[6][C](/\s*,\s*/);i=aa(bc[0]);E=aa(bc[1]);be=aa(bc[2]);return au.hsb2rgb(i,E,be);}if(bc[7]){bc=bc[7][C](/\s*,\s*/);i=aa(bc[0])*2.55;E=aa(bc[1])*2.55;be=aa(bc[2])*2.55;return au.hsb2rgb(i,E,be);}bc={r:i,g:E,b:be};var e=(~~i)[aJ](16),R=(~~E)[aJ](16),bd=(~~be)[aJ](16);e=e[aZ](a5,"0");R=R[aZ](a5,"0");bd=bd[aZ](a5,"0");bc.hex="#"+e+R+bd;return bc;}return{r:-1,g:-1,b:-1,hex:"none",error:1};},au);au.getColor=function(e){var i=this.getColor.start=this.getColor.start||{h:0,s:1,b:e||0.75},d=this.hsb2rgb(i.h,i.s,i.b);i.h+=0.075;if(i.h>1){i.h=0;i.s-=0.2;i.s<=0&&(this.getColor.start={h:0,s:1,b:i.b});}return d.hex;};au.getColor.reset=function(){delete this.start;};var aC=/([achlmqstvz])[\s,]*((-?\d*\.?\d*(?:e[-+]?\d+)?\s*,?\s*)+)/ig,ar=/(-?\d*\.?\d*(?:e[-+]?\d+)?)\s*,?\s*/ig;au.parsePathString=an(function(d){if(!d){return null;}var i={a:7,c:6,h:1,l:2,m:2,q:4,s:4,t:2,v:1,z:0},e=[];if(au.is(d,"array")&&au.is(d[0],"array")){e=aD(d);}if(!e[n]){(d+aA)[aZ](aC,function(R,E,bd){var bc=[],S=bb.call(E);bd[aZ](ar,function(bf,be){be&&bc[f](+be);});if(S=="m"&&bc[n]>2){e[f]([E][a2](bc.splice(0,2)));S="l";E=E=="m"?"l":"L";}while(bc[n]>=i[S]){e[f]([E][a2](bc.splice(0,i[S])));if(!i[S]){break;}}});}e[aJ]=au._path2string;return e;});au.findDotsAtSegment=function(e,d,bq,bo,bc,R,be,bd,bk){var bi=1-bk,bh=aV(bi,3)*e+aV(bi,2)*3*bk*bq+bi*3*bk*bk*bc+aV(bk,3)*be,bf=aV(bi,3)*d+aV(bi,2)*3*bk*bo+bi*3*bk*bk*R+aV(bk,3)*bd,bm=e+2*bk*(bq-e)+bk*bk*(bc-2*bq+e),bl=d+2*bk*(bo-d)+bk*bk*(R-2*bo+d),bp=bq+2*bk*(bc-bq)+bk*bk*(be-2*bc+bq),bn=bo+2*bk*(R-bo)+bk*bk*(bd-2*R+bo),bj=(1-bk)*e+bk*bq,bg=(1-bk)*d+bk*bo,E=(1-bk)*bc+bk*be,i=(1-bk)*R+bk*bd,S=(90-af.atan((bm-bp)/(bl-bn))*180/af.PI);(bm>bp||bl<bn)&&(S+=180);return{x:bh,y:bf,m:{x:bm,y:bl},n:{x:bp,y:bn},start:{x:bj,y:bg},end:{x:E,y:i},alpha:S};};var Y=an(function(bh){if(!bh){return{x:0,y:0,width:0,height:0};}bh=L(bh);var be=0,bd=0,R=[],e=[],E;for(var S=0,bg=bh[n];S<bg;S++){E=bh[S];if(E[0]=="M"){be=E[1];bd=E[2];R[f](be);e[f](bd);}else{var bc=aL(be,bd,E[1],E[2],E[3],E[4],E[5],E[6]);R=R[a2](bc.min.x,bc.max.x);e=e[a2](bc.min.y,bc.max.y);be=E[5];bd=E[6];}}var d=aR[a7](0,R),bf=aR[a7](0,e);return{x:d,y:bf,width:h[a7](0,R)-d,height:h[a7](0,e)-bf};}),aD=function(bc){var E=[];if(!au.is(bc,"array")||!au.is(bc&&bc[0],"array")){bc=au.parsePathString(bc);}for(var e=0,R=bc[n];e<R;e++){E[e]=[];for(var d=0,S=bc[e][n];d<S;d++){E[e][d]=bc[e][d];}}E[aJ]=au._path2string;return E;},ah=an(function(R){if(!au.is(R,"array")||!au.is(R&&R[0],"array")){R=au.parsePathString(R);}var bg=[],bi=0,bh=0,bl=0,bk=0,E=0;if(R[0][0]=="M"){bi=R[0][1];bh=R[0][2];bl=bi;bk=bh;E++;bg[f](["M",bi,bh]);}for(var bd=E,bm=R[n];bd<bm;bd++){var d=bg[bd]=[],bj=R[bd];if(bj[0]!=bb.call(bj[0])){d[0]=bb.call(bj[0]);switch(d[0]){case"a":d[1]=bj[1];d[2]=bj[2];d[3]=bj[3];d[4]=bj[4];d[5]=bj[5];d[6]=+(bj[6]-bi).toFixed(3);d[7]=+(bj[7]-bh).toFixed(3);break;case"v":d[1]=+(bj[1]-bh).toFixed(3);break;case"m":bl=bj[1];bk=bj[2];default:for(var bc=1,be=bj[n];bc<be;bc++){d[bc]=+(bj[bc]-((bc%2)?bi:bh)).toFixed(3);}}}else{d=bg[bd]=[];if(bj[0]=="m"){bl=bj[1]+bi;bk=bj[2]+bh;}for(var S=0,e=bj[n];S<e;S++){bg[bd][S]=bj[S];}}var bf=bg[bd][n];switch(bg[bd][0]){case"z":bi=bl;bh=bk;break;case"h":bi+=+bg[bd][bf-1];break;case"v":bh+=+bg[bd][bf-1];break;default:bi+=+bg[bd][bf-2];bh+=+bg[bd][bf-1];}}bg[aJ]=au._path2string;return bg;},0,aD),t=an(function(R){if(!au.is(R,"array")||!au.is(R&&R[0],"array")){R=au.parsePathString(R);}var bf=[],bh=0,bg=0,bk=0,bj=0,E=0;if(R[0][0]=="M"){bh=+R[0][1];bg=+R[0][2];bk=bh;bj=bg;E++;bf[0]=["M",bh,bg];}for(var bd=E,bl=R[n];bd<bl;bd++){var d=bf[bd]=[],bi=R[bd];if(bi[0]!=aX.call(bi[0])){d[0]=aX.call(bi[0]);switch(d[0]){case"A":d[1]=bi[1];d[2]=bi[2];d[3]=bi[3];d[4]=bi[4];d[5]=bi[5];d[6]=+(bi[6]+bh);d[7]=+(bi[7]+bg);break;case"V":d[1]=+bi[1]+bg;break;case"H":d[1]=+bi[1]+bh;break;case"M":bk=+bi[1]+bh;bj=+bi[2]+bg;default:for(var bc=1,be=bi[n];bc<be;bc++){d[bc]=+bi[bc]+((bc%2)?bh:bg);}}}else{for(var S=0,e=bi[n];S<e;S++){bf[bd][S]=bi[S];}}switch(d[0]){case"Z":bh=bk;bg=bj;break;case"H":bh=d[1];break;case"V":bg=d[1];break;default:bh=bf[bd][bf[bd][n]-2];bg=bf[bd][bf[bd][n]-1];}}bf[aJ]=au._path2string;return bf;},null,aD),a8=function(e,E,d,i){return[e,E,d,i,d,i];},aT=function(e,E,bc,R,d,i){var S=1/3,bd=2/3;return[S*e+bd*bc,S*E+bd*R,S*d+bd*bc,S*i+bd*R,d,i];},O=function(bl,bQ,bu,bs,bm,bg,S,bk,bP,bn){var R=af.PI,br=R*120/180,d=R/180*(+bm||0),by=[],bv,bM=an(function(bR,bU,i){var bT=bR*af.cos(i)-bU*af.sin(i),bS=bR*af.sin(i)+bU*af.cos(i);return{x:bT,y:bS};});if(!bn){bv=bM(bl,bQ,-d);bl=bv.x;bQ=bv.y;bv=bM(bk,bP,-d);bk=bv.x;bP=bv.y;var e=af.cos(R/180*bm),bi=af.sin(R/180*bm),bA=(bl-bk)/2,bz=(bQ-bP)/2;var bK=(bA*bA)/(bu*bu)+(bz*bz)/(bs*bs);if(bK>1){bK=af.sqrt(bK);bu=bK*bu;bs=bK*bs;}var E=bu*bu,bD=bs*bs,bF=(bg==S?-1:1)*af.sqrt(af.abs((E*bD-E*bz*bz-bD*bA*bA)/(E*bz*bz+bD*bA*bA))),bp=bF*bu*bz/bs+(bl+bk)/2,bo=bF*-bs*bA/bu+(bQ+bP)/2,bf=af.asin(((bQ-bo)/bs).toFixed(7)),be=af.asin(((bP-bo)/bs).toFixed(7));bf=bl<bp?R-bf:bf;be=bk<bp?R-be:be;bf<0&&(bf=R*2+bf);be<0&&(be=R*2+be);if(S&&bf>be){bf=bf-R*2;}if(!S&&be>bf){be=be-R*2;}}else{bf=bn[0];be=bn[1];bp=bn[2];bo=bn[3];}var bj=be-bf;if(af.abs(bj)>br){var bq=be,bt=bk,bh=bP;be=bf+br*(S&&be>bf?1:-1);bk=bp+bu*af.cos(be);bP=bo+bs*af.sin(be);by=O(bk,bP,bu,bs,bm,0,S,bt,bh,[be,bq,bp,bo]);}bj=be-bf;var bd=af.cos(bf),bO=af.sin(bf),bc=af.cos(be),bN=af.sin(be),bB=af.tan(bj/4),bE=4/3*bu*bB,bC=4/3*bs*bB,bL=[bl,bQ],bJ=[bl+bE*bO,bQ-bC*bd],bI=[bk+bE*bN,bP-bC*bc],bG=[bk,bP];bJ[0]=2*bL[0]-bJ[0];bJ[1]=2*bL[1]-bJ[1];if(bn){return[bJ,bI,bG][a2](by);}else{by=[bJ,bI,bG][a2](by)[aH]()[C](",");var bw=[];for(var bH=0,bx=by[n];bH<bx;bH++){bw[bH]=bH%2?bM(by[bH-1],by[bH],d).y:bM(by[bH],by[bH+1],d).x;}return bw;}},T=function(e,d,E,i,be,bd,bc,S,bf){var R=1-bf;return{x:aV(R,3)*e+aV(R,2)*3*bf*E+R*3*bf*bf*be+aV(bf,3)*bc,y:aV(R,3)*d+aV(R,2)*3*bf*i+R*3*bf*bf*bd+aV(bf,3)*S};},aL=an(function(i,d,R,E,bl,bk,bh,be){var bj=(bl-2*R+i)-(bh-2*bl+R),bg=2*(R-i)-2*(bl-R),bd=i-R,bc=(-bg+af.sqrt(bg*bg-4*bj*bd))/2/bj,S=(-bg-af.sqrt(bg*bg-4*bj*bd))/2/bj,bf=[d,be],bi=[i,bh],e;af.abs(bc)>1000000000000&&(bc=0.5);af.abs(S)>1000000000000&&(S=0.5);if(bc>0&&bc<1){e=T(i,d,R,E,bl,bk,bh,be,bc);bi[f](e.x);bf[f](e.y);}if(S>0&&S<1){e=T(i,d,R,E,bl,bk,bh,be,S);bi[f](e.x);bf[f](e.y);}bj=(bk-2*E+d)-(be-2*bk+E);bg=2*(E-d)-2*(bk-E);bd=d-E;bc=(-bg+af.sqrt(bg*bg-4*bj*bd))/2/bj;S=(-bg-af.sqrt(bg*bg-4*bj*bd))/2/bj;af.abs(bc)>1000000000000&&(bc=0.5);af.abs(S)>1000000000000&&(S=0.5);if(bc>0&&bc<1){e=T(i,d,R,E,bl,bk,bh,be,bc);bi[f](e.x);bf[f](e.y);}if(S>0&&S<1){e=T(i,d,R,E,bl,bk,bh,be,S);bi[f](e.x);bf[f](e.y);}return{min:{x:aR[a7](0,bi),y:aR[a7](0,bf)},max:{x:h[a7](0,bi),y:h[a7](0,bf)}};}),L=an(function(bl,bg){var R=t(bl),bh=bg&&t(bg),bi={x:0,y:0,bx:0,by:0,X:0,Y:0,qx:null,qy:null},d={x:0,y:0,bx:0,by:0,X:0,Y:0,qx:null,qy:null},bc=function(bm,bn){var i,bo;if(!bm){return["C",bn.x,bn.y,bn.x,bn.y,bn.x,bn.y];}!(bm[0] in {T:1,Q:1})&&(bn.qx=bn.qy=null);switch(bm[0]){case"M":bn.X=bm[1];bn.Y=bm[2];break;case"A":bm=["C"][a2](O[a7](0,[bn.x,bn.y][a2](bm.slice(1))));break;case"S":i=bn.x+(bn.x-(bn.bx||bn.x));bo=bn.y+(bn.y-(bn.by||bn.y));bm=["C",i,bo][a2](bm.slice(1));break;case"T":bn.qx=bn.x+(bn.x-(bn.qx||bn.x));bn.qy=bn.y+(bn.y-(bn.qy||bn.y));bm=["C"][a2](aT(bn.x,bn.y,bn.qx,bn.qy,bm[1],bm[2]));break;case"Q":bn.qx=bm[1];bn.qy=bm[2];bm=["C"][a2](aT(bn.x,bn.y,bm[1],bm[2],bm[3],bm[4]));break;case"L":bm=["C"][a2](a8(bn.x,bn.y,bm[1],bm[2]));break;case"H":bm=["C"][a2](a8(bn.x,bn.y,bm[1],bn.y));break;case"V":bm=["C"][a2](a8(bn.x,bn.y,bn.x,bm[1]));break;case"Z":bm=["C"][a2](a8(bn.x,bn.y,bn.X,bn.Y));break;}return bm;},e=function(bm,bn){if(bm[bn][n]>7){bm[bn].shift();var bo=bm[bn];while(bo[n]){bm.splice(bn++,0,["C"][a2](bo.splice(0,6)));}bm.splice(bn,1);bj=h(R[n],bh&&bh[n]||0);}},E=function(bq,bp,bn,bm,bo){if(bq&&bp&&bq[bo][0]=="M"&&bp[bo][0]!