[Mapbender-commits] r5846 - trunk/mapbender/resources/db
    svn_mapbender at osgeo.org
    Fri Mar 26 11:22:01 EDT 2010
Author: astrid_emde
Date: 2010-03-26 11:22:01 -0400 (Fri, 26 Mar 2010)
New Revision: 5846
   trunk/mapbender/resources/db/update.bat
fixed path to new sequences file
Modified: trunk/mapbender/resources/db/update.bat
--- trunk/mapbender/resources/db/update.bat	2010-03-26 15:20:23 UTC (rev 5845)
+++ trunk/mapbender/resources/db/update.bat	2010-03-26 15:22:01 UTC (rev 5846)
@@ -107,7 +107,7 @@
 echo   update to 2.7
 psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6.1_to_2.7rc1_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
 echo   update to 2.7
-psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/pgsql_serial_set_sequences_2.7.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/pgsql_serial_set_sequences_2.7.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
 goto END:
 :PGNOTFOUND
More information about the Mapbender_commits