="M"){bp.splice(bo,0,["M",bm.x,bm.y]);bn.bx=0;bn.by=0;bn.x=bq[bo][1];bn.y=bq[bo][2];bj=h(R[n],bh&&bh[n]||0);}};for(var be=0,bj=h(R[n],bh&&bh[n]||0);be<bj;be++){R[be]=bc(R[be],bi);e(R,be);bh&&(bh[be]=bc(bh[be],d));bh&&e(bh,be);E(R,bh,bi,d,be);E(bh,R,d,bi,be);var bd=R[be],bk=bh&&bh[be],S=bd[n],bf=bh&&bk[n];bi.x=bd[S-2];bi.y=bd[S-1];bi.bx=aa(bd[S-4])||bi.x;bi.by=aa(bd[S-3])||bi.y;d.bx=bh&&(aa(bk[bf-4])||d.x);d.by=bh&&(aa(bk[bf-3])||d.y);d.x=bh&&bk[bf-2];d.y=bh&&bk[bf-1];}return bh?[R,bh]:R;},null,aD),r=an(function(bg){var bf=[];for(var bc=0,bh=bg[n];bc<bh;bc++){var e={},be=bg[bc].match(/^([^:]*):?([\d\.]*)/);e.color=au.getRGB(be[1]);if(e.color.error){return null;}e.color=e.color.hex;be[2]&&(e.offset=be[2]+"%");bf[f](e);}for(bc=1,bh=bf[n]-1;bc<bh;bc++){if(!bf[bc].offset){var E=aa(bf[bc-1].offset||0),R=0;for(var S=bc+1;S<bh;S++){if(bf[S].offset){R=bf[S].offset;break;}}if(!R){R=100;S=bh;}R=aa(R);var bd=(R-E)/(S-bc+1);for(;bc<S;bc++){E+=bd;bf[bc].offset=E+"%";}}}return bf;}),av=function(d,R,i,E){var e;if(au.is(d,"string")||au.is(d,"object")){e=au.is(d,"string")?P.getElementById(d):d;if(e.tagName){if(R==null){return{container:e,width:e.style.pixelWidth||e.offsetWidth,height:e.style.pixelHeight||e.offsetHeight};}else{return{container:e,width:R,height:i};}}}else{if(au.is(d,aq)&&E!=null){return{container:1,x:d,y:R,width:i,height:E};}}},aP=function(d,i){var e=this;for(var E in i){if(i[W](E)&&!(E in d)){switch(typeof i[E]){case"function":(function(R){d[E]=d===e?R:function(){return R[a7](e,arguments);};})(i[E]);break;case"object":d[E]=d[E]||{};aP.call(this,d[E],i[E]);break;default:d[E]=i[E];break;}}}},ap=function(d,e){d==e.top&&(e.top=d.prev);d==e.bottom&&(e.bottom=d.next);d.next&&(d.next.prev=d.prev);d.prev&&(d.prev.next=d.next);},ac=function(d,e){if(e.top===d){return;}ap(d,e);d.next=null;d.prev=e.top;e.top.next=d;e.top=d;},l=function(d,e){if(e.bottom===d){return;}ap(d,e);d.next=e.bottom;d.prev=null;e.bottom.prev=d;e.bottom=d;},D=function(e,d,i){ap(e,i);d==i.top&&(i.top=e);d.next&&(d.next.prev=e);e.next=d.next;e.prev=d;d.next=e;},ax=function(e,d,i){ap(e,i);d==i.bottom&&(i.bottom=e);d.prev&&(d.prev.next=e);e.prev=d.prev;d.prev=e;e.next=d;},u=function(d){return function(){throw new Error("Rapha\xebl: you are calling to method \u201c"+d+"\u201d of removed object");};},az=/^r(?:\(([^,]+?)\s*,\s*([^\)]+?)\))?/;if(au.svg){a4[a9].svgns="http://www.w3.org/2000/svg";a4[a9].xlink="http://www.w3.org/1999/xlink";U=function(d){return +d+(~~d===d)*0.5;};var Z=function(S){for(var e=0,E=S[n];e<E;e++){if(bb.call(S[e][0])!="a"){for(var d=1,R=S[e][n];d<R;d++){S[e][d]=U(S[e][d]);}}else{S[e][6]=U(S[e][6]);S[e][7]=U(S[e][7]);}}return S;},aS=function(i,d){if(d){for(var e in d){if(d[W](e)){i[y](e,d[e]+aA);}}}else{return P.createElementNS(a4[a9].svgns,i);}};au[aJ]=function(){return"Your browser supports SVG.\nYou are running Rapha\xebl "+this.version;};var s=function(d,E){var e=aS("path");E.canvas&&E.canvas[aU](e);var i=new aF(e,E);i.type="path";ae(i,{fill:"none",stroke:"#000",path:d});return i;};var b=function(R,bk,d){var bh="linear",be=0.5,bc=0.5,bm=R.style;bk=(bk+aA)[aZ](az,function(bo,i,bp){bh="radial";if(i&&bp){be=aa(i);bc=aa(bp);var bn=((bc>0.5)*2-1);aV(be-0.5,2)+aV(bc-0.5,2)>0.25&&(bc=af.sqrt(0.25-aV(be-0.5,2))*bn+0.5)&&bc!=0.5&&(bc=bc.toFixed(5)-0.00001*bn);}return aA;});bk=bk[C](/\s*\-\s*/);if(bh=="linear"){var bd=bk.shift();bd=-aa(bd);if(isNaN(bd)){return null;}var S=[0,0,af.cos(bd*af.PI/180),af.sin(bd*af.PI/180)],bj=1/(h(af.abs(S[2]),af.abs(S[3]))||1);S[2]*=bj;S[3]*=bj;if(S[2]<0){S[0]=-S[2];S[2]=0;}if(S[3]<0){S[1]=-S[3];S[3]=0;}}var bg=r(bk);if(!bg){return null;}var e=R.getAttribute("fill");e=e.match(/^url\(#(.*)\)$/);e&&d.defs.removeChild(P.getElementById(e[1]));var E=aS(bh+"Gradient");E.id="r"+(au._id++)[aJ](36);aS(E,bh=="radial"?{fx:be,fy:bc}:{x1:S[0],y1:S[1],x2:S[2],y2:S[3]});d.defs[aU](E);for(var bf=0,bl=bg[n];bf<bl;bf++){var bi=aS("stop");aS(bi,{offset:bg[bf].offset?bg[bf].offset:!bf?"0%":"100%","stop-color":bg[bf].color||"#fff"});E[aU](bi);}aS(R,{fill:"url(#"+E.id+")",opacity:1,"fill-opacity":1});bm.fill=aA;bm.opacity=1;bm.fillOpacity=1;return 1;};var Q=function(e){var d=e.getBBox();aS(e.pattern,{patternTransform:au.format("translate({0},{1})",d.x,d.y)});};var ae=function(bi,br){var bl={"":[0],none:[0],"-":[3,1],".":[1,1],"-.":[3,1,1,1],"-..":[3,1,1,1,1,1],". ":[1,3],"- ":[4,3],"--":[8,3],"- .":[4,3,1,3],"--.":[8,3,1,3],"--..":[8,3,1,3,1,3]},bn=bi.node,bj=bi.attrs,bf=bi.rotate(),S=function(by,bx){bx=bl[bb.call(bx)];if(bx){var bv=by.attrs["stroke-width"]||"1",bt={round:bv,square:bv,butt:0}[by.attrs["stroke-linecap"]||br["stroke-linecap"]]||0,bw=[];var bu=bx[n];while(bu--){bw[bu]=bx[bu]*bv+((bu%2)?1:-1)*bt;}aS(bn,{"stroke-dasharray":bw[aH](",")});}};br[W]("rotation")&&(bf=br.rotation);var be=(bf+aA)[C](a);if(!(be.length-1)){be=null;}else{be[1]=+be[1];be[2]=+be[2];}aa(bf)&&bi.rotate(0,true);for(var bm in br){if(br[W](bm)){if(!k[W](bm)){continue;}var bk=br[bm];bj[bm]=bk;switch(bm){case"blur":bi.blur(bk);break;case"rotation":bi.rotate(bk,true);break;case"href":case"title":case"target":var bp=bn.parentNode;if(bb.call(bp.tagName)!="a"){var E=aS("a");bp.insertBefore(E,bn);E[aU](bn);bp=E;}bp.setAttributeNS(bi.paper.xlink,bm,bk);break;case"cursor":bn.style.cursor=bk;break;case"clip-rect":var e=(bk+aA)[C](a);if(e[n]==4){bi.clip&&bi.clip.parentNode.parentNode.removeChild(bi.clip.parentNode);var i=aS("clipPath"),bo=aS("rect");i.id="r"+(au._id++)[aJ](36);aS(bo,{x:e[0],y:e[1],width:e[2],height:e[3]});i[aU](bo);bi.paper.defs[aU](i);aS(bn,{"clip-path":"url(#"+i.id+")"});bi.clip=bo;}if(!bk){var bq=P.getElementById(bn.getAttribute("clip-path")[aZ](/(^url\(#|\)$)/g,aA));bq&&bq.parentNode.removeChild(bq);aS(bn,{"clip-path":aA});delete bi.clip;}break;case"path":if(bi.type=="path"){aS(bn,{d:bk?bj.path=Z(t(bk)):"M0,0"});}break;case"width":bn[y](bm,bk);if(bj.fx){bm="x";bk=bj.x;}else{break;}case"x":if(bj.fx){bk=-bj.x-(bj.width||0);}case"rx":if(bm=="rx"&&bi.type=="rect"){break;}case"cx":be&&(bm=="x"||bm=="cx")&&(be[1]+=bk-bj[bm]);bn[y](bm,U(bk));bi.pattern&&Q(bi);break;case"height":bn[y](bm,bk);if(bj.fy){bm="y";bk=bj.y;}else{break;}case"y":if(bj.fy){bk=-bj.y-(bj.height||0);}case"ry":if(bm=="ry"&&bi.type=="rect"){break;}case"cy":be&&(bm=="y"||bm=="cy")&&(be[2]+=bk-bj[bm]);bn[y](bm,U(bk));bi.pattern&&Q(bi);break;case"r":if(bi.type=="rect"){aS(bn,{rx:bk,ry:bk});}else{bn[y](bm,bk);}break;case"src":if(bi.type=="image"){bn.setAttributeNS(bi.paper.xlink,"href",bk);}break;case"stroke-width":bn.style.strokeWidth=bk;bn[y](bm,bk);if(bj["stroke-dasharray"]){S(bi,bj["stroke-dasharray"]);}break;case"stroke-dasharray":S(bi,bk);break;case"translation":var bc=(bk+aA)[C](a);bc[0]=+bc[0]||0;bc[1]=+bc[1]||0;if(be){be[1]+=bc[0];be[2]+=bc[1];}v.call(bi,bc[0],bc[1]);break;case"scale":bc=(bk+aA)[C](a);bi.scale(+bc[0]||1,+bc[1]||+bc[0]||1,isNaN(aa(bc[2]))?null:+bc[2],isNaN(aa(bc[3]))?null:+bc[3]);break;case"fill":var R=(bk+aA).match(c);if(R){i=aS("pattern");var bh=aS("image");i.id="r"+(au._id++)[aJ](36);aS(i,{x:0,y:0,patternUnits:"userSpaceOnUse",height:1,width:1});aS(bh,{x:0,y:0});bh.setAttributeNS(bi.paper.xlink,"href",R[1]);i[aU](bh);var bs=P.createElement("img");bs.style.cssText="position:absolute;left:-9999em;top-9999em";bs.onload=function(){aS(i,{width:this.offsetWidth,height:this.offsetHeight});aS(bh,{width:this.offsetWidth,height:this.offsetHeight});P.body.removeChild(this);bi.paper.safari();};P.body[aU](bs);bs.src=R[1];bi.paper.defs[aU](i);bn.style.fill="url(#"+i.id+")";aS(bn,{fill:"url(#"+i.id+")"});bi.pattern=i;bi.pattern&&Q(bi);break;}if(!au.getRGB(bk).error){delete br.gradient;delete bj.gradient;!au.is(bj.opacity,"undefined")&&au.is(br.opacity,"undefined")&&aS(bn,{opacity:bj.opacity});!au.is(bj["fill-opacity"],"undefined")&&au.is(br["fill-opacity"],"undefined")&&aS(bn,{"fill-opacity":bj["fill-opacity"]});}else{if((({circle:1,ellipse:1})[W](bi.type)||(bk+aA).charAt()!="r")&&b(bn,bk,bi.paper)){bj.gradient=bk;bj.fill="none";break;}}case"stroke":bn[y](bm,au.getRGB(bk).hex);break;case"gradient":(({circle:1,ellipse:1})[W](bi.type)||(bk+aA).charAt()!="r")&&b(bn,bk,bi.paper);break;case"opacity":case"fill-opacity":if(bj.gradient){var d=P.getElementById(bn.getAttribute("fill")[aZ](/^url\(#|\)$/g,aA));if(d){var bd=d.getElementsByTagName("stop");bd[bd[n]-1][y]("stop-opacity",bk);}break;}default:bm=="font-size"&&(bk=K(bk,10)+"px");var bg=bm[aZ](/(\-.)/g,function(bt){return aX.call(bt.substring(1));});bn.style[bg]=bk;bn[y](bm,bk);break;}}}I(bi,br);if(be){bi.rotate(be.join(at));}else{aa(bf)&&bi.rotate(bf,true);}};var j=1.2,I=function(d,R){if(d.type!="text"||!(R[W]("text")||R[W]("font")||R[W]("font-size")||R[W]("x")||R[W]("y"))){return;}var bf=d.attrs,e=d.node,bh=e.firstChild?K(P.defaultView.getComputedStyle(e.firstChild,aA).getPropertyValue("font-size"),10):10;if(R[W]("text")){bf.text=R.text;while(e.firstChild){e.removeChild(e.firstChild);}var E=(R.text+aA)[C]("\n");for(var S=0,bg=E[n];S<bg;S++){if(E[S]){var bd=aS("tspan");S&&aS(bd,{dy:bh*j,x:bf.x});bd[aU](P.createTextNode(E[S]));e[aU](bd);}}}else{E=e.getElementsByTagName("tspan");for(S=0,bg=E[n];S<bg;S++){S&&aS(E[S],{dy:bh*j,x:bf.x});}}aS(e,{y:bf.y});var bc=d.getBBox(),be=bf.y-(bc.y+bc.height/2);be&&isFinite(be)&&aS(e,{y:bf.y+be});},aF=function(e,d){var E=0,i=0;this[0]=e;this.id=au._oid++;this.node=e;e.raphael=this;this.paper=d;this.attrs=this.attrs||{};this.transformations=[];this._={tx:0,ty:0,rt:{deg:0,cx:0,cy:0},sx:1,sy:1};!d.bottom&&(d.bottom=this);this.prev=d.top;d.top&&(d.top.next=this);d.top=this;this.next=null;};aF[a9].rotate=function(e,d,E){if(this.removed){return this;}if(e==null){if(this._.rt.cx){return[this._.rt.deg,this._.rt.cx,this._.rt.cy][aH](at);}return this._.rt.deg;}var i=this.getBBox();e=(e+aA)[C](a);if(e[n]-1){d=aa(e[1]);E=aa(e[2]);}e=aa(e[0]);if(d!=null){this._.rt.deg=e;}else{this._.rt.deg+=e;}(E==null)&&(d=null);this._.rt.cx=d;this._.rt.cy=E;d=d==null?i.x+i.width/2:d;E=E==null?i.y+i.height/2:E;if(this._.rt.deg){this.transformations[0]=au.format("rotate({0} {1} {2})",this._.rt.deg,d,E);this.clip&&aS(this.clip,{transform:au.format("rotate({0} {1} {2})",-this._.rt.deg,d,E)});}else{this.transformations[0]=aA;this.clip&&aS(this.clip,{transform:aA});}aS(this.node,{transform:this.transformations[aH](at)});return this;};aF[a9].hide=function(){!this.removed&&(this.node.style.display="none");return this;};aF[a9].show=function(){!this.removed&&(this.node.style.display="");return this;};aF[a9].remove=function(){if(this.removed){return;}ap(this,this.paper);this.node.parentNode.removeChild(this.node);for(var d in this){delete this[d];}this.removed=true;};aF[a9].getBBox=function(){if(this.removed){return this;}if(this.type=="path"){return Y(this.attrs.path);}if(this.node.style.display=="none"){this.show();var E=true;}var bd={};try{bd=this.node.getBBox();}catch(S){}finally{bd=bd||{};}if(this.type=="text"){bd={x:bd.x,y:Infinity,width:0,height:0};for(var d=0,R=this.node.getNumberOfChars();d<R;d++){var bc=this.node.getExtentOfChar(d);(bc.y<bd.y)&&(bd.y=bc.y);(bc.y+bc.height-bd.y>bd.height)&&(bd.height=bc.y+bc.height-bd.y);(bc.x+bc.width-bd.x>bd.width)&&(bd.width=bc.x+bc.width-bd.x);}}E&&this.hide();return bd;};aF[a9].attr=function(E,bd){if(this.removed){return this;}if(E==null){var S={};for(var R in this.attrs){if(this.attrs[W](R)){S[R]=this.attrs[R];}}this._.rt.deg&&(S.rotation=this.rotate());(this._.sx!=1||this._.sy!=1)&&(S.scale=this.scale());S.gradient&&S.fill=="none"&&(S.fill=S.gradient)&&delete S.gradient;return S;}if(bd==null&&au.is(E,"string")){if(E=="translation"){return v.call(this);}if(E=="rotation"){return this.rotate();}if(E=="scale"){return this.scale();}if(E=="fill"&&this.attrs.fill=="none"&&this.attrs.gradient){return this.attrs.gradient;}return this.attrs[E];}if(bd==null&&au.is(E,"array")){var d={};for(var e=0,bc=E.length;e<bc;e++){d[E[e]]=this.attr(E[e]);}return d;}if(bd!=null){var be={};be[E]=bd;ae(this,be);}else{if(E!=null&&au.is(E,"object")){ae(this,E);}}return this;};aF[a9].toFront=function(){if(this.removed){return this;}this.node.parentNode[aU](this.node);var d=this.paper;d.top!=this&&ac(this,d);return this;};aF[a9].toBack=function(){if(this.removed){return this;}if(this.node.parentNode.firstChild!=this.node){this.node.parentNode.insertBefore(this.node,this.node.parentNode.firstChild);l(this,this.paper);var d=this.paper;}return this;};aF[a9].insertAfter=function(d){if(this.removed){return this;}var e=d.node;if(e.nextSibling){e.parentNode.insertBefore(this.node,e.nextSibling);}else{e.parentNode[aU](this.node);}D(this,d,this.paper);return this;};aF[a9].insertBefore=function(d){if(this.removed){return this;}var e=d.node;e.parentNode.insertBefore(this.node,e);ax(this,d,this.paper);return this;};aF[a9].blur=function(e){var d=this;if(+e!==0){var i=aS("filter"),E=aS("feGaussianBlur");d.attrs.blur=e;i.id="r"+(au._id++)[aJ](36);aS(E,{stdDeviation:+e||1.5});i.appendChild(E);d.paper.defs.appendChild(i);d._blur=i;aS(d.node,{filter:"url(#"+i.id+")"});}else{if(d._blur){d._blur.parentNode.removeChild(d._blur);delete d._blur;delete d.attrs.blur;}d.node.removeAttribute("filter");}};var V=function(e,d,S,R){d=U(d);S=U(S);var E=aS("circle");e.canvas&&e.canvas[aU](E);var i=new aF(E,e);i.attrs={cx:d,cy:S,r:R,fill:"none",stroke:"#000"};i.type="circle";aS(E,i.attrs);return i;};var aO=function(i,d,bd,e,S,bc){d=U(d);bd=U(bd);var R=aS("rect");i.canvas&&i.canvas[aU](R);var E=new aF(R,i);E.attrs={x:d,y:bd,width:e,height:S,r:bc||0,rx:bc||0,ry:bc||0,fill:"none",stroke:"#000"};E.type="rect";aS(R,E.attrs);return E;};var am=function(e,d,bc,S,R){d=U(d);bc=U(bc);var E=aS("ellipse");e.canvas&&e.canvas[aU](E);var i=new aF(E,e);i.attrs={cx:d,cy:bc,rx:S,ry:R,fill:"none",stroke:"#000"};i.type="ellipse";aS(E,i.attrs);return i;};var q=function(i,bc,d,bd,e,S){var R=aS("image");aS(R,{x:d,y:bd,width:e,height:S,preserveAspectRatio:"none"});R.setAttributeNS(i.xlink,"href",bc);i.canvas&&i.canvas[aU](R);var E=new aF(R,i);E.attrs={x:d,y:bd,width:e,height:S,src:bc};E.type="image";return E;};var ab=function(e,d,S,R){var E=aS("text");aS(E,{x:d,y:S,"text-anchor":"middle"});e.canvas&&e.canvas[aU](E);var i=new aF(E,e);i.attrs={x:d,y:S,"text-anchor":"middle",text:R,font:k.font,stroke:"none",fill:"#000"};i.type="text";ae(i,i.attrs);return i;};var a6=function(e,d){this.width=e||this.width;this.height=d||this.height;this.canvas[y]("width",this.width);this.canvas[y]("height",this.height);return this;};var z=function(){var E=av[a7](0,arguments),i=E&&E.container,e=E.x,bc=E.y,R=E.width,d=E.height;if(!i){throw new Error("SVG container not found.");}var S=aS("svg");R=R||512;d=d||342;aS(S,{xmlns:"http://www.w3.org/2000/svg",version:1.1,width:R,height:d});if(i==1){S.style.cssText="position:absolute;left:"+e+"px;top:"+bc+"px";P.body[aU](S);}else{if(i.firstChild){i.insertBefore(S,i.firstChild);}else{i[aU](S);}}i=new a4;i.width=R;i.height=d;i.canvas=S;aP.call(i,i,au.fn);i.clear();return i;};a4[a9].clear=function(){var d=this.canvas;while(d.firstChild){d.removeChild(d.firstChild);}this.bottom=this.top=null;(this.desc=aS("desc"))[aU](P.createTextNode("Created with Rapha\xebl"));d[aU](this.desc);d[aU](this.defs=aS("defs"));};a4[a9].remove=function(){this.canvas.parentNode&&this.canvas.parentNode.removeChild(this.canvas);for(var d in this){this[d]=u(d);}};}if(au.vml){var H={M:"m",L:"l",C:"c",Z:"x",m:"t",l:"r",c:"v",z:"x"},ay=/([clmz]),?([^clmz]*)/gi,ba=/-?[^,\s-]+/g,aI=1000+at+1000,p=10,aQ=function(bh){var be=/[ahqstv]/ig,E=t;(bh+aA).match(be)&&(E=L);be=/[clmz]/g;if(E==t&&!(bh+aA).match(be)){var bd=(bh+aA)[aZ](ay,function(bk,bm,bi){var bl=[],i=bb.call(bm)=="m",bj=H[bm];bi[aZ](ba,function(bn){if(i&&bl[n]==2){bj+=bl+H[bm=="m"?"l":"L"];bl=[];}bl[f](U(bn*p));});return bj+bl;});return bd;}var bf=E(bh),e,d;bd=[];for(var S=0,bg=bf[n];S<bg;S++){e=bf[S];d=bb.call(bf[S][0]);d=="z"&&(d="x");for(var R=1,bc=e[n];R<bc;R++){d+=U(e[R]*p)+(R!=bc-1?",":aA);}bd[f](d);}return bd[aH](at);};au[aJ]=function(){return"Your browser doesn\u2019t support SVG. Falling down to VML.\nYou are running Rapha\xebl "+this.version;};s=function(i,e){var S=al("group");S.style.cssText="position:absolute;left:0;top:0;width:"+e.width+"px;height:"+e.height+"px";S.coordsize=e.coordsize;S.coordorigin=e.coordorigin;var R=al("shape"),E=R.style;E.width=e.width+"px";E.height=e.height+"px";R.coordsize=aI;R.coordorigin=e.coordorigin;S[aU](R);var bc=new aF(R,S,e),d={fill:"none",stroke:"#000"};i&&(d.path=i);bc.isAbsolute=true;bc.type="path";bc.path=[];bc.Path=aA;ae(bc,d);e.canvas[aU](S);return bc;};ae=function(bf,bk){bf.attrs=bf.attrs||{};var bi=bf.node,bl=bf.attrs,bc=bi.style,E,bp=bf;for(var bd in bk){if(bk[W](bd)){bl[bd]=bk[bd];}}bk.href&&(bi.href=bk.href);bk.title&&(bi.title=bk.title);bk.target&&(bi.target=bk.target);bk.cursor&&(bc.cursor=bk.cursor);"blur" in bk&&bf.blur(bk.blur);if(bk.path&&bf.type=="path"){bl.path=bk.path;bi.path=aQ(bl.path);}if(bk.rotation!=null){bf.rotate(bk.rotation,true);}if(bk.translation){E=(bk.translation+aA)[C](a);v.call(bf,E[0],E[1]);if(bf._.rt.cx!=null){bf._.rt.cx+=+E[0];bf._.rt.cy+=+E[1];bf.setBox(bf.attrs,E[0],E[1]);}}if(bk.scale){E=(bk.scale+aA)[C](a);bf.scale(+E[0]||1,+E[1]||+E[0]||1,+E[2]||null,+E[3]||null);}if("clip-rect" in bk){var d=(bk["clip-rect"]+aA)[C](a);if(d[n]==4){d[2]=+d[2]+(+d[0]);d[3]=+d[3]+(+d[1]);var be=bi.clipRect||P.createElement("div"),bo=be.style,S=bi.parentNode;bo.clip=au.format("rect({1}px {2}px {3}px {0}px)",d);if(!bi.clipRect){bo.position="absolute";bo.top=0;bo.left=0;bo.width=bf.paper.width+"px";bo.height=bf.paper.height+"px";S.parentNode.insertBefore(be,S);be[aU](S);bi.clipRect=be;}}if(!bk["clip-rect"]){bi.clipRect&&(bi.clipRect.style.clip=aA);}}if(bf.type=="image"&&bk.src){bi.src=bk.src;}if(bf.type=="image"&&bk.opacity){bi.filterOpacity=" progid:DXImageTransform.Microsoft.Alpha(opacity="+(bk.opacity*100)+")";bc.filter=(bi.filterMatrix||aA)+(bi.filterOpacity||aA);}bk.font&&(bc.font=bk.font);bk["font-family"]&&(bc.fontFamily='"'+bk["font-family"][C](",")[0][aZ](/^['"]+|['"]+$/g,aA)+'"');bk["font-size"]&&(bc.fontSize=bk["font-size"]);bk["font-weight"]&&(bc.fontWeight=bk["font-weight"]);bk["font-style"]&&(bc.fontStyle=bk["font-style"]);if(bk.opacity!=null||bk["stroke-width"]!=null||bk.fill!=null||bk.stroke!=null||bk["stroke-width"]!=null||bk["stroke-opacity"]!=null||bk["fill-opacity"]!=null||bk["stroke-dasharray"]!=null||bk["stroke-miterlimit"]!=null||bk["stroke-linejoin"]!=null||bk["stroke-linecap"]!=null){bi=bf.shape||bi;var bj=(bi.getElementsByTagName("fill")&&bi.getElementsByTagName("fill")[0]),bm=false;!bj&&(bm=bj=al("fill"));if("fill-opacity" in bk||"opacity" in bk){var e=((+bl["fill-opacity"]+1||2)-1)*((+bl.opacity+1||2)-1);e<0&&(e=0);e>1&&(e=1);bj.opacity=e;}bk.fill&&(bj.on=true);if(bj.on==null||bk.fill=="none"){bj.on=false;}if(bj.on&&bk.fill){var i=bk.fill.match(c);if(i){bj.src=i[1];bj.type="tile";}else{bj.color=au.getRGB(bk.fill).hex;bj.src=aA;bj.type="solid";if(au.getRGB(bk.fill).error&&(bp.type in {circle:1,ellipse:1}||(bk.fill+aA).charAt()!="r")&&b(bp,bk.fill)){bl.fill="none";bl.gradient=bk.fill;}}}bm&&bi[aU](bj);var R=(bi.getElementsByTagName("stroke")&&bi.getElementsByTagName("stroke")[0]),bn=false;!R&&(bn=R=al("stroke"));if((bk.stroke&&bk.stroke!="none")||bk["stroke-width"]||bk["stroke-opacity"]!=null||bk["stroke-dasharray"]||bk["stroke-miterlimit"]||bk["stroke-linejoin"]||bk["stroke-linecap"]){R.on=true;}(bk.stroke=="none"||R.on==null||bk.stroke==0||bk["stroke-width"]==0)&&(R.on=false);R.on&&bk.stroke&&(R.color=au.getRGB(bk.stroke).hex);e=((+bl["stroke-opacity"]+1||2)-1)*((+bl.opacity+1||2)-1);var bg=(aa(bk["stroke-width"])||1)*0.75;e<0&&(e=0);e>1&&(e=1);bk["stroke-width"]==null&&(bg=bl["stroke-width"]);bk["stroke-width"]&&(R.weight=bg);bg&&bg<1&&(e*=bg)&&(R.weight=1);R.opacity=e;bk["stroke-linejoin"]&&(R.joinstyle=bk["stroke-linejoin"]||"miter");R.miterlimit=bk["stroke-miterlimit"]||8;bk["stroke-linecap"]&&(R.endcap=bk["stroke-linecap"]=="butt"?"flat":bk["stroke-linecap"]=="square"?"square":"round");if(bk["stroke-dasharray"]){var bh={"-":"shortdash",".":"shortdot","-.":"shortdashdot","-..":"shortdashdotdot",". ":"dot","- ":"dash","--":"longdash","- .":"dashdot","--.":"longdashdot","--..":"longdashdotdot"};R.dashstyle=bh[W](bk["stroke-dasharray"])?bh[bk["stroke-dasharray"]]:aA;}bn&&bi[aU](R);}if(bp.type=="text"){bc=bp.paper.span.style;bl.font&&(bc.font=bl.font);bl["font-family"]&&(bc.fontFamily=bl["font-family"]);bl["font-size"]&&(bc.fontSize=bl["font-size"]);bl["font-weight"]&&(bc.fontWeight=bl["font-weight"]);bl["font-style"]&&(bc.fontStyle=bl["font-style"]);bp.node.string&&(bp.paper.span.innerHTML=(bp.node.string+aA)[aZ](/</g,"<")[aZ](/&/g,"&")[aZ](/\n/g,"<br>"));bp.W=bl.w=bp.paper.span.offsetWidth;bp.H=bl.h=bp.paper.span.offsetHeight;bp.X=bl.x;bp.Y=bl.y+U(bp.H/2);switch(bl["text-anchor"]){case"start":bp.node.style["v-text-align"]="left";bp.bbx=U(bp.W/2);break;case"end":bp.node.style["v-text-align"]="right";bp.bbx=-U(bp.W/2);break;default:bp.node.style["v-text-align"]="center";break;}}};b=function(d,bd){d.attrs=d.attrs||{};var be=d.attrs,bg=d.node.getElementsByTagName("fill"),S="linear",bc=".5 .5";d.attrs.gradient=bd;bd=(bd+aA)[aZ](az,function(bi,bj,i){S="radial";if(bj&&i){bj=aa(bj);i=aa(i);aV(bj-0.5,2)+aV(i-0.5,2)>0.25&&(i=af.sqrt(0.25-aV(bj-0.5,2))*((i>0.5)*2-1)+0.5);bc=bj+at+i;}return aA;});bd=bd[C](/\s*\-\s*/);if(S=="linear"){var e=bd.shift();e=-aa(e);if(isNaN(e)){return null;}}var R=r(bd);if(!R){return null;}d=d.shape||d.node;bg=bg[0]||al("fill");if(R[n]){bg.on=true;bg.method="none";bg.type=(S=="radial")?"gradientradial":"gradient";bg.color=R[0].color;bg.color2=R[R[n]-1].color;var bh=[];for(var E=0,bf=R[n];E<bf;E++){R[E].offset&&bh[f](R[E].offset+at+R[E].color);}bg.colors&&(bg.colors.value=bh[n]?bh[aH](","):"0% "+bg.color);if(S=="radial"){bg.focus="100%";bg.focussize=bc;bg.focusposition=bc;}else{bg.angle=(270-e)%360;}}return 1;};aF=function(R,bc,d){var S=0,i=0,e=0,E=1;this[0]=R;this.id=au._oid++;this.node=R;R.raphael=this;this.X=0;this.Y=0;this.attrs={};this.Group=bc;this.paper=d;this._={tx:0,ty:0,rt:{deg:0},sx:1,sy:1};!d.bottom&&(d.bottom=this);this.prev=d.top;d.top&&(d.top.next=this);d.top=this;this.next=null;};aF[a9].rotate=function(e,d,i){if(this.removed){return this;}if(e==null){if(this._.rt.cx){return[this._.rt.deg,this._.rt.cx,this._.rt.cy][aH](at);}return this._.rt.deg;}e=(e+aA)[C](a);if(e[n]-1){d=aa(e[1]);i=aa(e[2]);}e=aa(e[0]);if(d!=null){this._.rt.deg=e;}else{this._.rt.deg+=e;}i==null&&(d=null);this._.rt.cx=d;this._.rt.cy=i;this.setBox(this.attrs,d,i);this.Group.style.rotation=this._.rt.deg;return this;};aF[a9].setBox=function(bo,e,d){if(this.removed){return this;}var bi=this.Group.style,R=(this.shape&&this.shape.style)||this.node.style;bo=bo||{};for(var bm in bo){if(bo[W](bm)){this.attrs[bm]=bo[bm];}}e=e||this._.rt.cx;d=d||this._.rt.cy;var bk=this.attrs,bd,bc,be,bn;switch(this.type){case"circle":bd=bk.cx-bk.r;bc=bk.cy-bk.r;be=bn=bk.r*2;break;case"ellipse":bd=bk.cx-bk.rx;bc=bk.cy-bk.ry;be=bk.rx*2;bn=bk.ry*2;break;case"rect":case"image":bd=+bk.x;bc=+bk.y;be=bk.width||0;bn=bk.height||0;break;case"text":this.textpath.v=["m",U(bk.x),", ",U(bk.y-2),"l",U(bk.x)+1,", ",U(bk.y-2)][aH](aA);bd=bk.x-U(this.W/2);bc=bk.y-this.H/2;be=this.W;bn=this.H;break;case"path":if(!this.attrs.path){bd=0;bc=0;be=this.paper.width;bn=this.paper.height;}else{var bl=Y(this.attrs.path);bd=bl.x;bc=bl.y;be=bl.width;bn=bl.height;}break;default:bd=0;bc=0;be=this.paper.width;bn=this.paper.height;break;}e=(e==null)?bd+be/2:e;d=(d==null)?bc+bn/2:d;var E=e-this.paper.width/2,bh=d-this.paper.height/2,bg;bi.left!=(bg=E+"px")&&(bi.left=bg);bi.top!=(bg=bh+"px")&&(bi.top=bg);this.X=this.type=="path"?-E:bd;this.Y=this.type=="path"?-bh:bc;this.W=be;this.H=bn;if(this.type=="path"){R.left!=(bg=-E*p+"px")&&(R.left=bg);R.top!=(bg=-bh*p+"px")&&(R.top=bg);}else{if(this.type=="text"){R.left!=(bg=-E+"px")&&(R.left=bg);R.top!=(bg=-bh+"px")&&(R.top=bg);}else{bi.width!=(bg=this.paper.width+"px")&&(bi.width=bg);bi.height!=(bg=this.paper.height+"px")&&(bi.height=bg);R.left!=(bg=bd-E+"px")&&(R.left=bg);R.top!=(bg=bc-bh+"px")&&(R.top=bg);R.width!=(bg=be+"px")&&(R.width=bg);R.height!=(bg=bn+"px")&&(R.height=bg);var S=(+bo.r||0)/aR(be,bn);if(this.type=="rect"&&this.arcsize.toFixed(4)!=S.toFixed(4)&&(S||this.arcsize)){var bj=al("roundrect"),bp={},bf=this.events&&this.events[n];bm=0;bj.arcsize=S;bj.raphael=this;this.Group[aU](bj);this.Group.removeChild(this.node);this[0]=this.node=bj;this.arcsize=S;for(bm in bk){bp[bm]=bk[bm];}delete bp.scale;this.attr(bp);if(this.events){for(;bm<bf;bm++){this.events[bm].unbind=ai(this.node,this.events[bm].name,this.events[bm].f,this);}}}}}};aF[a9].hide=function(){!this.removed&&(this.Group.style.display="none");return this;};aF[a9].show=function(){!this.removed&&(this.Group.style.display="block");return this;};aF[a9].getBBox=function(){if(this.removed){return this;}if(this.type=="path"){return Y(this.attrs.path);}return{x:this.X+(this.bbx||0),y:this.Y,width:this.W,height:this.H};};aF[a9].remove=function(){if(this.removed){return;}ap(this,this.paper);this.node.parentNode.removeChild(this.node);this.Group.parentNode.removeChild(this.Group);this.shape&&this.shape.parentNode.removeChild(this.shape);for(var d in this){delete this[d];}this.removed=true;};aF[a9].attr=function(e,bc){if(this.removed){return this;}if(e==null){var R={};for(var E in this.attrs){if(this.attrs[W](E)){R[E]=this.attrs[E];}}this._.rt.deg&&(R.rotation=this.rotate());(this._.sx!=1||this._.sy!=1)&&(R.scale=this.scale());R.gradient&&R.fill=="none"&&(R.fill=R.gradient)&&delete R.gradient;return R;}if(bc==null&&au.is(e,"string")){if(e=="translation"){return v.call(this);}if(e=="rotation"){return this.rotate();}if(e=="scale"){return this.scale();}if(e=="fill"&&this.attrs.fill=="none"&&this.attrs.gradient){return this.attrs.gradient;}return this.attrs[e];}if(this.attrs&&bc==null&&au.is(e,"array")){var S,d={};for(E=0,S=e[n];E<S;E++){d[e[E]]=this.attr(e[E]);}return d;}var bd;if(bc!=null){bd={};bd[e]=bc;}bc==null&&au.is(e,"object")&&(bd=e);if(bd){if(bd.text&&this.type=="text"){this.node.string=bd.text;}ae(this,bd);if(bd.gradient&&(({circle:1,ellipse:1})[W](this.type)||(bd.gradient+aA).charAt()!="r")){b(this,bd.gradient);}(this.type!="path"||this._.rt.deg)&&this.setBox(this.attrs);}return this;};aF[a9].toFront=function(){!this.removed&&this.Group.parentNode[aU](this.Group);this.paper.top!=this&&ac(this,this.paper);return this;};aF[a9].toBack=function(){if(this.removed){return this;}if(this.Group.parentNode.firstChild!=this.Group){this.Group.parentNode.insertBefore(this.Group,this.Group.parentNode.firstChild);l(this,this.paper);}return this;};aF[a9].insertAfter=function(d){if(this.removed){return this;}if(d.Group.nextSibling){d.Group.parentNode.insertBefore(this.Group,d.Group.nextSibling);}else{d.Group.parentNode[aU](this.Group);}D(this,d,this.paper);return this;};aF[a9].insertBefore=function(d){if(this.removed){return this;}d.Group.parentNode.insertBefore(this.Group,d.Group);ax(this,d,this.paper);return this;};var a3=/ progid:\S+Blur\([^\)]+\)/g;aF[a9].blur=function(d){var e=this.node.style,i=e.filter;i=i.replace(a3,"");if(+d!==0){this.attrs.blur=d;e.filter=i+" progid:DXImageTransform.Microsoft.Blur(pixelradius="+(+d||1.5)+")";e.margin=Raphael.format("-{0}px 0 0 -{0}px",Math.round(+d||1.5));}else{e.filter=i;e.margin=0;delete this.attrs.blur;}};V=function(e,d,bd,S){var R=al("group"),bc=al("oval"),i=bc.style;R.style.cssText="position:absolute;left:0;top:0;width:"+e.width+"px;height:"+e.height+"px";R.coordsize=aI;R.coordorigin=e.coordorigin;R[aU](bc);var E=new aF(bc,R,e);E.type="circle";ae(E,{stroke:"#000",fill:"none"});E.attrs.cx=d;E.attrs.cy=bd;E.attrs.r=S;E.setBox({x:d-S,y:bd-S,width:S*2,height:S*2});e.canvas[aU](R);return E;};aO=function(e,bd,bc,be,E,d){var R=al("group"),i=al("roundrect"),bf=(+d||0)/(aR(be,E));R.style.cssText="position:absolute;left:0;top:0;width:"+e.width+"px;height:"+e.height+"px";R.coordsize=aI;R.coordorigin=e.coordorigin;R[aU](i);i.arcsize=bf;var S=new aF(i,R,e);S.type="rect";ae(S,{stroke:"#000"});S.arcsize=bf;S.setBox({x:bd,y:bc,width:be,height:E,r:d});e.canvas[aU](R);return S;};am=function(d,be,bd,i,e){var R=al("group"),E=al("oval"),bc=E.style;R.style.cssText="position:absolute;left:0;top:0;width:"+d.width+"px;height:"+d.height+"px";R.coordsize=aI;R.coordorigin=d.coordorigin;R[aU](E);var S=new aF(E,R,d);S.type="ellipse";ae(S,{stroke:"#000"});S.attrs.cx=be;S.attrs.cy=bd;S.attrs.rx=i;S.attrs.ry=e;S.setBox({x:be-i,y:bd-e,width:i*2,height:e*2});d.canvas[aU](R);return S;};q=function(e,d,be,bd,bf,E){var R=al("group"),i=al("image"),bc=i.style;R.style.cssText="position:absolute;left:0;top:0;width:"+e.width+"px;height:"+e.height+"px";R.coordsize=aI;R.coordorigin=e.coordorigin;i.src=d;R[aU](i);var S=new aF(i,R,e);S.type="image";S.attrs.src=d;S.attrs.x=be;S.attrs.y=bd;S.attrs.w=bf;S.attrs.h=E;S.setBox({x:be,y:bd,width:bf,height:E});e.canvas[aU](R);return S;};ab=function(e,be,bd,bf){var R=al("group"),E=al("shape"),bc=E.style,bg=al("path"),d=bg.style,i=al("textpath");R.style.cssText="position:absolute;left:0;top:0;width:"+e.width+"px;height:"+e.height+"px";R.coordsize=aI;R.coordorigin=e.coordorigin;bg.v=au.format("m{0},{1}l{2},{1}",U(be*10),U(bd*10),U(be*10)+1);bg.textpathok=true;bc.width=e.width;bc.height=e.height;i.string=bf+aA;i.on=true;E[aU](i);E[aU](bg);R[aU](E);var S=new aF(i,R,e);S.shape=E;S.textpath=bg;S.type="text";S.attrs.text=bf;S.attrs.x=be;S.attrs.y=bd;S.attrs.w=1;S.attrs.h=1;ae(S,{font:k.font,stroke:"none",fill:"#000"});S.setBox();e.canvas[aU](R);return S;};a6=function(i,d){var e=this.canvas.style;i==+i&&(i+="px");d==+d&&(d+="px");e.width=i;e.height=d;e.clip="rect(0 "+i+" "+d+" 0)";return this;};var al;P.createStyleSheet().addRule(".rvml","behavior:url(#default#VML)");try{!P.namespaces.rvml&&P.namespaces.add("rvml","urn:schemas-microsoft-com:vml");al=function(d){return P.createElement("<rvml:"+d+' class="rvml">');};}catch(aj){al=function(d){return P.createElement("<"+d+' xmlns="urn:schemas-microsoft.com:vml" class="rvml">');};}z=function(){var i=av[a7](0,arguments),d=i.container,be=i.height,bf,e=i.width,bd=i.x,bc=i.y;if(!d){throw new Error("VML container not found.");}var R=new a4,S=R.canvas=P.createElement("div"),E=S.style;e=e||512;be=be||342;e==+e&&(e+="px");be==+be&&(be+="px");R.width=1000;R.height=1000;R.coordsize=p*1000+at+p*1000;R.coordorigin="0 0";R.span=P.createElement("span");R.span.style.cssText="position:absolute;left:-9999em;top:-9999em;padding:0;margin:0;line-height:1;display:inline;";S[aU](R.span);E.cssText=au.format("width:{0};height:{1};position:absolute;clip:rect(0 {0} {1} 0);overflow:hidden",e,be);if(d==1){P.body[aU](S);E.left=bd+"px";E.top=bc+"px";}else{d.style.width=e;d.style.height=be;if(d.firstChild){d.insertBefore(S,d.firstChild);}else{d[aU](S);}}aP.call(R,R,au.fn);return R;};a4[a9].clear=function(){this.canvas.innerHTML=aA;this.span=P.createElement("span");this.span.style.cssText="position:absolute;left:-9999em;top:-9999em;padding:0;margin:0;line-height:1;display:inline;";this.canvas[aU](this.span);this.bottom=this.top=null;};a4[a9].remove=function(){this.canvas.parentNode.removeChild(this.canvas);for(var d in this){this[d]=u(d);}return true;};}if((/^Apple|^Google/).test(aB.navigator.vendor)&&!(aB.navigator.userAgent.indexOf("Version/4.0")+1)){a4[a9].safari=function(){var d=this.rect(-99,-99,this.width+99,this.height+99);aB.setTimeout(function(){d.remove();});};}else{a4[a9].safari=function(){};}var ai=(function(){if(P.addEventListener){return function(R,i,e,d){var E=function(S){return e.call(d,S);};R.addEventListener(i,E,false);return function(){R.removeEventListener(i,E,false);return true;};};}else{if(P.attachEvent){return function(S,E,i,e){var R=function(bc){return i.call(e,bc||aB.event);};S.attachEvent("on"+E,R);var d=function(){S.detachEvent("on"+E,R);return true;};return d;};}}})();for(var ag=J[n];ag--;){(function(d){aF[a9][d]=function(e){if(au.is(e,"function")){this.events=this.events||[];this.events.push({name:d,f:e,unbind:ai(this.shape||this.node,d,e,this)});}return this;};aF[a9]["un"+d]=function(E){var i=this.events,e=i[n];while(e--){if(i[e].name==d&&i[e].f==E){i[e].unbind();i.splice(e,1);!i.length&&delete this.events;return this;}}return this;};})(J[ag]);}aF[a9].hover=function(e,d){return this.mouseover(e).mouseout(d);};aF[a9].unhover=function(e,d){return this.unmouseover(e).unmouseout(d);};a4[a9].circle=function(d,i,e){return V(this,d||0,i||0,e||0);};a4[a9].rect=function(d,R,e,i,E){return aO(this,d||0,R||0,e||0,i||0,E||0);};a4[a9].ellipse=function(d,E,i,e){return am(this,d||0,E||0,i||0,e||0);};a4[a9].path=function(d){d&&!au.is(d,"string")&&!au.is(d[0],"array")&&(d+=aA);return s(au.format[a7](au,arguments),this);};a4[a9].image=function(E,d,R,e,i){return q(this,E||"about:blank",d||0,R||0,e||0,i||0);};a4[a9].text=function(d,i,e){return ab(this,d||0,i||0,e||aA);};a4[a9].set=function(d){arguments[n]>1&&(d=Array[a9].splice.call(arguments,0,arguments[n]));return new X(d);};a4[a9].setSize=a6;a4[a9].top=a4[a9].bottom=null;a4[a9].raphael=au;function x(){return this.x+at+this.y;}aF[a9].scale=function(bi,bh,E,e){if(bi==null&&bh==null){return{x:this._.sx,y:this._.sy,toString:x};}bh=bh||bi;!+bh&&(bh=bi);var bm,bk,bl,bj,by=this.attrs;if(bi!=0){var bg=this.getBBox(),bd=bg.x+bg.width/2,R=bg.y+bg.height/2,bx=bi/this._.sx,bw=bh/this._.sy;E=(+E||E==0)?E:bd;e=(+e||e==0)?e:R;var bf=~~(bi/af.abs(bi)),bc=~~(bh/af.abs(bh)),bp=this.node.style,bA=E+(bd-E)*bx,bz=e+(R-e)*bw;switch(this.type){case"rect":case"image":var be=by.width*bf*bx,bo=by.height*bc*bw;this.attr({height:bo,r:by.r*aR(bf*bx,bc*bw),width:be,x:bA-be/2,y:bz-bo/2});break;case"circle":case"ellipse":this.attr({rx:by.rx*bf*bx,ry:by.ry*bc*bw,r:by.r*aR(bf*bx,bc*bw),cx:bA,cy:bz});break;case"path":var br=ah(by.path),bs=true;for(var bu=0,bn=br[n];bu<bn;bu++){var bq=br[bu],S=aX.call(bq[0]);if(S=="M"&&bs){continue;}else{bs=false;}if(S=="A"){bq[br[bu][n]-2]*=bx;bq[br[bu][n]-1]*=bw;bq[1]*=bf*bx;bq[2]*=bc*bw;bq[5]=+!(bf+bc?!+bq[5]:+bq[5]);}else{if(S=="H"){for(var bt=1,bv=bq[n];bt<bv;bt++){bq[bt]*=bx;}}else{if(S=="V"){for(bt=1,bv=bq[n];bt<bv;bt++){bq[bt]*=bw;}}else{for(bt=1,bv=bq[n];bt<bv;bt++){bq[bt]*=(bt%2)?bx:bw;}}}}}var d=Y(br);bm=bA-d.x-d.width/2;bk=bz-d.y-d.height/2;br[0][1]+=bm;br[0][2]+=bk;this.attr({path:br});break;}if(this.type in {text:1,image:1}&&(bf!=1||bc!=1)){if(this.transformations){this.transformations[2]="scale("[a2](bf,",",bc,")");this.node[y]("transform",this.transformations[aH](at));bm=(bf==-1)?-by.x-(be||0):by.x;bk=(bc==-1)?-by.y-(bo||0):by.y;this.attr({x:bm,y:bk});by.fx=bf-1;by.fy=bc-1;}else{this.node.filterMatrix=" progid:DXImageTransform.Microsoft.Matrix(M11="[a2](bf,", M12=0, M21=0, M22=",bc,", Dx=0, Dy=0, sizingmethod='auto expand', filtertype='bilinear')");bp.filter=(this.node.filterMatrix||aA)+(this.node.filterOpacity||aA);}}else{if(this.transformations){this.transformations[2]=aA;this.node[y]("transform",this.transformations[aH](at));by.fx=0;by.fy=0;}else{this.node.filterMatrix=aA;bp.filter=(this.node.filterMatrix||aA)+(this.node.filterOpacity||aA);}}by.scale=[bi,bh,E,e][aH](at);this._.sx=bi;this._.sy=bh;}return this;};aF[a9].clone=function(){var d=this.attr();delete d.scale;delete d.translation;return this.paper[this.type]().attr(d);};var g=an(function(E,d,bd,bc,bj,bi,bh,bg,R){var bf=0,S;for(var be=0;be<1.001;be+=0.001){var e=au.findDotsAtSegment(E,d,bd,bc,bj,bi,bh,bg,be);be&&(bf+=aV(aV(S.x-e.x,2)+aV(S.y-e.y,2),0.5));if(bf>=R){return e;}S=e;}}),aK=function(d,e){return function(bl,S,bc){bl=L(bl);var bh,bg,E,bd,R="",bk={},bi,bf=0;for(var be=0,bj=bl.length;be<bj;be++){E=bl[be];if(E[0]=="M"){bh=+E[1];bg=+E[2];}else{bd=o(bh,bg,E[1],E[2],E[3],E[4],E[5],E[6]);if(bf+bd>S){if(e&&!bk.start){bi=g(bh,bg,E[1],E[2],E[3],E[4],E[5],E[6],S-bf);R+=["C",bi.start.x,bi.start.y,bi.m.x,bi.m.y,bi.x,bi.y];if(bc){return R;}bk.start=R;R=["M",bi.x,bi.y+"C",bi.n.x,bi.n.y,bi.end.x,bi.end.y,E[5],E[6]][aH]();bf+=bd;bh=+E[5];bg=+E[6];continue;}if(!d&&!e){bi=g(bh,bg,E[1],E[2],E[3],E[4],E[5],E[6],S-bf);return{x:bi.x,y:bi.y,alpha:bi.alpha};}}bf+=bd;bh=+E[5];bg=+E[6];}R+=E;}bk.end=R;bi=d?bf:e?bk:au.findDotsAtSegment(bh,bg,E[1],E[2],E[3],E[4],E[5],E[6],1);bi.alpha&&(bi={x:bi.x,y:bi.y,alpha:bi.alpha});return bi;};},o=an(function(E,d,bc,S,bi,bh,bg,bf){var R={x:0,y:0},be=0;for(var bd=0;bd<1.01;bd+=0.01){var e=T(E,d,bc,S,bi,bh,bg,bf,bd);bd&&(be+=aV(aV(R.x-e.x,2)+aV(R.y-e.y,2),0.5));R=e;}return be;});var aw=aK(1),G=aK(),N=aK(0,1);aF[a9].getTotalLength=function(){if(this.type!="path"){return;}return aw(this.attrs.path);};aF[a9].getPointAtLength=function(d){if(this.type!="path"){return;}return G(this.attrs.path,d);};aF[a9].getSubpath=function(i,e){if(this.type!="path"){return;}if(af.abs(this.getTotalLength()-e)<0.000001){return N(this.attrs.path,i).end;}var d=N(this.attrs.path,e,1);return i?N(d,i).end:d;};au.easing_formulas={linear:function(d){return d;},"<":function(d){return aV(d,3);},">":function(d){return aV(d-1,3)+1;},"<>":function(d){d=d*2;if(d<1){return aV(d,3)/2;}d-=2;return(aV(d,3)+2)/2;},backIn:function(e){var d=1.70158;return e*e*((d+1)*e-d);},backOut:function(e){e=e-1;var d=1.70158;return e*e*((d+1)*e+d)+1;},elastic:function(i){if(i==0||i==1){return i;}var e=0.3,d=e/4;return aV(2,-10*i)*af.sin((i-d)*(2*af.PI)/e)+1;},bounce:function(E){var e=7.5625,i=2.75,d;if(E<(1/i)){d=e*E*E;}else{if(E<(2/i)){E-=(1.5/i);d=e*E*E+0.75;}else{if(E<(2.5/i)){E-=(2.25/i);d=e*E*E+0.9375;}else{E-=(2.625/i);d=e*E*E+0.984375;}}}return d;}};var M={length:0},a1=function(){var be=+new Date;for(var bq in M){if(bq!="length"&&M[W](bq)){var bv=M[bq];if(bv.stop||bv.el.removed){delete M[bq];M[n]--;continue;}var bc=be-bv.start,bn=bv.ms,bm=bv.easing,br=bv.from,bj=bv.diff,E=bv.to,bi=bv.t,bl=bv.prev||0,bd=bv.el,R=bv.callback,bk={},d;if(bc<bn){var S=au.easing_formulas[bm]?au.easing_formulas[bm](bc/bn):bc/bn;for(var bo in br){if(br[W](bo)){switch(ad[bo]){case"along":d=S*bn*bj[bo];E.back&&(d=E.len-d);var bp=G(E[bo],d);bd.translate(bj.sx-bj.x||0,bj.sy-bj.y||0);bj.x=bp.x;bj.y=bp.y;bd.translate(bp.x-bj.sx,bp.y-bj.sy);E.rot&&bd.rotate(bj.r+bp.alpha,bp.x,bp.y);break;case"number":d=+br[bo]+S*bn*bj[bo];break;case"colour":d="rgb("+[F(U(br[bo].r+S*bn*bj[bo].r)),F(U(br[bo].g+S*bn*bj[bo].g)),F(U(br[bo].b+S*bn*bj[bo].b))][aH](",")+")";break;case"path":d=[];for(var bt=0,bh=br[bo][n];bt<bh;bt++){d[bt]=[br[bo][bt][0]];for(var bs=1,bu=br[bo][bt][n];bs<bu;bs++){d[bt][bs]=+br[bo][bt][bs]+S*bn*bj[bo][bt][bs];}d[bt]=d[bt][aH](at);}d=d[aH](at);break;case"csv":switch(bo){case"translation":var bg=bj[bo][0]*(bc-bl),bf=bj[bo][1]*(bc-bl);bi.x+=bg;bi.y+=bf;d=bg+at+bf;break;case"rotation":d=+br[bo][0]+S*bn*bj[bo][0];br[bo][1]&&(d+=","+br[bo][1]+","+br[bo][2]);break;case"scale":d=[+br[bo][0]+S*bn*bj[bo][0],+br[bo][1]+S*bn*bj[bo][1],(2 in E[bo]?E[bo][2]:aA),(3 in E[bo]?E[bo][3]:aA)][aH](at);break;case"clip-rect":d=[];bt=4;while(bt--){d[bt]=+br[bo][bt]+S*bn*bj[bo][bt];}break;}break;}bk[bo]=d;}}bd.attr(bk);bd._run&&bd._run.call(bd);}else{if(E.along){bp=G(E.along,E.len*!E.back);bd.translate(bj.sx-(bj.x||0)+bp.x-bj.sx,bj.sy-(bj.y||0)+bp.y-bj.sy);E.rot&&bd.rotate(bj.r+bp.alpha,bp.x,bp.y);}(bi.x||bi.y)&&bd.translate(-bi.x,-bi.y);E.scale&&(E.scale=E.scale+aA);bd.attr(E);delete M[bq];M[n]--;bd.in_animation=null;au.is(R,"function")&&R.call(bd);}bv.prev=bc;}}au.svg&&bd&&bd.paper.safari();M[n]&&aB.setTimeout(a1);},F=function(d){return d>255?255:(d<0?0:d);},v=function(d,i){if(d==null){return{x:this._.tx,y:this._.ty,toString:x};}this._.tx+=+d;this._.ty+=+i;switch(this.type){case"circle":case"ellipse":this.attr({cx:+d+this.attrs.cx,cy:+i+this.attrs.cy});break;case"rect":case"image":case"text":this.attr({x:+d+this.attrs.x,y:+i+this.attrs.y});break;case"path":var e=ah(this.attrs.path);e[0][1]+=+d;e[0][2]+=+i;this.attr({path:e});break;}return this;};aF[a9].animateWith=function(e,i,d,R,E){M[e.id]&&(i.start=M[e.id].start);return this.animate(i,d,R,E);};aF[a9].animateAlong=aG();aF[a9].animateAlongBack=aG(1);function aG(d){return function(E,i,e,S){var R={back:d};au.is(e,"function")?(S=e):(R.rot=e);E&&E.constructor==aF&&(E=E.attrs.path);E&&(R.along=E);return this.animate(R,i,S);};}aF[a9].onAnimation=function(d){this._run=d||0;return this;};aF[a9].animate=function(bq,bh,bg,E){if(au.is(bg,"function")||!bg){E=bg||null;}var bl={},e={},be={};for(var bi in bq){if(bq[W](bi)){if(ad[W](bi)){bl[bi]=this.attr(bi);(bl[bi]==null)&&(bl[bi]=k[bi]);e[bi]=bq[bi];switch(ad[bi]){case"along":var bo=aw(bq[bi]),bj=G(bq[bi],bo*!!bq.back),R=this.getBBox();be[bi]=bo/bh;be.tx=R.x;be.ty=R.y;be.sx=bj.x;be.sy=bj.y;e.rot=bq.rot;e.back=bq.back;e.len=bo;bq.rot&&(be.r=aa(this.rotate())||0);break;case"number":be[bi]=(e[bi]-bl[bi])/bh;break;case"colour":bl[bi]=au.getRGB(bl[bi]);var bk=au.getRGB(e[bi]);be[bi]={r:(bk.r-bl[bi].r)/bh,g:(bk.g-bl[bi].g)/bh,b:(bk.b-bl[bi].b)/bh};break;case"path":var S=L(bl[bi],e[bi]);bl[bi]=S[0];var bf=S[1];be[bi]=[];for(var bn=0,bd=bl[bi][n];bn<bd;bn++){be[bi][bn]=[0];for(var bm=1,bp=bl[bi][bn][n];bm<bp;bm++){be[bi][bn][bm]=(bf[bn][bm]-bl[bi][bn][bm])/bh;}}break;case"csv":var d=(bq[bi]+aA)[C](a),bc=(bl[bi]+aA)[C](a);switch(bi){case"translation":bl[bi]=[0,0];be[bi]=[d[0]/bh,d[1]/bh];break;case"rotation":bl[bi]=(bc[1]==d[1]&&bc[2]==d[2])?bc:[0,d[1],d[2]];be[bi]=[(d[0]-bl[bi][0])/bh,0,0];break;case"scale":bq[bi]=d;bl[bi]=(bl[bi]+aA)[C](a);be[bi]=[(d[0]-bl[bi][0])/bh,(d[1]-bl[bi][1])/bh,0,0];break;case"clip-rect":bl[bi]=(bl[bi]+aA)[C](a);be[bi]=[];bn=4;while(bn--){be[bi][bn]=(d[bn]-bl[bi][bn])/bh;}break;}e[bi]=d;}}}}this.stop();this.in_animation=1;M[this.id]={start:bq.start||+new Date,ms:bh,easing:bg,from:bl,diff:be,to:e,el:this,callback:E,t:{x:0,y:0}};++M[n]==1&&a1();return this;};aF[a9].stop=function(){M[this.id]&&M[n]--;delete M[this.id];return this;};aF[a9].translate=function(d,e){return this.attr({translation:d+" "+e});};aF[a9][aJ]=function(){return"Rapha\xebl\u2019s object";};au.ae=M;var X=function(d){this.items=[];this[n]=0;if(d){for(var e=0,E=d[n];e<E;e++){if(d[e]&&(d[e].constructor==aF||d[e].constructor==X)){this[this.items[n]]=this.items[this.items[n]]=d[e];this[n]++;}}}};X[a9][f]=function(){var R,d;for(var e=0,E=arguments[n];e<E;e++){R=arguments[e];if(R&&(R.constructor==aF||R.constructor==X)){d=this.items[n];this[d]=this.items[d]=R;this[n]++;}}return this;};X[a9].pop=function(){delete this[this[n]--];return this.items.pop();};for(var B in aF[a9]){if(aF[a9][W](B)){X[a9][B]=(function(d){return function(){for(var e=0,E=this.items[n];e<E;e++){this.items[e][d][a7](this.items[e],arguments);}return this;};})(B);}}X[a9].attr=function(e,bc){if(e&&au.is(e,"array")&&au.is(e[0],"object")){for(var d=0,S=e[n];d<S;d++){this.items[d].attr(e[d]);}}else{for(var E=0,R=this.items[n];E<R;E++){this.items[E].attr(e,bc);}}return this;};X[a9].animate=function(S,e,be,bd){(au.is(be,"function")||!be)&&(bd=be||null);var d=this.items[n],E=d,bc=this,R;bd&&(R=function(){!--d&&bd.call(bc);});this.items[--E].animate(S,e,be||R,R);while(E--){this.items[E].animateWith(this.items[d-1],S,e,be||R,R);}return this;};X[a9].insertAfter=function(e){var d=this.items[n];while(d--){this.items[d].insertAfter(e);}return this;};X[a9].getBBox=function(){var d=[],bc=[],e=[],R=[];for(var E=this.items[n];E--;){var S=this.items[E].getBBox();d[f](S.x);bc[f](S.y);e[f](S.x+S.width);R[f](S.y+S.height);}d=aR[a7](0,d);bc=aR[a7](0,bc);return{x:d,y:bc,width:h[a7](0,e)-d,height:h[a7](0,R)-bc};};X[a9].clone=function(E){E=new X;for(var d=0,e=this.items[n];d<e;d++){E[f](this.items[d].clone());}return E;};au.registerFont=function(e){if(!e.face){return e;}this.fonts=this.fonts||{};var E={w:e.w,face:{},glyphs:{}},i=e.face["font-family"];for(var bc in e.face){if(e.face[W](bc)){E.face[bc]=e.face[bc];}}if(this.fonts[i]){this.fonts[i][f](E);}else{this.fonts[i]=[E];}if(!e.svg){E.face["units-per-em"]=K(e.face["units-per-em"],10);for(var R in e.glyphs){if(e.glyphs[W](R)){var S=e.glyphs[R];E.glyphs[R]={w:S.w,k:{},d:S.d&&"M"+S.d[aZ](/[mlcxtrv]/g,function(bd){return{l:"L",c:"C",x:"z",t:"m",r:"l",v:"c"}[bd]||"M";})+"z"};if(S.k){for(var d in S.k){if(S[W](d)){E.glyphs[R].k[d]=S.k[d];}}}}}}return e;};a4[a9].getFont=function(be,bf,e,R){R=R||"normal";e=e||"normal";bf=+bf||{normal:400,bold:700,lighter:300,bolder:800}[bf]||400;var S=au.fonts[be];if(!S){var E=new RegExp("(^|\\s)"+be[aZ](/[^\w\d\s+!~.:_-]/g,aA)+"(\\s|$)","i");for(var d in au.fonts){if(au.fonts[W](d)){if(E.test(d)){S=au.fonts[d];break;}}}}var bc;if(S){for(var bd=0,bg=S[n];bd<bg;bd++){bc=S[bd];if(bc.face["font-weight"]==bf&&(bc.face["font-style"]==e||!bc.face["font-style"])&&bc.face["font-stretch"]==R){break;}}}return bc;};a4[a9].print=function(R,E,d,bd,be,bn){bn=bn||"middle";var bj=this.set(),bm=(d+aA)[C](aA),bk=0,bg=aA,bo;au.is(bd,"string")&&(bd=this.getFont(bd));if(bd){bo=(be||16)/bd.face["units-per-em"];var e=bd.face.bbox.split(a),bc=+e[0],bf=+e[1]+(bn=="baseline"?e[3]-e[1]+(+bd.face.descent):(e[3]-e[1])/2);for(var bi=0,S=bm[n];bi<S;bi++){var bh=bi&&bd.glyphs[bm[bi-1]]||{},bl=bd.glyphs[bm[bi]];bk+=bi?(bh.w||bd.w)+(bh.k&&bh.k[bm[bi]]||0):0;bl&&bl.d&&bj[f](this.path(bl.d).attr({fill:"#000",stroke:"none",translation:[bk,0]}));}bj.scale(bo,bo,bc,bf).translate(R-bc,E-bf);}return bj;};var aW=/\{(\d+)\}/g;au.format=function(e,i){var d=au.is(i,"array")?[0][a2](i):arguments;e&&au.is(e,"string")&&d[n]-1&&(e=e[aZ](aW,function(R,E){return d[++E]==null?aA:d[E];}));return e||aA;};au.ninja=function(){m.was?(Raphael=m.is):delete Raphael;return au;};au.el=aF[a9];return au;})();
\ No newline at end of file
Modified: trunk/mapbender/http/javascripts/geometry.js
--- trunk/mapbender/http/javascripts/geometry.js 2010-03-24 13:43:40 UTC (rev 5829)
+++ trunk/mapbender/http/javascripts/geometry.js 2010-03-24 13:47:59 UTC (rev 5830)
@@ -10,6 +10,12 @@
var nameMultiGeometry = "MultiGeometry";
var nameGeometry = "Geometry";
+Mapbender.geometryType = {
+ polygon: "polygon",
+ line: "line",
+ point: "point"
* @class A class representing geometry types "polygon", "line" and "point".
@@ -1134,6 +1140,9 @@
if (this.geomType == geomType.line){
if (this.count() < 2){return false;}
+ if (this.geomType == geomType.point){
+ if (this.count() === 0){return false;}
return true;
@@ -1680,41 +1689,96 @@
else if(t == geomType.line || t==geomType.polygon) {
- for(var i=0, ilen = g.count(); i < ilen; i++){
- var currentGeom = g.get(i);
- // paint inner rings
- if (t==geomType.polygon && currentGeom.innerRings.count() > 0) {
- for (var k = 0; k < currentGeom.innerRings.count(); k++) {
- var currentRing = currentGeom.innerRings.get(k);
- var previousPoint = realToMap(mapframe, currentRing.get(0));
- for (var j=1, jlen = currentRing.count(); j < jlen; j++) {
- (function () {
- var currentPoint = realToMap(mapframe, currentRing.get(j));
- var pq = calculateVisibleDash(previousPoint, currentPoint, mapframeWidth, mapframeHeight);
- if (pq) {
- drawLine([pq[0].x-1, pq[1].x-1], [pq[0].y-1, pq[1].y-1], col);
+ if (typeof Raphael !== "undefined") {
+ var path = "";
+ // if (t == geomType.line) {
+ for (var i = 0, ilen = g.count(); i < ilen; i++) {
+ var currentGeom = g.get(i);
+ var previousPoint = realToMap(mapframe, currentGeom.get(0));
+ var segment = "";
+ for (var j = 1, jlen = currentGeom.count(); j < jlen; j++) {
+ (function(){
+ var currentPoint = realToMap(mapframe, currentGeom.get(j));
+ var pq = calculateVisibleDash(previousPoint, currentPoint, mapframeWidth, mapframeHeight);
+ if (pq) {
+ if (segment === "") {
+ segment += "M" + pq[0].x + " " + pq[0].y;
- previousPoint = currentPoint;
+ else {
+ if (!previousPoint.equals(pq[0])) {
+ if (t == geomType.polygon) {
+ segment += "L" + pq[0].x + " " + pq[0].y;
+ else {
+ segment += " L" + pq[1].x + " " + pq[1].y;
+ previousPoint = currentPoint;
+ segment += " Z";
+ path += segment;
- // paint line or outer ring
- var previousPoint = realToMap(mapframe, currentGeom.get(0));
- for (var j=1, jlen = currentGeom.count(); j < jlen; j++) {
- (function () {
- var currentPoint = realToMap(mapframe, currentGeom.get(j));
- if (pq) {
+ var canvasPath = canvas.path(path);
+ canvasPath.attr({
+ "fill": col,
+ "stroke": col,
+ "stroke-width": lineWidth,
+ "fill-opacity": 0.5
+ else {
+ canvasPath.attr({
+ "stroke": col,
+ else {
+ for(var i=0, ilen = g.count(); i < ilen; i++){
+ // paint inner rings
+ if (t==geomType.polygon && currentGeom.innerRings.count() > 0) {
+ for (var k = 0; k < currentGeom.innerRings.count(); k++) {
+ var currentRing = currentGeom.innerRings.get(k);
+ var previousPoint = realToMap(mapframe, currentRing.get(0));
+ for (var j=1, jlen = currentRing.count(); j < jlen; j++) {
+ (function () {
+ var currentPoint = realToMap(mapframe, currentRing.get(j));
+ if (pq) {
+ drawLine([pq[0].x-1, pq[1].x-1], [pq[0].y-1, pq[1].y-1], col);
+ // paint line or outer ring
+ for (var j=1, jlen = currentGeom.count(); j < jlen; j++) {
+ (function () {
+ if (pq) {
else {
var e = new Mb_exception("class Canvas: function drawGeometry: unknown geomType " + t);
@@ -1765,8 +1829,19 @@
* @param {String} color the color of the circle in hex format
var drawCircle = function(x, y, diameter, color) {
- canvas.setColor(color);
- canvas.drawEllipse(x-diameter/2,y-diameter/2,diameter,diameter);
+ var c = canvas.circle(x, y, diameter);
+ c.attr({
+ "fill": color,
+ "stroke": color,
+ else {
+ canvas.setColor(color);
+ canvas.drawEllipse(x-diameter/2,y-diameter/2,diameter,diameter);
@@ -1778,8 +1853,12 @@
* @param {String} color the color of the polyline in hex format
var drawLine = function(x_array, y_array, color) {
- canvas.drawPolyline(x_array, y_array);
+ else {
+ canvas.drawPolyline(x_array, y_array);
@@ -1854,16 +1933,28 @@
var minWidth = 8;
var lineWidth = aLineWidth || 2;
var style = aStyle;
- var canvas = new jsGraphics(aTagName, map.getDomElement().frameName ? window.frames[mapframe] : window);
- canvas.setStroke(lineWidth);
- mb_registerPanSubElement(aTagName);
+ var canvas = Raphael(this.canvasDivTag.getTag(), map.getWidth(), map.getHeight());
+ else {
+ var canvas = new jsGraphics(aTagName, map.getDomElement().frameName ? window.frames[mapframe] : window);
+ canvas.setStroke(lineWidth);
+ if (!map.isOverview) {
+ mb_registerPanSubElement(aTagName);
* cleans the canvas by emptying the canvas {@link DivTag}.
Canvas.prototype.clean = function () {
- this.canvasDivTag.clean();
+ this.getCanvas().clear();
+ else {
+ this.canvasDivTag.clean();
@@ -1895,7 +1986,9 @@
- this.getCanvas().paint();
+ if (typeof Raphael === "undefined") {
+ this.getCanvas().paint();
@@ -2280,8 +2373,15 @@
* @ignore
-function calculateVisibleDash (p0, p1, width, height) {
- if (p0.x > p1.x) {var p_temp = p0; p0 = p1; p1 = p_temp; p_temp = null;}
+function calculateVisibleDash (a, b, width, height) {
+ var p0 = new Mapbender.Point(a);
+ var p1 = new Mapbender.Point(b);
+ if (p0.x > p1.x) {
+ var switched = true;
+ var p_temp = p0;
+ p0 = p1;
+ p1 = p_temp; p_temp = null;
var p = p0; var q = p1; var m; var ix; var iy;
if (p1.x != p0.x) {
m = -(p1.y-p0.y)/(p1.x-p0.x);
@@ -2345,7 +2445,11 @@
else {return false;}
- return [new Point(Math.round(q.x), Math.round(q.y)), new Point(Math.round(p.x), Math.round(p.y))];
+ if (switched) {
+ return [new Point(Math.round(q.x), Math.round(q.y)), new Point(Math.round(p.x), Math.round(p.y))];
+ return [new Point(Math.round(p.x), Math.round(p.y)), new Point(Math.round(q.x), Math.round(q.y))];
More information about the Mapbender_commits
